DP.zip
(416 KB, 下载次数: 8)
板子有以下元件
Comment | Designator | Footprint | Quantity | 0.1uF | C1, C2, C3, C4, C5,C6, C9, C10, C11, C12, C13, C14, C18, C19, C20, C21, C22, C23, C24, C25, C26,C28, C29, C35, C36, C37, C38, C39, C40, C41, C42, C43, C44, C45, C46, C47,C48, C49, C50, C51, C53, C54, C55, C57, C58, C62, C63, C64, C65, C66, C67,C68, C69, C82, C83, C86, C100, C101, C123, C126, C127, C128, C129, C130,C133, C134, C135, C137, C145, C149, C162, C164, C165, C166 | C0603 | 74 | 18pF | C7, C8 | C0603 | 2 | 102/1KV | C56 | CD5028 | 1 | 22pF | C59, C60 | C0603 | 2 | 1uF | C61, C88, C136, C143,C144, C147 | C0603 | 6 | 1000pF | C84 | C0603 | 1 | 394 | C85 | C0603 | 1 | 3300pF | C87 | C0603 | 1 | 10nF | C121, C124 | C0603 | 2 | 82nF | C122 | C0603 | 1 | 33pF | C138, C140 | C0603 | 2 | 4.7uF | C139 | C0603 | 1 | 10uF | C146, C150, C151,C153, C155, C156, C157, C158, C159, TC2, TC4, TC5, TC6, TC7, TC8, TC9, TC10,TC11, TC12, TC22, TC24, TC25, TC26, TC31 | C0805 | 24 | 100pF | C148, C161, C163 | C0603 | 3 | 1nF | C152, C154, C160 | C0603 | 3 | 1N4148 | D7, D8, D10, D21 | D1206 | 4 | ESD-0603-LF | D13, D14, ESD1, ESD3,ESD4, ESD5, ESD6, ESD7, ESD8, ESD9, ESD10, ESD11, ESD12, ESD13, ESD14, ESD15,ESD16, ESD17 | ESD0603 | 18 | 1N5824 | D16, D17, D18 | D5030 | 3 | P6KE18A | D19 | D5030 | 1 | SS14 | D20 | D5030 | 1 | 600R-100M | FB3, FB4, FB5, FB9 | L0805 | 4 | RJ45 | J1 | RJ45-DIPLED | 1 | 开门按钮&门磁 | J5 | XH3 | 1 | ELock | J7 | XH3 | 1 | KEY | J10 | SH9-90 | 1 | IC MODULE | J11 | ph4 | 1 | DEBUG UART | J12 | PH4 | 1 | RS485 | J13 | XH3 | 1 | LEFT-SPEAKER | J15 | XH2 | 1 | LED | J22 | XH2 | 1 | TV IN | J23 | XH3 | 1 | KD43G7-40NM-B2 | J24 | FFC40-0.5F | 1 | Micphone | J25 | XH2 | 1 | 4.7uH | L2, L3, L4, L6 | L351 | 4 | 33uH/2A | L5 | LX10090 | 1 | RLED | LED3 | LED0603 | 1 | CON2 | PW1 | XH2 | 1 | 8550 | Q1, Q3, Q6 | SOT-23 | 3 | 2N9013 | Q2, Q4, Q11 | SOT-23 | 3 | SI2307DS | Q10 | SOT-23GDS | 1 | 200K | R2 | R0603 | 1 | 0R | R3, R46, R48, R211 | R0603 | 4 | 1K | R4, R5, R47, R50,R71, R88, R89, R95, R176, R177, R220, R221, R227 | R0603 | 13 | 22R | R6, R7, R8, R9, R10,R11, R12, R13, R14, R15, R16, R103, R104 | R0603 | 13 | 10K | R17, R18, R23, R39,R64, R65, R67, R72, R87, R90, R91, R92, R94, R96, R168, R192, R201, R218,R222, R223, R224 | R0603 | 21 | 0R(NC) | R19, R20, R37, R38 | R0603 | 4 | 4.87K | R22 | R0603 | 1 | 1.5K | R24 | R0603 | 1 | 75R | R25, R26 | R0603 | 2 | 49.9R | R27, R28, R29, R30 | R0603 | 4 | 1M | R31, R178 | R0603 | 2 | 5.1K | R32, R40, R42, R43,R44, R45 | R0603 | 6 | 1K(NC) | R33, R34 | R0603 | 2 | 2K | R35, R36, R109, R219 | R0603 | 4 | 47K | R41 | R0603 | 1 | 33R | R51, R52, R53, R54,R55, R56, R76, R77, R205, R206, R207, R208, R225, R226 | R0603 | 14 | 10R | R62, R69, R173 | R0603 | 3 | 4.7K | R82, R83, R84, R85 | R0603 | 4 | 20R | R97, R98 | R0805 | 2 | 3.6K | R110 | R0603 | 1 | 1.69K | R171 | R0603 | 1 | 100K | R175, R193 | R0603 | 2 | 37.4R | R179, R180 | R0603 | 2 | 20K | R190 | R0603 | 1 | 33K | R191 | R0603 | 1 | 1R | R212, R214, R215,R217 | R0603 | 4 | 200K1% | R213 | R0603 | 1 | 1R | R216, R228, R229 | R0805 | 3 | 22R | RN1, RN2, RN3, RN4 | RP8 | 4 | HRS1-DC12(NC) | RY1 | RELAY-23L | 1 | SD1 | SD1 | SD-DWM-1015 | 1 | 4.7uF | TC3 | c0805 | 1 | 100uF/16V | TC17, TC28 | ECS6522 | 2 | 10uF/16V | TC20, TC32 | TC3216 | 2 | 220uF/35V | TC27 | ECS8035 | 1 | 2.2uF | TC29, TC30 | C0805 | 2 | HR681686 | TR1 | TR100-16 | 1 | DP2000 | U1 | LQFP216 | 1 | HY5DU121622DTP-D43 | U2 | TSOP66 | 1 | H27U2G8F2CTR | U3 | TSOP48 | 1 | DP83848I | U5 | LQFP48 | 1 | DM2016 | U6 | SO8 | 1 | SP3485 | U9 | SO8 | 1 | LM4890 | U11 | MSOP8 | 1 | ADV7180 | U15 | LFCSP40 | 1 | AXP199 | U17 | QFP48-0.4 | 1 | LM2596S-5.0 | U18 | TO-263-5 | 1 | LT1937 | U19 | AT1308 | 1 | 24M | X1 | X-HC49S-G | 1 | 25MHz | Y1 | X-HC49S-G | 1 | 28.63636MHz | Y2 | XS-TF2X6 | 1 |
