RK3168 智能家具服务器主机 PCB文件共享下载
RK3168.7z
(938 KB, 下载次数: 51)
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | Part Type | PCB Decal | Value | ANT8 | CON2 | 2P1 | ANT1 | ANT9 | R1206 | R1206 | RF_ANT | ANT10 | R1206 | R1206 | RF_ANT | CON2 | CON_125_5P | CON_125_5P | | D3 | DIODE_3 | D1206 | 1N5819 | D4 | BAT54C | SOT23 | BAT54C | D7 | DIODE_ZENER13_0 | D1206 | 3.3V | D20 | DO-214AA | DO-214AA | SS32 | EC1 | CAP_B | E-B | 100uF/4V | ED40 | TVS | E0402N | ESD9B5VL | J1 | MINI_USB_MICRO | 701MICRO | USB_JACK | J2 | TF-CARD | TF-CARD | TF_SD_SOCKET | J3 | CON2 | 2P1 | SPK | J7 | TOUCH_SCREEN_2 | CON12P_0.5_BOTTOM | touch_screen | J8 | HDMI_C | HDMI-19PF_C | HDMI_C | J9 | OV2659 | FPC24-0.5 | OV2659 | J11 | PHONEJACK_STEREO_SW_0 | ST-0228S-061AA | PHONEJACK | J12 | CON5 | 757DC | DC_IN | J13 | MINI_USB_MICRO | 701MICRO | USB_JACK | J14 | UART-DEBUG | UART-DEBUG | UART-DEBUG | J15 | LP097X02_2 | FPC30-R-0.5 | TM097B36BA28_A01 | J18 | FPC30_DOWN_0.5 | FPC30-DOWN-0.5 | TM090B27BA41_A02 | J19 | FPC40PIN_05MM_A | FPC40PIN_05MM_A | CM101B36BA45 | J21 | R0603 | R0603 | CON2 | J25 | CON2 | 2P1 | SPK | J28 | BAT | BAT | BATTERY | M1 | MODULE/42P/5-IN-1 | MODULE/42P/5-IN-1 | J46620_15X15 | MIC1 | MIC1.3 | MIC1.3 | MIC D=4.5 带引脚 | RP14 | RESISTOR_4PACK | RES-ARRAY0402 | 33R | SW2 | IT_1204ASMD | IT_1204ASMD | RESET | SW6 | SW6P | SWITCH_A | POWER | T142 | TEST | HOLE | TEST | U1 | RK3188_0 | BGA453-19X19 | RK3168 | U2 | DS8008_6 | SOT25 | TCS6112 | U3 | RK610_BGA | BGA144 | RK610-G | U4 | LM4990 | MSOP8 | TT8642/NC | U5 | ESD4+1 | SLP2510P8 | NC/RClamp0524J/ESDA6V8UD | U6 | NANDFLASH_0 | TSOP1-48 | NAND_FLASH | U7 | TSOP1-48 | TSOP1-48 | NAND_FLASH | U8 | LP28300_11 | TDFN10-3X3 | TT8514 | U11 | LP28300_9 | PMUTPS6591001 | TPS659102 | U15 | DDRII_3 | FBGA96-9X14 | DDR3-512MB | U16 | LPW5206H | SOT25 | TT9107 | U17 | AT88SC0104C-1 | SOIC-8 | NC/BX88 | U19 | MMA7660FC_1 | MMA7660FC | MMA7660FC | U24 | G5121_1 | SOT26 | TCS9208 | U26 | LM4990 | MSOP8 | TT8642 | U27 | ESD4+1 | SLP2510P8 | NC/RClamp0524J/ESDA6V8UD | U28 | U_MP3202 | SOT26 | TD2514 | U31 | LM4990_0 | CW2013 | NC/CW2013 | U32 | FPC45 | FPC45_DOWN | CON45 | U42 | NANDFLASH8-LGA | VLGA60-13X18 | NANDFLASH-LGA | U44 | MXC6225XU | LCC6 | NC/MXC6225XU | U45 | FT5406EE | QFN68 | NC/FT5406EE8 | U78 | RLUM02BS_0 | ZH-WIFI-06 | RLUM02BS | Y1 | SHIELD-3P | SHIELD-3P | | Y2 | CRY-D3225 | CRY-D3225 | 24M20PPM | Y2A | SHIELD-3P | SHIELD-3P | | Y3 | SMD-OSC02 | SMD-OSC02 | 32.768K |
