CC3100MOD SimpleLink™ Certified Wi-Fi® Network Processor Internet-of-Things Module
Solution for MCU Applications
1.1 Features
• The CC3100MOD is a Wi-Fi Module that Consists
of the CC3100R11MRGC Wi-Fi Network Processor
and Power-Management Subsystems. This Fully
Integrated Module Includes all Required Clocks,
SPI Flash, and Passives.
• Modular FCC, IC, and CE Certifications Save
Customer Effort, Time, and Money
• Wi-Fi CERTIFIED™ Modules, With Ability to
Request Certificate Transfer for Wi-Fi Alliance
Members
• Wi-Fi Network Processor Subsystem
– Featuring Wi-Fi Internet-On-a-Chip™
– Dedicated ARM® MCU
Completely Offloads Wi-Fi and Internet
Protocols from the External Microcontroller
– Wi-Fi Driver and Multiple Internet Protocols in
ROM
– 802.11 b/g/n Radio, Baseband, and Medium
Access Control (MAC), Wi-Fi Driver, and
Supplicant
– TCP/IP Stack
• Industry-Standard BSD Socket Application
Programming Interfaces (APIs)
• 8 Simultaneous TCP or UDP Sockets
• 2 Simultaneous TLS and SSL Sockets
– Powerful Crypto Engine for Fast, Secure Wi-Fi
and Internet Connections With 256-Bit AES
Encryption for TLS and SSL Connections
– Station, AP, and Wi-Fi Direct™ Modes
– WPA2 Personal and Enterprise Security
– SimpleLink Connection Manager for
Autonomous and Fast Wi-Fi Connections
– SmartConfig™ Technology, AP Mode, and
WPS2 for Easy and Flexible Wi-Fi Provisioning
– TX Power
• 17 dBm at 1 DSSS
• 17.25 dBm at 11 CCK
• 13.5 dBm at 54 OFDM
– RX Sensitivity
• –94.7 dBm at 1 DSSS
• –87 dBm at 11 CCK
• –73 dBm at 54 OFDM
– Application Throughput
• UDP: 16 Mbps
• TCP: 13 Mbps
• Host Interface
– Wide Range of Power Supply (2.3 to 3.6 V)
– Interfaces With 8-, 16-, and 32-Bit MCU or
ASICs Over a Serial Peripheral Interface (SPI)
With up to 20-MHz Clock
– Low Footprint Host Driver: Less than 6KB
– Supports RTOS and No-OS Applications
• Power-Management Subsystem
– Integrated DC-DC Converter With a Wide
Supply Voltage:
• Direct Battery Mode: 2.3 to 3.6 V
– Low-Power Consumption at 3.6 V
• Hibernate With Real-Time Clock (RTC):
7 μA
• Standby: 140 μA
• RX Traffic: 54 mA at 54 OFDM
• TX Traffic: 223 mA at 54 OFDM
– Integrated Components on Module
• 40.0-MHz Crystal With Internal Oscillator
• 32.768-kHz Crystal (RTC)
• 8-Mbit SPI Serial Flash RF Filter and
Passive Components
– Package and Operating Conditions
• 1.27-mm Pitch, 63-Pin, 20.5-mm ×
17.5-mm LGA Package for Easy Assembly
and Low-Cost PCB Design
• Operating Temperature Range: –20°C to
70°C
cc3100mod.pdf
(2.36 MB, 下载次数: 0)
