via公司VL812方案 7 口 HUB USB3.0集线器 含原理图 orcad格式 pcb格式pads
7 Port HUB VL812_PCB与ORCAD原理图.rar
(405 KB, 下载次数: 66)
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | PCB Decal | Value | Part Type | C1 | CAP0603 | 1uF | C | C2 | CAP0402 | 0.1uF | C | C3 | CAP0402 | 0.01uF | C | C4 | CAP0603 | 1uF | C | C5 | CAP0402 | 0.1uF | C | C6 | CAP0402 | 0.1uF | C | C7 | CAP0603 | 10uF | C | C8 | CAP0805 | 4.7uF | C | C9 | CAP0402 | 0.1uF | C | C10 | CAP0402 | 0.1uF | C | C11 | CAP0402 | 0.1uF | C | C12 | CAP0402 | 0.1uF | C | C13 | CAP0402 | 0.1uF | C | C14 | CAP0402 | 0.1uF | C | C15 | CAP0402 | 0.1uF | C | C16 | CAP0402 | 0.1uF | C | C17 | CAP0402 | 0.1uF | C | C18 | CAP0402 | 0.1uF | C | C21 | CAP0402 | 0.1uF | C | C22 | CAP0402 | 0.1uF | C | C23 | CAP0402 | 0.1uF | C | C24 | CAP0402 | 0.1uF | C | C25 | CAP0402 | 0.1uF | C | C26 | CAP0402 | 0.1uF | C | C27 | CAP0805 | 4.7uF | C | C28 | CAP0603 | 4.7uF | C | C29 | CAP0402 | 18pF | C | C30 | CAP0402 | 18pF | C | C31 | CAP0402 | 0.1uF | C | C32 | CAP0402 | 0.1uF | C | C34 | CAP0402 | 0.1uF | C | C35 | CAP1210 | 10uF | C | C36 | CAP0402 | 0.1uF | C | C37 | CAP0402 | 0.1uF | C | C38 | CAP0402 | 0.1uF | C | C40 | CAP0402 | 0.1uF | C | C41 | CAP1210 | 10uF | C | C42 | CAP0402 | 0.1uF | C | C43 | CAP0402 | 0.1uF | C | C44 | CAP0402 | 0.1uF | C | C45 | CAP0603 | 1uF | C | C46 | CAP0402 | 0.1uF | C | C48 | CAP0402 | 0.1uF | C | C49 | CAP1210 | 10uF | C | C50 | CAP0402 | 0.1uF | C | C51 | CAP0402 | 0.1uF | C | C52 | CAP0402 | 0.1uF | C | C53 | CAP0402 | 0.1uF | C | C54 | CAP0402 | 0.1uF | C | C55 | CAP0402 | 1000pF | C | C56 | CAP0402 | 0.01uF | C | C58 | CAP0402 | 0.1uF | C | C59 | CAP1210 | 10uF | C | C60 | CAP0402 | 0.1uF | C | CE1 | EC5X7-80 | 100uF | CE | CM1 | L-WCM2012 | DLW2012B-900NP /X | TRAN_HM31_0 | CM2 | L-WCM2012 | DLW0805ST900NP /X | TRAN_HM31_0 | CM3 | L-WCM2012 | DLW2012B-900NP /X | TRAN_HM31_0 | CM4 | L-WCM2012 | DLW2012B-900NP /X | TRAN_HM31_0 | CM5 | L-WCM2012 | DLW2012B-900NP /X | TRAN_HM31_0 | CM6 | L-WCM2012 | DLW0805ST900NP /X | TRAN_HM31_0 | CM7 | L-WCM2012 | DLW2012B-900NP /X | TRAN_HM31_0 | CM8 | L-WCM2012 | DLW2012B-900NP /X | TRAN_HM31_0 | CM9 | L-WCM2012 | DLW0805ST900NP /X | TRAN_HM31_0 | CM10 | L-WCM2012 | DLW2012B-900NP /X | TRAN_HM31_0 | CM11 | L-WCM2012 | DLW2012B-900NP /X | TRAN_HM31_0 | CM12 | L-WCM2012 | DLW0805ST900NP /X | TRAN_HM31_0 | CM13 | L-WCM2012 | DLW2012B-900NP /X | TRAN_HM31_0 | CM14 | L-WCM2012 | DLW2012B-900NP /X | TRAN_HM31_0 | CM15 | L-WCM2012 | DLW0805ST900NP /X | TRAN_HM31_0 | D1 | 214AC | MMGZ5232BPT /X | SS22_2 | F1 | FUSE1206 | SMD1206P150TF | FUSE | F2 | FUSE1206 | SMD1206P150TF | FUSE | F3 | FUSE1206 | SMD1206P150TF | FUSE | FB1 | FUSE1206 | CBF-2012ES-121U | BEAD | FB2 | FUSE1206 | CBF-2012ES-121U | BEAD | FB3 | FUSE1206 | CBF-2012ES-121U | BEAD | FB4 | FUSE1206 | CBF-2012ES-121U | BEAD | FB5 | FUSE1206 | CBF-2012ES-121U | BEAD | J1 | DC-JACK | DC-003 | DCJACK-IDJ-D22-6T_2 | J2 | USB3.0A | UEA1112C-4HK1-4H | USB-UEA11123-4HK1-4H_0 | J3 | USB3.0A | UEA1112C-4HK1-4H | USB-UEA11123-4HK1-4H_0 | J4 | USB3.0A | UEA1112C-4HK1-4H | USB-UEA11123-4HK1-4H_0 | J5 | USB-UP | Micro_USB_CONN | USB-UEB11123-2JK1-4H_1 | J6 | USB3.0A | UEA1112C-4HK1-4H | USB-UEA11123-4HK1-4H_0 | L1 | CDLF-0503 | SDR32-4R7M | INDUCTOR | Q1 | SOT23-GDS | AM3401 | APM2301AAC-TR_0 | Q12 | SOT23-BCE | MMBT3906 | 2N3906_4 | Q13 | SOT23-BCE | MMBT3906 | 2N3906_3 | Q14 | SOT23-BCE | MMBT3906 | 2N3906_5 | R1 | RES0402 | 4.7K | R | R2 | RES0402 | 10K | R | R3 | RES0402 | 4.7K | R | R4 | RES0402 | 100K | R | R5 | RES0402 | 4.7K | R | R6 | RES0402 | 4.7K /X | R | R7 | RES0402 | 10K | R | R8 | RES0402 | 10K | R | R9 | RES0402 | 10K | R | R10 | RES0402 | 10K | R | R11 | RES0402 | 6.04K_1% | R | R12 | RES0402 | 470R | R | R13 | RES0402 | 470R | R | R14 | RES0402 | 470R | R | R15 | RES0402 | 470R | R | R16 | RES0402 | 5.1K | R | R17 | RES0402 | 10K | R | R18 | RES0402 | 10K | R | R19 | RES0402 | 0 /X | R | R20 | RES0402 | 5.1K | R | R21 | RES0402 | 10K | R | R22 | RES0402 | 5.1K | R | R23 | RES0402 | 10K | R | R24 | RES0402 | 4.7K | R | R25 | RES0402 | 680R | R | TP1 | SMD_TP_1 | TestPoint | TESTPOINT | TP2 | SMD_TP_1 | TestPoint | TESTPOINT | TP3 | SMD_TP_1 | TestPoint | TESTPOINT | TP4 | SMD_TP_1 | TestPoint | TESTPOINT | U1 | SOT23-132 | FR6809-29NS3G /X | BAT54C/SOT_0 | U2 | SO8-6-1.27 | MX25L512COI-12G | MX25L512COI-12G | U3 | QFN76-15P7-TH | VL812 HUB QFN76 | VT3470_HUB_QFN76_V1_4.02 | U4 | LED0603 | LED-LT8A23-51-UR96-T5_0 | LED-LT8A23-51-UR96-T5_2 | U5 | LED0603 | LED-LT8A23-51-UR96-T5_0 | LED-LT8A23-51-UR96-T5_2 | U6 | LED0603 | LED-LT8A23-51-UR96-T5_0 | LED-LT8A23-51-UR96-T5_2 | U7 | LED0603 | LED-LT8A23-51-UR96-T5_0 | LED-LT8A23-51-UR96-T5_2 | U8 | SO8-6-1.27 | G547E2P11U | G547E2P11U | U9 | LED0603 | LED-LT8A23-51-UR96-T5_0 | LED-LT8A23-51-UR96-T5_1 | X1 | XTAL | 25MHz /CL 12pF | SMD_CRYSTAL_1 |
