Name | Value | PCB Decal | Part Type | C8 | 1uF 50V | CAP_4MMX5MM | CAP_ALUMINUM_1UF50V | C9 | 104 | 603 | CAP0603 | C10 | 100uF 16V | CAP_6.5MMX7MM | CAP_ALUMINUM_100UF16V | C11 | 100uF 16V | CAP_6.5MMX7MM | CAP_ALUMINUM_100UF16V | C12 | 104 | 603 | CAP0603 | C13 | 100p | 603 | CAP0603 | C14 | 100p | 603 | CAP0603 | C15 | 22uF 16V | CAP_5.5MMX6.5MM | CAP_ALUMINUM_22UF16V | C16 | 22uF 16V | CAP_5.5MMX6.5MM | CAP_ALUMINUM_22UF16V | C17 | 103 | 603 | CAP0603 | C18 | 22uF/10V | 1210-P | CAP1210 | C19 | 470uF 16V | CAP_8MMX9MM | CAP_ALUMINUM_100UF16V | C20 | 47uF 16V | CAP_5.5MMX6.5MM | CAP_ALUMINUM_47UF16V | C21 | (0R *) | 603 | CAP0603 | C22 | (0R *) | 603 | CAP0603 | C23 | 10uF 16V | CAP_4MMX5MM | CAP_ALUMINUM_10UF16V | C24 | 10uF 16V | CAP_4MMX5MM | CAP_ALUMINUM_10UF16V | C25 | 104 | 603 | CAP0603 | C26 | 104 | 603 | CAP0603 | C27 | 22uF 16V | CAP_5.5MMX6.5MM | CAP_ALUMINUM_22UF16V | C28 | 47uF 16V | CAP_5.5MMX6.5MM | CAP_ALUMINUM_47UF16V | C57 | 100uF 16V | CAP_6.5MMX7MM | CAP_ALUMINUM_100UF16V | C77 | 10uF 16V | CAP_4MMX5MM | CAP_ALUMINUM_10UF16V | C78 | 10uF 16V | CAP_4MMX5MM | CAP_ALUMINUM_10UF16V | C79 | 104 | 603 | CAP0603 | C80 | 22uF | 1210 | CAP1210 | C81 | 103 | 603 | CAP0603 | C82 | 10uF 16V | CAP_4MMX5MM | CAP_ALUMINUM_10UF16V | C83 | 100uF 16V | CAP_6.5MMX7MM | CAP_ALUMINUM_100UF16V | C84 | 100uF 16V | CAP_6.5MMX7MM | CAP_ALUMINUM_100UF16V | C85 | 10uF 16V | CAP_4MMX5MM | CAP_ALUMINUM_10UF16V | C86 | 10uF 16V | CAP_4MMX5MM | CAP_ALUMINUM_10UF16V | C87 | 103 | 603 | CAP0603 | C88 | 15p | 603 | CAP0603 | C89 | 22uF 16V | CAP_5.5MMX6.5MM | CAP_ALUMINUM_22UF16V | C90 | 22uF | 1210 | CAP1210 | C91 | 100uF 16V | CAP_6.5MMX7MM | CAP_ALUMINUM_100UF16V | C92 | 100uF 16V | CAP_6.5MMX7MM | CAP_ALUMINUM_100UF16V | C93 | 1u | 603 | CAP0603 | C94 | 100uF 16V | CAP_6.5MMX7MM | CAP_ALUMINUM_100UF16V | C95 | 10uF 16V | CAP_4MMX5MM | CAP_ALUMINUM_10UF16V | D1 | LED GREEN | LED-0805 | LED | D2 | LED YELLOW | LED-0805 | LED | D3 | LED RED | LED-0805 | LED | D4 | BAT54A | SOT23-DECAL | BAT54_PART | D5 | BAV99 | SOT23-DECAL | BAV99_PART | D6 | 1N5822 | 1N5822 | DIODE-SCHOTTKY | D7 | 1N5822 | 1N5822 | DIODE-SCHOTTKY | D8 | 1N5822 | 1N5822 | DIODE-SCHOTTKY | D9 | BAT54A | SOT23-DECAL | BAT54_PART | J1 | POWER_CONNECTOR | CON4-2.5MM | 4PIN-PART | J2 | S-VIDEO | SVHS-4PIN | S-VHS-4PIN_PART | J3 | 3X2 AV CONNECTOR | AV_3X2_DECALS | AV_CONNECTOR_3X2_PART | J4 | POWER_CONNECTOR | CON7-2.5MM | 7PIN-PART | J5 | DB9-H-MALE | DB9-VM | RS232_M_PART | J6 | | IDC_6PIN_1_DECAL | IDC-6PIN_PART | J7 | 7X2 2.54mm JTAG | HEADER14-POL | IDC14_DEBUG_PART | J8 | 2PIN 2.54mm | SIP-2P | 2PIN | J9 | POWER_CONNECTOR | CON6-2.5MM | 6PIN-PART | J10 | 2PIN 2.54mm | SIP-2P | 2PIN | J11 | 3PIN 2.54mm | SIP-3P | CON3_PART | J12 | | POWER_JACK_DECALS | POWER_JACK_PART | J13 | POWER_CONNECTOR | CON8-2.5MM | 8PIN-PART | L1 | 10uH 10mA | 1210 | IND_1210 | L2 | 102K 20mA | 1812 | IND_1812 | L3 | FB | 0603-0805 | FB_IND | L5 | 220nH | 805 | IND_0805 | L6 | 220nH | 805 | IND_0805 | L7 | 100nH | 805 | IND_0805 | L9 | 1uH | 805 | IND_0805 | L12 | 102K 20mA | 1812 | IND_1812 | L27 | FB 1812 | 1812 | FB_IND | L28 | 15uH 1A | IND_10X10MM | IND | L29 | FB 1812 | 1812 | FB_IND | L30 | FB(NC) | 0603-0805 | FB_IND | Q1 | S8050 | SOT23-DECAL | NPN | Q2 | 2SC4081 | SOT23-DECAL | 2SC4081-PART | Q3 | s8550 | SOT23-DECAL | PNP_PART | Q4 | s8550 | SOT23-DECAL | PNP_PART | Q5 | 2SA1015Y | SOT23M2-DECAL | 2SA1015_PART | Q6 | 2SA1015Y | SOT23M2-DECAL | 2SA1015_PART | Q7 | 2SA1015Y | SOT23M2-DECAL | 2SA1015_PART | Q8 | 2SC1815Y | SOT23-DECAL | 2SC1815_PART | Q9 | 2SC1815Y | SOT23-DECAL | 2SC1815_PART | Q10 | 2SC1815Y | SOT23-DECAL | 2SC1815_PART | Q11 | BC846B | SOT23-DECAL | NPN-BC846B | Q12 | 2SC4081 | SOT23-DECAL | 2SC4081-PART | Q13 | 2SC4081 | SOT23-DECAL | 2SC4081-PART | U1 | ALPS | TUNER_ALPS_DECAL | TUNER_ALPS_PART | U2 | ENV56M05D8F | ENV56M05D8F-V | TUNER_PART | U3 | SP3232E | SSOP16-DECAL | SP3232E_PART | U4 | (TOTX179P) | TOTX179-DECAL | TOTX179P_PART | U5 | UM6K1N | SC-88 | UM6K1N_PART | U6 | (24LC256) | SO8M1 | 24CXX_PART | U7 | UM6K1N | SC-88 | UM6K1N_PART | U8 | UM6K1N | SC-88 | UM6K1N_PART | U9 | UM6K1N | SC-88 | UM6K1N_PART | U10 | MM1636XWRE | SO8-DECAL | MM1636XWRE_PART | U11 | UM6K1N | SC-88 | UM6K1N_PART | U12 | HY5DU561622ETP-5 | P-TSOPII-66-1 | HY25D256163CE_PARTS | U13 | R8A66953FP | QFP216-0.4 | R8A66953FP_PART | U14 | LM1086(1085)-ADJ | TO-263 | LM1085_PART | U15 | PCM1742 | PSOP16-DECAL | PCM1742_PART | U16 | MP1411/MP1412 | MSOP10_DECAL | MP1412_PART | U18 | BC857AW | SOT23-DECAL | BC857AW_PART | U19 | BC857AW | SOT23-DECAL | BC857AW_PART | U20 | LM1117-2.5 | SOT223-DECAL | LM1117_PART | U21 | BC857AW | SOT23-DECAL | BC857AW_PART | U22 | LM1117-3.3 | SOT223-DECAL | LM1117_PART | U23 | MP1411/MP1412 | MSOP10_DECAL | MP1412_PART | U24 | LM1117-3.3 | SOT223-DECAL | LM1117_PART | U25 | M5M29KT331AVP | TSOP-48 | FLASH_48PIN_PART | Y1 | 5mmX3mm VC-FXO-65F 27MHz | VCXO_5MMX3.2MM | VCXO_PART | Y2 | (7mmX5mm VC-FXO-35F 27M) | VCXO_7MMX5MM | VCXO_PART | Y3 | 25M | CRYSTAL_DECAL | CRYSTAL |
