PCB top
PCB bottom
原理图
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | PCB Decal | Value | Part Type | D201 | EMD2 | SDM20U40-7/RB520S-30 | DIODE_SCHOTTKY_1 | D202 | D0603 | CZRU52C5V1 | DIODE_SCHOTTKY_1 | D701 | EMD2 | ASKS02 | DIODE_SCHOTTKY_1_2 | D903 | EMD2 | SDM20U40-7/RB520S-30 | DIODE_0 | E701 | ANTENNA3X4 | ANTENNA-LENOVO | PIFA | F201 | 603 | Fuse 1A 0603 | FUSE | F401 | 402 | 750 beads | FERRITE_BEAD | F701 | 402 | 750 beads | FERRITE_BEAD | F801 | 402 | 750 beads | FERRITE_BEAD | F803 | 402 | 750 beads | FERRITE_BEAD | J201 | CON-BAT | 473590001-molex | BCON2_4 | J202 | SIM-D | SIM SOCKET | SIM_SOCKET_0 | J203 | SIM-D | SIM SOCKET | SIM_SOCKET_0 | J401 | LCD40PIN-2.8 | 2.8TFT | GPG12121IS1_4 | J402 | LCD40PIN-3.0 | 3.0TFT | GPG12121IS1_4 | J403 | FH26-39S-0.3SHW | HRS-FH26-39S-0.3SHW | GPG12121IS1_2 | J404 | _FPC-4PIN | 4-Pin_TouchPanel | CON4-0_1.8 | J501 | TF_5015880801-A | SD_CARD_SOCKET (SKT SD/MMC Standard Type) | SD_CARD_3 | J801 | B2B24P | CAMERA_24PIN | UP_CASE_IF_3 | J802 | B2B24P | CAMERA_24PIN | UP_CASE_IF_8 | J803 | CON3-0.8 | CON4-0.8 | CON4-0_0.8 | J901 | AXK5F16345YJ | BTBF5-01605-TPHO | GPG12121IS1_0 | J902 | AXR511889501 | AXR511889501 | SIO18_9 | J903 | MINI-USB-10PS-A | Mini 10pin I/O A | MINI_10PIN_5 | L201 | LQH2MC | 4.7 u | INDUCTOR | L203 | 603 | 700@1GHz | EMIFILTER | L204 | 603 | 700@1GHz | EMIFILTER | L312 | 402 | BLM15BB750SN1 | INDUCTOR_2 | L601 | 402 | 9.1nH | IND_0402 | L603 | 402 | 5.6nH | IND_0402_2 | L604 | 402 | 12pF | IND_0402 | L605 | 402 | 22nH | IND_0402_2 | L606 | 402 | BLM15BB750SN1 | INDUCTOR_FERRITE | L607 | 402 | nc | IND | L608 | 402 | BLM15BB750SN1 | INDUCTOR_FERRITE | L904 | 603 | BLM18BD252SN1 | INDUCTOR_FERRITE_0 | LS203 | REC-A | REC | SPEAKER | MIC301 | MIC-A | Microphone | MICROPHONE_2 | R101 | 0402-3P(1-2) | 0/0 | CON3_0 | R102 | 0402-3P(1-2) | 0/0 | CON3_0 | R103 | 0402-3P(1-2) | 0/0 | CON3_0 | R104 | 0402-3P(1-2) | 0/0 | CON3_0 | R105 | 0402-3P(1-2) | 0/0 | CON3_0 | RN201 | 8P4R-BR | 0 | RESARR_IS_4/SO | S901 | LSION2 | SIDE-SW : LS10N2 | SW_PUSHBUTTON_2 | S902 | LSION2 | SIDE-SW : LS10N2 | SW_PUSHBUTTON_2 | S903 | LSION2 | SIDE-SW : LS10N2 | SW_PUSHBUTTON_2 | S904 | LSION2 | SIDE-SW : LS10N2 | SW_PUSHBUTTON_2 | SPK+1 | TP1.5MM | TP40MIL | T_POINT_S | SPK+2 | TP1.5MM | TP40MIL | T_POINT_S | SPK+3 | PAD1.5X1.8MM | TP40MIL | T_POINT_S | SPK+4 | PAD1.5X1.8MM | TP40MIL | T_POINT_S | SPK-1 | TP1.5MM | TP40MIL | T_POINT_S | SPK-2 | TP1.5MM | TP40MIL | T_POINT_S | SPK-3 | PAD1.5X1.8MM | TP40MIL | T_POINT_S | SPK-4 | PAD1.5X1.8MM | TP40MIL | T_POINT_S | T201 | EMD2 | ESD5Z5.0T1 | ESD5Z5_0.0T1-ONSEMI | T305 | SOD-923 | ESD9X5.0ST5G | ESD9X5.0ST5G-ONSEMI | T306 | SOD-923 | ESD9X5.0ST5G | ESD9X5.0ST5G-ONSEMI | T307 | 402 | M1005C080MTAAB | AVR-M1005C080MTAAB-TDK_2 | T401 | EMD2 | ESD5Z5.0T1 | ESD5Z5_0.0T1-ONSEMI | T507 | 402 | M1005C080MTACB | AVR-M1005C080MTACB-TDK | T601 | ANTENNA3X2 | ANTENNA | ANTENNA_2 | T602 | ANTENNA3X2 | ANTENNA | ANTENNA_2 | T603 | ANTENNA3X2 | ANTENNA | ANTENNA | T801 | 402 | AVLC5S02050 | AVLC5S02050-AMOTECH | T802 | 402 | AVLC5S02050 | AVLC5S02050-AMOTECH | T803 | 402 | AVLC5S02050 | AVLC5S02050-AMOTECH | T806 | 402 | AVLC5S02050 | AVLC5S02050-AMOTECH | T807 | 402 | AVLC5S02050 | AVLC5S02050-AMOTECH | T901 | SOD-923 | ESD9X5.0ST5G | ESD9X5.0ST5G-ONSEMI | T902 | SOD-923 | ESD9X5.0ST5G | ESD9X5.0ST5G-ONSEMI | T903 | SOD-923 | ESD9X5.0ST5G | ESD9X5.0ST5G-ONSEMI | T904 | SOD-923 | ESD9X5.0ST5G | ESD9X5.0ST5G-ONSEMI | T905 | SOD-923 | ESD9X5.0ST5G | ESD9X5.0ST5G-ONSEMI | T906 | 402 | M1005C080MTAAB | AVR-M1005C080MTAAB-TDK | T907 | 402 | M1005C080MTAAB | AVR-M1005C080MTAAB-TDK | T908 | SOD-923 | ESD9X5.0ST5G | ESD9X5.0ST5G-ONSEMI | T909 | SOD-923 | ESD9X5.0ST5G | ESD9X5.0ST5G-ONSEMI | T910 | SOD-923 | ESD9X5.0ST5G | ESD9X5.0ST5G-ONSEMI | T911 | SOD-923 | ESD9X5.0ST5G | ESD9X5.0ST5G-ONSEMI | T912 | SOD-923 | ESD9X5.0ST5G | ESD9X5.0ST5G-ONSEMI | TN901 | 8P4R | AVNC5S05Q050 | AVNC5S05Q050-AMOTECH | TN902 | 8P4R | AVNC5S05Q050 | AVNC5S05Q050-AMOTECH | TN903 | 8P4R | AVNC5S05Q050 | AVNC5S05Q050-AMOTECH | TN904 | AVSC18S05E007 | AVSC18S05E007 | AVSC18S05E007-AMOTECH_0 | TN905 | RCLAMP0522P | RClamp0522P | UP_CASE_IF_4 | U101 | MT6235-362/P0.5/B0.27(13X13) | MT6235 | MT6217_121 | U202 | 1206-8CHIPFET | SI5853DC | SI4833_0 | U203 | MOTO-P2-KONKA | Motor | MOTOR_0 | U205 | S-PDSO-N8/P0.5 | NC | SI4833_1 | U206 | QFP16-0.4 | NC/FSA2567 | CM3200A3OP_11 | U301 | YDA144 | YDA144/LM4674 | PDIUSBP11A_10 | U302 | YDA144 | YDA144/LM4674 | PDIUSBP11A_10 | U402 | DS9360AB-09 | DS9360AB\SC604AG\SP6687 | DS9360 | U403 | LFA24 | EMIX21A390FNPE | EMIF04 | U404 | LFA24 | EMIX21A390FNPE | EMIF04 | U405 | LFA24 | EMIX21A390FNPE | EMIF04 | U406 | LFA24 | EMIX21A390FNPE | EMIF04 | U407 | LFA24 | EMIX21A390FNPE | EMIF04 | U408 | LFA24 | EMIX21A390FNPE | EMIF04 | U501 | BGA149/P0.8 | Toshiba TY9000A000GMGF | K5D1257DCA-D090_1 | U601 | RF3158 | RF3159 | RF3145_5 | U602 | LMSP33CA-465TEMP | LMSP33CA-465TEMP | ASM_5X4_11 | U603 | RF-650 | RF-600 | TST_PORT_2 | U604 | QFN40/0.5 | MT6140D | MT6119C_2 | U605 | TCXO3225 | X'tal 26MHz | TCVCXO_0 | U606 | SOT23-5 | NC | APL5151_0 | U607 | LF1005K1R8DAB | LF1005K1R8DAB | SAW_3 | U701 | TCXO3225 | 7M32000035 | TCVCXO_0_2 | U702 | TFBGA70/P0.5/B0.32(5X5) | SiW3500GIP1 | LANAI-CTBGA-132_50 | U703 | LFB182G45SG9A293 | LFB182G45SG9A293 | SAW_0 | U704 | MT6188/QFN28/P0.45(4X4) | MT6188(MTK) | SDFMM1N12CA2T_0 | U801 | SOT23-6 | AAT3110IGU-4.5-T1 | MIC2211_1 | U802 | LFA24 | EMIX21A390FNPE | EMIF04 | U803 | LFA24 | EMIX21A390FNPE | EMIF04 | U804 | LFA24 | EMIX21A390FNPE | EMIF04 | U805 | LFA24 | EMIX21A390FNPE | EMIF04 | U806 | SON1612-6 | NC | APL5151_2 | U901 | CM3204-A | CM3204A3OP | CM3200A3OP_7 | U902 | MXC6202GHMN | MXC6202XMB | UP_CASE_IF_2 | U903 | SC70-6-V1 | NC7SB3157P6X | NC7SB3157_DE | X101 | SC-1.27 | 32K | CRYSTAL | Z601 | QCS5F | FAR-F5KA-897M50-D4CN | SAW_1 | Z602 | QCS5F | SAFEA942MFL0F00R14 | SAW_1_2 | Z603 | QCS5F | SAFEA1G84FA0F00R14 | SAW_1_2 | Z604 | QCS5F | SAFEA1G96FA0F00R14 | SAW_1_2 |
评分
查看全部评分
