查看: 18421|回复: 90
[Allegro16.6以下] 天嵌 TQIMX6Q 开发板 主板PCB 文件共享下载
PADS-190603高级班
社区居民忠实会员终身成就奖
发表于 2016-6-19 12:02:56 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
12VDC POWERJACK_DC_JACK_IO_CONN PCONN PWRDC_JACK
BAT1BATTERY_BAT600_BATTERYBATTERYBAT600
BLCON6_DIP6P_2_0_CON6CON6DIP6P_2_0
BR2DIODE_KCAC_BRIDGE_BGX50APRTR5V0U2XSOT143
BR3DIODE_KCAC_BRIDGE_BGX50APRTR5V0U2XSOT143
BR4DIODE_KCAC_BRIDGE_BGX50APRTR5V0U2XSOT143
BR5DIODE_KCAC_BRIDGE_BGX50APRTR5V0U2XSOT143
CAMERAJTAG20_IDC20S_2_CAM_2.0CAM_2.0IDC20S_2
CANCON2_CN2P_3_5_CON2CON2CN2P_3_5
CAP_TCCON6_SMD_6P_1_25_90_CON6CON6SMD_6P_1_25_90
CE1CAPACITORPOL_1_1000U_220UF/50V220uF/50V1000U
CE2CAPACITORPOL_1_47U_220UF/16V220uF/16V47U
CE3CAPACITORPOL_1_47U_220UF/16V220uF/16V47U
COM1CONN_DB9F_MTGTABS_DB9RAM_IO_DB9DB9DB9RAM
COM2CONN_DB9F_MTGTABS_DB9RAM_IO_DB9DB9DB9RAM
CON40PCON_0_FPC_0_5_40P_LCD_40PLCD_40PFPC_0_5_40P
D1DIODEZENER_0_SMBJ_SMD_SMBJ15SMBJ15SMBJ_SMD
D3BAT54C_SOT23_BAT54CBAT54CSOT23
D7DIODE_SOD0530_MBR0530MBR0530SOD0530
D13DIODEZENER1_2_SOD_523_AZ5125-0AZ5125-01HSOD_523
D20DIODEZENER1_2_SOD_523_AZ5125-0AZ5125-01HSOD_523
D21DIODEZENER1_2_SOD_523_AZ5125-0AZ5125-01HSOD_523
FB7INDUCTOR_0603L_DISCRETE_120R/2A120R/2A0603L
FB8INDUCTOR_0603L_DISCRETE_120R/2A120R/2A0603L
FB9INDUCTOR_0603L_DISCRETE_120R/2A120R/2A0603L
FB10INDUCTOR_0603L_DISCRETE_120R/2A120R/2A0603L
FUSE1FUSE_0_FUSE_IC_2.6A2.6AFUSE
FUSE2FUSE_0_1206C_IC_2A2A1206C
HDMIHDMI_0_HDMI_HDMI-005HDMI-005HDMI
IRDAIRM3638_IRM3638_IRM-3638M3IRM-3638M3IRM3638
J1CON200_SMD_DIP200P_2MM_CON200CON200DIP200P_2MM
J6CON14A_2_NHDS4_2_54_CON8CON8NHDS4_2_54
J7CON2_DIP2P_2_0_CON2CON2DIP2P_2_0
J10CON4_1_SHIELD_CASE_CON4CON4SHIELD_CASE
K1KEY2_SW_PB2_KEY2KEY2SW_PB2
K2KEY2_SW_PB2_KEY2KEY2SW_PB2
K3KEY2_SW_PB2_KEY2KEY2SW_PB2
K4KEY2_SW_PB2_KEY2KEY2SW_PB2
L1INDUCTOR_IND_6M6_DISCRETE_4.7UH4.7uH/MNR6020-4R7MIND_6M6
L2INDUCTOR_IND_6M6_DISCRETE_4.7UH4.7uH/MNR6020-4R7MIND_6M6
L4INDUCTOR_IND_6M6_DISCRETE_4.7UH4.7uH/MNR6020-4R7MIND_6M6
LED1LED_0_LED_0805_REDREDLED_0805
LED2LED_0_LED_0805_REDREDLED_0805
LED4LED_1_LED_0805_GREENGREENLED_0805
LED5LED_1_LED_0805_GREENGREENLED_0805
LED6LED_1_LED_0805_GREENGREENLED_0805
LED7LED_0_LED_0805_REDREDLED_0805
LVDSCONN EDGE15X2_IDC30S_2_CONN EDCONN EDGE 15X2IDC30S_2
MICPJ-215-B_2_PJ_215_B_PJ-215-BPJ-215-BPJ_215_B
MINI_MICMIC_0_MIC_MICMICMIC
MINI_PCIEMINI_PCI_LATCH_52P_CON_2X26_0P8CON 2X26 MINI PCIEXPRESSCON_2X26_0P8_SMT_A
N1AO4459_SOIC8_AO4459AO4459SOIC8
N5Q_FET_N_ENH#2_0_SOT233_2N70022N7002SOT233
N6Q_FET_N_ENH#2_0_SOT233_2N70022N7002SOT233
N7Q_FET_N_ENH#2_0_SOT233_2N70022N7002SOT233
NETLA1S109_0_FC_202GYDNL_FC_202GYDFC_202GYDNLFC_202GYDNL
P47RCA_8_RCA8_3RATH_RCA_8RCA_8RCA8_3RATH
PHONEPJ-215-B_2_PJ_215_B_PJ-215-BPJ-215-BPJ_215_B
Q1PNP_0_SOT23_S8550S8550SOT23
Q28050_1_S9013SMD_S8050S8050S9013SMD
Q48050_1_S9013SMD_S8050S8050S9013SMD
Q78050_1_S9013SMD_S8050S8050S9013SMD
Q88050_1_S9013SMD_S8050S8050S9013SMD
Q98050_1_S9013SMD_S8050S8050S9013SMD
RN1NETW_B8_1_8P4R_0603_DISCRETE_1010K8P4R_0603
RN2NETW_B8_1_8P4R_0603_DISCRETE_4.4.7K8P4R_0603
RN3NETW_B8_1_8P4R_0603_DISCRETE_1010K8P4R_0603
RN4NETW_B8_1_8P4R_0603_DISCRETE_4.4.7K8P4R_0603
RSTKEY4_0_RST_KEY_SWSWRST_KEY
SATACONN_SATA_4_CON7_SATA_TH_17X5MM10029364-001LFCON7_SATA_TH_17X5MM
SATA_POWERCONN_SATA_5_CON4S_3_96_180_IO_110029364-001LFCON4S_3_96_180
SD_CARDSD-CARD_0_SD_5011_SD/MMCCARDSD/MMC CARDSD_5011
SIM1SIMCARD_SIM117_SIMCARDSIMCARDSIM117
SW1MTS102C317_MTS102C317_MTS102C31MTS102C317MTS102C317
TOUCHCON6_1_SIP6_2_CON6CON6SIP6_2
TVS1SRV05_SRV05_SRV05SRV05SRV05
TVS2CON4_6_SLP2510P8_SLP2510P8SLP2510P8SLP2510P8
TVS3CON4_6_SLP2510P8_SLP2510P8SLP2510P8SLP2510P8
U1MP1494DJ_TSOT23_8_MP1495DJMP1495DJTSOT23_8
U2MP1494DJ_TSOT23_8_MP1495DJMP1495DJTSOT23_8
U3MAX232SOP_SOP16_SP3232EENSP3232EENSOP16
U6AMS1117-1_2.5_SOT223_AMS1117-1.AMS1117-1.5SOT223
U7SGTL5000-XNAA3_0_QFN36_SGTL5000SGTL5000-XNAA3QFN36_SGTL5000
U8USB2514BQFN36USB2514B_QFN36_MINQFN36
U9MCP2551_SO_8_IC_MCP2551MCP2551SO_8
U10MP1494DJ_TSOT23_8_MP1495DJMP1495DJTSOT23_8
U11SA4148_SO_8_NS4148NS4148SO_8
U16MAX232SOP_SOP16_SP3232EENSP3232EENSOP16
U17RT9266PE_2_SOT_25_SY6280AACSY6280AACSOT_25
U18TSC2003_TSC2007IPW_TSC2007IPWTSC2007IPWTSC2007IPW
UART1CON4_DIP4P_2_0_CON4CON4DIP4P_2_0
UART2CON4_DIP4P_2_0_CON4CON4DIP4P_2_0
UART3CON4_DIP4P_2_0_CON4CON4DIP4P_2_0
UART4CON4_DIP4P_2_0_CON4CON4DIP4P_2_0
UART5CON4_DIP4P_2_0_CON4CON4DIP4P_2_0
USB1SKT_USB-ACONN_4PUSB_A
USB2SKT_USB-ACONN_4PUSB_A
USB3SKT_USB-ACONN_4PUSB_A
USB_OTGUSB_MINI_B_MINIUSB_IO_MINIUSBMINIUSBMINIUSB
WIFICON16_1_IDC20P_DIP_B_CON20CON20IDC20P_DIP_B
Y2ZTA_OSC2PR_1_24MHZ24MHzOSC2PR_1
游客,如果您要查看本帖隐藏内容请回复
重要提示:PCB作品文件展下载说明
终身成就奖社区居民忠实会员社区明星最爱沙发优秀斑竹奖宣传大使奖特殊贡献奖
发表于 2016-6-19 13:20:30 | 显示全部楼层
主板PCB  有核心板吗
q
    4 天前
  • 签到天数: 126 天
    你必须非常努力才能显
    发表于 2016-6-19 16:41:08 | 显示全部楼层
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2016-6-19 19:07:27 | 显示全部楼层
    这个以前是不是有人发过啊
    发表于 2016-6-19 22:19:54 | 显示全部楼层
    游客
    社区居民忠实会员社区劳模最爱沙发原创达人终身成就奖优秀斑竹奖
    发表于 2016-6-19 22:21:42 | 显示全部楼层
    昨天 17:53
  • 签到天数: 191 天
    社区居民社区劳模原创先锋奖终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2016-6-20 08:36:39 | 显示全部楼层
    终身成就奖原创先锋奖
    发表于 2016-6-20 08:48:47 | 显示全部楼层
    发表于 2016-6-20 08:52:14 | 显示全部楼层
    社区居民忠实会员社区劳模原创达人终身成就奖金点子奖
    发表于 2016-6-20 08:52:48 | 显示全部楼层
