查看: 1110|回复: 0
RK3288  USB  host 源码
社区居民社区明星忠实会员宣传大使奖终身成就奖特殊贡献奖
发表于 2015-7-8 09:00:48 | 显示全部楼层 |阅读模式
* Copyright (C) 2001-2004 by David Brownell
* This program is free software; you can redistribute it and/or modify it
* under the terms of the GNU General Public License as published by the
* Free Software Foundation; either version 2 of the License, or (at your
* option) any later version.
* This program is distributed in the hope that it will be useful, but
* WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY
* or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
* for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software Foundation,
* Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
/* this file is part of ehci-hcd.c */
* EHCI Root Hub ... the nonsharable stuff
* Registers don't need cpu_to_le32, that happens transparently
#include <linux/usb/otg.h>
#define    PORT_WAKE_BITS    (PORT_WKOC_E|PORT_WKDISC_E|PORT_WKCONN_E)
#ifdef    CONFIG_PM
static int ehci_hub_control(
    struct usb_hcd    *hcd,
    u16        typeReq,
    u16        wValue,
    u16        wIndex,
    char        *buf,
    u16        wLength
/* After a power loss, ports that were owned by the companion must be
* reset so that the companion can still own them.
static void ehci_handover_companion_ports(struct ehci_hcd *ehci)
    u32 __iomem    *reg;
    u32        status;
    int        port;
    __le32        buf;
    struct usb_hcd    *hcd = ehci_to_hcd(ehci);
    if (!ehci->owned_ports)
        return;
    /* Give the connections some time to appear */
    msleep(20);
    port = HCS_N_PORTS(ehci->hcs_params);
    while (port--) {
        if (test_bit(port, &ehci->owned_ports)) {
            reg = &ehci->regs->port_status[port];
            status = ehci_readl(ehci, reg) & ~PORT_RWC_BITS;
            /* Port already owned by companion? */
            if (status & PORT_OWNER)
                clear_bit(port, &ehci->owned_ports);
            else if (test_bit(port, &ehci->companion_ports))
                ehci_writel(ehci, status & ~PORT_PE, reg);
            else
                ehci_hub_control(hcd, SetPortFeature,
                        USB_PORT_FEAT_RESET, port + 1,
                        NULL, 0);
        return;
    msleep(90);        /* Wait for resets to complete */
    while (port--) {
            ehci_hub_control(hcd, GetPortStatus,
                    0, port + 1,
                    (char *) &buf, sizeof(buf));
            /* The companion should now own the port,
             * but if something went wrong the port must not
             * remain enabled.
                ehci_writel(ehci, status | PORT_CSC, reg);
            else {
                ehci_dbg(ehci, "failed handover port %d: %x\n",
                        port + 1, status);
    ehci->owned_ports = 0;
static int ehci_port_change(struct ehci_hcd *ehci)
    int i = HCS_N_PORTS(ehci->hcs_params);
    /* First check if the controller indicates a change event */
    if (ehci_readl(ehci, &ehci->regs->status) & STS_PCD)
        return 1;
     * Not all controllers appear to update this while going from D3 to D0,
     * so check the individual port status registers as well
    while (i--)
        if (ehci_readl(ehci, &ehci->regs->port_status) & PORT_CSC)
            return 1;
    return 0;
static __maybe_unused void ehci_adjust_port_wakeup_flags(struct ehci_hcd *ehci,
        bool suspending, bool do_wakeup)
    int        port;
    u32        temp;
    unsigned long    flags;
    /* If remote wakeup is enabled for the root hub but disabled
     * for the controller, we must adjust all the port wakeup flags
     * when the controller is suspended or resumed.  In all other
     * cases they don't need to be changed.
    if (!ehci_to_hcd(ehci)->self.root_hub->do_remote_wakeup || do_wakeup)
        return;
    spin_lock_irqsave(&ehci->lock, flags);
    /* clear phy low-power mode before changing wakeup flags */
    if (ehci->has_hostpc) {
        while (port--) {
            u32 __iomem    *hostpc_reg;
            hostpc_reg = (u32 __iomem *)((u8 *) ehci->regs
                    + HOSTPC0 + 4 * port);
            temp = ehci_readl(ehci, hostpc_reg);
            ehci_writel(ehci, temp & ~HOSTPC_PHCD, hostpc_reg);
        spin_unlock_irqrestore(&ehci->lock, flags);
        msleep(5);
    while (port--) {
        u32 __iomem    *reg = &ehci->regs->port_status[port];
        u32        t1 = ehci_readl(ehci, reg) & ~PORT_RWC_BITS;
        u32        t2 = t1 & ~PORT_WAKE_BITS;
        /* If we are suspending the controller, clear the flags.
         * If we are resuming the controller, set the wakeup flags.
        if (!suspending) {
            if (t1 & PORT_CONNECT)
                t2 |= PORT_WKOC_E | PORT_WKDISC_E;
            else
                t2 |= PORT_WKOC_E | PORT_WKCONN_E;
        ehci_vdbg(ehci, "port %d, %08x -> %08x\n",
                port + 1, t1, t2);
        ehci_writel(ehci, t2, reg);
    /* enter phy low-power mode again */
        while (port--) {
            ehci_writel(ehci, temp | HOSTPC_PHCD, hostpc_reg);
    /* Does the root hub have a port wakeup pending? */
    if (!suspending && ehci_port_change(ehci))
        usb_hcd_resume_root_hub(ehci_to_hcd(ehci));
static int ehci_bus_suspend (struct usb_hcd *hcd)
    struct ehci_hcd        *ehci = hcd_to_ehci (hcd);
    int            port;
    int            mask;
    int            changed;
    ehci_dbg(ehci, "suspend root hub\n");
    if (time_before (jiffies, ehci->next_statechange))
        msleep(5);
    del_timer_sync(&ehci->watchdog);
    del_timer_sync(&ehci->iaa_watchdog);
    spin_lock_irq (&ehci->lock);
    /* Once the controller is stopped, port resumes that are already
     * in progress won't complete.  Hence if remote wakeup is enabled
     * for the root hub and any ports are in the middle of a resume or
     * remote wakeup, we must fail the suspend.
    if (hcd->self.root_hub->do_remote_wakeup) {
        while (port--) {
            if (ehci->reset_done[port] != 0) {
                spin_unlock_irq(&ehci->lock);
                ehci_dbg(ehci, "suspend failed because "
                        "port %d is resuming\n",
                        port + 1);
                return -EBUSY;
    /* stop schedules, clean any completed work */
    if (HC_IS_RUNNING(hcd->state)) {
        ehci_quiesce (ehci);
        hcd->state = HC_STATE_QUIESCING;
    ehci->command = ehci_readl(ehci, &ehci->regs->command);
    ehci_work(ehci);
    /* Unlike other USB host controller types, EHCI doesn't have
     * any notion of "global" or bus-wide suspend.  The driver has
     * to manually suspend all the active unsuspended ports, and
     * then manually resume them in the bus_resume() routine.
    ehci->bus_suspended = 0;
    changed = 0;
    while (port--) {
        u32 __iomem    *reg = &ehci->regs->port_status [port];
        /* keep track of which ports we suspend */
        if (t1 & PORT_OWNER)
            set_bit(port, &ehci->owned_ports);
        else if ((t1 & PORT_PE) && !(t1 & PORT_SUSPEND)) {
            t2 |= PORT_SUSPEND;
            set_bit(port, &ehci->bus_suspended);
        /* enable remote wakeup on all ports, if told to do so */
            /* only enable appropriate wake bits, otherwise the
             * hardware can not go phy low power mode. If a race
             * condition happens here(connection change during bits
             * set), the port change detection will finally fix it.
            else
        if (t1 != t2) {
            ehci_vdbg (ehci, "port %d, %08x -> %08x\n",
                port + 1, t1, t2);
            changed = 1;
    if (changed && ehci->has_hostpc) {
        msleep(5);    /* 5 ms for HCD to enter low-power mode */
        spin_lock_irq(&ehci->lock);
        while (port--) {
            u32        t3;
            t3 = ehci_readl(ehci, hostpc_reg);
            ehci_writel(ehci, t3 | HOSTPC_PHCD, hostpc_reg);
            ehci_dbg(ehci, &quotort %d phy low-power mode %s\n",
                    port, (t3 & HOSTPC_PHCD) ?
                    "succeeded" : "failed");
    /* Apparently some devices need a >= 1-uframe delay here */
    if (ehci->bus_suspended)
        udelay(150);
    /* turn off now-idle HC */
    ehci_halt (ehci);
    hcd->state = HC_STATE_SUSPENDED;
    if (ehci->reclaim)
        end_unlink_async(ehci);
    /* allow remote wakeup */
    mask = INTR_MASK;
    if (!hcd->self.root_hub->do_remote_wakeup)
        mask &= ~STS_PCD;
    ehci_writel(ehci, mask, &ehci->regs->intr_enable);
    ehci_readl(ehci, &ehci->regs->intr_enable);
    ehci->next_statechange = jiffies + msecs_to_jiffies(10);
    spin_unlock_irq (&ehci->lock);
    /* ehci_work() may have re-enabled the watchdog timer, which we do not
     * want, and so we must delete any pending watchdog timer events.
    return 0;
/* caller has locked the root hub, and should reset/reinit on error */
static int ehci_bus_resume (struct usb_hcd *hcd)
    u32            temp;
    u32            power_okay;
    int            i;
    unsigned long        resume_needed = 0;
        msleep(5);
    if (!HCD_HW_ACCESSIBLE(hcd)) {
        return -ESHUTDOWN;
    if (unlikely(ehci->debug)) {
        if (!dbgp_reset_prep())
            ehci->debug = NULL;
        else
            dbgp_external_startup();
    /* Ideally and we've got a real resume here, and no port's power
     * was lost.  (For PCI, that means Vaux was maintained.)  But we
     * could instead be restoring a swsusp snapshot -- so that BIOS was
     * the last user of the controller, not reset/pm hardware keeping
     * state we gave to it.
    power_okay = ehci_readl(ehci, &ehci->regs->intr_enable);
    ehci_dbg(ehci, "resume root hub%s\n",
            power_okay ? "" : " after power loss");
    /* at least some APM implementations will try to deliver
     * IRQs right away, so delay them until we're ready.
    ehci_writel(ehci, 0, &ehci->regs->intr_enable);
    /* re-init operational registers */
    ehci_writel(ehci, 0, &ehci->regs->segment);
    ehci_writel(ehci, ehci->periodic_dma, &ehci->regs->frame_list);
    ehci_writel(ehci, (u32) ehci->async->qh_dma, &ehci->regs->async_next);
    /* restore CMD_RUN, framelist size, and irq threshold */
    ehci_writel(ehci, ehci->command, &ehci->regs->command);
    /* Some controller/firmware combinations need a delay during which
     * they set up the port statuses.  See Bugzilla #8190. */
    msleep(8);
    /* clear phy low-power mode before resume */
    if (ehci->bus_suspended && ehci->has_hostpc) {
        while (i--) {
            if (test_bit(i, &ehci->bus_suspended)) {
                        + HOSTPC0 + 4 * i);
                        hostpc_reg);
        msleep(5);
    /* manually resume the ports we suspended during bus_suspend() */
    i = HCS_N_PORTS (ehci->hcs_params);
    while (i--) {
        temp = ehci_readl(ehci, &ehci->regs->port_status );
        temp &= ~(PORT_RWC_BITS | PORT_WAKE_BITS);
        if (test_bit(i, &ehci->bus_suspended) &&
                (temp & PORT_SUSPEND)) {
            temp |= PORT_RESUME;
            set_bit(i, &resume_needed);
        ehci_writel(ehci, temp, &ehci->regs->port_status );
    /* msleep for 20ms only if code is trying to resume port */
    if (resume_needed) {
        msleep(20);
    while (i--) {
        if (test_bit(i, &resume_needed)) {
            temp &= ~(PORT_RWC_BITS | PORT_RESUME);
            ehci_vdbg (ehci, "resumed port %d\n", i + 1);
    (void) ehci_readl(ehci, &ehci->regs->command);
    /* maybe re-activate the schedule(s) */
    temp = 0;
    if (ehci->async->qh_next.qh)
        temp |= CMD_ASE;
    if (ehci->periodic_sched)
        temp |= CMD_PSE;
    if (temp) {
        ehci->command |= temp;
    ehci->next_statechange = jiffies + msecs_to_jiffies(5);
    hcd->state = HC_STATE_RUNNING;
    /* Now we can safely re-enable irqs */
    ehci_writel(ehci, INTR_MASK, &ehci->regs->intr_enable);
    ehci_handover_companion_ports(ehci);
    return 0;
#else
#define ehci_bus_suspend    NULL
#define ehci_bus_resume        NULL
#endif    /* CONFIG_PM */
/* Display the ports dedicated to the companion controller */
static ssize_t show_companion(struct device *dev,
                  struct device_attribute *attr,
                  char *buf)
    struct ehci_hcd        *ehci;
    int            nports, index, n;
    int            count = PAGE_SIZE;
    char            *ptr = buf;
    ehci = hcd_to_ehci(bus_to_hcd(dev_get_drvdata(dev)));
    nports = HCS_N_PORTS(ehci->hcs_params);
    for (index = 0; index < nports; ++index) {
        if (test_bit(index, &ehci->companion_ports)) {
            n = scnprintf(ptr, count, "%d\n", index + 1);
            ptr += n;
            count -= n;
    return ptr - buf;
* Sets the owner of a port
static void set_owner(struct ehci_hcd *ehci, int portnum, int new_owner)
    u32 __iomem        *status_reg;
    u32            port_status;
    int             try;
    status_reg = &ehci->regs->port_status[portnum];
     * The controller won't set the OWNER bit if the port is
     * enabled, so this loop will sometimes require at least two
     * iterations: one to disable the port and one to set OWNER.
    for (try = 4; try > 0; --try) {
        port_status = ehci_readl(ehci, status_reg);
        if ((port_status & PORT_OWNER) == new_owner
                || (port_status & (PORT_OWNER | PORT_CONNECT))
                    == 0)
            try = 0;
        else {
            port_status ^= PORT_OWNER;
            port_status &= ~(PORT_PE | PORT_RWC_BITS);
            ehci_writel(ehci, port_status, status_reg);
        if (try > 1)
            msleep(5);
* Dedicate or undedicate a port to the companion controller.
* Syntax is "[-]portnum", where a leading '-' sign means
* return control of the port to the EHCI controller.
static ssize_t store_companion(struct device *dev,
                   const char *buf, size_t count)
    int            portnum, new_owner;
    new_owner = PORT_OWNER;        /* Owned by companion */
    if (sscanf(buf, "%d", &portnum) != 1)
        return -EINVAL;
    if (portnum < 0) {
        portnum = - portnum;
        new_owner = 0;        /* Owned by EHCI */
    if (portnum <= 0 || portnum > HCS_N_PORTS(ehci->hcs_params))
        return -ENOENT;
    portnum--;
    if (new_owner)
        set_bit(portnum, &ehci->companion_ports);
    else
        clear_bit(portnum, &ehci->companion_ports);
    set_owner(ehci, portnum, new_owner);
    return count;
static DEVICE_ATTR(companion, 0644, show_companion, store_companion);
static inline int create_companion_file(struct ehci_hcd *ehci)
    int    i = 0;
    /* with integrated TT there is no companion! */
    if (!ehci_is_TDI(ehci))
        i = device_create_file(ehci_to_hcd(ehci)->self.controller,
                       &dev_attr_companion);
    return i;
static inline void remove_companion_file(struct ehci_hcd *ehci)
        device_remove_file(ehci_to_hcd(ehci)->self.controller,
static int check_reset_complete (
    int        index,
    u32 __iomem    *status_reg,
    int        port_status
    if (!(port_status & PORT_CONNECT))
        return port_status;
    /* if reset finished and it's still not enabled -- handoff */
    if (!(port_status & PORT_PE)) {
        /* with integrated TT, there's nobody to hand it to! */
        if (ehci_is_TDI(ehci)) {
            ehci_dbg (ehci,
                "Failed to enable port %d on root hub TT\n",
                index+1);
            return port_status;
        ehci_dbg (ehci, "port %d full speed --> companion\n",
            index + 1);
        // what happens if HCS_N_CC(params) == 0 ?
        port_status |= PORT_OWNER;
        port_status &= ~PORT_RWC_BITS;
        /* ensure 440EPX ohci controller state is operational */
        if (ehci->has_amcc_usb23)
            set_ohci_hcfs(ehci, 1);
    } else {
        ehci_dbg (ehci, "port %d high speed\n", index + 1);
        /* ensure 440EPx ohci controller state is suspended */
            set_ohci_hcfs(ehci, 0);
    return port_status;
/* build "status change" packet (one or two bytes) from HC registers */
static int
ehci_hub_status_data (struct usb_hcd *hcd, char *buf)
    u32        temp, status = 0;
    u32        mask;
    int        ports, i, retval = 1;
    u32        ppcd = 0;
    /* if !USB_SUSPEND, root hub timers won't get shut down ... */
    if (!HC_IS_RUNNING(hcd->state))
        return 0;
    /* init status to no-changes */
    buf [0] = 0;
    ports = HCS_N_PORTS (ehci->hcs_params);
    if (ports > 7) {
        buf [1] = 0;
        retval++;
    /* Some boards (mostly VIA?) report bogus overcurrent indications,
     * causing massive log spam unless we completely ignore them.  It
     * may be relevant that VIA VT8235 controllers, where PORT_POWER is
     * always set, seem to clear PORT_OCC and PORT_CSC when writing to
     * PORT_POWER; that's surprising, but maybe within-spec.
    if (!ignore_oc)
        mask = PORT_CSC | PORT_PEC | PORT_OCC;
    else
        mask = PORT_CSC | PORT_PEC;
    // PORT_RESUME from hardware ~= PORT_STAT_C_SUSPEND
    /* no hub change reports (bit 0) for now (power, ...) */
    /* port N changes (bit N)? */
    spin_lock_irqsave (&ehci->lock, flags);
    /* get per-port change detect bits */
    if (ehci->has_ppcd)
        ppcd = ehci_readl(ehci, &ehci->regs->status) >> 16;
    for (i = 0; i < ports; i++) {
        /* leverage per-port change bits feature */
        if (ehci->has_ppcd && !(ppcd & (1 << i)))
            continue;
         * Return status information even for ports with OWNER set.
         * Otherwise khubd wouldn't see the disconnect event when a
         * high-speed device is switched over to the companion
         * controller by the user.
        if ((temp & mask) != 0 || test_bit(i, &ehci->port_c_suspend)
                || (ehci->reset_done && time_after_eq(
                    jiffies, ehci->reset_done))) {
            if (i < 7)
                buf [0] |= 1 << (i + 1);
            else
                buf [1] |= 1 << (i - 7);
            status = STS_PCD;
    /* FIXME autosuspend idle root hubs */
    spin_unlock_irqrestore (&ehci->lock, flags);
    return status ? retval : 0;
static void
ehci_hub_descriptor (
    struct usb_hub_descriptor    *desc
    int        ports = HCS_N_PORTS (ehci->hcs_params);
    u16        temp;
    desc->bDescriptorType = 0x29;
    desc->bPwrOn2PwrGood = 10;    /* ehci 1.0, 2.3.9 says 20ms max */
    desc->bHubContrCurrent = 0;
    desc->bNbrPorts = ports;
    temp = 1 + (ports / 8);
    desc->bDescLength = 7 + 2 * temp;
    /* two bitmaps:  ports removable, and usb 1.0 legacy PortPwrCtrlMask */
    memset(&desc->u.hs.DeviceRemovable[0], 0, temp);
    memset(&desc->u.hs.DeviceRemovable[temp], 0xff, temp);
    temp = 0x0008;            /* per-port overcurrent reporting */
    if (HCS_PPC (ehci->hcs_params))
        temp |= 0x0001;        /* per-port power control */
    else
        temp |= 0x0002;        /* no power switching */
#if 0
// re-enable when we support USB_PORT_FEAT_INDICATOR below.
    if (HCS_INDICATOR (ehci->hcs_params))
        temp |= 0x0080;        /* per-port indicators (LEDs) */
#endif
    desc->wHubCharacteristics = cpu_to_le16(temp);
static int ehci_hub_control (
    u16        typeReq,
    u16        wValue,
    u16        wIndex,
    char        *buf,
    u16        wLength
    u32 __iomem    *status_reg = &ehci->regs->port_status[
                (wIndex & 0xff) - 1];
    u32 __iomem    *hostpc_reg = NULL;
    u32        temp, temp1, status;
    int        retval = 0;
    unsigned    selector;
     * FIXME:  support SetPortFeatures USB_PORT_FEAT_INDICATOR.
     * HCS_INDICATOR may say we can change LEDs to off/amber/green.
     * (track current state ourselves) ... blink for diagnostics,
     * power, "this is the one", etc.  EHCI spec supports this.
        hostpc_reg = (u32 __iomem *)((u8 *)ehci->regs
                + HOSTPC0 + 4 * ((wIndex & 0xff) - 1));
    switch (typeReq) {
    case ClearHubFeature:
        switch (wValue) {
        case C_HUB_LOCAL_POWER:
        case C_HUB_OVER_CURRENT:
            /* no hub-wide feature/status flags */
            break;
        default:
            goto error;
        break;
    case ClearPortFeature:
        if (!wIndex || wIndex > ports)
            goto error;
        wIndex--;
        temp = ehci_readl(ehci, status_reg);
         * Even if OWNER is set, so the port is owned by the
         * companion controller, khubd needs to be able to clear
         * the port-change status bits (especially
         * USB_PORT_STAT_C_CONNECTION).
        switch (wValue) {
        case USB_PORT_FEAT_ENABLE:
            ehci_writel(ehci, temp & ~PORT_PE, status_reg);
            break;
        case USB_PORT_FEAT_C_ENABLE:
            ehci_writel(ehci, (temp & ~PORT_RWC_BITS) | PORT_PEC,
                    status_reg);
            break;
        case USB_PORT_FEAT_SUSPEND:
            if (temp & PORT_RESET)
                goto error;
            if (ehci->no_selective_suspend)
                break;
#ifdef CONFIG_USB_OTG
            if ((hcd->self.otg_port == (wIndex + 1))
                && hcd->self.b_hnp_enable) {
                otg_start_hnp(ehci->transceiver);
                break;
#endif
            if (!(temp & PORT_SUSPEND))
                break;
            if ((temp & PORT_PE) == 0)
                goto error;
            if (hostpc_reg) {
                temp1 = ehci_readl(ehci, hostpc_reg);
                ehci_writel(ehci, temp1 & ~HOSTPC_PHCD,
                        hostpc_reg);
                msleep(5);/* wait to leave low-power mode */
            /* resume signaling for 20 msec */
            ehci_writel(ehci, temp | PORT_RESUME, status_reg);
            ehci->reset_done[wIndex] = jiffies
                    + msecs_to_jiffies(20);
            break;
        case USB_PORT_FEAT_C_SUSPEND:
            clear_bit(wIndex, &ehci->port_c_suspend);
            break;
        case USB_PORT_FEAT_POWER:
                ehci_writel(ehci,
                      temp & ~(PORT_RWC_BITS | PORT_POWER),
                      status_reg);
            break;
        case USB_PORT_FEAT_C_CONNECTION:
            if (ehci->has_lpm) {
                /* clear PORTSC bits on disconnect */
                temp &= ~PORT_LPM;
                temp &= ~PORT_DEV_ADDR;
            ehci_writel(ehci, (temp & ~PORT_RWC_BITS) | PORT_CSC,
                    status_reg);
            break;
        case USB_PORT_FEAT_C_OVER_CURRENT:
            ehci_writel(ehci, (temp & ~PORT_RWC_BITS) | PORT_OCC,
                    status_reg);
            break;
        case USB_PORT_FEAT_C_RESET:
            /* GetPortStatus clears reset */
            break;
        default:
            goto error;
        ehci_readl(ehci, &ehci->regs->command);    /* unblock posted write */
        break;
    case GetHubDescriptor:
        ehci_hub_descriptor (ehci, (struct usb_hub_descriptor *)
            buf);
        break;
    case GetHubStatus:
        memset (buf, 0, 4);
        //cpu_to_le32s ((u32 *) buf);
        break;
    case GetPortStatus:
            goto error;
        wIndex--;
        status = 0;
        // wPortChange bits
        if (temp & PORT_CSC)
            status |= USB_PORT_STAT_C_CONNECTION << 16;
        if (temp & PORT_PEC)
            status |= USB_PORT_STAT_C_ENABLE << 16;
        if ((temp & PORT_OCC) && !ignore_oc){
            status |= USB_PORT_STAT_C_OVERCURRENT << 16;
             * Hubs should disable port power on over-current.
             * However, not all EHCI implementations do this
             * automatically, even if they _do_ support per-port
             * power switching; they're allowed to just limit the
             * current.  khubd will turn the power back on.
            if ((temp & PORT_OC) && HCS_PPC(ehci->hcs_params)) {
                ehci_writel(ehci,
                    status_reg);
        /* whoever resumes must GetPortStatus to complete it!! */
        if (temp & PORT_RESUME) {
            /* Remote Wakeup received? */
            if (!ehci->reset_done[wIndex]) {
                /* check the port again */
                mod_timer(&ehci_to_hcd(ehci)->rh_timer,
                        ehci->reset_done[wIndex]);
            /* resume completed? */
            else if (time_after_eq(jiffies,
                    ehci->reset_done[wIndex])) {
                clear_bit(wIndex, &ehci->suspended_ports);
                set_bit(wIndex, &ehci->port_c_suspend);
                ehci->reset_done[wIndex] = 0;
                /* stop resume signaling */
                ehci_writel(ehci,
                    temp & ~(PORT_RWC_BITS | PORT_RESUME),
                    status_reg);
                retval = handshake(ehci, status_reg,
                       PORT_RESUME, 0, 2000 /* 2msec */);
                if (retval != 0) {
                    ehci_err(ehci,
                        "port %d resume error %d\n",
                        wIndex + 1, retval);
                    goto error;
                temp &= ~(PORT_SUSPEND|PORT_RESUME|(3<<10));
        /* whoever resets must GetPortStatus to complete it!! */
        if ((temp & PORT_RESET)
                && time_after_eq(jiffies,
            status |= USB_PORT_STAT_C_RESET << 16;
            ehci->reset_done [wIndex] = 0;
            /* force reset to complete */
            ehci_writel(ehci, temp & ~(PORT_RWC_BITS | PORT_RESET),
                    status_reg);
            /* REVISIT:  some hardware needs 550+ usec to clear
             * this bit; seems too long to spin routinely...
                    PORT_RESET, 0, 1000);
            if (retval != 0) {
                ehci_err (ehci, "port %d reset error %d\n",
                goto error;
            /* see what we found out */
            temp = check_reset_complete (ehci, wIndex, status_reg,
                    ehci_readl(ehci, status_reg));
        if (!(temp & (PORT_RESUME|PORT_RESET)))
        /* transfer dedicated ports to the companion hc */
        if ((temp & PORT_CONNECT) &&
                test_bit(wIndex, &ehci->companion_ports)) {
            temp &= ~PORT_RWC_BITS;
            temp |= PORT_OWNER;
            ehci_writel(ehci, temp, status_reg);
            ehci_dbg(ehci, "port %d --> companion\n", wIndex + 1);
         * Even if OWNER is set, there's no harm letting khubd
         * see the wPortStatus values (they should all be 0 except
         * for PORT_POWER anyway).
        if (temp & PORT_CONNECT) {
            status |= USB_PORT_STAT_CONNECTION;
            // status may be from integrated TT
                status |= ehci_port_speed(ehci, temp1);
            } else
                status |= ehci_port_speed(ehci, temp);
        if (temp & PORT_PE)
            status |= USB_PORT_STAT_ENABLE;
        /* maybe the port was unsuspended without our knowledge */
        if (temp & (PORT_SUSPEND|PORT_RESUME)) {
            status |= USB_PORT_STAT_SUSPEND;
        } else if (test_bit(wIndex, &ehci->suspended_ports)) {
            if (temp & PORT_PE)
        if (temp & PORT_OC)
            status |= USB_PORT_STAT_OVERCURRENT;
            status |= USB_PORT_STAT_RESET;
        if (temp & PORT_POWER)
            status |= USB_PORT_STAT_POWER;
        if (test_bit(wIndex, &ehci->port_c_suspend))
            status |= USB_PORT_STAT_C_SUSPEND << 16;
#ifndef    VERBOSE_DEBUG
    if (status & ~0xffff)    /* only if wPortChange is interesting */
#endif
        dbg_port (ehci, "GetStatus", wIndex + 1, temp);
        put_unaligned_le32(status, buf);
        break;
    case SetHubFeature:
        switch (wValue) {
            break;
        default:
            goto error;
        break;
    case SetPortFeature:
        selector = wIndex >> 8;
        wIndex &= 0xff;
            /* If the debug port is active any port
             * feature requests should get denied */
            if (wIndex == HCS_DEBUG_PORT(ehci->hcs_params) &&
                (readl(&ehci->debug->control) & DBGP_ENABLED)) {
                retval = -ENODEV;
                goto error_exit;
            goto error;
        wIndex--;
        if (temp & PORT_OWNER)
            break;
        switch (wValue) {
                break;
                    || (temp & PORT_RESET) != 0)
                goto error;
            /* After above check the port must be connected.
             * Set appropriate bit thus could put phy into low power
             * mode if we have hostpc feature
            temp &= ~PORT_WKCONN_E;
            temp |= PORT_WKDISC_E | PORT_WKOC_E;
            ehci_writel(ehci, temp | PORT_SUSPEND, status_reg);
            if (hostpc_reg) {
                msleep(5);/* 5ms for HCD enter low pwr mode */
                ehci_writel(ehci, temp1 | HOSTPC_PHCD,
                    hostpc_reg);
                ehci_dbg(ehci, &quotort%d phy low pwr mode %s\n",
                    wIndex, (temp1 & HOSTPC_PHCD) ?
            set_bit(wIndex, &ehci->suspended_ports);
            break;
                ehci_writel(ehci, temp | PORT_POWER,
                        status_reg);
            break;
        case USB_PORT_FEAT_RESET:
                goto error;
            /* line status bits may report this as low speed,
             * which can be fine if this root hub has a
             * transaction translator built in.
            if ((temp & (PORT_PE|PORT_CONNECT)) == PORT_CONNECT
                    && !ehci_is_TDI(ehci)
                    && PORT_USB11 (temp)) {
                ehci_dbg (ehci,
                    "port %d low speed --> companion\n",
                    wIndex + 1);
                temp |= PORT_OWNER;
            } else {
                ehci_vdbg (ehci, "port %d reset\n", wIndex + 1);
                temp |= PORT_RESET;
                temp &= ~PORT_PE;
                 * caller must wait, then call GetPortStatus
                 * usb 2.0 spec says 50 ms resets on root
                ehci->reset_done [wIndex] = jiffies
                        + msecs_to_jiffies (50);
            break;
        /* For downstream facing ports (these):  one hub port is put
         * into test mode according to USB2 11.24.2.13, then the hub
         * must be reset (which for root hub now means rmmod+modprobe,
         * or else system reboot).  See EHCI 2.3.9 and 4.14 for info
         * about the EHCI-specific stuff.
        case USB_PORT_FEAT_TEST:
            if (!selector || selector > 5)
                goto error;
            ehci_quiesce(ehci);
            /* Put all enabled ports into suspend */
            while (ports--) {
                u32 __iomem *sreg =
                        &ehci->regs->port_status[ports];
                temp = ehci_readl(ehci, sreg) & ~PORT_RWC_BITS;
                if (temp & PORT_PE)
                            sreg);
            ehci_halt(ehci);
            temp |= selector << 16;
            break;
        default:
            goto error;
        ehci_readl(ehci, &ehci->regs->command);    /* unblock posted writes */
        break;
    default:
error:
        /* "stall" on error */
        retval = -EPIPE;
error_exit:
    return retval;
static void ehci_relinquish_port(struct usb_hcd *hcd, int portnum)
    struct ehci_hcd        *ehci = hcd_to_ehci(hcd);
        return;
    set_owner(ehci, --portnum, PORT_OWNER);
static int ehci_port_handed_over(struct usb_hcd *hcd, int portnum)
    u32 __iomem        *reg;
        return 0;
    reg = &ehci->regs->port_status[portnum - 1];
    return ehci_readl(ehci, reg) & PORT_OWNER;
