电源pcb板
电源板.rar
(180 KB, 下载次数: 6)
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | PCB Decal | Part Type | C1 | 0402-SMALL | 0402-SMALL | C2 | 1210 | 1210 | C3 | 1210 | 1210 | C4 | CC0603SMALL | CC0603SMALL | C5 | 0402-SMALL | 0402-SMALL | C6 | 0402-SMALLB | 0402-SMALL | C7 | 0402-SMALL | 0402-SMALL | C8 | CC0603SMALL | CC0603SMALL | C9 | CC0603SMALL | CC0603SMALL | C10 | 1210 | 1210 | C11 | CC0603SMALL | CC0603SMALL | C12 | 7343-1812 | 7343-1812 | C13 | 7343-1812 | 7343-1812 | C14 | CC0603SMALL | CC0603SMALL | C15 | 805 | 805 | C16 | 7343-1812 | 7343-1812 | C17 | 805 | 805 | C18 | 0402-SMALL | 0402-SMALL | C19 | 0402-SMALL | 0402-SMALL | C20 | 0402-SMALL | 0402-SMALL | C21 | 805 | 805 | C22 | CC0603SMALL | CC0603SMALL | C23 | 7343-1812A | 7343-1812 | C24 | 1210 | 1210 | C25 | 0402-SMALL | 0402-SMALL | C26 | 1210 | 1210 | C27 | 0402-SMALL | 0402-SMALL | C28 | 0402-SMALL | 0402-SMALL | CO1 | 1210AB | 1210 | CO2 | 1210AB | 1210 | CO3 | 1210AB | 1210 | CO4 | 1210AB | 1210 | CO5 | 1210AB | 1210 | CO6 | 1210AB | 1210 | CO7 | 1210AB | 1210 | CO8 | 1210AB | 1210 | CO9 | 1210AB | 1210 | CO10 | 1210AB | 1210 | CO11 | 1210AB | 1210 | CO12 | 1210AB | 1210 | CO13 | 1210AB | 1210 | CO14 | 1210AB | 1210 | CO15 | 1210AB | 1210 | D1 | DIODE-AS1PD | DIODE-AS1PD | D2 | SOD-123 | SOD-123 | D3 | SOD-123 | SOD-123 | D4 | SOD-123 | SOD-123 | D5 | SOD-123 | SOD-123 | D6 | SOD-123B | SOD-123 | E1 | MILL-MAX-2308 | MILL-MAX-2308 | E2 | MILL-MAX-2308 | MILL-MAX-2308 | E3 | MILL-MAX-2308 | MILL-MAX-2308 | E4 | MILL-MAX-2308 | MILL-MAX-2308 | E5 | MILL-MAX-2308 | MILL-MAX-2308 | E6 | MILL-MAX-2308 | MILL-MAX-2308 | E7 | MILL-MAX-2308 | MILL-MAX-2308 | E8 | MILL-MAX-2308 | MILL-MAX-2308 | E9 | MILL-MAX-2308 | MILL-MAX-2308 | E10 | MILL-MAX-2308 | MILL-MAX-2308 | E11 | MILL-MAX-2308 | MILL-MAX-2308 | E12 | MILL-MAX-2308 | MILL-MAX-2308 | E13 | MILL-MAX-2308 | MILL-MAX-2308 | E14 | MILL-MAX-2308 | MILL-MAX-2308 | F1 | PAD70-70A | PAD70-70 | F2 | PAD70-70B | PAD70-70 | J1 | SMH-103-02-50-D | SMH-103-02-50-D | J2 | SMH-12PIN-100-DUST | SMH-12PIN-100-DUST | J3 | SMH-12PIN-100-TRANSDUCER-HDR | SMH-12PIN-100-TRANSDUCER-HDR | J4 | SMH-12PIN-100-TRANSDUCER-HDRA | SMH-12PIN-100-TRANSDUCER-HDR | JP1 | COMMCON2802S02G2 | COMMCON2802S02G2 | JP2 | COMMCON2802S02G2 | COMMCON2802S02G2 | JP3 | COMMCON2802S02G2 | COMMCON2802S02G2 | JP4 | COMMCON2802S02G2 | COMMCON2802S02G2 | JP5 | COMMCON2802S02G2 | COMMCON2802S02G2 | JP6 | COMMCON2802S02G2 | COMMCON2802S02G2 | JP7 | COMMCON2802S02G2 | COMMCON2802S02G2 | JP8 | COMMCON2802S02G2 | COMMCON2802S02G2 | JP9 | 2MMJUMP3 | 2MMJUMP3 | JP10 | 2MMJUMP3 | 2MMJUMP3 | L1 | IND-LPS5030 | IND-LPS5030 | L2 | IND-WE-744031100 | IND-WE-744031100 | L3 | IND_MURATA_0805 | IND_MURATA_0805 | L5 | INDUCTOR\SUMIDA\CDRH3D16 | INDUCTOR\SUMIDA\CDRH3D16 | L6 | IND-WE-744043220A | IND-WE-744043220 | L7 | IND-WE-744028220 | IND-WE-744028220 | MH1 | PAD150-094 | PAD150-094 | MH2 | PAD150-094 | PAD150-094 | MH3 | PAD150-094 | PAD150-094 | MH4 | PAD150-094 | PAD150-094 | Q1 | ZETEX-SOT23 | ZETEX-SOT23 | Q2 | ZETEX-SOT23 | ZETEX-SOT23 | Q3 | ZETEX-SOT23A | ZETEX-SOT23 | R1 | 0402-SMALL | 0402-SMALL | R2 | 0402-SMALL | 0402-SMALL | R3 | 0402-SMALL | 0402-SMALL | R4 | 0402-SMALL | 0402-SMALL | R5 | 0402-SMALLA | 0402-SMALL | R6 | 0402-SMALLA | 0402-SMALL | R7 | 0402-SMALLA | 0402-SMALL | R8 | 0402-SMALL | 0402-SMALL | R9 | 0402-SMALL | 0402-SMALL | R10 | 0402-SMALLA | 0402-SMALL | R11 | 0402-SMALLA | 0402-SMALL | R12 | 0402-SMALLA | 0402-SMALL | R13 | 0402-SMALL | 0402-SMALL | R14 | 0402-SMALLB | 0402-SMALL | R15 | 0402-SMALL | 0402-SMALL | R16 | 0402-SMALL | 0402-SMALL | R17 | 0402-SMALL | 0402-SMALL | R18 | 0402-SMALL | 0402-SMALL | R19 | 0402-SMALL | 0402-SMALL | R20 | 0402-SMALL | 0402-SMALL | R21 | 0402-SMALL | 0402-SMALL | R22 | 0402-SMALL | 0402-SMALL | R23 | 0402-SMALL | 0402-SMALL | R24 | 0402-SMALL | 0402-SMALL | R25 | 0402-SMALL | 0402-SMALL | R26 | 0402-SMALLA | 0402-SMALL | R27 | 0402-SMALLA | 0402-SMALL | R28 | 0402-SMALLA | 0402-SMALL | R29 | 0402-SMALL | 0402-SMALL | R30 | 0402-SMALL | 0402-SMALL | R31 | 0402-SMALLA | 0402-SMALL | R32 | 0402-SMALLA | 0402-SMALL | R33 | 0402-SMALLA | 0402-SMALL | R34 | 0402-SMALL | 0402-SMALL | R35 | 0402-SMALLA | 0402-SMALL | R36 | 0402-SMALLA | 0402-SMALL | T1 | HA3967 | HA3967 | TP1 | MILL-MAX-2308I | MILL-MAX-2308 | TP2 | MILL-MAX-2308I | MILL-MAX-2308 | TP3 | MILL-MAX-2308I | MILL-MAX-2308 | TP4 | MILL-MAX-2308I | MILL-MAX-2308 | TP5 | MILL-MAX-2308I | MILL-MAX-2308 | TP6 | MILL-MAX-2308I | MILL-MAX-2308 | TP7 | MILL-MAX-2308I | MILL-MAX-2308 | TP8 | MILL-MAX-2308I | MILL-MAX-2308 | TP9 | MILL-MAX-2308I | MILL-MAX-2308 | U1 | MSOP10E | MSOP10E | U2 | SOT23-8L | SOT23-8L | U3 | DFN4X3MM-12 | DFN4X3MM-12 | U4 | 10LD\3MMX3MM\DFN\DD | 10LD\3MMX3MM\DFN\DD | U5 | DFN(06)2MMX2MM | DFN(06)2MMX2MM | U6 | SOT23-8LA | SOT23-8L |
