查看: 2314|回复: 1
cypress USB-to-uart芯片, 上位机控制 gpio 的代码
发表于 2015-6-28 13:52:57 | 显示全部楼层 |阅读模式
源代码来自cypress的开发包 cyusbs232 RDK.
## Cypress USB-Serial Windows Example source file (gpio.cpp)
##  Copyright Cypress Semiconductor Corporation, 2013-2014,
##  All Rights Reserved
##  UNPUBLISHED, LICENSED SOFTWARE.
##  CONFIDENTIAL AND PROPRIETARY INFORMATION
##  WHICH IS THE PROPERTY OF CYPRESS.
##  Use of this file is governed
##  by the license agreement included in the file
##     <install>/license/license.txt
##  where <install> is the Cypress software
##  installation root directory path.
// gpio.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include <stdio.h>
#include <windows.h>
#include <dbt.h>
#include <conio.h>
#include "..\..\..\library\inc\CyUSBSerial.h"
Data Definitions
// Define VID & PID
// These numbers depends on individual products
#define VID 0x04B4
#define PID 0x0003 //4
//Variable to store cyHandle of the selected device
CY_HANDLE cyHandle;
//Varible to capture return values from USB Serial API
CY_RETURN_STATUS cyReturnStatus;
//CY_DEVICE_INFO provides additional details of each device such as product Name, serial number etc..
CY_DEVICE_INFO cyDeviceInfo, cyDeviceInfoList[16];
//Structure to store VID & PID defined in CyUSBSerial.h
CY_VID_PID cyVidPid;
//Variables used by application
UINT8 cyNumDevices;
unsigned char deviceID[16];
Functions
Function Name: int GPIOTasks(int deviceNumber)
Purpose: Demonstates how to communicate with USB-Serial device's GPIOs
Arguments:
deviceNumber - The device number identified during the enumeration process
Retrun Code: returns falure code of USB-Serial API, -1 for local failures.
    CY_DATA_BUFFER cyDatabuffer;
    unsigned char gpioNumber, value;
    unsigned char buffer[4096];
    CY_RETURN_STATUS rStatus;
    int interfaceNum = 0, count = 1000;
    unsigned char bytesPending = 0;
    cyDatabuffer.buffer = buffer;
    //Obtain handle for a USB-Serial device
    printf("\nOpening USB-Serial device with device number %d...\n",deviceNumber);
    rStatus = CyOpen (deviceNumber, interfaceNum, &cyHandle);
    if (rStatus){
        printf ("Failed to open USB-Serial device\n");
        return -1;
    // Verify that the GPIO is configured using Cypress USB-Serial Configuration Utility
    gpioNumber = 2;
    printf("Output 0 on GPIO-2 configured as OUTPUT using Cypress USB-Serial Configuration Utility...\n");
    rStatus = CySetGpioValue (cyHandle, gpioNumber, 0);
    if (rStatus){
        printf ("Set GPIO failed.\n");
        return -1;
    printf("Output 1 on GPIO-2 configured as OUTPUT using Cypress USB-Serial Configuration Utility...\n");
    rStatus = CySetGpioValue (cyHandle, gpioNumber, 1);
    if (rStatus){
        return -1;
    gpioNumber = 1;
    printf("Read from on GPIO-2 configured as INPUT using Cypress USB-Serial Configuration Utility...\n");
    rStatus = CyGetGpioValue (cyHandle, gpioNumber, &value);
    if (rStatus){
        printf ("Get GPIO value failed\n");
        return -1;
    printf ("GPIO-1 Value is %d \n", value);
    // Close the cyHandle to USB-Serial device
    return CyClose (cyHandle);
Function Name: int FindDeviceAtSCB0()
Purpose: Demonstates how to enumerate and find device from the list of devices.
- Demonstrates how to use deviceBlock member in DEVICE_INFO structure
Arguments: None
Retrun Code: returns -1, if no device is present or deviceIndex of the device.
    cyVidPid.vid = VID; //Defined as macro
    cyVidPid.pid = PID; //Defined as macro
    //Array size of cyDeviceInfoList is 16
    cyReturnStatus = CyGetDeviceInfoVidPid (cyVidPid, deviceID, (PCY_DEVICE_INFO)&cyDeviceInfoList, &cyNumDevices, 16);
    int deviceIndexAtSCB0 = -1;
    for (int index = 0; index < cyNumDevices; index++){
        printf ("\nNumber of interfaces: %d\n \
                Vid: 0x%X \n\
                Pid: 0x%X \n\
                Serial name is: %s\n\
                Manufacturer name: %s\n\
                Product Name: %s\n\
                SCB Number: 0x%X \n\
                Device Type: %d \n\
                Device Class: %d\n\n\n",
                cyDeviceInfoList[index].numInterfaces,
                cyDeviceInfoList[index].vidPid.vid,
                cyDeviceInfoList[index].vidPid.pid,
                cyDeviceInfoList[index].serialNum,
                cyDeviceInfoList[index].manufacturerName,
                cyDeviceInfoList[index].productName,
                cyDeviceInfoList[index].deviceBlock,
                cyDeviceInfoList[index].deviceType[0],
                cyDeviceInfoList[index].deviceClass[0]);
        // Find the device at device index at SCB0
        if (cyDeviceInfoList[index].deviceBlock == SerialBlock_MFG) //SerialBlock_SCB0
            deviceIndexAtSCB0 = index;
    return deviceIndexAtSCB0;
Application main() function
int _tmain(int argc, _TCHAR* argv[])
    //NOTE: SCB Index is not needed for accessing GPIO. But as this function call ensures
    //access to right SCB, this example uses this code.
    int deviceIndexAtSCB0 = FindDeviceAtSCB0();
    //Open the device at index deviceIndexAtSCB0
    if (deviceIndexAtSCB0 >= 0)
        //Assuming that device at "index" is USB-Serial device
        //Device Open, Close, Configuration, Data operations are handled in the function GPIOTasks
        int status = GPIOTasks(deviceIndexAtSCB0);
        if (status == CY_SUCCESS)
            printf("\nGPIOTasks returned success.\n");
        else
            printf("\nGPIOTasks returned failure code.\n");
        } //cyNumDevices > 0 && cyReturnStatus == CY_SUCCESS
    return 0;
    社区居民忠实会员最爱沙发终身成就奖优秀斑竹奖
    发表于 2015-6-28 14:23:31 | 显示全部楼层
