Name | Part Type | PCB Decal | Value | BATT1 | TP_S | TP1_5X3 | TP_S | BT1+ | TP_S | TP1_5X3 | TEST_POINT | BT1- | TP_S | TP1_5X3 | TEST_POINT | C_U1 | LDO_FB_5P | SOT23_5 | WL2003E18 | D1 | DIODE_SCHOTTKY | SOD_123 | B5819W | D2 | DIODE_SCHOTTKY | DO_214AC | SS34 | D3 | DIODE | SOD_123 | B5819W | D4 | DIODE_PN | SOT23 | BAV99 | D5 | DIODE_SCHOTTKY | SOD_123 | MM1Z16V | D6 | DIODE_PN | SOT23 | BAV99 | D7 | DIODE_SCHOTTKY | SOD_123 | ZMM6V8 | D8 | DIODE | SOD_523 | BD4148F | D9 | DIODE | SOD_123 | B5819W | D10 | DIODE | SOD_123 | B5819W | D11 | DIODE_SCHOTTKY | SOD_123 | ZMM5V6 | D12 | DIODE | SOD_523 | BD4148F | D13 | DIODE_SCHOTTKY | DO_214AC | SS34 | D14 | DIODE | SOD_523 | BD4148F | D15 | DIODE | SOD_523 | BD4148F | D16 | DIODE_PN | SOT23 | BAV99 | D24 | DIODE | SOD_523 | BD4148F | E1 | CAP_POL | C1206 | 10uF/25V | E2 | CAP_POL | C1206A | 47uF | E3 | CAP_POL | C1206A | 47uF | FB1 | INDUCTOR | L0603 | PBY160808T-121Y-N | FB2 | INDUCTOR | L1206 | PBY321609T-121Y-N/NC | FB3 | INDUCTOR | L1206 | PBY321609T-121Y-N | FB4 | INDUCTOR_2 | L1206 | PBY321609T-121Y-N | FB5 | INDUCTOR | L0603 | PBY160808T-121Y-N | GND1 | TP_S | TP1_5X3 | TEST_POINT | J4 | SDMMC_SLOT_11 | TF-W | MICROSD/TF_SLOT | J6 | HDMI_1_2 | HDMI_C1 | MINI-HDMI | J8 | MINI-B_USB | MINI_USB_1_MICRO_USB | CONN MICRO USB | J10 | CON_1 | FCC-40P-0.5 | CON_40PIN | J11 | ST-3507-05G_2 | PJ381 | ST-3507-05G | J13 | USB_CON | USB_CON | USB_CON | L1 | INDUCTOR | 7.00E+04 | ELL4FG100MA | L2 | INDUCTOR | CDH2D12 | ELLVGG100M | L3 | INDUCTOR | CDH5B18 | 4.7uH 1.5A | L4 | INDUCTOR | CDH2D12 | ELLVGG2R2N | L5 | INDUCTOR | CDH2D12 | ELLVGG2R2N | L6 | INDUCTOR | CDH2D12 | ELLVGG2R2N | L7 | INDUCTOR | CDH5B18 | 4.7uH 1.5A | L8 | INDUCTOR | L0402 | 2.7nF | L10 | INDUCTOR | R0402 | 1.5nH | L11 | INDUCTOR | R0402 | 1.8nH | L12 | INDUCTOR | L0402 | 600R | L13 | INDUCTOR | L0402 | 600R | MIC+1 | TP_S_2 | MIC | TEST_POINT | MIC-1 | TP_S_2 | MIC | TEST_POINT | P153 | TEST_0 | T_1 | TEST | P154 | TEST_0 | T_1 | TEST | P155 | TEST_0 | T_1 | TEST | P156 | TEST_0 | T_1 | TEST | PB12 | PAD | PAD_1_2MM | W_ANT | PB13 | PAD | PAD_2_5MM | GND | PB14 | PAD | PAD_2_5MM | GND | Q1 | MOSFET_P | SOT23 | WPM2341 | Q2 | NPN | SOT23 | MMBT3904 | Q3 | NPN | SOT23 | MMBT3904 | Q4 | NPN | SOT23 | NC/MMBT3904 | Q5 | MOSFET_P | SOT23 | WPM2341/NC | Q6 | PNP | SOT23 | MMBT3906/NC | Q7 | MOSFET_P | SOT23 | NC/WPM2341 | Q8 | NPN | SOT23 | MMBT3904 | RA1 | RES-PACK | R0402S4 | 22R | RA2 | RES-PACK | R0402S4 | 22R | RA4 | RES-PACK | R0402S4 | 22R | SPKLN1 | TP_S | TP1_5X3 | TEST_POINT | SPKLN2 | TP_S | TP1_5X3 | TEST_POINT | SPKLP1 | TP_S | TP1_5X3 | TEST_POINT | SPKLP2 | TP_S | TP1_5X3 | TEST_POINT | SW2 | SWITCH_4 | T024 | RST | SW10 | SWITCH_4_2 | TC0521 | PWRON | TVS12 | TVS | TVS_0402 | ESD5B5V-2/TR | TVS13 | TVS | TVS_0402 | ESD5B5V-2/TR | TVS14 | TVS | TVS_0402 | ESD5B5V-2/TR | TVS15 | TVS | TVS_0402 | ESD5B5V-2/TR | TVS18 | TVS | TVS_0402 | ESD5B5V-2/TR | TVS19 | TVS | TVS_0402 | TVS | TVS20 | TVS | TVS_0402 | TVS | TVS21 | TVS | TVS_0402 | NC/TVS | TVS22 | TVS | TVS_0402 | ESD5B5V-2/TR | TVS23 | TVS | TVS_0402 | ESD5B5V-2/TR | TVS24 | TVS | TVS_0402 | ESD5B5V-2/TR | TVS25 | TVS | TVS_0402 | ESD5B5V-2/TR | U1 | BGA441-AW1623_13 | FBGA441C80P19X19 | BGA441-APP | U6 | NAND__FLASH | TSOP48 | MT29F64G08CBAAA | U7 | BAKELIGHT_IC_6P | SOT23_6 | TCS5513-A | U8 | AT1308 | SOT23_5 | TCS3356-E | U9 | LDO_5P | SOT23_5 | WL2003E33 | U10 | ESD_SPE6V8UD | SLP2510P8 | SPE6V8UDFN10RGB | U11 | ESD_SPE6V8UD | SLP2510P8 | SPE6V8UDFN10RGB | U12 | LY8006 | SSOP8 | TX4890 | U13 | LY8006 | SSOP8 | TX4890 | U14 | DDR3_0 | FBGA96 | DDR3-FBGA96 | U15 | LDO_FB_5P | SOT23_5 | WL2003E33 | U16 | AW1612_2 | QFN48 | AXP209 | U17 | IT2105-ADJ | SOT23_5 | TCS4150 | U18 | RT9266PE_3 | SOT23_6 | TCS9208 | U19 | RT9266PE_2 | SOT23_5 | SY6280 | U20 | LDO_5P | SOT23_5 | WL2003E33 | U21 | RL_UM02BS | RL_UM02BS | RL-UM02BS | U22 | AT88SC0104C-SI_0 | SO8 | AT88S01040 | U23 | AT88SC0104C-SI_2 | RTL8201 | RTL8201 | U24 | AT88SC0104C-SI_3 | RJ45 | RJ45 | U25 | AT88SC0104C-SI_3 | SO8 | RJ45 | U26 | GL850G | SSOP_28 | GL850G | U27 | DDR3_0 | FBGA96 | DDR3-FBGA96 | U29 | CLAP070LF02CW_1 | FPC-CONN-30PIN_XF2 | CON30 | U30 | NAND__FLASH | TSOP48 | NC/MT29F64G08CBAAA | U32 | RDA5876 | RDA5876 | RDA5876 | U33 | USB_HOST_0 | USB_HOST_0 | USB | U34 | USB_HOST_1 | FPC16P | USB | U41 | NE555_0 | SO8 | NE555 | U42 | MAX485_1 | SO8 | MAX485 | U44 | GSL168X_0 | QFN40_0D4_5X5 | GSL168X | Y1 | CRYSTAL_4P_14 | TFL145D | 32.768K | Y2 | CRYSTAL_4P_13 | OSC3225 | 24MHz | Y3 | CRYSTAL_4P_13 | OSC3225 | 26MHz | Y4 | CRYSTAL_4P_13 | OSC3225 | 25MHz | Y5 | CRYSTAL_4P_13_2 | OSC3225 | 12MHz |
