查看: 6623|回复: 32
[PADS9.5以下] 展讯SC6531 智能手机PCB和原理图NMI601BAA+RTL8189ES+ATMXT112E
    17万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2017-4-8 23:47:34 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    NamePCB DecalValuePart Type
    ANT0401NC-PAD-RFANT-2X3NC-PAD-RFANT-2X3
    ANT0402NC-PAD-RFANT-2X3NC-PAD-RFANT-2X3
    ANT0403NC-PAD-RFANT-2X3NC-PAD-RFANT-2X3
    ANT7400NC-PAD-ATV-ANT-FP6530NC-PAD-ATV-ANT-FP6530
    ANT7401NC-PAD-ATV-ANT-FP6530NC-PAD-ATV-ANT-FP6530
    ANT7402NC-PAD-RFANT-2X3NC-PAD-RFANT-2X3
    D0300SOD-323-PRISEMIDIODE-ZENER-PZ3D4V2H
    D5200LED-LTE-C216R-14-1206LED-LTE-C216R-14-1206
    D6301LED-0603DIODE-LED-WHITE-0603
    D6302LED-0603DIODE-LED-WHITE-0603
    D7401TVS-RSBC6.8CSTVS-RSBC6.8CS
    FB3100SL04021000ohmBEAD-1000-OHM-100MHZ-0402
    FB3101SL04021000ohmBEAD-1000-OHM-100MHZ-0402
    FB3102SL04021000ohmBEAD-1000-OHM-100MHZ-0402
    FB3103SL04021000ohmBEAD-1000-OHM-100MHZ-0402
    FB3109SL0603-S600ohm@100MHz 500mABEAD-600-OHM-100MHZ-0603
    FB3110SL0603-S600ohm@100MHz 500mABEAD-600-OHM-100MHZ-0603
    FB3111SL0603-S600ohm@100MHz 500mABEAD-600-OHM-100MHZ-0603
    FB7102SL04021000ohm@100MHz(NF)BEAD-1K-OHM-100MHZ-250MA-0402
    FB7401SL0603-S600ohm@100MHz 500mABEAD-600-OHM-100MHZ-0603
    FB7402SL0603-S600ohm@100MHz 500mABEAD-600-OHM-100MHZ-0603
    FPC5100SENSOR-CAMERA-HQP-9652S(FRONT)SENSOR-CAMERA-HQP-9652S(FRONT)
    J3100CON-EAR-PJK-324S-WCON-EAR-PJK-324S-W
    J4100CON-FPC-FH26-25S-0.3SHW(05)CON-FPC-FH26-25S-0.3SHW(05)
    J4102CON-FPC-FH26-45S-0.3SHWCON-FPC-FH26-45S-0.3SHW
    J4104CON-FPC-AYF530635CON-FPC-AYF530635
    J5100CON-BTB-F-BAF04-24156-0502CON-BTB-F-BAF04-24156-0502
    J6100CON-BAT-AC0100-130CON-BAT-AC0100-130
    J6201CON-USB-MICRO-UAF95-05164-SF07CON-USB-MICRO-UAF95-05164-S107-A
    J6400SOCKET-SIM-CAF99-06183-SF17SOCKET-SIM-CAF99-06183-SF17
    J6401SOCKET-SIM-CAF99-06183-SF17SOCKET-SIM-CAF99-06183-SF17
    J6402SOCKET-SIM-CAF99-06183-SF17SOCKET-SIM-CAF99-06183-SF17
    J6500SOCKET-CARD-T-FLASH-CAF11-08373-S107SOCKET-CARD-T-FLASH-CAF11-08373-S107
    J7200CON-SPRING-PGC1.5-4.5-R-2P-3.0PHCON-SPRING-PGC1.5-4.5-R-2P-3.0PH
    J7300CON-SPRING-PGC1.5-4.5-R-2P-3.0PHCON-SPRING-PGC1.5-4.5-R-2P-3.0PH
    JS0322CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    L0210SL040239nHIND-CER-39NH-0402
    L0300SL0805-S2.2uHIND-POWER-CER-2.2UH-0805
    L0301SL0402600ohm@100MHZ 450mABEAD-600-OHM-100MHZ-0.45A-0402
    L0400SL04023.3nHIND-CER-3.3NH-0402
    L0401SL04022.7nHIND-CER-2.7NH-0402
    L0402SL04023.3nHIND-CER-3.3NH-0402
    L0403IND-NF-0402NFIND-NF-0402
    L0404CAP-NF-0402NFCAP-NF-0402
    L0405IND-NF-0402NFIND-NF-0402
    L0406SL040227nHIND-CER-27NH-0402
    L0407SL04027.5nHIND-CER-7.5NH-0402
    L0408SL04024.3nHIND-CER-4.3NH-0402
    L0409SL04027.5nHIND-CER-7.5NH-0402
    L0421IND-NF-0402NFIND-NF-0402
    L0422IND-NF-0402NFIND-NF-0402
    L0423SL04023.3nH(NF)IND-CER-3.3NH-0402
    L7300SL04022.7nHIND-CER-2.7NH-0402
    L7301SL04022.7nHIND-CER-2.7NH-0402
    L7302SL040210nHIND-CER-10NH-0402
    L7303SL040210nHIND-CER-10NH-0402
    L7304SL0805-S4.7uHIND-POWER-CER-4.7UH-0805
    L7305SL04022.7nHIND-CER-2.7NH-0402
    L7401SL04029.1nHIND-CER-9.1NH-0402
    L7403SL0402150nHIND-CER-150NH-0402
    L7405SL0402150nHIND-CER-150NH-0402
    L7406SL040256nHIND-CER-56NH-0402
    M0100PAD-FIDNC-FIDUCIALMARK
    M0101PAD-FIDNC-FIDUCIALMARK
    M0102PAD-FIDNC-FIDUCIALMARK
    M0103PAD-FIDNC-FIDUCIALMARK
    MIC3100AUDIO-MIC-ACMG4013-05S-443-006AUDIO-MIC-ACMG4013-05S-443-006
    MLV6330SMLV0402(NF)MLV-AVLC5S02050
    MOT6600MOTOR-V040833-060FMOTOR-V040833-060F
    Q5100VMT3TRIODE-NPN-DTC143ZM
    Q6100SOT-89TRIODE-PNP-PBSS5320X
    Q6101SOT-416FET-N-LSK3019FP8TL
    REC3100AUDIO-RECEIVER-SDRP0612KJ02-F1-GAUDIO-RECEIVER-SDRP0612KJ02-F1-G
    RN7401SR0402X4100RES-N-100X4-0402
    RN7402SR0402X4100RES-N-100X4-0402
    S6300SWITCH-PUSH-ST-1114RSWITCH-PUSH-ST-1114R
    S6301SWITCH-PUSH-ST-1114RSWITCH-PUSH-ST-1114R
    S6302SWITCH-PUSH-ST-1114RSWITCH-PUSH-ST-1114R
    S6305SWITCH-PUSH-ST-1114RSWITCH-PUSH-ST-1114R
    S6318NC-KEYPAD-4.8X3.2X1.6NC-KEYPAD-4.8X3.2X1.6
    SPK3100AUDIO-SPEAKER-HY20DBS-H44-L15AUDIO-SPEAKER-HY20DBS-H44-L15
    TPJ6201NC-TP-JTAG-10PINNC-TP-JTAG-10PIN
    TVS0300SOD-523(NF)TVS-ESD5Z3.3T1G-3.3V-105PF-SOD-523
    TVS4100SOT-553-5TVS-NZQA6V8XV5T1G
    TVS6200SOD-523TVS-ESD5Z7.0T1G
    U0100BGA11X10-233-0.5-SC6531ASIC-SC6531-233-0.5
    U0400RF-PA-HS8292RF-PA-HS8292U
    U0402CON-RF-SWITCH-MM8430-2610RA1CON-RF-SWITCH-MM8430-2610RA1
    U0500MEM-NOR-SPI-COMMON_1MEM-NOR-GD25LQ128YIG
    U3100WCSP9(NF)AUDIO-AMP-AW8110
    U4100SOT23-52.8V(NF)POWER-LDO-XC6221B282MR
    U4102QFN5X5-40ASIC-SENSOR-TP-ATMXT112E-MA5H
    U5200SENSOR-MOTION-ADXL346SENSOR-MOTION-ADXL346
    U5201SENSOR-LIGHT+PROX-LTR-501ALS-WASENSOR-LIGHT+PROX-LTR-501ALS-WA
    U7100QFN2X2-12(NF)RF-FM-BK1080NB
    U7202RF-SAW-LFB212G45CL1D172RF-SAW-LFB212G45CL1D172
    U7300RF-LPF-LFB212G45CG2D013RF-LPF-LFB212G45CG2D013
    U7301QFN5X5-32WIFI-RTL8189ES-CG
    U7302SOT23-53.3V(NF)POWER-LDO-XC6221B332MR
    U7400RF-TV-ATV168H(NMI601BAA)RF-TV-ATV168H(NMI601BAA)
    U7402SOT23-52.8VPOWER-LDO-XC6221B282MR
    X0201CRYSTAL-26M26MHzXTAL-CRYSTAL-E3SB26.0000F09G11
    X7300CRYSTAL-26M26MHzXTAL-CRYSTAL-E3SB26.0000F09G11
    重要提示:PCB作品文件展下载说明
    17万
    管理员
     楼主| 发表于 2017-4-8 23:48:07 | 显示全部楼层
    FP6531.7z (1.62 MB, 下载次数: 12)
    FP6531_sch.7z (491 KB, 下载次数: 13)
    昨天 10:11
  • 签到天数: 127 天
    你必须非常努力才能显
    发表于 2017-4-9 08:12:43 | 显示全部楼层
  • 签到天数: 19 天
    终身成就奖优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2017-4-9 08:45:23 | 显示全部楼层
    好复杂呀,多向各位老师前辈学习。。。
    终身成就奖原创先锋奖优秀斑竹奖
    发表于 2017-4-9 08:47:16 | 显示全部楼层
    前天 14:10
  • 签到天数: 87 天
    1元学习Allegro(1期)
    发表于 2017-4-9 08:49:49 | 显示全部楼层
    昨天 08:00
  • 签到天数: 155 天
    1元学习Allegro(230718)
    网络监控器IPCAMERA,视
    终身成就奖社区居民特殊贡献奖
    发表于 2017-4-9 08:51:31 | 显示全部楼层
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2017-4-9 08:56:34 | 显示全部楼层
    发表于 2017-4-9 08:58:30 | 显示全部楼层
    昨天 08:43
  • 签到天数: 228 天
    发表于 2017-4-9 08:58:51 | 显示全部楼层
