Name | PCB Decal | Value | Part Type |
ANT1201 | ANT/1P/SMD/818000378/ECT | | ANTENNA |
ANT1202 | ANT/1P/SMD/818000378/ECT | | ANTENNA |
AU_SPKR_N1 | 1PIN-1.2X2 | TEST POINT | TEST_POINT_DIP0.6 |
AU_SPKR_P1 | 1PIN-1.2X2 | TEST POINT | TEST_POINT_DIP0.6 |
BEAD412 | BEAD/SMD/0603 | BLM18BD252SN1 | BEAD |
BEAD413 | BEAD/SMD/0603 | BLM18BD252SN1 | BEAD |
BEAD414 | BEAD/SMD/0603 | BLM18BD252SN1 | BEAD |
BEAD415 | BEAD/SMD/0603 | BLM18BD252SN1 | BEAD |
BEAD416 | BEAD/SMD/0603 | BLM18BD252SN1 | BEAD |
CON402 | BBL1MM0.23MMW0.4MMPH10PIN | | OV7645FB_3 |
CON403 | J301T05GAGZL2 | | CXJC-PJ2_1 |
CON803 | BBL1MM0.23MMW0.4MMPH30PIN-Z | | OV7645FB_13 |
CON804 | BBL1MM0.23MMW0.4MMPH24PIN | | SUB_CAM |
CON807 | H3/SMD/P1.25/1.25A-WTT-3P/ZHENGHE | | OV7645FB_13_2 |
CON904 | LCD_40_0.5P_2.8H_HJ080NA-04F | IPEX-20455-040E | IPEX-20455-040E_4 |
CON1001 | MM8430-2600B | MM8430-2610B | CAR_KIT_/_MM8430-2610B |
CON1102 | ZIF_H51/SMD/P0.3-Z | AXT340124 | 33PIN_2 |
CON1402 | CAF11-08173-1514/9PIN/1.7H | | MMC_CONN_0 |
CON1713 | CON20X2/SMD/M/AXT440124 | AXT440124 | HEADER_1 |
D4 | RB551V-30(UMD2) | RB551V-30 | DIODE_SCHOTTKY_6 |
D6 | RCLAMP0524P/10P/SMD | | RCLAMP0524P |
D7 | RCLAMP0524P/10P/SMD | | RCLAMP0524P |
D8 | ESD0603/SMD | | DIODE_DIAC |
D9 | ESD0603/SMD | | DIODE_DIAC |
D11 | SOT23 | | BAT54S |
D12 | SOT23 | | BAT54S |
D13 | 5819 | | DIODE_SCHOTTKY_2 |
D300 | RB551V-30(UMD2) | | DIODE_SCHOTTKY_6 |
D303 | DIODE/SMD/MMSZ5221B | MMSZ5231BT1G | DIODE/ZENER |
D401 | SOD923/SMD | | PG05BSESC_0 |
D402 | D/SMD/UMD2 | | DIODE_SCHOTTKY_0 |
D1602 | SOD-323/SMD/RB551V-30 | RB551V-30 | DIODE_SCHOTTKY_6 |
EMI801 | FILTER/SMD/ICVE10184E150R101FR | ICVE10184E070R100FR | EMIX21A390FNPE_0 |
EMI802 | FILTER/SMD/ICVE10184E150R101FR | ICVE10184E070R100FR | EMIX21A390FNPE_0 |
EMI803 | FILTER/SMD/ICVE10184E150R101FR | ICVE10184E070R100FR | EMIX21A390FNPE_0 |
EMI804 | FILTER/SMD/ICVE10184E150R101FR | ICVE10184E070R100FR | EMIX21A390FNPE_0 |
F201 | DIPLEXER/6P/SMD/DP1608 | | BL1608-05K2450_0 |
GND1 | TP/SMD/D0.6 | TEST POINT | TEST_POINT_DIP0.6 |
GND2 | TP/SMD/D0.6 | TEST POINT | TEST_POINT_DIP0.6 |
J300 | HDMI/SMD/CON/A | HDMI TYPE-A | PORT_HDMI_TYPE-A |
J301 | MICROHDMI/19P/SMD/ATOMO10130010031 | HDMI TYPE-A | PORT_HDMI_TYPE-A |
L4 | L/IND/SMD/LVS252010-2R2 | | INDUCTOR |
L212 | BEAD/SMD/0603 | BLM18PG221SH1 | INDUCTOR |
L213 | BEAD/SMD/0603 | BLM18PG221SH1 | INDUCTOR |
L214 | BEAD/SMD/0402 | | INDUCTOR |
L305 | L/IND/SMD/2520 | | INDUCTOR |
L308 | L/IND/SMD/2520 | 2.2uH | INDUCTOR |
L309 | L/IND/SMD/2520 | 2.2uH | INDUCTOR |
L313 | L/IND/SMD/2520 | | INDUCTOR |
L402 | BEAD/SMD/0603 | | BEAD |
L802 | L/IND/SMD/LVS-S3016 | | INDUCTOR_1 |
L1005 | L0402 | L / NC / nH / 0402 | L_/_39_/_NH_/_0402 |
L1006 | L0402 | | L_/_27_/_NH_/_0201 |
L1008 | L0402 | 5.6nH | L_/_8.2_/_NH_/_0402 |
L1009 | L0402 | | INDUCTOR_3 |
L1201 | L/IND/SMD/0603 | FB | FERRITE_BEAD_SMD_0402 |
L1202 | L/IND/SMD/0603 | FB | FERRITE_BEAD_SMD_0402 |
L1203 | L/IND/SMD/LVS252010-2R2 | | INDUCTOR_1 |
L1601 | L/IND/SMD/LVS252010-2R2 | | INDUCTOR |
LED304 | LED/4P/SMD/19-237A | | DIODE_10 |
Q1602 | SOT23 | | TRANSISTOR_NPN_SMD(B-C-E)_0 |
SW1201 | KEY_RESET | POWER | KEY_1 |
SW1302 | DSWD | POWER | KEY_0 |
SW1303 | DSWD | POWER | KEY_0 |
SW1306 | DSWD | POWER | KEY_0 |
U1 | SOT23/5P/SMD | | R1172X_1 |
U2 | MT6627-NS/MQFN40/SMD/P0.4/5X5 | MT6627_IPD | MT6611_SMD_WLCSP-61_0 |
U3 | SOT23/5P/SMD | | R1172X_1 |
U5 | FBGA96/SMD/P0.8/10X14/DDR3L/16B | IC DDR3 x16 FBGA-96 | IC_DDR3_X16_FBGA-96 |
U6 | FBGA96/SMD/P0.8/10X14/DDR3L/16B | IC DDR3 x16 FBGA-96 | IC_DDR3_X16_FBGA-96 |
U12 | SOT23-6/SMD | | APL5151_0 |
U13 | SOT23-6/SMD | | SY7208_2 |
U17 | DFN8/SMD/P1.0/OTS0800D | | EPC1_0 |
U22 | TSOP48/SMD | | AM29PL160C_3 |
U201 | MT8127/TFBGA393/P0.5/B0.27/12.1X12.6 | | MT8127E1_DDR316_0916_RMNC |
U301 | SOT-6 | STT818B | FDG6303_2 |
U302 | MT6323L/TFBGA158/P0.5/B0.27/7.6X7.6 | MT6323 | MT6323_E1_4 |
U303 | 2-1L1B/SMD/SSM3K35MFV | SSM3K35MFV | MOSFET_N_2 |
U406 | SOT23-6/SMD | | TEA1206T_0 |
U502 | BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA | | 169_BALL_EMMC |
U901 | FILTER_EXC24CE_1 | | FILTER_EXC24CE_2 |
U906 | FILTER_EXC24CE_1 | | FILTER_EXC24CE_3 |
U907 | FILTER_EXC24CE_1 | | FILTER_EXC24CE_4 |
U909 | FILTER_EXC24CE_1 | | FILTER_EXC24CE_5 |
U911 | FILTER_EXC24CE_1 | | FILTER_EXC24CE_6 |
U1005 | TCXO/SMD/2.5X2.0/IT2205BE | ?MHz | TCXO_RAKON_SMD_4P_3 |
U1006 | SAW/SMD/1.05X1.35 | SAFEB1G57KE0F00 | SAFEB1G57KA0F00 |
U1010 | TSLP6/SMD/P0.4/BGA725L6/S | INFINEON_BGA725L6 | NJG1107HB3_0 |
U1101 | QFN52/SMD/P0.4/GT911/S | GT911 | GT800_0 |
U1201 | MT6605/MQFN32/SMD/P0.4/4X4/S | ????? | MT3301-140_SMD_PBGA-140_0 |
U1208 | HALL_IC_AH1883 | | HALL_IC_AH1883 |
U1601 | SOT23-6/SMD | | SY7208_2 |
U1602 | WLCSP8/SMD/P0.4/B0.25/AK09911_ | | ADXL345_4 |
U1604 | LGA12/SMD/P0.5/BMA250E | | ADXL345_5 |
U1607 | ALS_APDS9930 | | CM3623_2 |
U1609 | QFN24/SMD/P0.4/MPU-6880_ | MPU-3050 | 74ALVC74PW_2 |
U1901 | DSBGA4/SMD/P0.4/B0.25/TMP103 | TMP103AYFFT | TMP103AYFFT |
U1902 | WLCSP6/SMD/P0.4/B0.23/NB3L03 | | TMP103AYFFT_0 |
U1905 | SOT23-5 | | LED_DRIVER_SY8006 |
VBAT1 | TP/SMD/D0.6 | TEST POINT | TEST_POINT_DIP0.6 |
VIB_GND1 | ANT-1.5-2.5 | TEST POINT | TEST_POINT_DIP0_4.6 |
VIB_POWER1 | ANT-1.5-2.5 | TEST POINT | TEST_POINT_DIP0_4.6 |
ANT | PAD_3PIN | | CAR_KIT_/_MM8430-2610B_0 |
X302 | CRYS/SMD/MS3V-T1R | 32K (MS3V-T1R) | CRYSTAL_1 |
X601 | TCXO/SMD/2.5X2.0/IT2205BE | ?MHz | TCXO_RAKON_SMD_4P_3 |
X1201 | CRYS/SMD/FA-128 | QUARTZ 27.12 Mhz | QUARTZ_IQX0_1 |
