REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
C1 | CAP_INDC_0402CS_1.0PF | 1.0pF | INDC_0402CS |
C2 | CAP_CC0402_10PF | 10pF | CC0402 |
C3 | CAP_CC0402_6.2PF | 6.2pF | CC0402 |
C4 | CAP_CC0402_6.2PF | 6.2pF | CC0402 |
C5 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C6 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C7 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C8 | C_CC0603_10UF | 10uF | CC0603 |
C9 | CAP_CC0402_1.0UF | 1.0uF | CC0402 |
C10 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C11 | C_CC0402_4.7UF | 4.7uF | CC0402 |
C12 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C13 | C_CC0402_4.7UF | 4.7uF | CC0402 |
C14 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C15 | C_CC0603_22UF | 22uF | CC0603 |
C16 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C17 | C_CC0603_22UF | 22uF | CC0603 |
C18 | C_CC0402_4.7UF | 4.7uF | CC0402 |
C19 | C_CC0603_10UF | 10uF | CC0603 |
C20 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C21 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C22 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C23 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C24 | C_CC0603_10UF | 10uF | CC0603 |
C25 | C_CC0402_10PF | 10pF | CC0402 |
C26 | C_CC0402_10PF | 10pF | CC0402 |
C27 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C28 | CAP_CC0805_10UF | 10uF | CC0805 |
C29 | CAP_CC0402_15PF | 15pF | CC0402 |
C30 | CAP_TANT_1206_100UF | 100uF | TANT_1206 |
C31 | CAP_CC0805_10UF | 10uF | CC0805 |
C32 | CAP_TANT_1206_100UF | 100uF | TANT_1206 |
D1 | LED_LED_0603_LED | LED | LED_0603 |
D2 | DIODE_DIO_CD0603-S0180R_CUS_CD0 | CD0603-B00340 | DIO_CD0603-S0180R_CUS |
D3 | MBR130_SOD-123_2P_SOD_123FL_ | | SOD_123FL |
D4 | MBR130_SOD-123_2P_SOD_123FL_ | | SOD_123FL |
D5 | LED_LED_0603_ | | LED_0603 |
D6 | LED_LED_0603_LED | LED | LED_0603 |
E1 | CHIP_ANTENNA_2T_ANT_AH316M_2.45 | 2.45GHz Ant | ANT_AH316M |
FL1 | TDK_FILTER_DEA20_FIL_DEA202450B | 2.4GHz Filter | FIL_DEA202450BT-1294C1 |
J2 | CONN_UFL_3P_EMERSON_128-0711-20 | CONN_U.FL | EMERSON_128-0711-201 |
J3 | CONN_COAX_MURATA_4P_CON_RF_MM80 | RF SWITCH | CON_RF_MM8030-2600B |
J4 | HEADER_3X2_FCI_20021111-00006T4 | HEADER_3X2 | FCI_20021111-00006T4LF |
J5 | HEADER_1X2_HDR_THVT_1X2_100_M_H | HEADER_2 | HDR_THVT_1X2_100_M |
J6 | HEADER_1X2_HDR_THVT_1X2_100_M_H | HEADER_2 | HDR_THVT_1X2_100_M |
J7 | CONN_MICRO_USB_5P_6G_FCI_101181 | CONN_MICRO_USB | FCI_10118194-0001 |
J8 | HEADER_3_HDR_THVT_1X3_100_M_HEA | HEADER_3 | HDR_THVT_1X3_100_M |
J9 | CONN_RCPT_0_HDR_THVT_2X10_100_F | CONN_RCPT_10x2 | HDR_THVT_2X10_100_F |
J10 | CONN_RCPT_0_HDR_THVT_2X10_100_F | CONN_RCPT_10x2 | HDR_THVT_2X10_100_F |
J11 | HEADER_1_HDR_THVT_1X1_100_M_TP_ | TP_THRU | HDR_THVT_1X1_100_M |
J12 | HEADER_1_HDR_THVT_1X1_100_M_TP_ | TP_THRU | HDR_THVT_1X1_100_M |
J13 | HEADER_1_HDR_THVT_1X1_100_M_TP_ | TP_THRU | HDR_THVT_1X1_100_M |
J14 | HEADER_1_HDR_THVT_1X1_100_M_TP_ | TP_THRU | HDR_THVT_1X1_100_M |
L1 | INDUCTOR_CC0402_3.6NH | 3.6nH | CC0402 |
L2 | INDUCTOR_INDC_0402CS_5.6NH | 5.6nH | INDC_0402CS |
L3 | INDUCTOR_INDC2520X100N_MM_2.2UH | 2.2uH | INDC2520X100N_MM |
L4 | INDUCTOR_IND_CB2518_MM_1UH | 1uH | IND_CB2518_MM |
L5 | INDUCTOR_INDC2520X100N_MM_2.2UH | 2.2uH | INDC2520X100N_MM |
L7 | BEAD_FERRITE_INDC0805_BEAD_FERR | BEAD_FERRITE | INDC0805 |
L8 | BEAD_FERRITE_INDC0805_BEAD_FERR | BEAD_FERRITE | INDC0805 |
Q1 | MOSFET_I_EN_GSD_SOT_23_321_BSS1 | BSS138LT3G | SOT_23_321 |
Q2 | MOSFET_I_EN_GSD_SOT_23_321_BSS1 | BSS138LT3G | SOT_23_321 |
R1 | RESISTOR_RC0603_270 | 270 | RC0603 |
R2 | RESISTOR_RC0402_10K | 10k | RC0402 |
R3 | RESISTOR_RC0402_100R | 100R | RC0402 |
R4 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R5 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R6 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R7 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R8 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R9 | RESISTOR_RC0402_100K | 100k | RC0402 |
R10 | RESISTOR_RC0402_10K | 10k | RC0402 |
R11 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R12 | RESISTOR_RC0402_10K | 10k | RC0402 |
R13 | RESISTOR_RC0402_3.3K | 3.3K | RC0402 |
R14 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R15 | RESISTOR_RC0402_1K | 1k | RC0402 |
R16 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R17 | RESISTOR_RC0402_100K | 100k | RC0402 |
R18 | RESISTOR_RC0402_100K | 100k | RC0402 |
R19 | RESISTOR_RC0402_10K | 10k | RC0402 |
R20 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R21 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R22 | R_RC0402_1K | 1k | RC0402 |
R23 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R24 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R25 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R26 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R27 | RESISTOR_RC0402_DNP | DNP | RC0402 |
R28 | RESISTOR_RC0402_100K | 100k | RC0402 |
R29 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R30 | RESISTOR_RC0402_DNP | DNP | RC0402 |
R31 | R_RC0402_33K | 33k | RC0402 |
R32 | RESISTOR_RC0402_DNP | DNP | RC0402 |
R33 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R34 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R35 | R_RC0603_0.1 | 0.1 | RC0603 |
R36 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R37 | RESISTOR_RC0402_DNP | DNP | RC0402 |
R38 | RESISTOR_RC0402_100K | 100k | RC0402 |
R39 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R40 | RESISTOR_RC0402_DNP | DNP | RC0402 |
R41 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R42 | RESISTOR_RC0805_0.1 R | 0.1 R | RC0805 |
R43 | RESISTOR_RC0402_30.1K | 30.1K | RC0402 |
R44 | RESISTOR_RC0402_1K | 1k | RC0402 |
R45 | RESISTOR_RC0402_51K | 51K | RC0402 |
R46 | R_RC0402_33K | 33k | RC0402 |
R47 | RESISTOR_RC0603_270 | 270 | RC0603 |
R48 | RESISTOR_RC0402_100R | 100R | RC0402 |
R49 | RESISTOR_RC0603_270 | 270 | RC0603 |
R50 | R_RC0603_0.1 | 0.1 | RC0603 |
R51 | R_RC0603_DNP | DNP | RC0603 |
SW1 | SW_TACT_SPST_SW_EVQ-11A05R_SWT | SW TACT | SW_EVQ-11A05R |
SW2 | SW_TACT_SPST_SW_EVQ-11A05R_SWT | SW TACT | SW_EVQ-11A05R |
SW3 | SW_TACT_SPST_SW_EVQ-11A05R_SWT | SW TACT | SW_EVQ-11A05R |
TP1 | TP_1206_TP_RCW1206_TP_1206 | TP_1206 | TP_RCW1206 |
U1 | FLASH_SOIC_8_197X157_50_8M(1M | 8M (1M x 8) | SOIC_8_197X157_50 |
U2 | FLASH_USON_PSON50P300X200X60-9N | 8M (1M x 8) | PSON50P300X200X60-9N |
U3 | CC3100_BP_V2_QFN50P900X900_64_P | CC3100 | QFN50P900X900_64_PWP_A_EINF |
U4 | TPS79601_SOT-223_6P_SOT_223_6_T | TPS79601 | SOT_223_6_TG |
Y1 | CRYSTAL_EPSON_FA20H_4P_XTAL_4_S | | XTAL_4_SM_104X83X20 |
Y2 | SG615/SM_XTAL_4_SM_104X83X20_32 | 32.768KHz | XTAL_4_SM_104X83X20 |
Y3 | CRYSTAL_XTAL_ABS07_CRYSTAL | Crystal | XTAL_ABS07 |
