查看: 1801|回复: 8
[学习经历] 每天一小段英语(44)
命运的号角已经吹响
社区居民忠实会员社区劳模原创达人终身成就奖金点子奖优秀斑竹奖
发表于 2016-4-20 11:46:13 | 显示全部楼层 |阅读模式 来自 黑龙江佳木斯
Once that’s under control, they can do a more involved procedure that surgically accesses the major blood vessels in your thigh and hooks them up to this guy:
接下来还有很多事要做,他们像做外科手术似的往你大腿主动脉扎这玩意:
That’s a heart-lung machine that takes care of circulation and oxygenation so they can stop the much cruder CPS. In addition to circulating your blood, the machine draws heat out of your body, cooling it to just above the freezing temperature of water, and replaces some of your blood with an organ preservation solution that supports life at super low temperatures (this is similar to how transplant surgeons keep organs alive when they have to transport them long distances).
这是一个心肺机,帮你做体循环和氧合作用,那个简陋的中央处理系统就可以拿下去了。除了血液循环,它还帮你的身体吸收热量,保持水在冷冻温度以下,用一种维持生命低温的器官保护液替换掉血液(就像移植外科医生远距离移植器官用的那种保护液)。
If you have to be flown to the cryonics facility, they pack you in ice and put you on board what they hope is not your last ever flight.
比如到时候你不得不飞到冷冻设施那,他们会把你放进冰里再上飞机并希望这不是你的最后一程。
Step 7) Get vitrified
玻璃化
Most people who know what cryonics is think it means getting frozen. It doesn’t. It means getting vitrified.
很多人认为人体冷冻就是把人冻住,其实是把人玻璃化。
Glass is weird. It’s not a typical solid because as it cools from its liquid phase, it never crystallizes into an orderly structure. But, as I learned when a bunch of commenters yelled at me about after I published this post, it’s not actually a liquid either, since it doesn’t flow. So, it’s neither a typical solid nor a liquid—it’s an “amorphous solid,” sometimes compared to a giant molecule. For our purposes, the key is that like a liquid, glass doesn’t crystallize—rather, as it cools the molecules just move slower and slower until they stop.
玻璃很奇特,它不是一种典型的固体因为从液态冷却到固态的结晶是不规则结构。但是我发表这篇文章时候一些评论说玻璃也不是液体因为它不流动。既然玻璃不是典型固体也不是液体,和大分子物质相比较那就是非晶体固体。我们认为主要是玻璃像液体一样不结晶,冷却时候分子运动越来越慢直到停止。
为了读者看到更好的排版,更方便的阅读,我弄了个微信订阅号:enhanver(无广告,无推广)
逆天pcb是首发平台,在微信订阅号中会进一步修改硬错误
对于我的翻译,欢迎大家提出意见,纠正错误(论坛和微信都会收到消息)
谢谢支持,谢谢原作者。望大家有所收获
新人一枚
命运的号角已经吹响
 楼主| 发表于 2016-4-20 11:47:37 | 显示全部楼层 来自 黑龙江佳木斯
每日一词
surgical
adj. 外科的;手术上的
n. 外科手术;外科病房
新人一枚
命运的号角已经吹响
 楼主| 发表于 2016-4-20 11:48:34 | 显示全部楼层 来自 黑龙江佳木斯
新人一枚
    终身成就奖社区居民忠实会员社区劳模最爱沙发原创达人优秀斑竹奖
    发表于 2016-4-20 12:47:16 | 显示全部楼层 来自 黑龙江哈尔滨
    英语不学真不行 datasheet都英文的
    命运的号角已经吹响
     楼主| 发表于 2016-4-20 18:58:29 | 显示全部楼层 来自 黑龙江佳木斯
    新人一枚
    社区居民终身成就奖原创先锋奖
    发表于 2016-4-20 19:37:36 | 显示全部楼层 来自 内蒙古包头
    既学习英语,有学知识!
    昨天 15:10
  • 签到天数: 411 天
    [LV.9]以坛为家II
    35
    发表于 2016-4-21 08:56:04 | 显示全部楼层 来自 湖北
    发表于 2016-4-21 08:56:36 | 显示全部楼层 来自 福建厦门
