汽车音响导航一体机原理图与PCB文件WINCE S3C2451平台 PADS2007打开
BX-ARM9板子元件
Name | PCB Decal | Value | Part Type |
ANT-TUNER1 | ANT-T-DIP | | ANT-TUNER |
ANT1 | ANT_G_DIP | | GPS_ANT |
BZ1 | BUZ | 5V-DC12MM | BUZZER |
C1 | 603 | 1UF NPO | CAP0603 |
C2 | 603 | 104 | CAP0603 |
C3 | 603 | 150P | CAP0603 |
C4 | 603 | 104 | CAP0603 |
C5 | 805 | 10uF/10V | CAP0603 |
C6 | 603 | 104 | CAP0603 |
C7 | 603 | 104 | CAP0603 |
C8 | 603 | 103 | CAP0603 |
C9 | 805 | 10uF/10V | CAP0603 |
C10 | 603 | 225 | CAP0603 |
C11 | 603 | 8.2N | CAP0603 |
C12 | 603 | 8.2N | CAP0603 |
C13 | 603 | 105 | CAP0603 |
C14 | 603 | 0.33uF/50 | CAP0603 |
C15 | 1210 | 22uF/25V | CAP0603 |
C16 | 603 | 33p | CAP0603 |
C17 | 603 | 33p | CAP0603 |
C18 | 603 | 102 | CAP0603 |
C19 | 603 | 33p | CAP0603 |
C20 | 805 | 10uF/10V | CAP0603 |
C21 | 603 | 47n | CAP0603 |
C22 | 603 | 225 | CAP0603 |
C23 | 603 | 102 | CAP0603 |
C24 | 603 | 105 | CAP0603 |
C25 | 603 | 104 | CAP0603 |
C26 | 603 | 104 | CAP0603 |
C27 | 603 | 223 | CAP0603 |
C28 | 603 | 105 | CAP0603 |
C29 | 603 | 105 | CAP0603 |
C30 | 603 | 105 | CAP0603 |
C31 | 603 | 105 | CAP0603 |
C32 | 603 | 105 | CAP0603 |
C33 | 603 | 105 | CAP0603 |
C34 | 603 | 105 | CAP0603 |
C35 | 603 | 105 | CAP0603 |
C36 | 603 | 105 | CAP0603 |
C37 | 603 | 105 | CAP0603 |
C38 | 603 | 105 | CAP0603 |
C39 | 603 | 105 | CAP0603 |
C40 | 805 | 10uF/10V | CAP0603 |
C41 | 603 | 102 | CAP0603 |
C42 | 603 | 102 | CAP0603 |
C43 | 603 | 120p | CAP0603 |
C44 | 805 | 10uF/10V | CAP0603 |
C45 | 603 | 104 | CAP0603 |
C46 | 603 | 103 | CAP0603 |
C47 | 603 | 103 | CAP0603 |
C48 | 603 | 8.2nF | CAP0603 |
C49 | 603 | 105 | CAP0603 |
C50 | 603 | 103 | CAP0603 |
C51 | 603 | 103 | CAP0603 |
C52 | 603 | 104 | CAP0603 |
C53 | 603 | 104 | CAP0603 |
C54 | 603 | 103 | CAP0603 |
C55 | 603 | 105 | CAP0603 |
C56 | 603 | 105 | CAP0603 |
C57 | 603 | 105 | CAP0603 |
C58 | 603 | 105 | CAP0603 |
C59 | 603 | 105 | CAP0603 |
C60 | 603 | 105 | CAP0603 |
C61 | 603 | 105 | CAP0603 |
C62 | 603 | 0.33uF/50 | CAP0603 |
C63 | 603 | 105 | CAP0603 |
C64 | 603 | 103 | CAP0603 |
C65 | 603 | 8.2nF | CAP0603 |
C66 | 603 | 223 | CAP0603 |
C67 | 603 | 0.33uF/50 | CAP0603 |
C68 | 603 | 18p NPO | CAP0603 |
C69 | 603 | 18p NPO | CAP0603 |
C70 | 603 | 102/NC | CAP0603 |
C71 | 603 | 33p | CAP0603 |
C72 | 603 | 102/NC | CAP0603 |
C73 | 603 | 104 | CAP0603 |
C74 | 603 | 104 | CAP0603 |
C75 | 603 | 104 | CAP0603 |
C76 | 603 | 104 | CAP0603 |
C77 | 603 | 120p | CAP0603 |
C78 | 603 | 33p | CAP0603 |
C79 | 603 | 120p | CAP0603 |
C80 | 603 | 120p | CAP0603 |
C81 | 603 | 105 | CAP0603 |
C82 | 603 | 105 | CAP0603 |
C83 | 603 | 103 | CAP0603 |
C84 | 603 | 103 | CAP0603 |
C85 | 603 | 103 | CAP0603 |
C86 | 603 | 0.33uF/50 | CAP0603 |
C87 | 603 | 104 | CAP0603 |
C88 | 603 | 104 | CAP0603 |
C89 | 603 | 104 | CAP0603 |
C90 | 603 | 8.2nF | CAP0603 |
C91 | 603 | 8.2nF | CAP0603 |
C92 | 603 | 47n | CAP0603 |
C93 | 603 | 104 | CAP0603 |
C94 | 603 | 104 | CAP0603 |
C95 | 603 | 8n2 | CAP0603 |
C96 | 603 | NC | CAP0603 |
C97 | 603 | 68n | CAP0603 |
C98 | 603 | 27n | CAP0603 |
C99 | 603 | 223 | CAP0603 |
C100 | 805 | 10uF/10V | CAP0603 |
C101 | 805 | 10uF/10V | CAP0603 |
C102 | 805 | 10uF/10V | CAP0603 |
C103 | 603 | 225 | CAP0603 |
C104 | 603 | 104 | CAP0603 |
C105 | 603 | 104 | CAP0603 |
C106 | 603 | 8n2 | CAP0603 |
C107 | 603 | 0.47uF/50V | CAP0603 |
C108 | 805 | 10uF/10V | CAP0603 |
C134 | 805 | 10uF/10V | CAP0603 |
C145 | 603 | 105 | CAP0603 |
C157 | 603 | 105 | CAP0603 |
C158 | 603 | 103 | CAP0603 |
C159 | 603 | 103 | CAP0603 |
C160 | 603 | 103 | CAP0603 |
C161 | 603 | 103 | CAP0603 |
C165 | 603 | 103 | CAP0603 |
C166 | 603 | 103 | CAP0603 |
C168 | 603 | 105 | CAP0603 |
C171 | 603 | 103 | CAP0603 |
C173 | 603 | 103 | CAP0603 |
C175 | 603 | 105 | CAP0603 |
C176 | 1210 | 22uF/25V | CAP0603 |
C177 | 603 | 103 | CAP0603 |
C180 | 1210 | 22uF/25V | CAP0603 |
C181 | 603 | 104 | CAP0603 |
C182 | 603 | 104 | CAP0603 |
C185 | 603 | NC | CAP0603 |
C186 | 1210 | 22uF/16V | CAP0603 |
C187 | 603 | 104 | CAP0603 |
C190 | 603 | 105 | CAP0603 |
C191 | 805 | 10uF/10V | CAP0603 |
C192 | 805 | 10uF/10V | CAP0603 |
C202 | 603 | 30p NPO | CAP0603 |
C203 | 603 | 30p NPO | CAP0603 |
C204 | 603 | 104 | CAP0603 |
C233 | 603 | 105 | CAP0603 |
C234 | 603 | 105 | CAP0603 |
C235 | 603 | 120p | CAP0603 |
C236 | 603 | 1.5n | CAP0603 |
C237 | 603 | 120p | CAP0603 |
C238 | 603 | 1.5n | CAP0603 |
CON1 | CON6-DIP-2.0 | | CON-6PIN |
CON2 | CON10-1.25MM | 10PIN-1.25MMá¢ê? | CON-10PIN |
CON3 | ISO-CON-26PIN | 26PIN?2??×ù | ISO-CON-26PIN |
CON4 | CON34-SMT-0.5 | SMT-36PIN-0.5MM???ó | CON-34PIN |
CON5 | CON50-SMT-0.5 | 50PIN-0.5MM???ó | CON-50PIN |
CON6 | CON5-1.25MMA | 5PIN-1.25MMá¢ê? | CON-5PIN-1.25 |
CON8 | CON12-SMD-0.5 | 14PIN-0.5MM???ó | CON-12PIN |
CON9 | CON10-1.25MM | 10PIN-1.25MMá¢ê? | CON-10PIN |
CON10 | CON5-1.25MM | 5PIN-1.25MMá¢ê? | CON-5PIN-1.25 |
CON13 | CON10-1.25MM | 10PIN-1.25MMá¢ê? | CON-10PIN |
CON14 | CON10-1.25MM | 10PIN-1.25á¢ê? | CON-10PIN |
D1 | SOD-323 | 1N4148 | DIODE |
D4 | SOD-106 | 1N4004 | DIODE |
D5 | SOD-323 | 1N4148 | DIODE |
D6 | SOD-323 | 1N4148 | DIODE |
D7 | SOD-323 | 1N4148 | DIODE |
D8 | SOD-323 | 1N4148 | DIODE |
D9 | SOD-323 | 1N4148 | DIODE |
D10 | SOD-323 | 1N4148 | DIODE |
D11 | SOD-323 | 1N4148 | DIODE |
D12 | SOD-323 | 1N4148 | DIODE |
D13 | SOD-323 | 1N4148 | DIODE |
D14 | SOD-323 | 1N4148 | DIODE |
D15 | SOD-323 | 1N4148 | DIODE |
D16 | SOD-323 | 1N4148 | DIODE |
D18 | SOD-323 | 1N4148 | DIODE |
D19 | SOD-323 | 1N4148 | DIODE |
D20 | SOD-323 | 1N4148 | DIODE |
D21 | SOD-323 | 1N4148 | DIODE |
D22 | SOD-323 | 1N4148 | DIODE |
D23 | SOD-323 | 1N4148 | DIODE |
D24 | SOD-323 | 1N4148/NC | DIODE |
D25 | SOD-323 | 1N4148 | DIODE |
D26 | SOD-323 | 1N4148 | DIODE |
D27 | SOD-323 | 1N4148 | DIODE |
D28 | SOD-323 | 1N4148 | DIODE |
D29 | SOD-SS33 | 1N5404 | DIODE |
D30 | SOD-SS33 | 1N5404 | DIODE |
D31 | SOD-214 | SK34 | DIODE |
D32 | SOD-106 | 1N4004 | DIODE |
D33 | SOD-323 | 1N4148 | DIODE |
D34 | SOD-323 | 1N4148 | DIODE |
D35 | SOD-323 | 1N4148 | DIODE |
D36 | SOD-323 | 1N4148 | DIODE |
D37 | SOD-323 | 1N4148 | DIODE |
D38 | SOD-106 | NC/1N4004 | DIODE |
D42 | SOD-323 | 1N4148 | DIODE |
D43 | SOD-323 | 1N4148 | DIODE |
D44 | SOD-106 | 1N4004 | DIODE |
D46 | SOD-323 | 1N4148 | DIODE |
D47 | SOD-323 | 1N4148 | DIODE |
D48 | SOD-323 | 1N5404 | DIODE |
D52 | SOD-323 | 1N4148 | DIODE |
D53 | SOD-323 | 1N4148 | DIODE |
D54 | SOD-323 | 1N4148 | DIODE |
D55 | SOD-323 | 1N4148 | DIODE |
FB1 | 603 | 600R | IND |
FB2 | 603 | 600R | IND |
FB3 | 603 | 600R | IND |
FB9 | 603 | 600R | IND |
FB10 | 603 | 600R | IND |
FB13 | 603 | 600R | IND |
FB14 | 603 | 600R | IND |
FB15 | 603 | 600R | IND |
FB19 | 603 | 600R | IND |
FB20 | 603 | 600R | IND |
FB21 | 603 | 600R | IND |
FB32 | 603 | 600R | IND |
FB33 | 603 | 600R | IND |
FB36 | 603 | 600R | IND |
FB37 | 603 | 600R | IND |
FB64 | 603 | 600R | IND |
FB65 | 603 | 600R | IND |
J1 | WF10/2 | FLC-BTMDC732-I2U | CN10 |
J3 | LAVIDA_LINV | CAN LIN | CAN_LIN |
L1 | INDCD43 | 10uH | IND-MOLDED |
L2 | INDCD43 | 100uH | IND-MOLDED |
L3 | CHOKE-COLL | 1¤×?μ??D-510uH/15A | CHOKE-COLL |
L4 | INDCD75 | 100uH | IND-MOLDED |
L5 | INDCD75 | 100uH | IND-MOLDED |
L6 | INDCD75 | 100uH | IND-MOLDED |
L7 | INDCD43 | 100uH | IND-MOLDED |
L8 | INDCD75 | 100uH | IND-MOLDED |
L9 | SC75470SMD | 22uH | IND-MOLDED |
L10 | INDCDH8B28 | 22uH | IND-MOLDED |
L12 | INDCD43 | 100uH | IND-MOLDED |
L13 | INDCD43 | 100uH | IND-MOLDED |
L14 | INDCD43 | 100uH | IND-MOLDED |
L15 | INDCD43 | 100uH | IND-MOLDED |
L75 | INDCD43 | 470uH | IND-MOLDED |
P31 | TP\1 | | TP |
P32 | TP\1 | | TP |
Q1 | SOT-23 | AMP2307 | 2N3906 |
Q2 | SOT-23 | 2N3904 | 2N3904 |
Q3 | KRA304 | DTC144 | DTC144 |
Q4 | SOT-23 | 8550 | 2N3906 |
Q5 | SOT-23 | DTC144 | DTC144 |
Q6 | SOT-23 | 8550 | 2N3906 |
Q7 | SOT-23 | APM2307 | 2N3906 |
Q8 | SOT-23 | DTC144 | DTC144 |
Q9 | SOT-23 | APM2307 | 2N3906 |
Q10 | SOT-23 | DTC144 | DTC144 |
Q11 | SOT-23 | 2N3906 | 2N3906 |
Q12 | SOT-23 | 2N3906 | 2N3906 |
Q13 | SOT-23 | 2N3904 | 2N3904 |
Q14 | SOT-23 | DTC144 | DTC144 |
Q15 | SOT-23 | DTC144 | DTC144 |
Q16 | SOT-23 | DTC144 | DTC144 |
Q17 | SOT-23 | DTC144 | DTC144 |
Q18 | SOT-23 | 2N3904 | 2N3904 |
Q19 | SOT-23 | APM2307 | 2N3906 |
Q20 | SOT-23 | 2N3904 | 2N3904 |
Q21 | SOT-23 | 2N3906 | 2N3906 |
Q22 | SOT-23 | DTC144 | DTC144 |
Q23 | SOT-23 | 2N3904 | 2N3904 |
Q24 | SOT-23 | 8550 | 2N3906 |
Q25 | SOT-23 | 2N3906 | 2N3906 |
Q26 | SOT-23 | DTC144 | DTC144 |
Q27 | SOT-23 | DTC144 | DTC144 |
Q28 | SOT-23 | 8550 | 2N3906 |
Q29 | SOT-23 | 2N3904 | 2N3904 |
Q30 | SOT-23 | DTC144 | DTC144 |
Q31 | SI2307 | APM2307 | 2N3906 |
Q32 | SOT-23 | DTC144 | DTC144 |
Q33 | SOT-23 | DTC144 | DTC144 |
Q37 | SOT-23 | 2N3904 | 2N3904 |
Q39 | SOT-23 | SC3265 | 2N3904 |
Q40 | KRA304 | DTC114EU | KRA304 |
Q41 | SOT-23 | SC3265 | 2N3904 |
Q42 | KRA304 | DTC114EU | KRA304 |
Q43 | SOT-23 | SC3265 | 2N3904 |
Q44 | KRA304 | DTC114EU | KRA304 |
Q45 | SOT-23 | SC3265 | 2N3904 |
Q46 | KRA304 | DTC114EU | KRA304 |
Q48 | KRA304 | DTC114EU | KRA304 |
Q49 | SOT-23 | SC3265 | 2N3904 |
Q51 | SOT-23 | SC3265 | 2N3904 |
Q52 | KRA304 | DTC114EU | KRA304 |
Q54 | KRA304 | DTC114EU | KRA304 |
Q57 | SOT-63 | KTC2020 | 2N3904 |
Q58 | SOT-23 | DTC144 | DTC144 |
Q59 | SOT-23 | SC3265 | 2N3904 |
Q60 | SOT-89 | KTC4375 | 2N3904 |
Q61 | SOT-23 | DTC144 | DTC144 |
R1 | 1206 | 10K/0R | RES0603 |
R2 | 603 | 10K | RES0603 |
R3 | 603 | 470R | RES0603 |
R4 | 603 | 0R/NC | RES0603 |
R5 | 1206 | 4K7 | RES0603 |
R6 | 603 | 200K | RES0603 |
R7 | 603 | 180K | RES0603 |
R8 | 603 | 4K7 | RES0603 |
R9 | 603 | 4K7 | RES0603 |
R10 | 603 | 30K 1% | RES0603 |
R11 | 603 | 10K 1% | RES0603 |
R12 | 603 | 10K | RES0603 |
R13 | 603 | 0R | RES0603 |
R14 | 603 | 100R | RES0603 |
R15 | 603 | 100R | RES0603 |
R16 | 603 | 0R/NC | RES0603 |
R17 | 603 | 100K | RES0603 |
R18 | 603 | 10K | RES0603 |
R19 | 603 | 1K | RES0603 |
R20 | 603 | 1K | RES0603 |
R21 | 603 | NC | RES0603 |
R22 | 603 | 100R | RES0603 |
R23 | 603 | 47K | RES0603 |
R24 | 603 | 100R | RES0603 |
R25 | 603 | 47K | RES0603 |
R26 | 603 | 10K | RES0603 |
R27 | 603 | 100K | RES0603 |
R28 | 603 | 4K7 | RES0603 |
R29 | 603 | 10K | RES0603 |
R32 | JUMP2.0 | JUMP2.0 | RES0603 |
R33 | 603 | 0R | RES0603 |
R34 | 603 | 4K7 | RES0603 |
R35 | 603 | 4K7 | RES0603 |
R36 | 603 | 1K | RES0603 |
R37 | 603 | 1K | RES0603 |
R38 | 603 | 100K | RES0603 |
R39 | 603 | 4K7 | RES0603 |
R40 | 603 | 100K | RES0603 |
R41 | 603 | 4K7 | RES0603 |
R42 | 603 | 1K | RES0603 |
R43 | 603 | 20K | RES0603 |
R44 | 603 | 0R | RES0603 |
R45 | 603 | 0R | RES0603 |
R46 | 603 | 12K | RES0603 |
R47 | 603 | 12K | RES0603 |
R49 | 603 | 0R | RES0603 |
R50 | 603 | 0R | RES0603 |
R51 | 603 | 100R | RES0603 |
R52 | 603 | 100R | RES0603 |
R53 | 603 | 100K | RES0603 |
R54 | 603 | 0R | RES0603 |
R55 | 603 | 3K9 | RES0603 |
R56 | 603 | 100K | RES0603 |
R57 | 603 | 1K | RES0603 |
R58 | 603 | 1K | RES0603 |
R59 | 603 | 4K7 | RES0603 |
R60 | 603 | 100R | RES0603 |
R61 | 603 | 100R | RES0603 |
R62 | 603 | 100R | RES0603 |
R63 | 603 | 100R | RES0603 |
R64 | 603 | 1K | RES0603 |
R65 | 603 | 4K7 | RES0603 |
R66 | 603 | 1K | RES0603 |
R67 | 603 | 4K7 | RES0603 |
R68 | 603 | 5K6 | RES0603 |
R69 | 603 | 20K | RES0603 |
R70 | 603 | 22R | RES0603 |
R71 | 603 | 10K | RES0603 |
R72 | 603 | 0R | RES0603 |
R73 | 603 | 0R | RES0603 |
R75 | 603 | 10K | RES0603 |
R76 | 603 | 100R | RES0603 |
R77 | 603 | 100R | RES0603 |
R78 | 1206 | 10K | RES0603 |
R79 | 603 | 20K | RES0603 |
R80 | 603 | 4K7 | RES0603 |
R81 | 603 | 1K | RES0603 |
R82 | 603 | 1K | RES0603 |
R83 | 603 | 1K | RES0603 |
R84 | 603 | 1K | RES0603 |
R85 | 603 | 100K | RES0603 |
R86 | 603 | 4K7 | RES0603 |
R87 | 603 | 1K | RES0603 |
R88 | 603 | 0R | RES0603 |
R90 | 603 | 4K7 | RES0603 |
R91 | 603 | 4K7 | RES0603 |
R92 | 603 | 47K | RES0603 |
R93 | 603 | 47K | RES0603 |
R94 | 603 | 47K | RES0603 |
R96 | 603 | 4K7 | RES0603 |
R97 | 603 | 4K7 | RES0603 |
R98 | 603 | 10K | RES0603 |
R100 | 603 | 10K | RES0603 |
R101 | 603 | 10K | RES0603 |
R104 | 603 | 10K | RES0603 |
R105 | 603 | 10K | RES0603 |
R106 | 603 | 10K | RES0603 |
R107 | 603 | 10K | RES0603 |
R108 | 603 | 10K | RES0603 |
R109 | 603 | 1K | RES0603 |
R110 | 603 | 1K | RES0603 |
R111 | 603 | 10K | RES0603 |
R112 | 603 | 10K | RES0603 |
R114 | 603 | 10K | RES0603 |
R115 | 603 | 10K | RES0603 |
R116 | 1206 | 39K | RES0603 |
R117 | 603 | 10K | RES0603 |
R118 | 603 | 1K | RES0603 |
R119 | 603 | 20K | RES0603 |
R120 | 603 | 10K/NC | RES0603 |
R121 | 603 | 4K7 | RES0603 |
R122 | 603 | 100K/NC | RES0603 |
R123 | 1206 | 10K | RES0603 |
R124 | 603 | 20K | RES0603 |
R125 | 603 | 20K | RES0603 |
R126 | 603 | 10K | RES0603 |
R127 | 603 | 10K | RES0603 |
R128 | 603 | 20K | RES0603 |
R129 | 603 | 10K | RES0603 |
R130 | 603 | 30K | RES0603 |
R131 | 1206 | 100K 1% | RES0603 |
R132 | 603 | 100K | RES0603 |
R133 | 603 | 10K | RES0603 |
R134 | 603 | 10K | RES0603 |
R135 | 603 | 10K | RES0603 |
R137 | 603 | 4K7 | RES0603 |
R138 | 603 | 100K | RES0603 |
R139 | 603 | 4K7 | RES0603 |
R140 | 603 | 10K | RES0603 |
R142 | 603 | 10K | RES0603 |
R144 | 603 | 100R | RES0603 |
R145 | 603 | 100R | RES0603 |
R146 | 603 | 100R | RES0603 |
R147 | 603 | 100R | RES0603 |
R148 | 603 | 10K | RES0603 |
R149 | 603 | 10K | RES0603 |
R150 | 603 | 10K | RES0603 |
R151 | 603 | 20K | RES0603 |
R152 | 603 | 20K | RES0603 |
R153 | 1206 | 0R | RES0603 |
R154 | 603 | 100K | RES0603 |
R155 | 603 | 10K | RES0603 |
R156 | 603 | 27K | RES0603 |
R157 | 603 | 47K | RES0603 |
R158 | 603 | NC/10K | RES0603 |
R159 | 603 | NC/10K | RES0603 |
R160 | 1206 | 1K | RES0603 |
R162 | 603 | 100K | RES0603 |
R163 | 603 | 10K | RES0603 |
R164 | 1206 | 1K | RES0603 |
R165 | 1206 | 1K | RES0603 |
R166 | 603 | 47K | RES0603 |
R167 | 603 | 4K7 | RES0603 |
R168 | 603 | 47K | RES0603 |
R169 | 603 | 10K | RES0603 |
R171 | 1206 | 1K | RES0603 |
R172 | 603 | 0R | RES0603 |
R173 | 603 | 0R | RES0603 |
R174 | 1206 | 1K | RES0603 |
R175 | 603 | 0R | RES0603 |
R176 | 603 | 47K/NC | RES0603 |
R177 | 603 | 0R | RES0603 |
R178 | 603 | 47K | RES0603 |
R179 | 603 | 47K/NC | RES0603 |
R180 | 603 | 33R | RES0603 |
R181 | 603 | 33R | RES0603 |
R182 | 603 | 33R | RES0603 |
R183 | 603 | 100R | RES0603 |
R184 | 603 | 10K | RES0603 |
R185 | 603 | 100K | RES0603 |
R186 | 603 | 100R | RES0603 |
R188 | 1206 | 39K | RES0603 |
R189 | 603 | 10K | RES0603 |
R190 | 603 | 20K | RES0603 |
R191 | 603 | 1K | RES0603 |
R192 | 603 | 1K | RES0603 |
R193 | 603 | 47K | RES0603 |
R195 | 603 | 0R | RES0603 |
R196 | 603 | NC | RES0603 |
R198 | 603 | 1K | RES0603 |
R200 | 603 | 75R | RES0603 |
R201 | 603 | 75R | RES0603 |
R202 | 603 | 75R | RES0603 |
R203 | 603 | 75R | RES0603 |
R204 | 603 | 470R | RES0603 |
R205 | 603 | 4K7 | RES0603 |
R207 | 603 | 470R | RES0603 |
R208 | 603 | 470R | RES0603 |
R210 | 603 | 10R | RES0603 |
R211 | 603 | 10R | RES0603 |
R212 | 603 | 10R | RES0603 |
R213 | 603 | 10R | RES0603 |
R214 | 603 | 10R | RES0603 |
R215 | 603 | 100R | RES0603 |
R216 | 603 | 82K | RES0603 |
R217 | 603 | 82K | RES0603 |
R218 | 603 | 82K | RES0603 |
R219 | 603 | 82K | RES0603 |
R220 | 603 | 100K | RES0603 |
R221 | 603 | 100K | RES0603 |
R222 | 603 | 100K | RES0603 |
R223 | 603 | 100K | RES0603 |
R224 | 603 | 4K7 | RES0603 |
R225 | 603 | 4K7 | RES0603 |
R226 | 603 | 100R | RES0603 |
R228 | 603 | 20K | RES0603 |
R229 | 603 | 1K | RES0603 |
R230 | 603 | 470R | RES0603 |
R231 | 603 | 75R | RES0603 |
R232 | 603 | 1K/NC | RES0603 |
R233 | 603 | 4.7K | RES0603 |
R234 | 603 | 0R | RES0603 |
R245 | 1206 | 0R/NC | RES0603 |
R258 | 603 | 75R | RES0603 |
R259 | 603 | 75R | RES0603 |
R291 | 603 | 1K | RES0603 |
R295 | 603 | 12K | RES0603 |
R296 | 603 | 12K | RES0603 |
R297 | 603 | 3K9 | RES0603 |
R298 | 603 | 2M | RES0603 |
R330 | 1206 | 1K | RES0603 |
R335 | 603 | 100R | RES0603 |
R336 | 603 | 100R | RES0603 |
R339 | 603 | 20K | RES0603 |
R340 | 603 | 20K | RES0603 |
R341 | 603 | 3K3 | RES0603 |
R342 | 603 | 3K3 | RES0603 |
R344 | 603 | 100R | RES0603 |
R346 | 603 | 100R | RES0603 |
R347 | 603 | 20K | RES0603 |
R348 | 603 | 20K | RES0603 |
R349 | 603 | 3K3 | RES0603 |
R350 | 603 | 3K3 | RES0603 |
R355 | 603 | 100R | RES0603 |
R359 | 603 | 20K | RES0603 |
R361 | 603 | 3K3 | RES0603 |
R364 | 603 | 100R | RES0603 |
R366 | 603 | 100R | RES0603 |
R367 | 603 | 20K | RES0603 |
R368 | 603 | 20K | RES0603 |
R369 | 603 | 3K3 | RES0603 |
R370 | 603 | 3K3 | RES0603 |
R385 | 1206 | 470R | RES0603 |
R386 | 603 | 30K | RES0603 |
R387 | 603 | 12K | RES0603 |
R388 | 603 | 180K | RES0603 |
R389 | 603 | 4K7 | RES0603 |
R390 | 1206 | 0R | RES0603 |
R394 | 603 | 200K 1% | RES0603 |
R395 | 603 | 36K 1% | RES0603 |
R396 | 603 | 100K | RES0603 |
R421 | 603 | 1M | RES0603 |
R427 | 603 | 20K | RES0603 |
R428 | 603 | 100R | RES0603 |
R429 | 603 | 100R | RES0603 |
R444 | 603 | 22K | RES0603 |
R445 | 603 | 22K | RES0603 |
RXD60 | TP\1 | | TP |
TC1 | SMTC4 | 10uF/25V | ECAP |
TC2 | SMTC4 | 10uF/25V | ECAP |
TC3 | SMTC4 | 22uF/16V | ECAP |
TC5 | SMTC6.5 | 100uF/6V3 | ECAP |
TC6 | SMTC6.5 | 100uF/6V3 | ECAP |
TC7 | SMTC6.5 | 100uF/25V | ECAP |
TC10 | SMTC5 | 47uF/16V | ECAP |
TC11 | SMTC4 | 10uF/16V | ECAP |
TC12 | SMTC6.5 | 220uF/6V3 | ECAP |
TC14 | SMTC6.5 | 220uF/6V3 | ECAP |
TC15 | SMTC6.5 | 100uF/16V | ECAP |
TC16 | SMTC6.5 | 100uF/16V | ECAP |
TC19 | SMTC4 | 10uF/16V | ECAP |
TC20 | SMTC6.5 | 100uF/16V | ECAP |
TC22 | SMTC4 | 10uF/16V | ECAP |
TC23 | SMTC6.5 | 220uF/6.3V | ECAP |
TC24 | SMTC6.5 | 220uF/6.3V | ECAP |
TC25 | SMTC5 | 47uF/6V3 | ECAP |
TC31 | SMTC5 | 47uF/16V | ECAP |
TC50 | SMTC5 | 47uF/16V | ECAP |
TC56 | SMTC6.5 | 100uF/16V | ECAP |
TC59 | SMTC4 | 22uF/16V | ECAP |
TC60 | SMTC4 | 22uF/16V | ECAP |
TC65 | SMTC4 | 22uF/16V | ECAP |
TC67 | SMTC4 | 22uF/16V | ECAP |
TC70 | SMTC4 | 22uF/16V | ECAP |
TC75 | SMTC4 | 10uF/16V | ECAP |
TC76 | SMTC4 | 22uF/16V | ECAP |
TC77 | SMTC4 | 10uF/16V | ECAP |
TC78 | SMTC4 | 22uF/16V | ECAP |
TC81 | DC10 | 1000uF/25V | ECAP |
TC82 | DC16 | 4700uF/20V | ECAP |
TC83 | SMTC5 | 47uF/16V | ECAP |
TC84 | SMTC6.5 | 100uF/16V | ECAP |
TC85 | DC13 | 2200uF/16V | ECAP |
TC86 | DC8 | 470uF/6V3 | ECAP |
TC89 | SMTC6.5 | 100uF/25V | ECAP |
TC90 | DC8 | 470uF/6V3 | ECAP |
TC91 | TAN-TYPE-C | 100uF/10V | ECAP |
TC92 | SMTC6.5 | 100uF/16V | ECAP |
TC93 | DC6.3 | 220uF/6V3 | ECAP |
TC94 | DC6.3 | 470uF/10 | ECAP |
TC99 | SMTC6.5 | 220uF/6V3 | ECAP |
TC111 | SMTC6.5 | 100uF/16V | ECAP |
TC112 | SMTC6.5 | 100uF/16V | ECAP |
TP1 | TP\1 | | TP |
TP2 | TP\1 | | TP |
TP3 | TP\1 | | TP |
TP4 | TP\1 | | TP |
TP5 | TP\1 | | TP |
TP6 | TP\1 | | TP |
TP7 | TP\1 | | TP |
TP8 | TP\1 | | TP |
TP9 | TP\1 | | TP |
TP10 | TP\1 | | TP |
TP11 | TP\1 | | TP |
TP12 | TP\1 | | TP |
TP13 | TP\1 | | TP |
TP14 | TP\1 | | TP |
TUNER2 | NXP4462_TUNER | | NXP-TUNER |
TXD60 | TP\1 | | TP |
U1 | SOT-63 | CJ78M12 | 78D12 |
U2 | TSSOP16 | 74HC4052 | 74HC4052 |
U3 | TSSOP16 | 74HC4052 | 74HC4052 |
U4 | SOT-25 | AP2204K-ADJ | AP2204K-ADJ |
U6 | SOT-89 | | KIA7035 |
U7 | SO8M1A | MP1584 | MP4462 |
U8 | GPS_1613 | GPS-1613 | GPS_1613 |
U9 | SO8NB | PCF8563 | PCF8563 |
U10 | SOT-23-5 | XC6219B332MR | XC6221B332MR |
U11 | SSOP36 | PT2348 | PT2348 |
U12 | SOT23 | NC | IMP809TEUR |
U13 | TDA7386 | TDA7388 | TDA7386 |
U14 | SOT-23-5 | NC/1.2V LDO | XC6221B332MR |
U16 | TSSOP24 | FMS6502 | FMS6502 |
U17 | NEC_0893 | NEC-0893 | NEC_0893 |
U25 | SO8M1 | APM9435 | IRF7205 |
U27 | SO8NB | AT24C04 | 24C04 |
U32 | SO8M1 | NJM4558 | NJM4558 |
X2 | OSC-1 | 16M | OSC |
X3 | X'TAL-32768 | 32.768KHZ | OSC |
ZD1 | SOD-323 | 5V6 | ZENER-DIODE |
ZD2 | SOD-323 | 5V6 | ZENER-DIODE |
ZD3 | SOD-323 | 5V6 | ZENER-DIODE |
ZD4 | SOD-323 | 5V6 | ZENER-DIODE |
ZD5 | 603 | TVS | ZENER-DIODE |
ZD6 | SOD-323 | 5V1/NC | ZENER-DIODE |
ZD7 | SOD-323 | 18V | ZENER-DIODE |
ZD8 | SOD-323 | 5V6 | ZENER-DIODE |
ZD9 | 603 | TVS | ZENER-DIODE |
ZD10 | 603 | TVS | ZENER-DIODE |
ZD11 | 603 | TVS | ZENER-DIODE |
ZD12 | 603 | TVS | ZENER-DIODE |
ZD13 | 603 | TVS | ZENER-DIODE |
ZD14 | 603 | TVS | ZENER-DIODE |
ZD15 | 603 | TVS | ZENER-DIODE |
ZD26 | SOD-323 | 18V | ZENER-DIODE |
ZD32 | SOD-323 | 6V8 | ZENER-DIODE |
ZD33 | TL431 | TLC431 | ZDIODE-REF |
DVD板子元件
AGND | TP\1 | | TP |
C1 | CAP0603 | 104 | CAP0603 |
C2 | CAP0603 | 104 | CAP0603 |
C3 | CAP0603 | 104 | CAP0603 |
C4 | CAP0603 | 15nF | CAP0603 |
C5 | CAP0603 | 104 | CAP0603 |
C6 | CAP0603 | 330p | CAP0603 |
C7 | CAP0603 | 330p | CAP0603 |
C8 | CAP0603 | 0.1U | CAP0603 |
C9 | CAP0603 | 33P/NC | CAP0603 |
C10 | CAP0603 | 104 | CAP0603 |
C11 | CAP0603 | 104 | CAP0603 |
C12 | CAP0603 | 104 | CAP0603 |
C13 | CAP0603 | 33P/NC | CAP0603 |
C14 | CAP0603 | 104 | CAP0603 |
C15 | CAP0603 | 104 | CAP0603 |
C16 | CAP0603 | 0.1U | CAP0603 |
C17 | CAP0603 | 102 | CAP0603 |
C18 | CAP0603 | 1500P | CAP0603 |
C19 | CAP0603 | 220p | CAP0603 |
C20 | CAP0603 | 105 | CAP0603 |
C25 | CAP0603 | 100P | CAP0603 |
C26 | CAP0603 | 100P | CAP0603 |
C27 | CAP0603 | 104 | CAP0603 |
C28 | CAP0603 | 104 | CAP0603 |
C29 | CAP0603 | 104 | CAP0603 |
C30 | CAP0805 | 106 | CAP0603 |
C31 | CAP0603 | 104 | CAP0603 |
C32 | CAP0603 | 20pF | CAP0603 |
C33 | CAP0805 | 10U | CAP0603 |
C34 | CAP0603 | 100P | CAP0603 |
C35 | CAP0603 | 6800P/0.1U | CAP0603 |
C36 | CAP0805 | 10U | CAP0603 |
C37 | CAP0603 | 0.1U | CAP0603 |
C38 | CAP0805 | 10UF | CAP0603 |
C39 | CAP0805 | 10U | CAP0603 |
C40 | CAP0805 | 10U | CAP0603 |
C41 | CAP0603 | 103 | CAP0603 |
C42 | CAP0603 | 104 | CAP0603 |
C43 | CAP0603 | 104 | CAP0603 |
C44 | CAP0805 | 10U | CAP0603 |
C45 | CAP0603 | 104 | CAP0603 |
C47 | CAP1210 | 22uF/25V | CAP0603 |
C48 | CAP0603 | 0.1U | CAP0603 |
C49 | CAP1210 | 22uF/25V | CAP0603 |
C50 | CAP0805 | 10UF | CAP0603 |
C51 | CAP0805 | 10UF | CAP0603 |
C52 | CAP0603 | 1000P | CAP0603 |
C53 | CAP0603 | 1000P | CAP0603 |
C54 | CAP0603 | 100p | CAP0603 |
C55 | CAP0603 | 100p | CAP0603 |
C56 | CAP0603 | 105 | CAP0603 |
C57 | CAP0603 | 105 | CAP0603 |
C58 | CAP0603 | 100P | CAP0603 |
C59 | CAP0603 | 102P | CAP0603 |
C60 | CAP0603 | 104 | CAP0603 |
C61 | CAP0603 | 102P | CAP0603 |
C62 | CAP0603 | 104 | CAP0603 |
C63 | CAP0603 | 100P | CAP0603 |
C64 | CAP0603 | 100P | CAP0603 |
C65 | CAP0603 | 100P | CAP0603 |
C66 | CAP0603 | 100P | CAP0603 |
C67 | CAP0603 | 104 | CAP0603 |
C70 | 603 | 150P | CAP0603 |
C219 | CAP0603 | 120pF/NC | CAP0603 |
C223 | CAP0603 | 104 | CAP0603 |
C224 | CAP0603 | 104 | CAP0603 |
C229 | CAP0603 | 104 | CAP0603 |
C230 | CAP0603 | 104 | CAP0603 |
C236 | CAP0603 | 104 | CAP0603 |
C237 | CAP0603 | 104 | CAP0603 |
C239 | CAP0603 | 104 | CAP0603 |
C242 | CAP0603 | 22pF | CAP0603 |
C243 | CAP0603 | 22pF | CAP0603 |
C256 | CAP0603 | 104 | CAP0603 |
C257 | CAP0603 | 104 | CAP0603 |
C258 | CAP0603 | 104 | CAP0603 |
C259 | CAP0603 | 104 | CAP0603 |
C260 | CAP0603 | 104 | CAP0603 |
C261 | CAP0603 | 104 | CAP0603 |
C262 | CAP0603 | 104 | CAP0603 |
C263 | CAP0603 | 104 | CAP0603 |
C264 | CAP0603 | 104 | CAP0603 |
C265 | CAP0603 | 0.1U | CAP0603 |
C266 | CAP0603 | 104 | CAP0603 |
C267 | CAP0603 | 104 | CAP0603 |
C268 | CAP0603 | 15pF | CAP0603 |
C292 | CAP0603 | 104 | CAP0603 |
C294 | CAP0603 | 104 | CAP0603 |
C295 | CAP0603 | 104 | CAP0603 |
C296 | CAP0603 | 104 | CAP0603 |
C297 | CAP0603 | 104 | CAP0603 |
C298 | CAP0603 | 104 | CAP0603 |
C299 | CAP0603 | 104 | CAP0603 |
C300 | CAP0603 | 104 | CAP0603 |
CON1 | CON34-SMT-0.5-BOTTOM | | CON-34PIN |
CON2 | CON2.0-4-A1 | | CON-4PIN-4 |
CON4 | SMT-2MM-6 | | CON-6PIN-A |
CON5 | JACK-24SMD-2 | | CON-24PIN |
CON6 | CON2.0-4 | | CON-4PIN-4 |
CON8 | CON2P-2.0 | | CON-2PIN-A |
CON9 | SMT-3.5MM-3 | | CON-3PIN |
CON20 | CON10-SMT-1.25 | | CON-10PIN |
D3 | SOD-106 | 1N4004 | DIODE |
FB1 | L0603 | 600R/0R | IND |
FB2 | L0603 | 600R/0R | IND |
IC72 | SOT-223 | | LDO1 |
L1 | IND1210 | 47uH | IND-MOLDED |
L2 | IND0805 | 10uH | IND-MOLDED |
L3 | IND0805 | 10uH | IND-MOLDED |
L4 | IND0805 | 10uH | IND-MOLDED |
L5 | 805 | 10UH | L |
L7 | INDCDH8B28 | 22uH | IND-MOLDED |
L8 | 805 | 0.9A-22|? | L |
L9 | IND0805 | 10uH | IND-MOLDED |
L10 | 805 | 0.9A-22|? | L |
L11 | 805 | 10UH | L |
L13 | 805 | 0.9A-22|? | L |
L14 | 805 | 10UH | L |
L15 | IND1210 | 47uH | IND-MOLDED |
L16 | IND1210 | 100uH | IND-MOLDED |
L17 | IND1210 | 100uH | IND-MOLDED |
L18 | 805 | 0.9A-22|? | L |
L19 | INDCD75 | 100uH | IND-MOLDED |
L20 | 805 | 0.9A-22|? | L |
L21 | 805 | 0.9A-22|? | L |
L23 | IND1210 | 47uH | IND-MOLDED |
L26 | INDCD43 | 15uH | IND-MOLDED |
L27 | 805 | 10UH | L |
LED1 | LED2 | | LED |
LED2 | LED2 | | LED |
Q3 | SOT-23 | BAT54C | 2N3904 |
Q5 | SOT-23 | 8550 | 2N3906 |
Q10 | SOT-23 | 2N3904 | 2N3904 |
Q11 | SOT-23 | 8550 | 2N3906 |
R1 | RES0603 | 27K/47K | RES0603 |
R2 | RES0603 | 27K/47K | RES0603 |
R3 | RES0603 | 15K | RES0603 |
R4 | RES0603 | 10K | RES0603 |
R5 | RES0603 | 10K | RES0603 |
R6 | RES0603 | 10K | RES0603 |
R7 | RES0603 | 10R | RES0603 |
R8 | RES0603 | 10R | RES0603 |
R9 | RES0603 | 1.8UH | RES0603 |
R10 | 805 | 1 | RES0603 |
R11 | RES0603 | NC | RES0603 |
R12 | RES0603 | 10K | RES0603 |
R13 | RES0603 | 10K | RES0603 |
R14 | RES0603 | 680R/510R | RES0603 |
R15 | RES0603 | 20K | RES0603 |
R16 | RES0603 | 1.8UH | RES0603 |
R17 | RES0603 | NC | RES0603 |
R18 | RES0603 | 4.7K | RES0603 |
R19 | RES0603 | NC | RES0603 |
R20 | RES0603 | 5K1 1% | RES0603 |
R21 | 603 | 4.7K | RES0603 |
R22 | RES0603 | 10k | RES0603 |
R23 | RES0603 | 10k | RES0603 |
R24 | RES0603 | 10k | RES0603 |
R25 | RES0603 | 33R/0R | RES0603 |
R26 | RES0603 | 0R/NC | RES0603 |
R27 | RES0603 | 33R | RES0603 |
R28 | RES0603 | 4.7K | RES0603 |
R29 | RES0603 | 1.8UH | RES0603 |
R30 | RES0603 | 75R(1%) | RES0603 |
R31 | RES0603 | 75R(1%) | RES0603 |
R32 | 603 | 10K | RES0603 |
R33 | RES0603 | 75R(1%) | RES0603 |
R34 | RES0603 | 0R | RES0603 |
R35 | RES0603 | 0R | RES0603 |
R36 | RES0603 | 4R7/5.6R/10R | RES0603 |
R37 | RES0603 | 4R7/5.6R/10R | RES0603 |
R38 | RES0603 | 15K | RES0603 |
R39 | RES0603 | 20K | RES0603 |
R40 | RES0603 | 1.8UH | RES0603 |
R41 | RES0603 | 75R(1%) | RES0603 |
R42 | RES0603 | 10K | RES0603 |
R43 | RES0603 | 10K | RES0603 |
R44 | RES0603 | 10K | RES0603 |
R45 | RES0603 | 10K | RES0603 |
R46 | RES0603 | 20K | RES0603 |
R47 | RES0603 | 1K | RES0603 |
R48 | RES0603 | 10K | RES0603 |
R49 | RES0603 | 10K | RES0603 |
R50 | RES0603 | 10K | RES0603 |
R51 | RES0603 | 10K | RES0603 |
R52 | RES0603 | 33R | RES0603 |
R53 | RES0603 | 22K | RES0603 |
R54 | RES0603 | 22K | RES0603 |
R55 | RES0603 | 30K | RES0603 |
R56 | RES0603 | 33R | RES0603 |
R57 | RES0603 | 30K | RES0603 |
R58 | RES0603 | 10K | RES0603 |
R59 | RES0603 | 33R/0R | RES0603 |
R60 | 603 | 0R | RES0603 |
R61 | RES0603 | 0R | RES0603 |
R62 | RES0603 | 0R/33R | RES0603 |
R63 | 603 | 10K | RES0603 |
R64 | RES0603 | 0R/NC | RES0603 |
R65 | RES0603 | 5.1K | RES0603 |
R66 | RES0603 | 5.1K | RES0603 |
R67 | 603 | 75K 1% | RES0603 |
R68 | RES0603 | 0R | RES0603 |
R69 | RES0603 | NC/4.7K | RES0603 |
R70 | RES0603 | 0R | RES0603 |
R71 | RES0603 | 47K | RES0603 |
R72 | RES0603 | 0R/33R | RES0603 |
R73 | RES0603 | 15K | RES0603 |
R74 | RES0603 | 15K | RES0603 |
R75 | RES0603 | 4.7K | RES0603 |
R79 | 603 | 110K | RES0603 |
R80 | 603 | 0R | RES0603 |
R83 | RES0603 | 1K | RES0603 |
R84 | RES0603 | 1K | RES0603 |
R111 | RES0603 | 100R | RES0603 |
R112 | RES0603 | 22K | RES0603 |
R115 | 603 | 24K 1% | RES0603 |
R213 | RES0603 | 1K | RES0603 |
R214 | RES0603 | 1K | RES0603 |
R407 | JUMP2.0 | JUMP2.0 | RES0603 |
R445 | RES0603 | 330R | RES0603 |
R446 | RES0603 | 10K | RES0603 |
R470 | RES0603 | 560R/2.2K | RES0603 |
R474 | RES0603 | 100K | RES0603 |
R478 | RES0603 | 33R | RES0603 |
R479 | RES0603 | 10K | RES0603 |
RE0 | TP\1 | | TP |
SERVO_+5V | TP\1 | | TP |
SW1 | SW-202 | sw | SW_4 |
T26 | TP\1 | | TP |
T33 | TP\1 | | TP |
T44 | TP\1 | | TP |
T94 | TP\1 | | TP |
TC1 | SMTC4 | 10uF/16V | ECAP |
TC2 | SMTC6.5 | 100uF/16V | ECAP |
TC3 | SMTC6.5 | 100uF/16V | ECAP |
TC4 | SMTC5 | 47uF/6V3 | ECAP |
TC5 | SMTC5 | 47uF/6V3 | ECAP |
TC6 | SMTC5 | 100uF/6.3v | ECAP |
TC7 | TAN-TYPE-B | 100uF/6V3(TAN B) | ECAP |
TC8 | SMTC5 | 100uF/6.3v | ECAP |
TC9 | SMTC5 | 100uF/6V3 | ECAP |
TC10 | SMTC5 | 100uF/6.3V | ECAP |
TC11 | SMTC5 | 47uF/16 | ECAP |
TC12 | SMTC5 | 100uF/6V3 | ECAP |
TC13 | SMTC5 | 100uF/16 | ECAP |
TC14 | SMTC5 | 100uF/6V3 | ECAP |
TC15 | SMTC5 | 100uF/6.3v | ECAP |
TC16 | SMTC5 | 100uF/6.3V | ECAP |
TC18 | SMTC5 | 47uF/16 | ECAP |
TC24 | SMTC5 | 47uF/10V | ECAP |
TC25 | SMTC5 | 47uF/10V | ECAP |
TC102 | SMTC4 | 10uF/6V3 | ECAP |
TC104 | SMTC6.5 | 100uF/16V | ECAP |
TC105 | SMTC6.5 | 100uF/16V | ECAP |
TC106 | SMTC6.5 | 100uF/16V | ECAP |
TR0 | TP\1 | | TP |
U1 | SSOP30 | CD5888 | IC_AM5888_SMD_HSOP-28 |
U2 | LQFP128-0.4 | | 1389L |
U3 | SOP8-5 | | AT25FS |
U6 | SO8NB | MP1582 | MP4462 |
U24 | SO8M1 | | NJM4558 |
U29 | SO8NB | 24C16 | EEPROM |
U30 | TSOP54NEW | | M12L64_164A-7T |
UA | SO8NB | KDY | EEPROM |
VGND | TP\1 | | TP |
Y1 | OSC | 27M | OSC |
