Name | PCB Decal | Value | Part Type | ANT1 | PAD_DIP_0.9MM | ANT | PAD_DIP_0.9MM | D1 | SOD-123 | CRS01 | SOD-123 | D2 | SOD-323 | 5819 | SOD-323 | D4 | 3-2B1A | 1N4148 | 3-2B1A | D6 | LED0603 | RED | LED0603 | D7 | LED0603 | LED | LED0603 | D8 | LED0603 | LED | LED0603 | D13 | 3-2B1A | 1N4148 | 3-2B1A | J2 | LIBAT-3 | LIBAT-3 | LIBAT-3 | J4 | FPC24-0.5 | FPC24-0.5-UP | CON24 | J6 | HDMI19\0.4\C-TYPE | HDMI_TYPE_(MINI) | HDMI19\0.4\C-TYPE | J8 | FPC40-0.5-A | FPC40-0.5-UP-TOD1.5 | FPC40-0.5-A | J13 | MMUSB_1 | USB-B_MINI | CON_USB_B_3 | J14 | CON-4PIN/0.5MM-DIP | FPC4-0.5-DOWN | CON-4PIN/0.5MM-DIP | L1 | L0603 | 24NH | L0603 | L2 | L0603 | 39NH | L0603 | L16 | 3D12 | 4.7UH | 3D12 | L17 | 3D12 | 4.7UH | 3D12 | L18 | 3D12 | 4.7UH | 3D12 | MIC1 | MIC-4.5MM | MAIN_MIC | MIC-4.5MM | Q1 | SOT-23 | AO3401A | SOT-23 | Q7 | UMT3 | DTC144EUA | NPN_DTC114EUA | Q10 | SOT-23 | AO3401A | SOT-23 | Q19 | UMT3 | DTC114EUA | NPN_DTC114EUA | SD1 | TF-109BC | TF_CARD | TF-109BC | SW14 | IT1100 | MENU | SW_PUSHBUTTON | SW15 | IT1100 | MODE | SW_PUSHBUTTON | SW16 | IT1100 | UP | SW_PUSHBUTTON | SW17 | IT1100 | DOWN | SW_PUSHBUTTON | SW20 | SW_01C | RESET | SW_01 | TP6 | TEST_PIN | TESTPOINT | TEST_PIN | TP7 | TEST_PIN | TESTPOINT | TEST_PIN | TP8 | TEST_PIN | TESTPOINT | TEST_PIN | TP27 | TEST_PIN | 0 | TEST_PIN | TP28 | TEST_PIN | 2 | TEST_PIN | TP29 | TEST_PIN | 1 | TEST_PIN | TP30 | TEST_PIN | 3 | TEST_PIN | TP32 | TEST_PINBA | 2 | TEST_PIN | TP33 | TEST_PINC | 2 | TEST_PIN | U2 | DIP8-SOP1 | PS007 | DIP8-SOP1 | U4 | SOT-23 | RCR3135-3.3V | SOT-23 | U5 | SOT23-5 | LN2054 | SOT23-5 | U6 | BGA305-NT96650ES | NT96650 | BGA305-NT96650ES | U7 | SOT-23 | RCR3135-3.0V | SOT-23 | U8 | SOT-23 | RCR3135-28V | SOT-23 | U11 | SOIC-8 | MX25L32MBIT | SOIC-8 | U12 | BGA96-NYDDR3-X16 | DDRIIIDRAM | BGA96-NYDDR3-X16 | U13 | SOT-23-6 | G5910-50TBU | SOT-23-6 | U15 | SOT23 | RCR3135_33 | SOT23 | U18 | LGA10 | DS380 | LGA10 | U21 | SOT-23-5 | AP2406 | SOT-23-5 | U24 | SOT-23-5 | AP2406 | SOT-23-5 | U25 | SOT-23-5 | AP2406 | SOT-23-5 | U29 | SOT-23-5 | RT9193-18 | SOT-23-5 | U703 | QSOP16 | MICRF211ABQS | QSOP16 | Y2 | XT2520_4PIN_SMD | 12MHZ | XT2520_4PIN_SMD | Y3 | XT3.2X1.5X0.8-SMD | 32.768KHZ | XT3.2X1.5X0.8-SMD | Y6 | XT2520_4PIN_SMD | 13.52127MHZ | XT2520_4PIN_SMD |
