查看: 547|回复: 0
[IC] CNS21XX-STR81XX-DS-V1.6 Network Access Processor
发表于 2016-6-4 09:34:34 | 显示全部楼层 |阅读模式
FEATURES
32-bit RISC Core
High-performance ARM922-compatible RISC with 8kB I-cache, 8kB D-cache, and memory management unit (MMU) for
high-level RTOS, with programmable CPU core clocks up to 200/250MHz
9 Advanced system bus architecture
9 Supports TRACE32, RealView and Multi-ICE JTAG debugging interfaces
9 Support IRQ/FIQ interrupt modes
9 Support Little-/Big-endian ordering
9 Built-in intelligent power management for normal and power-saving mode of
operations
CNS21XX-STR81XX-DS-V1.6 Network Access Processor.pdf (2.07 MB, 下载次数: 0)
