****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | Part Type | PCB Decal | Value | D4 | BAT54C | SOT23 | BAT54C | D5 | DIODE_0 | SOD128 | SCS240P | D6 | BAT54C | SOT23 | BAT54C | D7 | DIODE_2 | RB886G | RB886G | D10 | DIODE_0 | SOD123 | SCS240P | D11 | DIODE_2 | SOD323 | 1N4148 | D12 | DIODE | SOD128 | PMEG3030EP | D13 | DIODE_2 | B550C-13-F | B550A | D15 | DIODE_ZENER13_0 | D1206 | 3.6V | D16 | DIODE_ZENER13_0 | D1206 | 3.6V | D21 | DIODE | DO214AC | SS34 | ED33 | DIODE_BI-DIR_TRIG | E0402N | NC | ED35 | TVS | E0402N | ESD9B5V | H12 | PAD | SC_PTC0703B | PAD | J2 | USB_MIN_4_2 | USB-MCD-HXQK5F-LJ10 | HUM011D-5-S | J15 | UART-DEBUG | CON3 | UART-DEBUG | J16 | CON4_16 | DC-044B-OUT | CON2 | J17 | EDP_FLEX | AJ752-B-S-51 | eDP_Flex | J18 | CON4_22 | DS_CPM211 | DS_CPM211 | J19 | CON4_17 | DC-044A-IN | CON2 | J24 | CON4_10_2 | LP2980-N | LP2980 | J25 | CON4_24 | FPC0310-31B2-GXX-L | 31PIN | J6000 | ANT_0 | WIFIANT | RFANT5220 | Q3 | 2N7002_0 | SOT23 | 2N7002 | Q4 | MOSFET_N_0 | SOT23 | WPM2026 | Q5 | 2N7002_0 | SOT23 | 2N7002 | Q8 | NPN | SOT23 | 8050 | Q14 | MOSFET_N_0 | SOT23 | WPM2026 | Q15 | MOSFET_N_0 | SOT23 | WPM2026 | Q17 | 40852_1 | SOT23 | 8050 | Q19 | MOSFET_N_0 | SOT23 | WPM2026 | Q20 | MOSFET_N_0 | SOT23 | WPM2026 | Q2205 | FET_P_MOS | SOT23 | NC/WPM2015 | U1 | RK3188 | BGA453-19X19 | RK3188 | U2 | DDRII_3 | FBGA96-9X14 | DDR3-512MB | U6 | NANDFLASH_0 | TSOP1-48 | NAND_FLASH_1 | U9 | LM1086_2 | TSOP-6 | NC/NL27WZU04 (SOT-363) | U10 | AP6493_8 | AP6XXX | AP6xxx | U11 | BL8506 | SOT23 | AP061CN3302MR | U14 | G5121_9 | RT8279 | RT8279 | U16 | LPW5206H | SOT25 | LPW5206H/SY6280AAC | U18 | G5121_1 | SOT26 | TS1208/TCS9208/TG4111SL | U19 | DS8008_6 | SOT25 | FP6161/SY8008B | U20 | LPW5206H_1 | SOP8 | GS4407 | U21 | LPW5206H_2 | 6101FH | LTC6101 | U23 | CON4_7 | MFI-8PIN | PYD5790 | U24 | DS8008_6 | SOT25 | APS2415 | U28 | MP3202-QFN8_2 | QFN8-2X3 | MP3302 | U31 | LM4990_0 | MSOP8 | HYM8563 | U33 | DS8008_4 | SOT25 | PT5107-25 | U40 | MMA7660FC_2 | MMA7660FC | MMA7660FC | U56 | ANT_5 | ECT_ECT818000157_S | NC/RFANT5220 | U76 | ACT8847_0 | QFN48-6X6 | ACT8846 | U81 | MMA8653FC | MMA865XFC | MMA8653FC | U93 | INAND_FLASH | INAND_169 | FLASH | U94 | ANX9804_7 | BGA81-8X8 | ANX6345 | U3900 | LDO_PT5108 | SOT23-5 | PT5108E23E-18 | U4601 | MMA7660FC_2_2 | LGA2-1_12L_0-5 | RT3000BGQM | U7300 | CODEC_ES8316 | ES8316-QFN32-0404-0.4 | ES8316 | U7301 | LDO_PT5108 | SOT23-5 | PT5108E23E-18 | X2 | FB2H2G45_CELL_2 | CRY-D3225 | NC/TCXO 26MHz (2520) | X3 | FB2H2G45_CELL_2 | CRY-D3225 | TCXO 26MHz (2520) | Y1 | CRYSTAL_2 | CRY_MC146 | 32.768K | Y2 | CRYSTAL-4 | CRY-D3225 | 24M-20ppm | Y3 | CRYSTAL_0 | 2520 | 26MHz (3225) | Y4 | CRYSTAL-4_1 | CRY-D3225 | 27M-20ppm |
