Name | Part Type | PCB Decal | Value | ANT0001 | G1-FM-ANT | G1-FM-ANT | | ANT0401 | G1-BT-ANT | G1-BT-ANT | | CON1 | FPC_CONNECTOR_4PINS | G1-KEY-4PIN | FPC 4Pins | CON909 | FPC_CONNECTOR_4PINS | G1-KEY-4PIN | FPC 4Pins | D806 | KKS_LED | LED-0603 | RED | FB1 | BEAD-1000-OHM-100MHZ-0402 | SL0402 | 1000ohm | FB0300 | BEAD-600-OHM-100MHZ-0.45A-0402 | SL0402 | 600ohm@100MHZ 450mA | FB6205 | BEAD-1000-OHM-100MHZ-0402 | SL0402 | 1000ohm | J1 | USBF-P0765-H23-0323 | USBF-P0765-H23-0323 | | J2 | G1-FPC-CAMERA22PIN | G1-FPC-22PIN | | J3 | G1-FPC-18PIN | G1-FPC-18PIN | | J12 | DJK-L75-0302 | DJK-L75-0302 | | J6100 | BAT-P0337-H451-0303 | BAT-P0337-H451-0303 | | J6501 | T_H1.5_DRWR | VT15H811F | | J7200 | G1-GSM-ANT | G1-GSM-ANT | | L0001 | IND-NF-0402 | IND-NF-0402 | NF | L0002 | IND-NF-0402 | IND-NF-0402 | NF | L0200 | IND-CER-10NH-0402 | SL0402 | 10nH | L0300 | IND-POWER-CER-2.2UH-0805 | SL0805-S | 2.2uH | L0400 | IND-CER-1NH-0402 | SL0402 | 1.0nH | L0404 | IND-CER-1NH-0402 | SL0402 | 1.0nH | L0406 | IND-CER-3.9NH-0402 | SL0402 | 3.9nH | L0407 | IND-CER-3.9NH-0402 | SL0402 | 3.9nH | L0421 | IND-NF-0402 | IND-NF-0402 | NF | L0422 | IND-NF-0402 | IND-NF-0402 | NF | MIC3100 | G1-MIC | G1-MIC | | MOT6600 | G1-VIB | G1-VIB | | Q6100 | FET-P_DIODE-FDFMA2P853 | MICROFET-2X2 | | REC3100 | G1-REC | G1-REC | | RF-RES | RF-RES | G1-TEST | 0 | SIM1 | SIM_SOCKET | SIM_1.5H | SIM_SOCKET | SIM2 | SIM_SOCKET | SIM_1.5H | SIM_SOCKET | SPK1 | G1-SPK | G1-SPK | | SW22 | G1-RF | G1-RF-TEST | KEY | TP1 | NC-TP-M | NC-TP-1.016 | | TP0105 | NC-TP-M | NC-TP-1.016 | | TP6101 | NC-TP-M | NC-TP-1.016 | | TP6102 | NC-TP-M | NC-TP-1.016 | | TP6200 | NC-PAD | NC-PAD-0.5X0.5 | | TP6201 | NC-PAD | NC-PAD-0.5X0.5 | | TP6202 | NC-PAD | NC-PAD-0.5X0.5 | | TP6203 | NC-PAD | NC-PAD-0.5X0.5 | | TVS0006 | ESD9X5VU | ESD9X5VU | | TVS0007 | ESD9X5VU | ESD9X5VU | | TVS0008 | ESD9X5VU | ESD9X5VU | | TVS6200 | TVS-ESD5Z7.0T1G | SOD-523 | | U8 | AW9733 | QFN20C40P300X300X75N_AW8733 | NS4730 | U0100 | ASIC-SC6531-233-0.5 | BGA11X10-233-0.5-SC6531 | | U0201 | RF-SAW-LFB212G45CL1D172 | RF-SAW-LFB212G45CL1D172 | | U0401 | RF-BALUN-LFB21914MDZ2D326 | RF-BALUN-LFB21914MDZ2D326 | | U0403 | RF-PA-SC2661D | RF-PA-SC2661D | | X0201 | XTAL-CRYSTAL-SQ3D02600B2IBA | CRYSTAL-26M | 26MHz |
