TA的每日心情 | 开心 2024-7-30 20:56 |
签到天数: 5 天 [LV.2]偶尔看看I
- 131
AD7190-PCBDesignSupport.rar
(748 KB, 下载次数: 14)
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | PCB Decal | Value | Part Type | D1 | DO-214AA | 5.8V | DIODE-DO-214AA | D31 | SOT23 | BAT721C | BAT721C | D32 | SOT23 | BAT721C | BAT721C | D33 | SOT23 | BAT721C | BAT721C | D34 | SOT23 | BAT721C | BAT721C | G1 | COMPONENTLINK | | GROUNDLINK | G2 | PATCH | | PATCH_10PIN | G5 | PATCH | | PATCH_10PIN | G6 | PATCH | | PATCH_10PIN | G40 | PATCH | | PATCH_10PIN | G41 | PATCH | | PATCH_10PIN | G42 | PATCH | | PATCH_10PIN | G43 | PATCH | | PATCH_10PIN | J1 | HEADER8_SMD | 2x4-pin | HEADER08B | J2 | DIP-16P_SMD | 2x8-pin | HEADER16B | J3 | DIP-16P_SMD | 2x8-pin | HEADER16B | J4 | CON\POWER8RIGHTANGLE(3_81PITCH) | 8-pin | SREWTERM-8_RA | J5 | SMB | SMB | SMB | J6 | SMB | SMB | SMB | J7 | SMB | SMB | SMB | J8 | SMB | SMB | SMB | J9 | SMB | SMB | SMB | J10 | CON\POWER2(3_81PITCH) | 2-pin | SREWTERM-2 | J31 | CON\BARREL_SMD | Pwr_Jack | PWR_JACK | J51 | USB-MINI-B | Mini-USB | USB-MINI-B | J52 | SIP-4P-RA_SMD | 1x4-pin | HEADER-4X1POL | L1 | 805 | 0.5uH | IND | LED1 | LED-0603HSML-C191 | Red | LED | LED2 | LED-0603HSML-C191 | Red | LED_0603HSML-C191 | LED3 | LED-0603HSML-C191 | Red | LED | LED4 | LED-0805 | Green | LED_0603HSMC191 | LED5 | LED-0805 | Green | LED_0603HSMC191 | LED6 | LED-0805 | Green | LED_0603HSMC191 | LED7 | LED-0805 | Green | LED_0603HSMC191 | LED8 | LED-0805 | Green | LED_0603HSMC191 | LED51 | LED-0603HSML-C191 | Red | LED | Q51 | SOT23-3 | BSS138 | BSS138N | S1 | SW_PB_SMD_6MM | Switch | SW-PUSH | S2 | SW_PB_SMD_6MM | Switch | SW-PUSH | S3 | SW_PB_SMD_6MM | Switch | SW-PUSH | S4 | SW_PB_SMD_6MM | Switch | SW-PUSH | S5 | SW_PB_SMD_6MM | Switch | SW-PUSH | SAMPLE1 | TSSOP24-SAMPLE | AD7190 | AD7190_SAMPLE | SAMPLE2 | TSSOP24-SAMPLE | AD7190 | AD7190_SAMPLE | U1 | TSSOP24 | AD7190 | AD7190 | U1-CLAMP | CLAMP-SOIC-TSSOP | CLAMP | CLAMP-SOIC-TSSOP | U2 | SO8NB | ADR421 | ADR421A | U31 | SO8NB | ADP3303-5V | ADP3303 | U32 | SO8NB | ADP3303-3.3V | ADP3303 | U50 | MSO10 | AD5258-10kohm | AD5258_59-MSOP | U51 | LFCSP-56_RP | CY7C68013 | CY7C68013-CSP | U52 | SO8NB | 24LC64 | 24LC64A | U53 | SAMTEC-SSM-150-L-SV | LCD_2x16 | LCD2X16 | W45 | SO28WB_NB | | SO28WM_NB | W46 | SO28WB_NB | | SO28WM_NB | X500 | CON\POWER8RIGHTANGLE(3_81PITCH) | 8-pin | SREWTERM-8_RA | XTAL1 | HC49 | - | XTAL | XTAL51 | XTAL-CSM-8A | 24MHz | XTAL-CSM-8A |
