AD16安装过程
此方法适用AD16以上的所有版本安装(只是有些版本,授权文件存放到Licenses文件夹下,名称跟下面安装教程中的不同而已,请大家安装的时候注意看一下就可以了)
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg
一.安装过程
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpg
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image008.jpg
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image010.jpg
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image012.jpg
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image014.jpg
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image016.jpg
二,激活过程
1.安装包中找到Licenses文件夹,打开后复制如下文件,粘贴到软件安装后的文件夹下, (我是安装到D:\Program Files (x86)\Altium\AD16
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image018.jpg
2,打开软件,添加刚才复制过去的授权文件NB201601.alf
(64位系统第一次打开软件会弹出如下情况,勾选不再显示就可以了)
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image020.jpg
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image022.jpg
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image024.jpg
三,安装导入插件
1.打开软件,点左上角的DXP菜单
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image026.jpg
2.点开下图
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image028.jpg
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image030.jpg
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image032.jpg
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image034.jpg
四.中文版本设置方法:
打开DXP菜单,
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image036.jpg
14选择Preferences,根据下面选择,重启后就是中文的
file:///C:/Users/ZSW/AppData/Local/Temp/msohtmlclip1/01/clip_image038.jpg
