查看: 10077|回复: 50
[Allegro16.6以下] IMX6Q主板 PCB  KSZ9031RNX+SP3232EEY+WM8962+TXB0104PWR+LAN9514+CM2
人人为我,我为人人。
社区居民最爱沙发宣传大使奖终身成就奖社区明星忠实会员优秀斑竹奖
发表于 2017-5-23 22:10:02 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BR1DIODE_KCAC_BRIDGE_BGX50ABGX50ASOT143
BR2DIODE_KCAC_BRIDGE_BGX50ABGX50ASOT143
BR3DIODE_KCAC_BRIDGE_BGX50ABGX50ASOT143
BT1BATTERY_BATTERY2_SL_BATTERYBATTERYBATTERY2_SL
CON1SF7W006S1A_CON_SIM_CD_2P54MM_IOCON 6 SIM CARDCON_SIM_CD_2P54MM
D1LED_1_R0603_LED_IC_LED_GREENLED_GREENR0603_LED
D2DIODETAZ_6_SOD_123_MMSZ52_MMSZMMSZ5232BT1GSOD_123_MMSZ52
D3DIODETAZ_5_SOD123FL_5A_2R7X1R6SMF5.0ASOD123FL_5A_2R7X1R65
D4DIODESCHOTTKY_DO-214AA_SS32SS32DO-214AA
D5DIODESCHOTTKY_SOD123_MBR0520MBR0520SOD123
D6LED_1_R0603_LED_IC_LED_REDLED_REDR0603_LED
D7LED_1_R0603_LED_IC_LED_GREENLED_GREENR0603_LED
D8DIODE_SOD323_IC_BAT54HT1BAT54HT1SOD323
D9LED_2_R0603_LED_IC_LED_ORANGELED_ORANGER0603_LED
D10LED_2_R0603_LED_IC_LED_GREENLED_GREENR0603_LED
D11LED_2_R0603_LED_IC_LED_YELLOWLED_YELLOWR0603_LED
D12DIODESCHOTTKY_DO-214AA_SS32SS32DO-214AA
D13DIODE_SOD323_IC_BAS16HT1GBAS16HT1GSOD323
E1LM3526-L_SOIC8_LM3526MX-HLM3526MX-HSOIC8
E2ANTENNA_3_CDMA_T_ANTENNA_1ANTENNA_1CDMA_T
E3ANTENNA_0_CDMA_T_ANTENNA_1ANTENNA_1CDMA_T
F1FUSE_1812_FUSE 3AFUSE 3A1812
J1CON2_DIP_1X2P_254_CON2CON2DIP_1X2P_254
J212HEADER_0_DOUBLE_USB_12 HEADE12 HEADERDOUBLE_USB
J3CON2_SW_NEW_CON2CON2SW_NEW
J4POWER_IN_1_POWER_NEW_POWER_DC9VPOWER_DC9VPOWER_NEW
J5MINIUSB_MINI_USB_MINI_UBmini_ubMINI_USB
J6CONN_HDMI_19P_TYPE_A_CON_HDMI_110029449-001RLFCON_HDMI_19F_20_SM_RA
J7CONN EDGE10X2_DIP_2X10P_254_COCONN EDGE 10X2DIP_2X10P_254
J8MINI_PCI_LATCH_52P_MINI_PCI_3G_CON 2X26 MINI PCIEXPRESSMINI_PCI_3G
J9SATA_PLUG7_CON7_SATA_TH_17X5MM_CON 7 SATACON7_SATA_TH_17X5MM
J10CON4_DIP_1X4P_254_CON4CON4DIP_1X4P_254
J11CON2_DIP_1X2P_508_CON2CON2DIP_1X2P_508
J12CONN EDGE10X2_DIP_2X10P_254_COCONN EDGE 10X2DIP_2X10P_254
J13CONN EDGE10X2_DIP_2X10P_254_COCONN EDGE 10X2DIP_2X10P_254
J14PHONEJACK STEREOSW_5_EAR_JACK_CK-3P5-025(GREEN)EAR_JACK
J15CON2_DIP_1X2P_508_CON2CON2DIP_1X2P_508
J16PHONEJACK STEREOSW_5_EAR_JAC_1CK-3P5-025(RED)EAR_JACK
J17CON2_DIP_1X2P_508_CON2CON2DIP_1X2P_508
J18CON20_WM8962_YOUPIAO_CON20CON20WM8962_YOUPIAO
J19CONN EDGE10X2_DIP_2X10P_254_COCONN EDGE 10X2DIP_2X10P_254
J20CON40_OMRON_XF2M-4015-1A_CON40CON40OMRON_XF2M-4015-1A
J21CON40_OMRON_XF2M-4015-1A_CON40CON40OMRON_XF2M-4015-1A
J22CON40_OMRON_XF2M-4015-1A_CON40CON40OMRON_XF2M-4015-1A
J23CONN PLUG6X2_DIP_2X6P_254_CONNCONN PLUG 6x2DIP_2X6P_254
J24CONN EDGE10X2_DIP_2X10P_20_CONCONN EDGE 10X2DIP_2X10P_20
J25SDCARDSOCKET_0_SDCARD_PROCONN_SSDCardSDCARD_PROCONN
J26CON24_FFC-24_CON24(NC)CON24(NC)FFC-24
J27CON32_FH28-32S-05SH_CON32CON32FH28-32S-05SH
L1INDUCTOR/SM_2520_LQM2HPN2R2MJ0LLQM2HPN2R2MJ0L2520
L2INDUCTOR/SM_2520_LQM2HPN2R2MJ0LLQM2HPN2R2MJ0L2520
L3INDUCTOR/SM_2520_LQM2HPN2R2MJ0LLQM2HPN2R2MJ0L2520
L4INDUCTOR/SM_SLF7032_6.8UH3A6.8uH 3ASLF7032
L50504CHOKEMCZ1210AH900TMCZ1210AH900T
L60504CHOKEMCZ1210AH900TMCZ1210AH900T
L7BEAD_L_0603_BLM18PG121SN1D_25%BLM18PG121SN1DL_0603
L80504CHOKEMCZ1210AH900TMCZ1210AH900T
L9BEAD_L_0603_BLM18PG121SN1D_25%BLM18PG121SN1DL_0603
L100504CHOKEMCZ1210AH900TMCZ1210AH900T
L19INDUCTOR_L_0603_LQG18HN2N7S00DLQG18HN2N7S00DL_0603
L200504CHOKEMCZ1210AH900TMCZ1210AH900T
L21BEAD_L_0603_BLM18PG121SN1D_25%BLM18PG121SN1DL_0603
L220504CHOKEMCZ1210AH900TMCZ1210AH900T
L23BEAD_L_0603_BLM18BD471SN1DBLM18BD471SN1DL_0603
L24BEAD_L_0603_LQG18HN2N7S00DLQG18HN2N7S00DL_0603
L25BEAD_L_0603_BLM18PG121SN1DBLM18PG121SN1DL_0603
P1HR911105A_7_HR911105A_HR911105AHR911105AHR911105A
P2CONNECTORDB9_1_CONNECTORDB9_DBDB9_FEMALECONNECTORDB9
P3CONNECTORDB9_1_CONNECTORDB9_DBDB9_FEMALECONNECTORDB9
Q1SI7617DN-T1-GE3_QFN_8_3R3X3R3_SSi7129DN-T1-GE3QFN_8_3R3X3R3
Q2PNPDIAC_0_SOT_23_MMBT3906_MMBTMMBT3906TT1SOT_23_MMBT3906
Q32N7002_SOT23_3_2N70022N7002SOT23_3
SW1SWDIP-2_0_A2S-5104-PH_SW DIP-2SW DIP-2A2S-5104-PH
SW2SWPUSHBUTTON-SPST-2_SW4_PB_ESWSW PUSHBUTTON-SPST-2SW4_PB_ESW_SM_P177
SW3SWPUSHBUTTON-SPST-2_SW4_PB_ESWSW PUSHBUTTON-SPST-2SW4_PB_ESW_SM_P177
SW4SWPUSHBUTTON-SPST-2_SW4_PB_ESWSW PUSHBUTTON-SPST-2SW4_PB_ESW_SM_P177
SW5SWPUSHBUTTON-SPST-2_SW4_PB_ESWSW PUSHBUTTON-SPST-2SW4_PB_ESW_SM_P177
TP1TEST PAD_H30_IC_TESTPADTest padH30
TP2TEST PAD_H30_IC_TESTPADTest padH30
TP3TEST PAD_H30_IC_TESTPADTest padH30
TP4TEST PAD_H30_IC_TESTPADTest padH30
TP5TP_TP_TEST POINTTEST POINTTP
TP6TP_TP_TEST POINTTEST POINTTP
TP7TEST PAD_H20_IC_TESTPADTest padH20
TP8TP_TP_TEST POINTTEST POINTTP
TP9TEST PAD_H20_IC_TESTPADTest padH20
TP10TEST PAD_H20_IC_TESTPADTest padH20
TP11TEST PAD_H30_IC_TESTPADTest padH30
TP12TEST PAD_H30_IC_TESTPADTest padH30
TP13TEST PAD_H30_IC_TESTPADTest padH30
TP14TEST PAD_H30_IC_TESTPADTest padH30
U1N070ICN-GB1_FH28-31S-05SH_N070IN070ICN-GB1FH28-31S-05SH
U2TPS62240DDCR_SOT23_5_TPS62240DDTPS62240DDCRSOT23_5
U3TPS62240DDCR_SOT23_5_TPS62240DDTPS62240DDCRSOT23_5
U4TPS62240DDCR_SOT23_5_TPS62240DDTPS62240DDCRSOT23_5
U5FDC642P_SOT23_6_FDC642PFDC642PSOT23_6
U6SP7656_HSOICN8_SP7656EN2-L/TRSP7656EN2-L/TRHSOICN8
U793LC66A_0_SOIC8_93LC66A93LC66ASOIC8
U8ISL1208_SOIC8_ISL1208ISL1208SOIC8
U9LAN9514_QFN_9X9-64_LAN9514LAN9514QFN_9X9-64
U10CM2020_TSSOP_38P_TSSOP38_0P5_4PCM2020TSSOP38_0P5_4P5X9P8
U11JTAG_DIP_2X5P_254_JTAGJTAGDIP_2X5P_254
U12HR911130C_GBE_RJ45_HR911130C_HRHR911130CGBE_RJ45_HR911130C
U13SPE3495EEN-L_5_SO8_SP3495EEN-LSP3495EEN-LSO8
U14CON20X2_DIP_2X20P_254_CON20X2con20x2DIP_2X20P_254
U15SP3232EEY_TSSOP16_SP3232EEYSP3232EEYTSSOP16
U16KSZ9031RNX_QFN48_KSZ9031RNXKSZ9031RNXQFN48
U17MXM314_MXM_314PIN_MXM314MXM314MXM_314PIN
U18PESD5V0S1BA_1_SOD323_PESD_PESD5PESD5V0S1BASOD323_PESD
U19TJA1040T_SO_8P_SO8_1P27_4X5_IC_TJA1040TSO8_1P27_4X5
U20PESD5V0S2BT_SOT23_PESD5V0S2BTPESD5V0S2BTSOT23
U21TXB0104PWR_0_TSSOP20_TXS0108PWRTXS0108PWRTSSOP20
U22TJA1040T_SO_8P_SO8_1P27_4X5_IC_TJA1040TSO8_1P27_4X5
U23SP3232EEY_TSSOP16_SP3232EEYSP3232EEYTSSOP16
U24RL-UM02B_0_UM12BS-8188EUS_RL-UMRL-UM12BS-8188EUS-V1.2UM12BS-8188EUS
U25NLSV1T34_0_SC70_5_IC_NLSV1T34DFNLSV1T34DFT2GSC70_5
U26NLSV1T34_0_SC70_5_IC_NLSV1T34DFNLSV1T34DFT2GSC70_5
U27NEO-5Q_NEO_6M_16R0X12R2_NEO-6MNEO-6MNEO_6M_16R0X12R2
Y1CRYSTAL_0_Y_D1P5MM_XTAL32768XTAL 32768Y_D1P5MM
Y2CRYSTAL_Y_12P4X4P83X2P5_25MHZ25MHZY_12P4X4P83X2P5
Y3CRYSTAL_Y_12P4X4P83X2P5_25MHZ25MHZY_12P4X4P83X2P5
重要提示:PCB作品文件展下载说明
人人为我,我为人人。希望大家下载资料的同时能回帖支持,你们的支持,是我最大的共享动力。不回帖以后不共享了。哈哈
人人为我,我为人人。
 楼主| 发表于 2017-5-23 22:11:24 | 显示全部楼层
I.MX6.7z (1.18 MB, 下载次数: 49)
社区居民新人进步奖终身成就奖
发表于 2017-5-23 22:57:56 | 显示全部楼层
  • 签到天数: 103 天
    7万
    发表于 2017-5-24 00:05:32 | 显示全部楼层
    3 天前
  • 签到天数: 154 天
    1元学习Allegro(230718)
    网络监控器IPCAMERA,视
    终身成就奖社区居民特殊贡献奖
    发表于 2017-5-24 07:49:59 | 显示全部楼层
    3 天前
  • 签到天数: 177 天
    发表于 2017-5-24 07:58:56 | 显示全部楼层
    发表于 2017-5-24 08:17:37 | 显示全部楼层
    5 天前
  • 签到天数: 126 天
    你必须非常努力才能显
    发表于 2017-5-24 08:25:32 | 显示全部楼层
    发表于 2017-5-24 08:28:15 | 显示全部楼层
    昨天 10:14
  • 签到天数: 213 天
    社区居民社区劳模终身成就奖特殊贡献奖
    发表于 2017-5-24 08:39:52 | 显示全部楼层
