平板电脑板子。原理图也为PADS格式的。一起打包。
8层PCB.rar
(1.5 MB, 下载次数: 19)
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | Part Type | PCB Decal | Value | C1 | CAPACITOR_0 | C0603 | 475 | C5 | CAPACITOR_0_2 | C0805 | 10uF | C228 | CAP_2 | C0402 | 1uF | C230 | CAP_NP_4 | C0603 | 1uF | C232 | CAPACITOR_NON-POL_1 | C0603 | 100nF | C244 | C_0 | C0603 | 15pF | CN2 | SPEAKER | SPK-SMD | LEFT-SPEAKER | CON1 | HDMI19_TYPE_C | HDMI | HDMI_TYPE_C | CON2 | CAM_BIG_0 | CON-SMD-30PIN-0.5PITCH-DOWNSIDE | CAM_BIG_5650 | CON3 | USB_CON_OUT_2 | USB-CON-10PIN | MNXF-370110-03G | CON4 | LCD_CON_0 | CON-40PIN-SMD-DOWNSIDE-0.5PITCH | LCD_CON | CT1 | CAP_POL | C0805 | 10uF/10V | D1 | 1N4500 | SOD123 | 1N4148 | D2 | LED-DOUBLECOLOR_0 | LED-3SMD | LED-DOUBLECOLOR | D9 | LED_0 | LED-DIP-2.54PITCH | LED | ESD1 | ESD | ESD0402 | ESD | ESD3 | DIODE_TVS_LC_2 | ESD0402 | ESD-0402-LF | FB1 | INDUCTOR_2 | L0805 | 600R-100M | FB3 | INDUCTOR_1 | R0805 | 75R@100MHz | HR1 | RESISTOR | R0402 | 2K2 | HR2 | RESISTOR | R0402 | 2K2 | J3 | CON-BAT-2-2.0 | CON-BAT-2-2.0 | CON-BAT-2-2.0 | J4 | PJ-242 | PJ-242 | PJ-242 | K1 | RESET | KEY-TS1121K-SMD | KEY-TS1121K | K3 | KEY-2PIN_5 | KEY-SS208GS26-SMD | VOL+1 | L6 | INDUCTOR | CDRH3B14 | 2.2uH@1.5A DCR<0.1R | L13 | IND_3 | L0402 | 2.7nH | L14 | INDUCTOR_2 | R0603 | 2.7uH | L18 | INDUCTOR | CDRH3B14 | 2.2uH@1.5A DCR<0.1R | MIC1 | MICPHONE | MIC_450X250 | Micphone | OC1 | CAPACITOR_2 | C0402 | 1uF | 1-Oct | CAPACITOR_POL | C0805 | 10uF | 2-Oct | CAPACITOR_POL | C0805 | 10uF | OD1 | DIODE_SCHOTTKY | SOD123 | SS14/XBS104S14 | OL1 | INDUCTOR | CDRH3B14 | 4.7uH-2A-DCR<0.1R | OQ2 | PMOS_2 | SOT-23-A | AO3423 | OU1 | RT9266PE_3 | SOT23-6 | SY7208 | OU2 | RT9266PE_2 | SOT-23-5 | SY6280 | PAD1 | T_POINT_R | PAD2520 | VIA | PAD8 | ANT | ANT-2 | ANT | Q3 | NPN | SOT23 | MMBT3904 | Q4 | NPN | SOT-23-A | MMBT3904 | Q6 | PMOS | SOT-23-A | AO3423 | Q7 | NPN_2 | SOT23 | MMBT3904 | Q8 | NPN | SOT-23-A | MMBT3904 | Q11 | PNP_1 | SOT23 | 3906 | R1 | R_2 | R0402 | 240R_1% | SP1 | ~WB_1X2 | MOTOR-4ZK868U | MOTOR-4ZK868U | SU1 | SDMMC_SLOT_0 | TFK-1-CB | MICROSD/TF_SLOT | TP5 | T_POINT_R | TP_PAD | T_POINT_R | U1 | BGA441-AW1623_13 | FBGA441C80P19X19 | BGA441-APP | U2 | AW1612_2 | QFN48 | AXP209 | U6 | RRCLAMP0524P | RCLAMP0524P | rRClamp0524P | U9 | LP3985IM5-3_2.3 | SOT23-5 | LP3992IMF-1.5 | U11 | DDR2_3 | DDRIII_BGA82 | H5TQ1G83BFR | U16 | NAND_FLASH_X8 | TSOP-48 | K9GAG08U0E-S CB | U18 | LY8006 | MSOP8 | LY8006 | U19 | SWL-N10S_0 | RL-SM02B-8723AS/MLK02A | 8723-MODULE | U20 | TVP5150 | S-PQFP-G32 | TVP5150AM1PBS | U21 | MIC5219BM5 | SOT23-5 | MIC5319-1.8BD5 | U22 | RT9293B_0 | SOT-23-5 | SY8008B | X1 | CRYSTAL_SMD3_0 | XTAL_SMD_3225_4P-XW | 24M | X2 | CRYSTAL_XCOL-3_0 | CRY4X1.5 | 32.768KHZ_12.5P_10PPM |
