LM2575T-5.0 1A Step-Down Voltage Regulator
1FEATURES
23• 3.3V, 5V, 12V, 15V, and Adjustable Output Versions
• Adjustable Version Output Voltage Range,
– 1.23V to 37V (57V for HV Version) ±4% Max Over
– Line and Load Conditions
• Specified 1A Output Current
• Wide Input Voltage Range, 40V up to 60V for HV Version
• Requires Only 4 External Components
• 52 kHz Fixed Frequency Internal Oscillator
• TTL Shutdown Capability, Low Power Standby Mode
• High Efficiency
• Uses Readily Available Standard Inductors
• Thermal Shutdown and Current Limit Protection
• P+ Product Enhancement Tested
LM2575T-5.0 1A Step-Down Voltage Regulator.pdf
(5.85 MB, 下载次数: 0)
