wsc2800系列是一种先进的视频格式转换器,转换成多种格式的数字输入.
学学走蛇形走线等长等。
如果有重复,请告知。
wsc2800datasheet.rar
(164 KB, 下载次数: 3)
WSC2800蛇形走线.rar
(827 KB, 下载次数: 8)
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下元件和封装库,如有需要可以下载提取使用。
Name | Value | PCB Decal | Part Type | C1 | 0.1uF | C0603 | CAP0603 | C2 | 0.1uF | C0603 | CAP0603 | C3 | 22pF | C0603 | CAP0603 | C4 | 22pF | C0603 | CAP0603 | C5 | 22pF | C0603 | CAP0603 | C6 | 22pF | C0603 | CAP0603 | C7 | 0.1uF | C0603 | CAP0603 | C8 | 0.1uF | C0603 | CAP0603 | C9 | 0.1uF | C0603 | CAP0603 | C10 | 10PF | C0603 | CAP0603 | C11 | 0.1uF | C0603 | CAP0603 | C12 | 0.1uF | C0603 | CAP0603 | C13 | 10uF/16V | CT1206 | CT1206 | C14 | 10uF/16V | CT1206 | CT1206 | C15 | 0.1uF | C0603 | CAP0603 | C21 | 1uF | C0603 | CAP0603 | C24 | 1uF | C0603 | CAP0603 | C25 | 0.1uF | C0603 | CAP0603 | C26 | 22pF | C0603 | CAP0603 | C27 | 22pF | C0603 | CAP0603 | C28 | 10uF/16V | C1206 | CAP0603 | C29 | 0.1uF | C0603 | CAP0603 | C31 | 0.1uF | C0603 | CAP0603 | C32 | 1uF | C0603 | CAP0603 | C33 | 0.1uF | C0603 | CAP0603 | C34 | 0.1uF | C0603 | CAP0603 | C35 | 1uF | C0603 | CAP0603 | C37 | 0.1uF | C0603 | CAP0603 | C38 | 10uF/16V | C1206 | CAP0603 | C41 | 1uF | C0603 | CAP0603 | C42 | 0.1uF | C0603 | CAP0603 | C44 | 0.1uF | C0603 | CAP0603 | C45 | 10uF/16V | C1206 | CAP0603 | C46 | 0.1uF | C0603 | CAP0603 | C48 | 0.1uF | C0603 | CAP0603 | C49 | 0.1uF | C0603 | CAP0603 | C50 | 0.1uF | C0603 | CAP0603 | C51 | 0.1uF | C0603 | CAP0603 | C52 | 0.1uF | C0603 | CAP0603 | C53 | 0.1uF | C0603 | CAP0603 | C54 | 0.1uF | C0603 | CAP0603 | C55 | 0.1uF | C0603 | CAP0603 | C56 | 0.1uF | C0603 | CAP0603 | C57 | 0.1uF | C0603 | CAP0603 | C58 | 0.1uF | C0603 | CAP0603 | C59 | 0.1uF | C0603 | CAP0603 | C60 | 0.1uF | C0603 | CAP0603 | C61 | 0.1uF | C0603 | CAP0603 | C62 | 0.1uF | C0603 | CAP0603 | C63 | 0.1uF | C0603 | CAP0603 | C64 | 0.1uF | C0603 | CAP0603 | C65 | 0.1uF | C0603 | CAP0603 | C66 | 0.1uF | C0603 | CAP0603 | C68 | 220pF/NC | C0603 | CAP0603 | C69 | 220pF/NC | C0603 | CAP0603 | C70 | 220pF/NC | C0603 | CAP0603 | C71 | 220pF/NC | C0603 | CAP0603 | C72 | 220pF/NC | C0603 | CAP0603 | C73 | 220pF/NC | C0603 | CAP0603 | C74 | 0.1uF | C0603 | CAP0603 | C75 | 0.1uF | C0603 | CAP0603 | C76 | 0.1uF | C0603 | CAP0603 | C77 | 0.1uF | C0603 | CAP0603 | C78 | 0.1uF | C0603 | CAP0603 | C79 | 0.1uF | C0603 | CAP0603 | C80 | 0.1uF | C0603 | CAP0603 | C81 | 0.1uF | C0603 | CAP0603 | C82 | 0.1uF | C0603 | CAP0603 | C83 | 0.1uF | C0603 | CAP0603 | C84 | 0.1uF | C0603 | CAP0603 | C85 | 0.1uF | C0603 | CAP0603 | C86 | 0.1uF | C0603 | CAP0603 | C88 | 0.1uF | C0603 | CAP0603 | C90 | 0.1uF | C0603 | CAP0603 | C93 | 0.1uF | C0603 | CAP0603 | C99 | 10uF/16V | CT1206 | CT1206 | C106 | 0.01uF | C0603 | CAP0603 | C107 | 0.1uF | C0603 | CAP0603 | C111 | 0.1uF | C0603 | CAP0603 | C112 | 0.01uF | C0603 | CAP0603 | C114 | 0.1uF | C0603 | CAP0603 | C115 | 10uF/16V | C1206 | CAP0603 | C117 | 10uF/16V | C1206 | CAP0603 | C118 | 0.1uF | C0603 | CAP0603 | C119 | 0.1uF | C0603 | CAP0603 | C121 | 0.1uF | C0603 | CAP0603 | C122 | 0.01uF | C0603 | CAP0603 | C123 | 0.1uF | C0603 | CAP0603 | C124 | 0.01uF | C0603 | CAP0603 | C126 | 10uF/16V | C1206 | CAP0603 | C128 | 0.1uF | C0603 | CAP0603 | C133 | 0.1uF | C0603 | CAP0603 | C134 | 0.01uF | C0603 | CAP0603 | C135 | 0.1uF | C0603 | CAP0603 | C136 | 0.01uF | C0603 | CAP0603 | C283 | 0.1uF | C0603 | CAP0603 | C284 | 0.1uF | C0603 | CAP0603 | C287 | 0.1uF | C0603 | CAP0603 | C288 | 10uF/6.3V | CT1206 | CAP1206 | C289 | 0.1uF | C0603 | CAP0603 | C293 | 0.1uF | C0603 | CAP0603 | C301 | 0.1uF | C0603 | CAP0603 | C304 | 10pF | C0603 | CAP0603 | C305 | 10pF | C0603 | CAP0603 | C306 | 10pF | C0603 | CAP0603 | CE1 | 470uF | CE80 | CE | CE2 | 470uF | CE80 | CE | CE4 | 470uF | CE80 | CE | CE5 | 470uF | CE80 | CE | CT3 | 10uF/10V | CT3216 | CT3216 | CT4 | 10uF/10V | CT3216 | CT3216 | CT8 | 10uF/10V | CT3216 | CT3216 | CT9 | 10uF/10V | CT3216 | CT3216 | CT10 | 10uF/10V | CT3216 | CT3216 | CT12 | 10uF/10V | CT3216 | CT3216 | CT13 | 10uF/10V | CT3216 | CT3216 | CT14 | 10uF/10V | CT3216 | CT3216 | CT15 | 10uF/10V | CT3216 | CT3216 | CT16 | 10uF/10V | CT3216 | CT3216 | CT17 | 10uF/10V | CT3216 | CT3216 | CT18 | 10uF/10V | CT3216 | CT3216 | D1 | | LED0805 | LED0805 | EC1 | 100uF/6.3V | PACAP300 | CAP55 | EC2 | 100uF/6.3V | PACAP300 | CAP55 | EC4 | 100uF/6.3V | PACAP300 | CAP55 | FB1 | 220/200MA | L0805 | INDDUCTOR-SMD | FB7 | BLM21P221SG | L0805 | INDDUCTOR-SMD | FB33 | BLM21P221SG | L0805 | INDDUCTOR-SMD | J1 | | CON-1.25-11 | SIP-11 | J2 | | USB-4.0-D | USB_SLAVE | J3 | | CON-1.25-10 | 10PIN-SIP | J4 | | CON-2.0-3 | CON-3 | J6 | | CON-2.54-4 | SIP-4P | J8 | | DB-15/F | DB15-VGA | J12 | | POWERJACK | POWERJACK-001 | J23 | | HOLE-3.5/6.0 | HOLE-001 | J24 | | CON-2.0-2/W | SIP-2 | J26 | | HOLE-3.5/6.0 | HOLE-001 | J27 | | HOLE-3.5/6.0 | HOLE-001 | J29 | | HOLE-3.5/6.0 | HOLE-001 | L1 | BLM21P221SG | L0805 | L0805 | L2 | 10uH 2A Irms | LMS73 | DO1608C | L3 | 10uH 2A Irms | LMS73 | DO1608C | L5 | 10uH 2A Irms | LMS73 | DO1608C | L6 | BLM21P221SG | L0805 | L0805 | L7 | BLM21P221SG | L0805 | L0805 | L8 | BLM21P221SG | L0805 | L0805 | L9 | BLM21P221SG | L0805 | L0805 | L10 | BLM21P221SG | L0805 | L0805 | Q1 | | SOT-23 | NPN(SOT-23) | Q2 | | SOT-23 | NPN(SOT-23) | Q3 | | SOT-23 | PNP(SOT-23) | Q5 | | SSOT-6 | FDC638P | Q10 | | SSOT-6 | FDC638P | R1 | 510R | R0603 | RES0603 | R2 | 1M | R0603 | RES0603 | R3 | 33 | R0603 | RES0603 | R4 | 10K | R0603 | RES0603 | R5 | 2K | R0603 | RES0603 | R6 | 1K | R0603 | RES0603 | R7 | 33 | R0603 | RES0603 | R8 | 33 | R0603 | RES0603 | R9 | 100 | R0603 | RES0603 | R10 | 0 | R0603 | RES0603 | R11 | 100 | R0603 | RES0603 | R12 | 10K | R0603 | RES0603 | R13 | 100 | R0603 | RES0603 | R14 | 1K | R0603 | RES0603 | R15 | 4.7K | R0603 | RES0603 | R16 | 4.7K | R0603 | RES0603 | R17 | 4.7K | R0603 | RES0603 | R18 | 44.2K 1% | R0603 | RES0603 | R19 | 10K 1% | R0603 | RES0603 | R22 | 4.7K | R0603 | RES0603 | R23 | 4.7K/NC | R0603 | RES0603 | R24 | 4.7K/NC | R0603 | RES | R28 | 1M | R0603 | RES0603 | R29 | 1M | R0603 | RES0603 | R30 | 0 | R0603 | RES0603 | R31 | 8.2K(1%) | R0603 | RES0603 | R32 | 4.7K | R0603 | RES0603 | R33 | 4.7K | R0603 | RES0603 | R34 | 4.7K | R0603 | RES0603 | R35 | 47K | R0603 | RES0603 | R36 | 4.7K | R0603 | RES0603 | R37 | NC/47K | R0603 | RES0603 | R38 | 4.7K | R0603 | RES0603 | R39 | 100R | R0603 | RES0603 | R40 | 75R | R0603 | RES0603 | R41 | 75R | R0603 | RES0603 | R42 | 75R | R0603 | RES0603 | R43 | 6.8K | R0603 | RES0603 | R44 | 4.7K | R0603 | RES0603 | R45 | 4.7K | R0603 | RES0603 | R46 | 22R | R0603 | RES0603 | R47 | 0R | R0603 | RES0603 | R48 | 22R | R0603 | RES0603 | R49 | 22R | R0603 | RES0603 | R50 | 4.7k | R0603 | RES0603 | R51 | 4.7k | R0603 | RES0603 | R52 | 4.7k | R0603 | RES0603 | R53 | 1K(1%) | R0603 | RES0603 | R54 | 1K(1%) | R0603 | RES0603 | R66 | 100K | R0603 | RES0603 | R67 | 10K | R0603 | RES0603 | R69 | 26K 1% | R0603 | RES0603 | R70 | 10K 1% | R0603 | RES0603 | R72 | 100K | R0603 | RES0603 | R73 | 10K | R0603 | RES0603 | R85 | 9.5K 1% | R0603 | RES0603 | R86 | 10K 1% | R0603 | RES0603 | R87 | 100K | R0603 | RES0603 | R88 | 5.1K | R0603 | RES0603 | R114 | 4.7K | R0603 | RES0603 | R155 | 10K | R0603 | RES | R156 | 4.7K | R0603 | RES | R158 | 4.7K | R0603 | RES | R160 | 4.7K | R0603 | RES0603 | R161 | 10K | R0603 | RES0603 | RN1 | 33 | RN0603-4 | RN | RN2 | 33 | RN0603-4 | RN | S2 | | SMD_PAD | SMD_PAD | S3 | | SMD_PAD | SMD_PAD | S4 | | SMD_PAD | SMD_PAD | S5 | | SMD_PAD | SMD_PAD | TC15 | 10uF/16V | C1206 | CAP55 | TP2 | | TP-SMD/0.8 | TP | TP3 | | TP-SMD/0.8 | TP | TP4 | | TP-SMD/0.8 | TP | TP5 | | TP-SMD/0.8 | TP | TP6 | | TP-SMD/0.8 | TP | TP7 | | TP-SMD/0.8 | TP | U1 | | SOP-1.27-8/5.3 | MX25L8005 | U2 | | PQFP-0.8-44 | STC11LE32XE | U4 | | VC0361PLNA | VC0361PLNA | U6 | | SO-0.95-6/2.80 | SRV05_4 | U7 | AT24Cxx | SO-1.27-8/4.0 | AT24C01 | U8 | K4H511638D | TSSOP-0.65-66 | MT46V16M16 | U10 | L1117-2.5V | SOT-223 | L1117 | U11 | | SO-1.27-9/4.0 | MP1482 | U12 | | LQFP-0.4-128/14X14 | WSC2800 | U20 | | SO-1.27-9/4.0 | MP1482 | U21 | | SO-1.27-9/4.0 | MP1482 | U24 | | SOT-23 | BAV99WT1 | U31 | | TSSOP-0.5-48/12.5X6.1 | FIN1218 | U39 | L1117-3.3V | SOT-223 | L1117 | U45 | | SOT-23 | BAV99WT1 | U46 | | SOT-23 | BAV99WT1 | Y1 | 11.0592MHz | 49US-SMD | XTAL-1 | Y2 | 27MHz | 49US-SMD | XTAL-1 | Y3 | 12MHz | 49US-SMD | XTAL-1 |
评分
查看全部评分
