查看: 1081|回复: 0
RK3288  USB  触摸屏驱动
社区居民社区明星忠实会员宣传大使奖终身成就奖特殊贡献奖
发表于 2015-7-7 09:20:56 | 显示全部楼层 |阅读模式
* usbtouchscreen.c
* Driver for USB Touchscreens, supporting those devices:
*  - eGalax Touchkit
*    includes eTurboTouch CT-410/510/700
*  - 3M/Microtouch  EX II series
*  - ITM
*  - PanJit TouchSet
*  - eTurboTouch
*  - Gunze AHL61
*  - DMC TSC-10/25
*  - IRTOUCHSYSTEMS/UNITOP
*  - IdealTEK URTC1000
*  - General Touch
*  - GoTop Super_Q2/GogoPen/PenPower tablets
*  - JASTEC USB touch controller/DigiTech DTR-02U
*  - Zytronic capacitive touchscreen
*  - NEXIO/iNexio
* Copyright (C) 2004-2007 by Daniel Ritz <daniel.ritz@gmx.ch>
* Copyright (C) by Todd E. Johnson (mtouchusb.c)
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of the
* License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful, but
* WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
* General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
* Driver is based on touchkitusb.c
* - ITM parts are from itmtouch.c
* - 3M parts are from mtouchusb.c
* - PanJit parts are from an unmerged driver by Lanslott Gish
* - DMC TSC 10/25 are from Holger Schurig, with ideas from an unmerged
*   driver from Marius Vollmer
//#define DEBUG
#include <linux/kernel.h>
#include <linux/slab.h>
#include <linux/input.h>
#include <linux/module.h>
#include <linux/init.h>
#include <linux/usb.h>
#include <linux/usb/input.h>
#include <linux/hid.h>
#define DRIVER_VERSION        "v0.6"
#define DRIVER_AUTHOR        "Daniel Ritz <daniel.ritz@gmx.ch>"
#define DRIVER_DESC        "USB Touchscreen Driver"
static int swap_xy;
module_param(swap_xy, bool, 0644);
MODULE_PARM_DESC(swap_xy, "If set X and Y axes are swapped.");
static int hwcalib_xy;
module_param(hwcalib_xy, bool, 0644);
MODULE_PARM_DESC(hwcalib_xy, "If set hw-calibrated X/Y are used if available");
/* device specifc data/functions */
struct usbtouch_usb;
struct usbtouch_device_info {
    int min_xc, max_xc;
    int min_yc, max_yc;
    int min_press, max_press;
    int rept_size;
     * Always service the USB devices irq not just when the input device is
     * open. This is useful when devices have a watchdog which prevents us
     * from periodically polling the device. Leave this unset unless your
     * touchscreen device requires it, as it does consume more of the USB
     * bandwidth.
    bool irq_always;
    void (*process_pkt) (struct usbtouch_usb *usbtouch, unsigned char *pkt, int len);
     * used to get the packet len. possible return values:
     * > 0: packet len
     * = 0: skip one byte
     * < 0: -return value more bytes needed
    int  (*get_pkt_len) (unsigned char *pkt, int len);
    int  (*read_data)   (struct usbtouch_usb *usbtouch, unsigned char *pkt);
    int  (*alloc)       (struct usbtouch_usb *usbtouch);
    int  (*init)        (struct usbtouch_usb *usbtouch);
    void (*exit)        (struct usbtouch_usb *usbtouch);
/* a usbtouch device */
struct usbtouch_usb {
    unsigned char *data;
    dma_addr_t data_dma;
    unsigned char *buffer;
    int buf_len;
    struct urb *irq;
    struct usb_interface *interface;
    struct input_dev *input;
    struct usbtouch_device_info *type;
    char name[128];
    char phys[64];
    void *priv;
    int x, y;
    int touch, press;
/* device types */
enum {
    DEVTYPE_IGNORE = -1,
    DEVTYPE_EGALAX,
    DEVTYPE_PANJIT,
    DEVTYPE_3M,
    DEVTYPE_ITM,
    DEVTYPE_ETURBO,
    DEVTYPE_GUNZE,
    DEVTYPE_DMC_TSC10,
    DEVTYPE_IRTOUCH,
    DEVTYPE_IDEALTEK,
    DEVTYPE_GENERAL_TOUCH,
    DEVTYPE_GOTOP,
    DEVTYPE_JASTEC,
    DEVTYPE_E2I,
    DEVTYPE_ZYTRONIC,
    DEVTYPE_TC45USB,
    DEVTYPE_NEXIO,
#define USB_DEVICE_HID_CLASS(vend, prod) \
    .match_flags = USB_DEVICE_ID_MATCH_INT_CLASS \
        | USB_DEVICE_ID_MATCH_INT_PROTOCOL \
        | USB_DEVICE_ID_MATCH_DEVICE, \
    .idVendor = (vend), \
    .idProduct = (prod), \
    .bInterfaceClass = USB_INTERFACE_CLASS_HID, \
    .bInterfaceProtocol = USB_INTERFACE_PROTOCOL_MOUSE
static const struct usb_device_id usbtouch_devices[] = {
#ifdef CONFIG_TOUCHSCREEN_USB_EGALAX
    /* ignore the HID capable devices, handled by usbhid */
    {USB_DEVICE_HID_CLASS(0x0eef, 0x0001), .driver_info = DEVTYPE_IGNORE},
    {USB_DEVICE_HID_CLASS(0x0eef, 0x0002), .driver_info = DEVTYPE_IGNORE},
    /* normal device IDs */
    {USB_DEVICE(0x3823, 0x0001), .driver_info = DEVTYPE_EGALAX},
    {USB_DEVICE(0x3823, 0x0002), .driver_info = DEVTYPE_EGALAX},
    {USB_DEVICE(0x0123, 0x0001), .driver_info = DEVTYPE_EGALAX},
    {USB_DEVICE(0x0eef, 0x0001), .driver_info = DEVTYPE_EGALAX},
    {USB_DEVICE(0x0eef, 0x0002), .driver_info = DEVTYPE_EGALAX},
    {USB_DEVICE(0x1234, 0x0001), .driver_info = DEVTYPE_EGALAX},
    {USB_DEVICE(0x1234, 0x0002), .driver_info = DEVTYPE_EGALAX},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_PANJIT
    {USB_DEVICE(0x134c, 0x0001), .driver_info = DEVTYPE_PANJIT},
    {USB_DEVICE(0x134c, 0x0002), .driver_info = DEVTYPE_PANJIT},
    {USB_DEVICE(0x134c, 0x0003), .driver_info = DEVTYPE_PANJIT},
    {USB_DEVICE(0x134c, 0x0004), .driver_info = DEVTYPE_PANJIT},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_3M
    {USB_DEVICE(0x0596, 0x0001), .driver_info = DEVTYPE_3M},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_ITM
    {USB_DEVICE(0x0403, 0xf9e9), .driver_info = DEVTYPE_ITM},
    {USB_DEVICE(0x16e3, 0xf9e9), .driver_info = DEVTYPE_ITM},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_ETURBO
    {USB_DEVICE(0x1234, 0x5678), .driver_info = DEVTYPE_ETURBO},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_GUNZE
    {USB_DEVICE(0x0637, 0x0001), .driver_info = DEVTYPE_GUNZE},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_DMC_TSC10
    {USB_DEVICE(0x0afa, 0x03e8), .driver_info = DEVTYPE_DMC_TSC10},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_IRTOUCH
    {USB_DEVICE(0x595a, 0x0001), .driver_info = DEVTYPE_IRTOUCH},
    {USB_DEVICE(0x6615, 0x0001), .driver_info = DEVTYPE_IRTOUCH},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_IDEALTEK
    {USB_DEVICE(0x1391, 0x1000), .driver_info = DEVTYPE_IDEALTEK},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_GENERAL_TOUCH
    {USB_DEVICE(0x0dfc, 0x0001), .driver_info = DEVTYPE_GENERAL_TOUCH},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_GOTOP
    {USB_DEVICE(0x08f2, 0x007f), .driver_info = DEVTYPE_GOTOP},
    {USB_DEVICE(0x08f2, 0x00ce), .driver_info = DEVTYPE_GOTOP},
    {USB_DEVICE(0x08f2, 0x00f4), .driver_info = DEVTYPE_GOTOP},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_JASTEC
    {USB_DEVICE(0x0f92, 0x0001), .driver_info = DEVTYPE_JASTEC},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_E2I
    {USB_DEVICE(0x1ac7, 0x0001), .driver_info = DEVTYPE_E2I},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_ZYTRONIC
    {USB_DEVICE(0x14c8, 0x0003), .driver_info = DEVTYPE_ZYTRONIC},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_ETT_TC45USB
    /* TC5UH */
    {USB_DEVICE(0x0664, 0x0309), .driver_info = DEVTYPE_TC45USB},
    /* TC4UM */
    {USB_DEVICE(0x0664, 0x0306), .driver_info = DEVTYPE_TC45USB},
#endif
#ifdef CONFIG_TOUCHSCREEN_USB_NEXIO
    /* data interface only */
    {USB_DEVICE_AND_INTERFACE_INFO(0x10f0, 0x2002, 0x0a, 0x00, 0x00),
        .driver_info = DEVTYPE_NEXIO},
    {USB_DEVICE_AND_INTERFACE_INFO(0x1870, 0x0001, 0x0a, 0x00, 0x00),
#endif
* e2i Part
static int e2i_init(struct usbtouch_usb *usbtouch)
    int ret;
    struct usb_device *udev = interface_to_usbdev(usbtouch->interface);
    ret = usb_control_msg(udev, usb_rcvctrlpipe(udev, 0),
                          0x01, 0x02, 0x0000, 0x0081,
                          NULL, 0, USB_CTRL_SET_TIMEOUT);
    dbg("%s - usb_control_msg - E2I_RESET - bytes|err: %d",
        __func__, ret);
    return ret;
static int e2i_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    int tmp = (pkt[0] << 8) | pkt[1];
    dev->x  = (pkt[2] << 8) | pkt[3];
    dev->y  = (pkt[4] << 8) | pkt[5];
    tmp = tmp - 0xA000;
    dev->touch = (tmp > 0);
    dev->press = (tmp > 0 ? tmp : 0);
    return 1;
#endif
* eGalax part
#ifndef MULTI_PACKET
#define MULTI_PACKET
#endif
#define EGALAX_PKT_TYPE_MASK        0xFE
#define EGALAX_PKT_TYPE_REPT        0x80
#define EGALAX_PKT_TYPE_DIAG        0x0A
static int egalax_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    if ((pkt[0] & EGALAX_PKT_TYPE_MASK) != EGALAX_PKT_TYPE_REPT)
        return 0;
    dev->x = ((pkt[3] & 0x0F) << 7) | (pkt[4] & 0x7F);
    dev->y = ((pkt[1] & 0x0F) << 7) | (pkt[2] & 0x7F);
    dev->touch = pkt[0] & 0x01;
    return 1;
static int egalax_get_pkt_len(unsigned char *buf, int len)
    switch (buf[0] & EGALAX_PKT_TYPE_MASK) {
    case EGALAX_PKT_TYPE_REPT:
        return 5;
    case EGALAX_PKT_TYPE_DIAG:
        if (len < 2)
            return -1;
        return buf[1] + 2;
    return 0;
#endif
* PanJit Part
static int panjit_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    dev->x = ((pkt[2] & 0x0F) << 8) | pkt[1];
    dev->y = ((pkt[4] & 0x0F) << 8) | pkt[3];
    return 1;
#endif
* 3M/Microtouch Part
#define MTOUCHUSB_ASYNC_REPORT          1
#define MTOUCHUSB_RESET                 7
#define MTOUCHUSB_REQ_CTRLLR_ID         10
static int mtouch_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    if (hwcalib_xy) {
        dev->x = (pkt[4] << 8) | pkt[3];
        dev->y = 0xffff - ((pkt[6] << 8) | pkt[5]);
    } else {
        dev->x = (pkt[8] << 8) | pkt[7];
        dev->y = (pkt[10] << 8) | pkt[9];
    dev->touch = (pkt[2] & 0x40) ? 1 : 0;
    return 1;
static int mtouch_init(struct usbtouch_usb *usbtouch)
    int ret, i;
                          MTOUCHUSB_RESET,
                          USB_DIR_OUT | USB_TYPE_VENDOR | USB_RECIP_DEVICE,
                          1, 0, NULL, 0, USB_CTRL_SET_TIMEOUT);
    dbg("%s - usb_control_msg - MTOUCHUSB_RESET - bytes|err: %d",
        __func__, ret);
    if (ret < 0)
        return ret;
    msleep(150);
    for (i = 0; i < 3; i++) {
                      MTOUCHUSB_ASYNC_REPORT,
                      1, 1, NULL, 0, USB_CTRL_SET_TIMEOUT);
        dbg("%s - usb_control_msg - MTOUCHUSB_ASYNC_REPORT - bytes|err: %d",
            __func__, ret);
        if (ret >= 0)
            break;
        if (ret != -EPIPE)
            return ret;
    /* Default min/max xy are the raw values, override if using hw-calib */
    if (hwcalib_xy) {
        input_set_abs_params(usbtouch->input, ABS_X, 0, 0xffff, 0, 0);
        input_set_abs_params(usbtouch->input, ABS_Y, 0, 0xffff, 0, 0);
    return 0;
#endif
* ITM Part
static int itm_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    int touch;
     * ITM devices report invalid x/y data if not touched.
     * if the screen was touched before but is not touched any more
     * report touch as 0 with the last valid x/y data once. then stop
     * reporting data until touched again.
    dev->press = ((pkt[2] & 0x01) << 7) | (pkt[5] & 0x7F);
    touch = ~pkt[7] & 0x20;
    if (!touch) {
        if (dev->touch) {
            dev->touch = 0;
            return 1;
        return 0;
    dev->x = ((pkt[0] & 0x1F) << 7) | (pkt[3] & 0x7F);
    dev->y = ((pkt[1] & 0x1F) << 7) | (pkt[4] & 0x7F);
    dev->touch = touch;
    return 1;
#endif
* eTurboTouch part
#endif
static int eturbo_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    unsigned int shift;
    /* packets should start with sync */
    if (!(pkt[0] & 0x80))
        return 0;
    shift = (6 - (pkt[0] & 0x03));
    dev->x = ((pkt[3] << 7) | pkt[4]) >> shift;
    dev->y = ((pkt[1] << 7) | pkt[2]) >> shift;
    dev->touch = (pkt[0] & 0x10) ? 1 : 0;
    return 1;
static int eturbo_get_pkt_len(unsigned char *buf, int len)
    if (buf[0] & 0x80)
        return 5;
    if (buf[0] == 0x01)
        return 3;
    return 0;
#endif
* Gunze part
static int gunze_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    if (!(pkt[0] & 0x80) || ((pkt[1] | pkt[2] | pkt[3]) & 0x80))
        return 0;
    dev->x = ((pkt[0] & 0x1F) << 7) | (pkt[2] & 0x7F);
    dev->y = ((pkt[1] & 0x1F) << 7) | (pkt[3] & 0x7F);
    dev->touch = pkt[0] & 0x20;
    return 1;
#endif
* DMC TSC-10/25 Part
* Documentation about the controller and it's protocol can be found at
*   http://www.dmccoltd.com/files/controler/tsc10usb_pi_e.pdf
*   http://www.dmccoltd.com/files/controler/tsc25_usb_e.pdf
/* supported data rates. currently using 130 */
#define TSC10_RATE_POINT    0x50
#define TSC10_RATE_30        0x40
#define TSC10_RATE_50        0x41
#define TSC10_RATE_80        0x42
#define TSC10_RATE_100        0x43
#define TSC10_RATE_130        0x44
#define TSC10_RATE_150        0x45
/* commands */
#define TSC10_CMD_RESET        0x55
#define TSC10_CMD_RATE        0x05
#define TSC10_CMD_DATA1        0x01
static int dmc_tsc10_init(struct usbtouch_usb *usbtouch)
    struct usb_device *dev = interface_to_usbdev(usbtouch->interface);
    int ret = -ENOMEM;
    unsigned char *buf;
    buf = kmalloc(2, GFP_NOIO);
    if (!buf)
        goto err_nobuf;
    /* reset */
    buf[0] = buf[1] = 0xFF;
    ret = usb_control_msg(dev, usb_rcvctrlpipe (dev, 0),
                          TSC10_CMD_RESET,
                          USB_DIR_IN | USB_TYPE_VENDOR | USB_RECIP_DEVICE,
                          0, 0, buf, 2, USB_CTRL_SET_TIMEOUT);
    if (ret < 0)
        goto err_out;
    if (buf[0] != 0x06) {
        ret = -ENODEV;
        goto err_out;
    /* set coordinate output rate */
                          TSC10_CMD_RATE,
                          TSC10_RATE_150, 0, buf, 2, USB_CTRL_SET_TIMEOUT);
    if (ret < 0)
        goto err_out;
    if ((buf[0] != 0x06) && (buf[0] != 0x15 || buf[1] != 0x01)) {
        ret = -ENODEV;
        goto err_out;
    /* start sending data */
                          TSC10_CMD_DATA1,
                          0, 0, NULL, 0, USB_CTRL_SET_TIMEOUT);
err_out:
    kfree(buf);
err_nobuf:
    return ret;
static int dmc_tsc10_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    dev->x = ((pkt[2] & 0x03) << 8) | pkt[1];
    dev->y = ((pkt[4] & 0x03) << 8) | pkt[3];
    return 1;
#endif
* IRTOUCH Part
static int irtouch_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    dev->x = (pkt[3] << 8) | pkt[2];
    dev->y = (pkt[5] << 8) | pkt[4];
    dev->touch = (pkt[1] & 0x03) ? 1 : 0;
    return 1;
#endif
* ET&T TC5UH/TC4UM part
static int tc45usb_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    return 1;
#endif
* IdealTEK URTC1000 Part
#endif
static int idealtek_get_pkt_len(unsigned char *buf, int len)
    if (buf[0] & 0x80)
        return 5;
    if (buf[0] == 0x01)
        return len;
    return 0;
static int idealtek_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    switch (pkt[0] & 0x98) {
    case 0x88:
        /* touch data in IdealTEK mode */
        dev->x = (pkt[1] << 5) | (pkt[2] >> 2);
        dev->y = (pkt[3] << 5) | (pkt[4] >> 2);
        dev->touch = (pkt[0] & 0x40) ? 1 : 0;
        return 1;
    case 0x98:
        /* touch data in MT emulation mode */
        dev->x = (pkt[2] << 5) | (pkt[1] >> 2);
        dev->y = (pkt[4] << 5) | (pkt[3] >> 2);
        return 1;
    default:
        return 0;
#endif
* General Touch Part
static int general_touch_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    dev->x = (pkt[2] << 8) | pkt[1];
    dev->y = (pkt[4] << 8) | pkt[3];
    dev->press = pkt[5] & 0xff;
    return 1;
#endif
* GoTop Part
static int gotop_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    dev->x = ((pkt[1] & 0x38) << 4) | pkt[2];
    dev->y = ((pkt[1] & 0x07) << 7) | pkt[3];
    return 1;
#endif
* JASTEC Part
static int jastec_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    dev->x = ((pkt[0] & 0x3f) << 6) | (pkt[2] & 0x3f);
    dev->y = ((pkt[1] & 0x3f) << 6) | (pkt[3] & 0x3f);
    dev->touch = (pkt[0] & 0x40) >> 6;
    return 1;
#endif
* Zytronic Part
static int zytronic_read_data(struct usbtouch_usb *dev, unsigned char *pkt)
    switch (pkt[0]) {
    case 0x3A: /* command response */
        dbg("%s: Command response %d", __func__, pkt[1]);
        break;
    case 0xC0: /* down */
        dev->x = (pkt[1] & 0x7f) | ((pkt[2] & 0x07) << 7);
        dev->y = (pkt[3] & 0x7f) | ((pkt[4] & 0x07) << 7);
        dev->touch = 1;
        dbg("%s: down %d,%d", __func__, dev->x, dev->y);
        return 1;
    case 0x80: /* up */
        dev->touch = 0;
        dbg("%s: up %d,%d", __func__, dev->x, dev->y);
        return 1;
    default:
        dbg("%s: Unknown return %d", __func__, pkt[0]);
        break;
    return 0;
#endif
* NEXIO Part
#define NEXIO_TIMEOUT    5000
#define NEXIO_BUFSIZE    1024
#define NEXIO_THRESHOLD    50
struct nexio_priv {
    struct urb *ack;
    unsigned char *ack_buf;
struct nexio_touch_packet {
    u8    flags;        /* 0xe1 = touch, 0xe1 = release */
    __be16    data_len;    /* total bytes of touch data */
    __be16    x_len;        /* bytes for X axis */
    __be16    y_len;        /* bytes for Y axis */
    u8    data[];
} __attribute__ ((packed));
static unsigned char nexio_ack_pkt[2] = { 0xaa, 0x02 };
static unsigned char nexio_init_pkt[4] = { 0x82, 0x04, 0x0a, 0x0f };
static void nexio_ack_complete(struct urb *urb)
static int nexio_alloc(struct usbtouch_usb *usbtouch)
    struct nexio_priv *priv;
    int ret = -ENOMEM;
    usbtouch->priv = kmalloc(sizeof(struct nexio_priv), GFP_KERNEL);
    if (!usbtouch->priv)
        goto out_buf;
    priv = usbtouch->priv;
    priv->ack_buf = kmemdup(nexio_ack_pkt, sizeof(nexio_ack_pkt),
                GFP_KERNEL);
    if (!priv->ack_buf)
        goto err_priv;
    priv->ack = usb_alloc_urb(0, GFP_KERNEL);
    if (!priv->ack) {
        dbg("%s - usb_alloc_urb failed: usbtouch->ack", __func__);
        goto err_ack_buf;
    return 0;
err_ack_buf:
    kfree(priv->ack_buf);
err_priv:
    kfree(priv);
out_buf:
    return ret;
static int nexio_init(struct usbtouch_usb *usbtouch)
    struct usb_host_interface *interface = usbtouch->interface->cur_altsetting;
    struct nexio_priv *priv = usbtouch->priv;
    int ret = -ENOMEM;
    int actual_len, i;
    unsigned char *buf;
    char *firmware_ver = NULL, *device_name = NULL;
    int input_ep = 0, output_ep = 0;
    /* find first input and output endpoint */
    for (i = 0; i < interface->desc.bNumEndpoints; i++) {
        if (!input_ep &&
            usb_endpoint_dir_in(&interface->endpoint.desc))
            input_ep = interface->endpoint.desc.bEndpointAddress;
        if (!output_ep &&
            usb_endpoint_dir_out(&interface->endpoint.desc))
            output_ep = interface->endpoint.desc.bEndpointAddress;
    if (!input_ep || !output_ep)
        return -ENXIO;
    buf = kmalloc(NEXIO_BUFSIZE, GFP_NOIO);
    if (!buf)
        goto out_buf;
    /* two empty reads */
    for (i = 0; i < 2; i++) {
        ret = usb_bulk_msg(dev, usb_rcvbulkpipe(dev, input_ep),
                   buf, NEXIO_BUFSIZE, &actual_len,
                   NEXIO_TIMEOUT);
        if (ret < 0)
            goto out_buf;
    /* send init command */
    memcpy(buf, nexio_init_pkt, sizeof(nexio_init_pkt));
    ret = usb_bulk_msg(dev, usb_sndbulkpipe(dev, output_ep),
               buf, sizeof(nexio_init_pkt), &actual_len,
               NEXIO_TIMEOUT);
    if (ret < 0)
        goto out_buf;
    /* read replies */
        memset(buf, 0, NEXIO_BUFSIZE);
                   NEXIO_TIMEOUT);
        if (ret < 0 || actual_len < 1 || buf[1] != actual_len)
            continue;
        switch (buf[0]) {
        case 0x83:    /* firmware version */
            if (!firmware_ver)
                firmware_ver = kstrdup(&buf[2], GFP_NOIO);
            break;
        case 0x84:    /* device name */
            if (!device_name)
                device_name = kstrdup(&buf[2], GFP_NOIO);
            break;
    printk(KERN_INFO "Nexio device: %s, firmware version: %s\n",
           device_name, firmware_ver);
    kfree(firmware_ver);
    kfree(device_name);
    usb_fill_bulk_urb(priv->ack, dev, usb_sndbulkpipe(dev, output_ep),
              priv->ack_buf, sizeof(nexio_ack_pkt),
              nexio_ack_complete, usbtouch);
    ret = 0;
out_buf:
    kfree(buf);
    return ret;
static void nexio_exit(struct usbtouch_usb *usbtouch)
    usb_kill_urb(priv->ack);
    usb_free_urb(priv->ack);
    kfree(priv);
static int nexio_read_data(struct usbtouch_usb *usbtouch, unsigned char *pkt)
    struct nexio_touch_packet *packet = (void *) pkt;
    unsigned int data_len = be16_to_cpu(packet->data_len);
    unsigned int x_len = be16_to_cpu(packet->x_len);
    unsigned int y_len = be16_to_cpu(packet->y_len);
    int x, y, begin_x, begin_y, end_x, end_y, w, h, ret;
    /* got touch data? */
    if ((pkt[0] & 0xe0) != 0xe0)
        return 0;
    if (data_len > 0xff)
        data_len -= 0x100;
    if (x_len > 0xff)
        x_len -= 0x80;
    /* send ACK */
    ret = usb_submit_urb(priv->ack, GFP_ATOMIC);
    if (!usbtouch->type->max_xc) {
        usbtouch->type->max_xc = 2 * x_len;
                     0, usbtouch->type->max_xc, 0, 0);
        usbtouch->type->max_yc = 2 * y_len;
                     0, usbtouch->type->max_yc, 0, 0);
     * The device reports state of IR sensors on X and Y axes.
     * Each byte represents "darkness" percentage (0-100) of one element.
     * 17" touchscreen reports only 64 x 52 bytes so the resolution is low.
     * This also means that there's a limited multi-touch capability but
     * it's disabled (and untested) here as there's no X driver for that.
    begin_x = end_x = begin_y = end_y = -1;
    for (x = 0; x < x_len; x++) {
        if (begin_x == -1 && packet->data[x] > NEXIO_THRESHOLD) {
            begin_x = x;
            continue;
        if (end_x == -1 && begin_x != -1 && packet->data[x] < NEXIO_THRESHOLD) {
            end_x = x - 1;
            for (y = x_len; y < data_len; y++) {
                if (begin_y == -1 && packet->data[y] > NEXIO_THRESHOLD) {
                    begin_y = y - x_len;
                    continue;
                if (end_y == -1 &&
                    begin_y != -1 && packet->data[y] < NEXIO_THRESHOLD) {
                    end_y = y - 1 - x_len;
                    w = end_x - begin_x;
                    h = end_y - begin_y;
#if 0
                    /* multi-touch */
                    input_report_abs(usbtouch->input,
                            ABS_MT_TOUCH_MAJOR, max(w,h));
                            ABS_MT_TOUCH_MINOR, min(x,h));
                            ABS_MT_POSITION_X, 2*begin_x+w);
                            ABS_MT_POSITION_Y, 2*begin_y+h);
                            ABS_MT_ORIENTATION, w > h);
                    input_mt_sync(usbtouch->input);
#endif
                    /* single touch */
                    usbtouch->x = 2 * begin_x + w;
                    usbtouch->y = 2 * begin_y + h;
                    usbtouch->touch = packet->flags & 0x01;
                    return 1;
            begin_x = end_x = -1;
    return 0;
#endif
* the different device descriptors
#ifdef MULTI_PACKET
static void usbtouch_process_multi(struct usbtouch_usb *usbtouch,
#endif
static struct usbtouch_device_info usbtouch_dev_info[] = {
    [DEVTYPE_EGALAX] = {
        .min_xc        = 0x0,
        .max_xc        = 0x07ff,
        .min_yc        = 0x0,
        .max_yc        = 0x07ff,
        .rept_size    = 16,
        .process_pkt    = usbtouch_process_multi,
        .get_pkt_len    = egalax_get_pkt_len,
        .read_data    = egalax_read_data,
#endif
    [DEVTYPE_PANJIT] = {
        .min_xc        = 0x0,
        .max_xc        = 0x0fff,
        .min_yc        = 0x0,
        .max_yc        = 0x0fff,
        .rept_size    = 8,
        .read_data    = panjit_read_data,
#endif
    [DEVTYPE_3M] = {
        .min_xc        = 0x0,
        .max_xc        = 0x4000,
        .min_yc        = 0x0,
        .max_yc        = 0x4000,
        .rept_size    = 11,
        .read_data    = mtouch_read_data,
        .init        = mtouch_init,
#endif
    [DEVTYPE_ITM] = {
        .min_xc        = 0x0,
        .max_xc        = 0x0fff,
        .min_yc        = 0x0,
        .max_yc        = 0x0fff,
        .max_press    = 0xff,
        .rept_size    = 8,
        .read_data    = itm_read_data,
#endif
    [DEVTYPE_ETURBO] = {
        .min_xc        = 0x0,
        .max_xc        = 0x07ff,
        .min_yc        = 0x0,
        .max_yc        = 0x07ff,
        .rept_size    = 8,
        .get_pkt_len    = eturbo_get_pkt_len,
        .read_data    = eturbo_read_data,
#endif
    [DEVTYPE_GUNZE] = {
        .min_xc        = 0x0,
        .max_xc        = 0x0fff,
        .min_yc        = 0x0,
        .max_yc        = 0x0fff,
        .rept_size    = 4,
        .read_data    = gunze_read_data,
#endif
    [DEVTYPE_DMC_TSC10] = {
        .min_xc        = 0x0,
        .max_xc        = 0x03ff,
        .min_yc        = 0x0,
        .max_yc        = 0x03ff,
        .rept_size    = 5,
        .init        = dmc_tsc10_init,
        .read_data    = dmc_tsc10_read_data,
#endif
    [DEVTYPE_IRTOUCH] = {
        .min_xc        = 0x0,
        .max_xc        = 0x0fff,
        .min_yc        = 0x0,
        .max_yc        = 0x0fff,
        .rept_size    = 8,
        .read_data    = irtouch_read_data,
#endif
    [DEVTYPE_IDEALTEK] = {
        .min_xc        = 0x0,
        .max_xc        = 0x0fff,
        .min_yc        = 0x0,
        .max_yc        = 0x0fff,
        .rept_size    = 8,
        .get_pkt_len    = idealtek_get_pkt_len,
        .read_data    = idealtek_read_data,
#endif
    [DEVTYPE_GENERAL_TOUCH] = {
        .min_xc        = 0x0,
        .max_xc        = 0x7fff,
        .min_yc        = 0x0,
        .max_yc        = 0x7fff,
        .rept_size    = 7,
        .read_data    = general_touch_read_data,
#endif
    [DEVTYPE_GOTOP] = {
        .min_xc        = 0x0,
        .max_xc        = 0x03ff,
        .min_yc        = 0x0,
        .max_yc        = 0x03ff,
        .rept_size    = 4,
        .read_data    = gotop_read_data,
#endif
    [DEVTYPE_JASTEC] = {
        .min_xc        = 0x0,
        .max_xc        = 0x0fff,
        .min_yc        = 0x0,
        .max_yc        = 0x0fff,
        .rept_size    = 4,
        .read_data    = jastec_read_data,
#endif
    [DEVTYPE_E2I] = {
        .min_xc        = 0x0,
        .max_xc        = 0x7fff,
        .min_yc        = 0x0,
        .max_yc        = 0x7fff,
        .rept_size    = 6,
        .init        = e2i_init,
        .read_data    = e2i_read_data,
#endif
    [DEVTYPE_ZYTRONIC] = {
        .min_xc        = 0x0,
        .max_xc        = 0x03ff,
        .min_yc        = 0x0,
        .max_yc        = 0x03ff,
        .rept_size    = 5,
        .read_data    = zytronic_read_data,
        .irq_always     = true,
#endif
    [DEVTYPE_TC45USB] = {
        .min_xc        = 0x0,
        .max_xc        = 0x0fff,
        .min_yc        = 0x0,
        .max_yc        = 0x0fff,
        .rept_size    = 5,
        .read_data    = tc45usb_read_data,
#endif
    [DEVTYPE_NEXIO] = {
        .rept_size    = 1024,
        .irq_always    = true,
        .read_data    = nexio_read_data,
        .alloc        = nexio_alloc,
        .init        = nexio_init,
        .exit        = nexio_exit,
#endif
* Generic Part
static void usbtouch_process_pkt(struct usbtouch_usb *usbtouch,
    struct usbtouch_device_info *type = usbtouch->type;
    if (!type->read_data(usbtouch, pkt))
            return;
    input_report_key(usbtouch->input, BTN_TOUCH, usbtouch->touch);
    if (swap_xy) {
        input_report_abs(usbtouch->input, ABS_X, usbtouch->y);
        input_report_abs(usbtouch->input, ABS_Y, usbtouch->x);
    } else {
        input_report_abs(usbtouch->input, ABS_X, usbtouch->x);
        input_report_abs(usbtouch->input, ABS_Y, usbtouch->y);
    if (type->max_press)
        input_report_abs(usbtouch->input, ABS_PRESSURE, usbtouch->press);
    input_sync(usbtouch->input);
#ifdef MULTI_PACKET
    int pkt_len, pos, buf_len, tmp;
    /* process buffer */
    if (unlikely(usbtouch->buf_len)) {
        /* try to get size */
        pkt_len = usbtouch->type->get_pkt_len(
                usbtouch->buffer, usbtouch->buf_len);
        /* drop? */
        if (unlikely(!pkt_len))
            goto out_flush_buf;
        /* need to append -pkt_len bytes before able to get size */
        if (unlikely(pkt_len < 0)) {
            int append = -pkt_len;
            if (unlikely(append > len))
                   append = len;
            if (usbtouch->buf_len + append >= usbtouch->type->rept_size)
                goto out_flush_buf;
            memcpy(usbtouch->buffer + usbtouch->buf_len, pkt, append);
            usbtouch->buf_len += append;
            if (pkt_len < 0)
                return;
        /* append */
        tmp = pkt_len - usbtouch->buf_len;
        if (usbtouch->buf_len + tmp >= usbtouch->type->rept_size)
            goto out_flush_buf;
        memcpy(usbtouch->buffer + usbtouch->buf_len, pkt, tmp);
        usbtouch_process_pkt(usbtouch, usbtouch->buffer, pkt_len);
        buffer = pkt + tmp;
        buf_len = len - tmp;
    } else {
        buffer = pkt;
        buf_len = len;
    /* loop over the received packet, process */
    pos = 0;
    while (pos < buf_len) {
        /* get packet len */
        pkt_len = usbtouch->type->get_pkt_len(buffer + pos,
                            buf_len - pos);
        /* unknown packet: skip one byte */
        if (unlikely(!pkt_len)) {
            pos++;
            continue;
        /* full packet: process */
        if (likely((pkt_len > 0) && (pkt_len <= buf_len - pos))) {
            usbtouch_process_pkt(usbtouch, buffer + pos, pkt_len);
        } else {
            /* incomplete packet: save in buffer */
            memcpy(usbtouch->buffer, buffer + pos, buf_len - pos);
            usbtouch->buf_len = buf_len - pos;
            return;
        pos += pkt_len;
out_flush_buf:
    usbtouch->buf_len = 0;
    return;
#endif
static void usbtouch_irq(struct urb *urb)
    struct usbtouch_usb *usbtouch = urb->context;
    int retval;
    switch (urb->status) {
    case 0:
        /* success */
        break;
    case -ETIME:
        /* this urb is timing out */
        dbg("%s - urb timed out - was the device unplugged?",
            __func__);
        return;
    case -ECONNRESET:
    case -ENOENT:
    case -ESHUTDOWN:
    case -EPIPE:
        /* this urb is terminated, clean up */
        dbg("%s - urb shutting down with status: %d",
            __func__, urb->status);
        return;
    default:
        dbg("%s - nonzero urb status received: %d",
        goto exit;
    usbtouch->type->process_pkt(usbtouch, usbtouch->data, urb->actual_length);
exit:
    usb_mark_last_busy(interface_to_usbdev(usbtouch->interface));
    retval = usb_submit_urb(urb, GFP_ATOMIC);
    if (retval)
        err("%s - usb_submit_urb failed with result: %d",
            __func__, retval);
static int usbtouch_open(struct input_dev *input)
    struct usbtouch_usb *usbtouch = input_get_drvdata(input);
    int r;
    usbtouch->irq->dev = interface_to_usbdev(usbtouch->interface);
    r = usb_autopm_get_interface(usbtouch->interface) ? -EIO : 0;
    if (r < 0)
        goto out;
    if (!usbtouch->type->irq_always) {
        if (usb_submit_urb(usbtouch->irq, GFP_KERNEL)) {
            r = -EIO;
            goto out_put;
    usbtouch->interface->needs_remote_wakeup = 1;
out_put:
    usb_autopm_put_interface(usbtouch->interface);
out:
    return r;
static void usbtouch_close(struct input_dev *input)
    int r;
        usb_kill_urb(usbtouch->irq);
    r = usb_autopm_get_interface(usbtouch->interface);
    usbtouch->interface->needs_remote_wakeup = 0;
    if (!r)
static int usbtouch_suspend
(struct usb_interface *intf, pm_message_t message)
    struct usbtouch_usb *usbtouch = usb_get_intfdata(intf);
    return 0;
static int usbtouch_resume(struct usb_interface *intf)
    struct input_dev *input = usbtouch->input;
    int result = 0;
    mutex_lock(&input->mutex);
    if (input->users || usbtouch->type->irq_always)
        result = usb_submit_urb(usbtouch->irq, GFP_NOIO);
    mutex_unlock(&input->mutex);
    return result;
static int usbtouch_reset_resume(struct usb_interface *intf)
    int err = 0;
    /* reinit the device */
    if (usbtouch->type->init) {
        err = usbtouch->type->init(usbtouch);
        if (err) {
            dbg("%s - type->init() failed, err: %d",
                __func__, err);
            return err;
    /* restart IO if needed */
    if (input->users)
        err = usb_submit_urb(usbtouch->irq, GFP_NOIO);
    return err;
static void usbtouch_free_buffers(struct usb_device *udev,
    usb_free_coherent(udev, usbtouch->type->rept_size,
              usbtouch->data, usbtouch->data_dma);
    kfree(usbtouch->buffer);
static struct usb_endpoint_descriptor *
usbtouch_get_input_endpoint(struct usb_host_interface *interface)
    int i;
        if (usb_endpoint_dir_in(&interface->endpoint.desc))
            return &interface->endpoint.desc;
    return NULL;
static int usbtouch_probe(struct usb_interface *intf,
              const struct usb_device_id *id)
    struct usbtouch_usb *usbtouch;
    struct input_dev *input_dev;
    struct usb_endpoint_descriptor *endpoint;
    struct usb_device *udev = interface_to_usbdev(intf);
    int err = -ENOMEM;
    /* some devices are ignored */
    if (id->driver_info == DEVTYPE_IGNORE)
        return -ENODEV;
    endpoint = usbtouch_get_input_endpoint(intf->cur_altsetting);
    if (!endpoint)
        return -ENXIO;
    usbtouch = kzalloc(sizeof(struct usbtouch_usb), GFP_KERNEL);
    input_dev = input_allocate_device();
    if (!usbtouch || !input_dev)
        goto out_free;
    type = &usbtouch_dev_info[id->driver_info];
    usbtouch->type = type;
    if (!type->process_pkt)
        type->process_pkt = usbtouch_process_pkt;
    usbtouch->data = usb_alloc_coherent(udev, type->rept_size,
                        GFP_KERNEL, &usbtouch->data_dma);
    if (!usbtouch->data)
        goto out_free;
    if (type->get_pkt_len) {
        usbtouch->buffer = kmalloc(type->rept_size, GFP_KERNEL);
        if (!usbtouch->buffer)
            goto out_free_buffers;
    usbtouch->irq = usb_alloc_urb(0, GFP_KERNEL);
    if (!usbtouch->irq) {
        dbg("%s - usb_alloc_urb failed: usbtouch->irq", __func__);
    usbtouch->interface = intf;
    usbtouch->input = input_dev;
    if (udev->manufacturer)
        strlcpy(usbtouch->name, udev->manufacturer, sizeof(usbtouch->name));
    if (udev->product) {
            strlcat(usbtouch->name, " ", sizeof(usbtouch->name));
        strlcat(usbtouch->name, udev->product, sizeof(usbtouch->name));
    if (!strlen(usbtouch->name))
        snprintf(usbtouch->name, sizeof(usbtouch->name),
            "USB Touchscreen %04x:%04x",
             le16_to_cpu(udev->descriptor.idVendor),
             le16_to_cpu(udev->descriptor.idProduct));
    usb_make_path(udev, usbtouch->phys, sizeof(usbtouch->phys));
    strlcat(usbtouch->phys, "/input0", sizeof(usbtouch->phys));
    input_dev->name = usbtouch->name;
    input_dev->phys = usbtouch->phys;
    usb_to_input_id(udev, &input_dev->id);
    input_dev->dev.parent = &intf->dev;
    input_set_drvdata(input_dev, usbtouch);
    input_dev->open = usbtouch_open;
    input_dev->close = usbtouch_close;
    input_dev->evbit[0] = BIT_MASK(EV_KEY) | BIT_MASK(EV_ABS);
    input_dev->keybit[BIT_WORD(BTN_TOUCH)] = BIT_MASK(BTN_TOUCH);
    input_set_abs_params(input_dev, ABS_X, type->min_xc, type->max_xc, 0, 0);
    input_set_abs_params(input_dev, ABS_Y, type->min_yc, type->max_yc, 0, 0);
        input_set_abs_params(input_dev, ABS_PRESSURE, type->min_press,
                             type->max_press, 0, 0);
    if (usb_endpoint_type(endpoint) == USB_ENDPOINT_XFER_INT)
        usb_fill_int_urb(usbtouch->irq, udev,
             usb_rcvintpipe(udev, endpoint->bEndpointAddress),
             usbtouch->data, type->rept_size,
             usbtouch_irq, usbtouch, endpoint->bInterval);
    else
        usb_fill_bulk_urb(usbtouch->irq, udev,
             usb_rcvbulkpipe(udev, endpoint->bEndpointAddress),
             usbtouch_irq, usbtouch);
    usbtouch->irq->dev = udev;
    usbtouch->irq->transfer_dma = usbtouch->data_dma;
    usbtouch->irq->transfer_flags |= URB_NO_TRANSFER_DMA_MAP;
    /* device specific allocations */
    if (type->alloc) {
        err = type->alloc(usbtouch);
        if (err) {
            dbg("%s - type->alloc() failed, err: %d", __func__, err);
            goto out_free_urb;
    /* device specific initialisation*/
    if (type->init) {
        err = type->init(usbtouch);
        if (err) {
            dbg("%s - type->init() failed, err: %d", __func__, err);
            goto out_do_exit;
    err = input_register_device(usbtouch->input);
    if (err) {
        dbg("%s - input_register_device failed, err: %d", __func__, err);
        goto out_do_exit;
    usb_set_intfdata(intf, usbtouch);
    if (usbtouch->type->irq_always) {
        /* this can't fail */
        usb_autopm_get_interface(intf);
        err = usb_submit_urb(usbtouch->irq, GFP_KERNEL);
        if (err) {
            usb_autopm_put_interface(intf);
                __func__, err);
            goto out_unregister_input;
    return 0;
out_unregister_input:
    input_unregister_device(input_dev);
    input_dev = NULL;
out_do_exit:
    if (type->exit)
        type->exit(usbtouch);
out_free_urb:
    usb_free_urb(usbtouch->irq);
out_free_buffers:
    usbtouch_free_buffers(udev, usbtouch);
out_free:
    input_free_device(input_dev);
    kfree(usbtouch);
    return err;
static void usbtouch_disconnect(struct usb_interface *intf)
    dbg("%s - called", __func__);
    if (!usbtouch)
        return;
    dbg("%s - usbtouch is initialized, cleaning up", __func__);
    usb_set_intfdata(intf, NULL);
    /* this will stop IO via close */
    input_unregister_device(usbtouch->input);
    if (usbtouch->type->exit)
        usbtouch->type->exit(usbtouch);
    usbtouch_free_buffers(interface_to_usbdev(intf), usbtouch);
    kfree(usbtouch);
MODULE_DEVICE_TABLE(usb, usbtouch_devices);
static struct usb_driver usbtouch_driver = {
    .name        = "usbtouchscreen",
    .probe        = usbtouch_probe,
    .disconnect    = usbtouch_disconnect,
    .suspend    = usbtouch_suspend,
    .resume        = usbtouch_resume,
    .reset_resume    = usbtouch_reset_resume,
    .id_table    = usbtouch_devices,
    .supports_autosuspend = 1,
static int __init usbtouch_init(void)
    return usb_register(&usbtouch_driver);
static void __exit usbtouch_cleanup(void)
    usb_deregister(&usbtouch_driver);
module_init(usbtouch_init);
module_exit(usbtouch_cleanup);
MODULE_AUTHOR(DRIVER_AUTHOR);
MODULE_DESCRIPTION(DRIVER_DESC);
MODULE_LICENSE("GPL");
MODULE_ALIAS("touchkitusb");
MODULE_ALIAS("itmtouch");
MODULE_ALIAS("mtouchusb");
