查看: 831|回复: 0
UI层  3288 布局代码
社区居民社区明星忠实会员宣传大使奖终身成就奖特殊贡献奖
发表于 2015-7-14 20:34:03 | 显示全部楼层 |阅读模式
<?xml version="1.0" encoding="UTF-8"?>
<!--  Copyright (C) 2007 The Android Open Source Project
     Licensed under the Apache License, Version 2.0 (the "License");
     you may not use this file except in compliance with the License.
     You may obtain a copy of the License at
          http://www.apache.org/licenses/LICENSE-2.0
     Unless required by applicable law or agreed to in writing, software
     distributed under the License is distributed on an "AS IS" BASIS,
     WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
     See the License for the specific language governing permissions and
     limitations under the License.
<resources xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:xliff="urnasis:names:tc:xliff:document:1.2">
    <string name="yes" msgid="4676390750360727396">"是"</string>
    <string name="no" msgid="6731231425810196216">"否"</string>
    <string name="create" msgid="3578857613172647409">"创建"</string>
    <string name="allow" msgid="3349662621170855910">"允许"</string>
    <string name="deny" msgid="6947806159746484865">"拒绝"</string>
    <string name="device_info_default" msgid="7847265875578739287">"未知"</string>
  <plurals name="show_dev_countdown">
    <item quantity="one" msgid="5295687242294085452">"只需 <xliff:g id="STEP_COUNT">%1$d</xliff:g> 步操作即可进入开发者模式。"</item>
    <item quantity="other" msgid="6722953419953594148">"只需 <xliff:g id="STEP_COUNT">%1$d</xliff:g> 步操作即可进入开发者模式。"</item>
  </plurals>
    <string name="show_dev_on" msgid="1110711554982716293">"您现在处于开发者模式!"</string>
    <string name="show_dev_already" msgid="2151632240145446227">"您已处于开发者模式,无需进行此操作。"</string>
    <string name="header_category_wireless_networks" msgid="4944823405420438623">"无线和网络"</string>
    <string name="header_category_device" msgid="5781174212691167553">"设备"</string>
    <string name="header_category_personal" msgid="6225932173498802187">"个人"</string>
    <string name="header_category_system" msgid="2073558547468647128">"系统"</string>
    <string name="turn_on_radio" msgid="8706561489788373676">"打开无线通信"</string>
    <string name="turn_off_radio" msgid="1820294552893884115">"关闭无线通信"</string>
    <string name="sms_over_ims_on" msgid="5085290395865632925">"启用通过 IMS 发送短信的功能"</string>
    <string name="sms_over_ims_off" msgid="8354792045992793959">"停用通过 IMS 发送短信的功能"</string>
    <string name="ims_reg_required_on" msgid="3885152087309614653">"需要打开 IMS 注册"</string>
    <string name="ims_reg_required_off" msgid="1720570343422743943">"需要关闭 IMS 注册"</string>
    <string name="lte_ram_dump_on" msgid="8568568019520172177">"打开 LTE RAM 转储"</string>
    <string name="lte_ram_dump_off" msgid="2514507918652378283">"关闭 LTE RAM 转储"</string>
    <string name="radioInfo_menu_viewADN" msgid="8743377494429930831">"查看 SIM 卡地址簿"</string>
    <string name="radioInfo_menu_viewFDN" msgid="7934301566925610318">"查看固定拨号号码"</string>
    <string name="radioInfo_menu_viewSDN" msgid="7130280686244955669">"查看服务拨号"</string>
    <string name="radioInfo_menu_getPDP" msgid="560610293888406317">"获取 PDP 列表"</string>
    <string name="radioInfo_service_in" msgid="1915416319177520020">"正在使用中"</string>
    <string name="radioInfo_service_out" msgid="5238736759641916278">"不在服务区"</string>
    <string name="radioInfo_service_emergency" msgid="2485604591272668370">"只能拨打紧急呼救电话"</string>
    <string name="radioInfo_service_off" msgid="1434084741785525415">"关闭无线通信"</string>
    <string name="radioInfo_roaming_in" msgid="9045363884600341051">"漫游"</string>
    <string name="radioInfo_roaming_not" msgid="2851853244069662307">"非漫游"</string>
    <string name="radioInfo_phone_idle" msgid="7489244938838742820">"空闲"</string>
    <string name="radioInfo_phone_ringing" msgid="4883724645684297895">"响铃"</string>
    <string name="radioInfo_phone_offhook" msgid="4174402846862780998">"正在通话"</string>
    <string name="radioInfo_data_disconnected" msgid="1959735267890719418">"已断开连接"</string>
    <string name="radioInfo_data_connecting" msgid="8404571440697917823">"正在连接"</string>
    <string name="radioInfo_data_connected" msgid="7074301157399238697">"已连接"</string>
    <string name="radioInfo_data_suspended" msgid="5315325487890334196">"已暂停"</string>
    <string name="radioInfo_unknown" msgid="737385314432468266">"未知"</string>
    <string name="radioInfo_display_packets" msgid="8654359809877290639">"pkts"</string>
    <string name="radioInfo_display_bytes" msgid="4018206969492931883">"字节"</string>
    <string name="radioInfo_display_dbm" msgid="3621221793699882781">"dBm"</string>
    <string name="radioInfo_display_asu" msgid="1422248392727818082">"asu"</string>
    <string name="radioInfo_lac" msgid="8415219164758307156">"LAC"</string>
    <string name="radioInfo_cid" msgid="4362599198392643138">"CID"</string>
    <string name="sdcard_unmount" product="nosdcard" msgid="6325292633327972272">"卸载 USB 存储设备"</string>
    <string name="sdcard_unmount" product="default" msgid="3364184561355611897">"卸载 SD 卡"</string>
    <string name="sdcard_format" product="nosdcard" msgid="6285310523155166716">"格式化 USB 存储设备"</string>
    <string name="sdcard_format" product="default" msgid="6713185532039187532">"格式化 SD 卡"</string>
    <string name="small_font" msgid="2295331917424072635">"小"</string>
    <string name="medium_font" msgid="2068475425515133701">"中"</string>
    <string name="large_font" msgid="599055175160971446">"大"</string>
    <string name="font_size_save" msgid="3450855718056759095">"确定"</string>
    <string name="sdcard_setting" product="nosdcard" msgid="8281011784066476192">"USB 存储设
