重要提示:PCB作品文件展下载说明
Centrality GPS经典方案,
完整电路设计,原理图是ORCAD,PCB是PADS格式的.一起打包。
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | PCB Decal | Value | Part Type | D1 | SOT_23 | MMBZ 5232B | DIODE_SCHOTTKY_1 | D2 | SOD_323N | RB161va-20 | DIODE | D3 | SOD_323N | RB161va-20 | DIODE | D4 | SOD_323N | RB161va-20 | DIODE | D5 | DL_35 | NC/Zener Diode 15V | DIODE_ZENER | D6 | DL_35 | NC/Zener Diode 10V | DIODE_ZENER | D7 | SOT_23 | BAT54S | 10CTQ150/TO_0 | D8 | SOT_23 | BAT54S | 10CTQ150/TO_0 | D9 | SOT_23 | BAT54S | 10CTQ150/TO_0 | D10 | SOT_23 | BAT54S | 10CTQ150/TO_0 | D11 | SOD_323N | RB161va-20 | DIODE | E1 | SOT_23_6 | SRV05-4 | SPARK_2 | E2 | SOT_23_6 | SRV05-4 | SPARK_2 | EC1 | CCAP | 47uF | CAPACITOR_POL_2 | FL1 | B7708 | EPCOS-B7708 | GPS-FILTER_1 | G_BD1 | R0603 | FBM-10-160808-121T | BEAD | G_BD2 | R0603 | FBM-10-160808-121T | BEAD | G_R6 | R0402 | 100K | RESISTOR_0 | G_S1 | MMCX-SWITH-25-501A | MMCX card switch,Aliner | RF-MACH-SWITCH_0 | G_U1 | QFN24 | SE4110L | SE4110L_1 | G_U2 | SOT23_5 | LP3985IM5-3.3 | LP3985IM5-3.3 | G_Y1 | TTS14N | 16.367667MHz +/-0.5PPM | TCXO_0 | H1 | DW | HOLE | 7406_1 | H2 | DW | HOLE | 7406_1 | H3 | DW | HOLE | 7406_1 | H4 | DW | HOLE | 7406_1 | J1 | DS-339A | DC CONNECTOR | POWER-JACK-JPM213-F01TR_4 | J2 | MINIUSB_AB | CONN Mini-B USB | MINI-B_USB | J3 | ST-012SMT | AUDIO OUTPUT | PHONEJACK_STEREO_SW_3 | J4 | SIVN-SD-CARD | SIVN-SD-CARD | HONDA-SD-DR9LFYGE1_1 | J5 | CON24_0.5MM | CONN-T60139-A024 | PDACON_MID_8 | L1 | L0603 | BEAD0603 | INDUCTOR_6 | L2 | CDRH3D16 | LPS3015-332MLC | INDUCTOR_2 | L3 | CDRH3D16 | LPS3015-332MLC | INDUCTOR_2 | L4 | L0603 | BEAD0603 | INDUCTOR_6 | L5 | L0603 | BEAD0603 | INDUCTOR_6 | L6 | L0603 | BEAD0603 | INDUCTOR | L7 | L0603 | BEAD0603 | INDUCTOR | L8 | L0603 | BEAD0603 | INDUCTOR_6 | L9 | CDRH3D16 | LPS3015-332MLC | INDUCTOR_2 | L10 | CDRH3D16 | LPS3015-332MLC | INDUCTOR_3 | LED1 | LED0603 | LED | LED_0 | LED2 | LED0603 | LED | LED_0 | LED3 | LED0603 | LED | LED_0 | LS1 | CON2_1.25MM | CONN PCB 2 | CONN_PCB_2_0 | Q1 | SOT_23 | MMBT3904 | NPN_0 | Q2 | SOT_23 | FDN338P | MOSFET_P_0_2 | Q3 | SOT_23 | 2N7002 | BUZ84_2 | Q4 | SOT_23 | FDN338P | MOSFET_P_0_2 | Q5 | SOT_23 | FDN338P | MOSFET_P_0_2 | Q6 | SOT_23 | FDN338P | MOSFET_P_0_2 | RA1 | 8P4R_0402 | 22x8P4R | R-PACK_1 | RA2 | 8P4R_0402 | 22x8P4R | R-PACK_1 | RA3 | 8P4R_0402 | 22x8P4R | R-PACK_1 | RA4 | 8P4R_0402 | 22x8P4R | R-PACK_1 | RA5 | 8P4R_0402 | 22x8P4R | R-PACK_1 | RA6 | 8P4R_0402 | 22x8P4R | R-PACK_1 | RA7 | 8P4R_0402 | 22x8P4R | R-PACK_1 | RA8 | 8P4R_0402 | 22x8P4R | R-PACK_1 | RA9 | 8P4R_0402 | 22x8P4R | R-PACK_1 | RA10 | 8P4R_0402 | 22x8P4R | R-PACK_1 | RA11 | 8P4R_0402 | 22x8P4R | R-PACK_1 | RL1 | MMRL | RL | 1N6265/TO_0 | S1 | 3DKEY_A | TS-M05-1002 | SW_PUSHBUTTON-SPST_7 | SW1 | SLIDE_SWITCH | SW PUSHBUTTON-SPST_3 | SW_PUSHBUTTON-SPST_1 | SW2 | SW-PB-EVQPL-BB | CONN-PUSH-BUTTON | SHINAN-TPM032J-4P | SW3 | SW-PB-EVQPL-BB | CONN-PUSH-BUTTON | SHINAN-TPM032J-4P | SW4 | SW-PB-EVQPL-BB | CONN-PUSH-BUTTON | SHINAN-TPM032J-4P | U1 | TF332 | AtlasII 14x14 | ATLASII-324_13 | U2 | TSOP_54 | HY57V561620FTP -H | MT48LC16M16LFFG_0 | U3 | TSOP_54 | HY57V561620FTP -H | MT48LC16M16LFFG_0 | U4 | TSOP1_48 | HY27UF081G2A- TPCB | KM28C256_0 | U5 | S_PQFP_N24 | TPS65053 | S-80825ALNP_9 | U6 | R_PQFP_N20 | BQ24070 | MAX1935ETA_26 | U7 | SOT_23_5 | S-1000C33-M5T1G | S-1000C | U8 | QFN48_TH | WM9712LEFL | WM9705_0 | U9 | S-PDSO-G8 | NC TPA2005D1 (MSOP) | LM4667MM_2 | U10 | QFN8-TI | TPA2005D1 (QFN) | LM4667MM_2 | U11 | TSSOP14 | NXP P89LPC915FDH | FMS6408_0 | U12 | HS0038S | IRM-H238 | IRM-3638_0 | U13 | MMLCC_8 | G-SENSOR | CON8_0 | U14 | SOT-23-5 | NCP5005 | MP1541_0_2 | U15 | FH12_54S_0.5SH | LTF0345CA6T1 | PT035TN01V3_0 | U16 | SOT-23-5 | NCP1406 | MP1541_0 | U17 | SO8M1 | TL3414-SO8 | AD8072_1 | VR1 | VR | N.C.VR20K | RESISTOR_VAR_1 | VR2 | VR | N.C.VR20K | RESISTOR_VAR_1 | Y1 | TAS_4025A | 12MHz TZ0225G | CRYSTAL_3 | Y2 | FC_135 | 32.768KHz FC-135 | CRYSTAL_4 | Y3 | TAS_4025B | 24.576MHz | CRYSTAL |
评分
查看全部评分
重要提示:PCB作品文件展下载说明
