查看: 26348|回复: 78
[Allegro16.6以下] 华硕I7笔记本电脑主板PCB文件共享下载 8层PCB设计
    17万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2017-2-21 14:19:55 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    板子有以下主要元件。
    D2505DIODE_NBS_SOD323_2P_006_DISCRET1N4148WSNBS_SOD323_2P_006
    D2802DUAL_DIODE_3CATHODE_NBS_SOT323_BAT54CWNBS_SOT323_3P_000
    D3101AZ1015_04SR7F_NBS_SOT23_6P_005_TVLST2304AD0NBS_SOT23_6P_005
    D3204DIODE_NBS_SOD323_2P_006_DISCRET1N4148WSNBS_SOD323_2P_006
    D3401IP4223_CZ6_NBS_SOT457_6P_000_DIIP4223-CZ6NBS_SOT457_6P_000
    D3402IP4223_CZ6_NBS_SOT457_6P_000_DIIP4223-CZ6NBS_SOT457_6P_000
    D3723VPORT0603_VARISTOR_0402_H24_DISVPORT0402220MV05VARISTOR_0402_H24
    D3725VPORT0603_NBS_VARISTOR_2P_002_D331KNBS_VARISTOR_2P_002
    D4501BAT54AW_NBS_SOT323_3P_000_DISCRBAT54AWNBS_SOT323_3P_000
    D4502AZ1015_04SR7F_NBS_SOT23_6P_005_TVLST2304AD0NBS_SOT23_6P_005
    D4701DIODE_NBS_SOD123_2P_001_DISCRETSS0540NBS_SOD123_2P_001
    D5401AZ1015_04SR7F_NBS_SOT23_6P_005_TVLST2304AD0NBS_SOT23_6P_005
    D5601VPORT_0603_NBS_DIODE_2P_000_DISEGA10603V05A1NBS_DIODE_2P_000
    D5801BAT54AW_NBS_SOT323_3P_000_DISCRBAT54AWNBS_SOT323_3P_000
    D5805SCHOTTKY_BAT54C_NBS_SOT523_3P_0BAT54CTBNBS_SOT523_3P_000
    D6703AZ1015_04SR7F_NBS_SOT23_6P_007_AZC099-04SPNBS_SOT23_6P_007
    D7701DIODE_NBS_SOD323_2P_006_DISCRET1N4148WSNBS_SOD323_2P_006
    D7702DUAL_DIODE_3CATHODE_NBS_SOT323_BAT54CWNBS_SOT323_3P_000
    D7773VPORT_0603_NBS_ESD_2P_001_AZ572AZ5725-01FNBS_ESD_2P_001
    H5301SCREWHOLE_SMT_NBS_NUT_1P_133_CTCT217BI158D138NBS_NUT_1P_133
    H6501HOLE_PTH_NBS_H_111_1338_CRT276XCRT276X354B276D98NBS_H_111_1338
    H6502HOLE_PTH_NBS_H_111_0782_C276D98C276D98NBS_H_111_0782
    H6505HOLE_PTH_NBS_H_111_1232_ST315CRST315CRB938X625D110NBS_H_111_1232
    H6506HOLE_PTH_NBS_H_111_1230_S315D94S315D94NBS_H_111_1230
    H6507HOLE_PTH_NBS_H_111_1240_ST276X3ST276X315CB276D94NBS_H_111_1240
    H6508SCREWHOLE_PTH_6NPTH_NBS_H_117_07D_D94_6D39NNBS_H_117_0001
    H6509HOLE_PTH_NBS_H_111_1228_ST315CBST315CB276D94NBS_H_111_1228
    H6517HOLE_NPTH_HOLE_O138X98DO138X98NO138x98DO138x98NHOLE_O138X98DO138X98N
    H6518HOLE_NPTH_HOLE_C98D98N_C98D98NC98D98NHOLE_C98D98N
    H6519HOLE_PTH_NBS_H_111_1241_R315X31R315X315D94NBS_H_111_1241
    H6521HOLE_NPTH_HOLE_C67D67N_C67D67NC67D67NHOLE_C67D67N
    H6531SCREWHOLE_SMT_NBS_NUT_1P_129_CTCT217CB176D146NBS_NUT_1P_129
    H6540HOLE_PTH_NBS_H_111_1238_CRT402XCRT402X374CB276D98NBS_H_111_1238
    H6541HOLE_PTH_NBS_H_111_1234_CT315CBCT315CB138D118NBS_H_111_1234
    H6542HOLE_NPTH_NBS_H_121_0175_O98X17O98X177DO98X177NNBS_H_121_0175
    H6543HOLE_PTH_NBS_H_111_0782_C276D98C276D98NBS_H_111_0782
    J1701DDR4_DIMM_260P_4HOLD_NBS_DDR4_DDDR4_DIMM_260PNBS_DDR4_DIMM_260P_005C
    J3101FPC_CON_24P_2HOLD_SUN_NBS_FPC_2FPC_CON_24PNBS_FPC_24P_008C
    J3102FPC_CON_8P_2HOLD_MOLEX_NBS_FPC_FPC_CON_8PNBS_FPC_8P_002C
    J3401LAN_JACK_8P_4HD_FOXCONN_NBS_U_LLAN_JACK_8PNBS_U_LAN_JACK_8P_019
    J3712AUDIO_JACK_6P_SAN_NBS_U_AUDIO_JAUDIO_JACK_6PNBS_U_AUDIO_JACK_6P_040
    J4201SD_SOCKET_9P_6HD_NBS_SD_SOCKET_SD_SOCKET_9PNBS_SD_SOCKET_9P_010
    J4501WTOB_CON_40P_4HD_NBS_WTOB_40P_0WTOB_CON_40PNBS_WTOB_40P_006C
    J4701D_SUB_15P_2HOLD_SUYI_NBS_U_D_SUD_SUB_15PNBS_U_D_SUB_15P_015
    J4801HDMI_CON_19P_4HOLD_MOLEX_NBS_U_HDMI_CON_19PNBS_U_HDMI_19P_031
    J5001FPC_4P_2HOLD_NBS_WTOB_4P_000C_IWtoB_CON_4PNBS_WTOB_4P_000C
    J5201USB_9P_4HOLD_KORTAK_NBS_U_USB_9USB_CON_9PNBS_U_USB_9P_024
    J5301MINI_PCI_75P_REMOVE8_4HD_NBS_MIMINI_PCI_75PNBS_MINI_PCI_75P_006C
    J5401USB_CON_24P_8HOLD_NBS_USB_24P_0USB_CON_24PNBS_USB_24P_012
    J5602AH180_FJG_7_NBS_SOT23_3P_003__YYB8248ST23NBS_SOT23_3P_003
    J6001DC_PWR_JACK_9P_NBS_U_DC_PWR_JACDC_PWR_JACK_9PNBS_U_DC_PWR_JACK_9P_004
    J6003BATT_CON_8P_2HOLD_SUYIN_NBS_BATBATT_CON_8PNBS_BATT_8P_000
    J6701USB_CON_1X4P_4HD_SU_NBS_U_USB_4USB_CON_4PNBS_U_USB_4P_019
    J6702ZIF_CON_30P_2HOLD_NBS_FPC_30P_0FPC_CON_30PNBS_FPC_30P_005C
    J6801BTOB_CON_60P_6HOLD_AECS_NBS_BTOBTOB_CON_60PNBS_BTOB_60P_026
    JDEBUG1FPC_CON_12P_2HOLD_KEC_NBS_FPC_1FPC_12PNBS_FPC_12P_006C
    JP33013MMO_S_NBS_1MM_OPEN_5MIL_000_1M1MM_OPEN_5MILNBS_1MM_OPEN_5MIL_000
    JP48043MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PT
    JRST24023MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PT
    L3301INDUCTOR_NBS_CHOKE_2P_000_DISCR4.7UHNBS_CHOKE_2P_000
    L3401COMMON_CHOKE_12_43_NBS_CHOKE_4P90Ohm/100MhzNBS_CHOKE_4P_011C
    L3709SL_0402_NBS_R0402_SHORTED_000S_SHORT_LANDNBS_R0402_SHORTED_000S
    L4509COMMON_CHOKE_12_43_NBS_CHOKE_4P90Ohm/100MhzNBS_CHOKE_4P_011C
    L4701INDUCTOR_NBS_INDUCTOR_2P_020_DI0.12UHNBS_INDUCTOR_2P_020
    L4702INDUCTOR_NBS_INDUCTOR_2P_020_DI0.12UHNBS_INDUCTOR_2P_020
    L4703INDUCTOR_NBS_INDUCTOR_2P_020_DI0.12UHNBS_INDUCTOR_2P_020
    L4801COMMON_CHOKE_12_43_NBS_CHOKE_4P90Ohm/100MhzNBS_CHOKE_4P_011C
    L5302BEAD_NBS_L0603_H37_000S_120OHM120OhmNBS_L0603_H37_000S
    L6701COMMON_CHOKE_12_43_NBS_CHOKE_4P90Ohm/100MhzNBS_CHOKE_4P_011C
    LED5609LED_4P_O&G_NBS_LED_4P_003_WHITEWHITE&ORANGENBS_LED_4P_003
    PD6001AZ1015_04SR7F_NBS_SOT23_6P_007_AZC099-04SPNBS_SOT23_6P_007
    PJP9102SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PT
    PJP93003MMO_S_NBS_1MM_OPEN_5MIL_000_1M1MM_OPEN_5MILNBS_1MM_OPEN_5MIL_000
    PQ8102NTMFS4955NT1G_NBS_POWERPAK_3P_0QM3054M6NBS_POWERPAK_3P_001C
    PQ8704PH8230E_NBS_POWERPAK_5P_011_QM1QM1830M3NBS_POWERPAK_5P_011
    PQ8705UM6K1N_NB_NBS_SOT666_6P_000_EM6EM6K1-G-T2RNBS_SOT666_6P_000
    PQ8801PH8230E_NBS_POWERPAK_5P_011_QM1QM1830M3NBS_POWERPAK_5P_011
    PQ8802NB_NPN_SOT23_NBS_SOT23_3P_001_DPMBS3904NBS_SOT23_3P_001
    PQ8803UM6K1N_NB_NBS_SOT666_6P_000_EM6EM6K1-G-T2RNBS_SOT666_6P_000
    PQ8804UM6K1N_NB_NBS_SOT666_6P_000_EM6EM6K1-G-T2RNBS_SOT666_6P_000
    PQ8805PE532DY_NBS_DFN_6P_021_PEA32DYPEA32DYNBS_DFN_6P_021
    PQ8807PUMD12_NBS_SOT363_6P_000_DISCREPUMD12NBS_SOT363_6P_000
    PQ8810PUMD12_NBS_SOT363_6P_000_DISCREPUMD12NBS_SOT363_6P_000
    PQ8811PE532DY_NBS_DFN_6P_021_PEA32DYPEA32DYNBS_DFN_6P_021
    PQ8812NB_NPN_SOT23_NBS_SOT23_3P_001_DPMBS3904NBS_SOT23_3P_001
    PQ8813PH8230E_NBS_POWERPAK_5P_011_QM1QM1830M3NBS_POWERPAK_5P_011
    PQ8814PMPB20EN_NBS_SOT1220_8P_000C_RFRF4E080BNTBNBS_SOT1220_8P_000C
    PQ8850UM6K1N_NB_NBS_SOT666_6P_000_EM6EM6K1-G-T2RNBS_SOT666_6P_000
    PQ8901UM6K1N_NB_NBS_SOT666_6P_000_EM6EM6K1-G-T2RNBS_SOT666_6P_000
    PQ8902PH8230E_NBS_POWERPAK_5P_011_QM1QM1830M3NBS_POWERPAK_5P_011
    PQ8903PH8230E_NBS_POWERPAK_5P_011_QM0QM0930M3NBS_POWERPAK_5P_011
    PQ8904UM6K1N_NB_NBS_SOT666_6P_000_EM6EM6K1-G-T2RNBS_SOT666_6P_000
    PQ8905PH8230E_NBS_POWERPAK_5P_011_QM1QM1830M3NBS_POWERPAK_5P_011
    PQ8906PH8230E_NBS_POWERPAK_5P_011_QM3QM3016M3NBS_POWERPAK_5P_011
    PQ8907PH8230E_NBS_POWERPAK_5P_011_QM0QM0930M3NBS_POWERPAK_5P_011
    PQ8908UM6K1N_NB_NBS_SOT666_6P_000_EM6EM6K1-G-T2RNBS_SOT666_6P_000
    PQ9001UM6K1N_NB_NBS_SOT363_6P_001_DISUM6K1NNBS_SOT363_6P_001
    PQ9100NTMFS4955NT1G_NBS_POWERPAK_3P_0QM3054M6NBS_POWERPAK_3P_001C
    PQL9301PH8230E_NBS_POWERPAK_5P_011_PEAPEA16BANBS_POWERPAK_5P_011
    PU8001ATK1501BC_4VIA_NBS_QFN_52P_4V_0ATK1501BCGQWNBS_QFN_52P_4V_002
    PU8301EM5106VT_2VIA_NBS_DFN_10P_2V_00UP0132PDDANBS_DFN_10P_2V_007
    PU8701RT8249CGQW_2VIA_NBS_QFN_20P_2V_RT8249CGQWNBS_QFN_20P_2V_000
    PU8803APL3533QBI_TRG_NBS_DFN_14P_002_APL3533QBI-TRGNBS_DFN_14P_002
    PU8806APL3527AHAI_TRG_NBS_BGA_6P_018_APL3527SAHAI-TRGNBS_BGA_6P_018
    PU8901SN2867RUYR_4VIA_NBS_QFN_28P_4V_SN2867RUYRNBS_QFN_28P_4V_006
    PU9000UP1905AMA8_NBS_SOT23_8P_000_IC_UP1905AMA8NBS_SOT23_8P_000
    PU9100UP1658P_2VIA_NBS_QFN_20P_2V_000UP9013QQKFNBS_QFN_20P_2V_000
    PU9300UP9002PQKF_2VIA_NBS_QFN_20P_2V_UP9002PQKFNBS_QFN_20P_2V_000
    Q0501UM6K1N_NB_NBS_SOT666_6P_000_EM6EM6K1-G-T2RNBS_SOT666_6P_000
    Q2180UM6K1N_NB_NBS_SOT363_6P_001_DISUM6K1NNBS_SOT363_6P_001
    Q2201UM6K1N_NB_NBS_SOT666_6P_000_EM6EM6K1-G-T2RNBS_SOT666_6P_000
    Q24012N7002K_PANJIT_NBS_SOT23_3P_0072N7002KNBS_SOT23_3P_007
    Q2802UM6K1N_NB_NBS_SOT363_6P_001_DISUM6K1NNBS_SOT363_6P_001
    Q2804UM6K1N_NB_NBS_SOT363_6P_001_DISUM6K1NNBS_SOT363_6P_001
    Q3202UM6K1N_NB_NBS_SOT666_6P_000_EM6EM6K1-G-T2RNBS_SOT666_6P_000
    Q3314PH8230E_NBS_POWERPAK_5P_011_QM1QM1830M3NBS_POWERPAK_5P_011
    Q4501P_MOS_TO252_NBS_SOT89_3P_000_DIP06P03LCGNBS_SOT89_3P_000
    Q4701UM6K1N_NB_NBS_SOT363_6P_001_D_1UM6K31NNBS_SOT363_6P_001
    Q48012N7002K_PANJIT_NBS_SOT23_3P_0072N7002KNBS_SOT23_3P_007
    Q4802N_MOS_SOT23_NBS_SOT23_3P_018_SISI2304DDS-T1-GE3NBS_SOT23_3P_018
    Q48042N7002K_PANJIT_NBS_SOT23_3P_0072N7002KNBS_SOT23_3P_007
    Q4807UM6K1N_NB_NBS_SOT363_6P_001_D_1UM6K31NNBS_SOT363_6P_001
    Q5101PH8230E_NBS_POWERPAK_5P_011_QM1QM1830M3NBS_POWERPAK_5P_011
    Q5102UM6K1N_NB_NBS_SOT363_6P_001_D_1UM6K31NNBS_SOT363_6P_001
    Q53012N7002K_PHILIPS_NBS_SOT23_3P_002N7002KNBS_SOT23_3P_007
    Q7710UM6K1N_NB_NBS_SOT666_6P_000_EM6EM6K1-G-T2RNBS_SOT666_6P_000
    Q7711PH8230E_NBS_POWERPAK_5P_011_QM1QM1830M3NBS_POWERPAK_5P_011
    U0301SKL_ULT_NBS_BGA_1356P_000_SKL-USKL-ULTNBS_BGA_1356P_000
    U040174LVC1G07GW_NBS_SOT353_5P_001_I74AUP1G07GWNBS_SOT353_5P_001
    U1401MT40A512M8HX_093E_NBS_BGA_78P_0MT40A512M8HX-093ENBS_BGA_78P_006C
    U2502HD74ALVC1G08_NBS_SOT353_5P_001_74LVC1G08GWNBS_SOT353_5P_001
    U2802W25Q16BVSSIG_NBS_SOIC_8P_026_ICW25Q64FVSSIQNBS_SOIC_8P_026
    U3301RTL8111G_CG_VIA_NBS_QFN_32P_1V_RTL8111GUX-CGNBS_QFN_32P_1V_009
    U3401N_1020G_NBS_TRANS_25P_000_N-102N-1020GNBS_TRANS_25P_000
    U4203RTS5129_GR_VIA_NBS_QFN_24P_1V_0RTS5170-GRNBS_QFN_24P_1V_011
    U4503NCT3527U_NBS_SOT23_6P_007_IC_NCNCT3527UNBS_SOT23_6P_007
    U4510NC7SZ08M5_NBS_SOT23_5P_004_IC_NNC7SZ08P5XNBS_SOT23_5P_004
    U4701RTD2168_CG_VIA_NBS_QFN_32P_1V_0RTD2168-VAS-CGNBS_QFN_32P_1V_007
    U4802AZ1045_04F_NBS_DFN_9P_000C_DISCAZ1045-04FNBS_DFN_9P_000C
    U4803AZ1045_04F_NBS_DFN_9P_000C_DISCAZ1045-04FNBS_DFN_9P_000C
    U5001NCT7717U_NBS_SOT23_5P_003_NCT77NCT7717UNBS_SOT23_5P_003
    U5204AZ1045_04F_NBS_DFN_9P_000C_DISCAZ1045-04FNBS_DFN_9P_000C
    U5255G547B2P1U_NBS_SOIC_8P_013_IC_G5G547F1P81UNBS_SOIC_8P_013
    U5401G547B2P1U_NBS_SOIC_8P_029_BD820BD82034FVJ-E2NBS_SOIC_8P_029
    U5402LM358MX_NBS_SOIC_8P_017_IC_LM35LM358MXNBS_SOIC_8P_017
    U5405L15ESDL5V0NA_4_NBS_ESD_10P_000_TVWDF1004AD0NBS_ESD_10P_000
    U5406L15ESDL5V0NA_4_NBS_ESD_10P_000_TVWDF1004AD0NBS_ESD_10P_000
    U5410SN1507044RVCR_VIA_NBS_QFN_20P_1SN1507044RVCRNBS_QFN_20P_1V_014
    U6501ANT_PAD_RD9_NBS_SMDPAD_1P_243_SSMD260X162NBS_SMDPAD_1P_243
    U6504ANT_PAD_RD9_NBS_SMDPAD_1P_266_SSMD138X394NBS_SMDPAD_1P_266
    U6505ANT_PAD_RD9_NBS_SMDPAD_1P_267_SSMD138X591NBS_SMDPAD_1P_267
    U6506ANT_PAD_RD9_NBS_SMDPAD_1P_456_SSMD472X158NBS_SMDPAD_1P_456
    U6710G547B2P1U_NBS_SOIC_8P_013_IC_G5G547F1P81UNBS_SOIC_8P_013
    U7001N14M_GE_S_A1_NBS_BGA_595P_000_NN14M_GE_S_A1NBS_BGA_595P_000
    U7002NC7SZ08M5_NBS_SOT23_5P_004_IC_NNC7SZ08P5XNBS_SOT23_5P_004
    U7201MT41J128M16JT_093G_NBS_BGA_96P_MT41J256M16HA-093G:ENBS_BGA_96P_011C
    U7602NC7SZ08M5_NBS_SOT23_5P_004_IC_NNC7SZ08P5XNBS_SOT23_5P_004
    U7708IT8995E_AX_NBS_QFP_128P_002_IT8IT8995E/CX-S001NBS_QFP_128P_002
    X2401CRYSTAL_SMD_24GND_NBS_XTAL_4P_024MHZNBS_XTAL_4P_015
    X2402CRYSTAL_NBS_XTAL_2P_002_32.768K32.768KHZNBS_XTAL_2P_002
    X3301CRYSTAL_SMD_24GND_NBS_XTAL_4P_125.00MHZNBS_XTAL_4P_016
    X4701CRYSTAL_SMD_24GND_NBS_XTAL_4P_227MhzNBS_XTAL_4P_001
    X7501CRYSTAL_SMD_24GND_NBS_XTAL_4P_327MHZNBS_XTAL_4P_016
    重要提示:PCB作品文件展下载说明
    17万
    管理员
     楼主| 发表于 2017-2-21 14:30:17 | 显示全部楼层
    日期还算比较新。  其实这资料已经在我手上很久了。春节前就已经发了很多电脑主板 PCB文件。。 但是由于这段时间,论坛上很多资料被其他网站偷过去了,大家有目共睹,就不点名说了。。 所以这段时间我自己很少更新论坛资料。  论坛上很多资料,我都是花很大的代价才弄到的。 有很多都是直接花钱买来共享给大家的。。 但是被一些网站直接就搬走了。。哎。。。不想说啥了。。公道自在人心吧。。抄袭永远得不到尊重。
    未来防止被搬走只能设置RMB  1个。 有用的1元不贵。没用的看看图片就好。
    I7_PC_BRD.7z (7.78 MB, 下载次数: 121)
    前天 13:27
  • 签到天数: 89 天
    1元学习Allegro(1期)
    发表于 2017-2-21 14:49:32 | 显示全部楼层
    支持老吴!没有原理图啊?
    终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2017-2-21 14:53:57 | 显示全部楼层
       非常 支持版主,鄙视其他 网站偷窃
    17万
    管理员
     楼主| 发表于 2017-2-21 14:56:16 | 显示全部楼层
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2017-2-21 19:19:05 | 显示全部楼层
    终身成就奖社区居民忠实会员
    发表于 2017-2-21 19:56:05 | 显示全部楼层
    楼主好资料真是多多啊。
    发表于 2017-2-21 20:44:07 | 显示全部楼层
    大部分人都是下载之后就丢在一边的
    发表于 2017-2-21 22:05:00 | 显示全部楼层
    社区居民忠实会员社区劳模最爱沙发终身成就奖优秀斑竹奖
    发表于 2017-2-21 22:08:53 | 显示全部楼层
