重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | ANGLE-3V3 | TEST | T_1 | TEST | ANT3 | ANT_WFL-R-SMT | 10102A-CYT-A | WFL-R-SMT | CE7 | CAPACITOR_0 | C0805 | 226 | CLK_O | TEST | T_1 | TEST | CN1 | 5PIN11 | A2006WF-04A | | CN2 | 4PIN2111 | A2006WF-04A | | CN3 | 5PIN2111 | A2006WF-04A | | CN4 | CAMERA_6PIN | A1254WF-06A | | CN5 | 6PIN-MIC | A2006WF-06A-1 | | CN8 | CAMERA_6PIN | A1254WF-06A | | CR1 | DIO_ESD_2 | ESD0402 | HR02B5VM | CR7006 | DIO_ESD_2 | ESD0402 | HR02B5VM/NC | CR7007 | DIO_ESD_2 | ESD0402 | HR02B5VM/NC | CR7008 | DIO_ESD_2 | ESD0402 | HR02B5VM | CR7009 | DIO_ESD_2 | ESD0402 | HR02B5VM | D1 | B5819WS | SO323-01 | SUP4148WS | D2 | B5819WS | SO323-01 | SUP4148WS | D3 | B5819WS | SO323-01 | SUP4148WS/NC | D4 | B5819WS | SO323-01 | SUP4148WS/NC | D5 | TVS1 | SOD-123A | SUP58L3V3/SOD123/NC | D6 | DIODE-3 | SOT23 | SUP5522F | D7 | DIODE-3 | SOT23 | SUP5522F | D8 | TVS2 | SOD-123A | SUP58L5V1/SOD123 | D9 | DIODE | D1206 | SUP5519W-2/TR/SOD123 | D10 | DIODE | D1206 | SUPK34/SOD-123FL | D11 | TVS | D1206_2A | HRAJ16A | D12 | B5819WS | SO323-01 | SUP4148WS/NC | D13 | TVS1 | SOD-123A | SUP58L5V1/SOD123 | D14 | DIODE | D1206 | SUPK34/SOD-123FL | D23 | B5819WS | SO323-01 | SUP4148WS | DM | TP | STD_PAD1.0 | DDRVCC | DP | TP | STD_PAD1.0 | DDRVCC | ED12 | ESD0402 | SOD-123A | ESD | ED26 | ESD0402 | E0402N | ESD | ED28 | ESD0402 | E0402N | ESD | ED31 | ESD0402 | E0402N | ESD | ED32 | ESD0402 | E0402N | ESD | EU1AU11 | ALC5672 | LCC48_P4MM_SQ6MM_1P0H | ALC5672 | FB2 | L_CHOKE_CM14 | DLW5BTN102SQ2 | DLW5BTN102SQ2/NC | FB6AU91 | FERRITE | L0402 | FERRITE | FW3V3 | TP | STD_PAD1.0 | DDRVCC | GND | TP | STD_PAD1.0 | DDRVCC | GPIO1 | TEST_POINT | TP-1.0 | TEST POINT | GPIO2 | TEST_POINT | TP-1.0 | TEST POINT | GPIO3 | TEST_POINT | TP-1.0 | TEST POINT | GPIOB6 | TP | STD_PAD1.0 | DDRVCC | ISP | CON4 | XH-4 | CN6 | J1 | CON30-1-RTC11 | 30PIN-FPC | | J2 | CON2 | A2006WF-02A | swith | J3 | CON6_M830 | A2006WF-06A | TP (6PIN) | J7 | TFT9K2513-A_ZIF | TFT-40 | | J8 | THCV236-65 | THCV236 | | J11 | CON6_M83011111 | A1254WF-08A | TP (6PIN) | J12 | MICRO_USB | MICRO-5S | MICRO USB 5PIN | J14 | THCV236-65 | THCV236 | | J9311 | CON2 | A2006WF-02A | SPEAK_L | J9312 | CON2 | A2006WF-02A | SPEAK_R | L1 | L0603 | L0603 | 600R@100MHZ | L2 | EMI_EXC14CG | EXC14CE900U | CPAB42F91RZ | L7 | L0603 | L0603 | 600R@100MHZ | L8 | INDUCTOR_1 | L/IND/SMD/2520 | GAP252012CL-2R2N/2520/1.2mm | L9 | INDUCTOR_1 | L/IND/SMD/2520 | GAP252012CL-2R2N/2520/1.2mm/NC | L10 | SML_XFL5015 | SML_XFL5015 | 4.7UH | L11 | INDUCTOR_1 | L/IND/SMD/2520 | GAP252012CL-2R2N/2520/1.2mm | L12 | L0603 | L0603 | 600R@100MHZ | L14 | INDUCTOR_1 | L/IND/SMD/2520 | GAP252012CL-2R2N/2520/1.2mm | L15 | IND_ALTSIZE_31 | EM-22AM23V01 | 4.7UH | L17 | L0603 | 603 | 3.9uH | L18 | SML_XFL5015 | SML_XFL5015 | 4.7UH | L19 | L0603 | 603 | 3.9uH | L20 | L0603 | 603 | 3.9uH | L21 | L0603 | 603 | 3.9uH | L23 | INDUCTOR_2 | L/IND/SMD/2520 | 4.7uH | L24 | INDUCTOR_011 | TMPC0512 | DZM50504R7MESH/2.0mm | L25 | INDUCTOR_01 | TMPC0512 | DZM5050100MESH/2.0mm | L30 | EMI_EXC14CG | EXC14CE900U | CPAB42F91RZ*/nc | L31 | EMI_EXC14CG | EXC14CE900U | CPAB42F91RZ | L33 | SML_XFL5015 | SML_XFL5015 | 4.7UH | L34 | L0603 | L0603 | 330R@100MHZ/BLM21BB331SN1D | L35 | L0603 | L0603 | 600R@100MHZ | L36 | L0603 | L0603 | 600R@100MHZ | L241 | L0603 | L0603 | 330R@100MHZ/BLM21BB331SN1D | Q3 | 40852_4 | SOT23A | SUP2F04 | Q4 | 40852_4 | SOT23A | SUP2F04 | Q5 | BJT_23 | SOT23 | SUP2F04 | Q6 | MOS_23 | SOT23 | HR8031GS6 | Q7 | 40852_1 | SOT23 | SUP2F04 | Q9 | MOSFET-N_SOT-723_WNM2030 | SOT723 | HR8020GS9 | Q10 | MOS_23 | SOT23 | HR8031GS6 | Q11 | MOSFET-N_SOT-723_WNM2030 | SOT723 | HR8020GS9 | Q12 | BJT_23 | SOT23 | SUP2F04 | Q16 | MOSFET_N | SOT23 | NC | Q17 | MOSFET-N_SOT-723_WNM2030 | SOT723 | HR8020GS9 | Q21 | BJT_23 | SOT23 | SUP2F04 | Q23 | MOS_23 | SOT23 | HR8031GS6 | QA4 | MOSFET-P_SOT23_WPM2026-3/TR | SOT23 | HR8031GS6/SOT23 | RH0/3V3 | TP | STD_PAD1.0 | DDRVCC | RP6100 | RESISTOR_4PACK | R0402S4 | 10K | RX | TP | STD_PAD1.0 | DDRVCC | S1 | S1 | IT-1185AU2 | RECOVERY | S2 | S1 | IT-1185AU2 | POWER | S3 | S1 | IT-1185AU2 | POWER /NC | SCK | TEST | T_1 | TEST | SCL_TP | TP | STD_PAD1.0 | DDRVCC | SDA | TEST | T_1 | TEST | SDA_TP | TP | STD_PAD1.0 | DDRVCC | SH2AU21 | RESISTOR_0 | 603 | 0R | SHIELD21 | CON5_1 | RF1201Y | CON5 | SPKL+ | TP | STD_PAD1.0 | DDRVCC | SPKL- | TP | STD_PAD1.0 | DDRVCC | SPKR+ | TP | STD_PAD1.0 | DDRVCC | SPKR- | TP | STD_PAD1.0 | DDRVCC | TX | TP | STD_PAD1.0 | DDRVCC | U1 | RK3066_2 | BGA453-19X19 | RK3066 | U2 | DDRIII_8BIT | BGA78 | DDR3_512M_8BIT | U3 | DDRIII_8BIT | BGA78 | DDR3_256M_8BIT | U4 | DDRIII_8BIT | BGA78 | DDR3_256M_8BIT | U5 | DDRIII_8BIT | BGA78 | DDR3_256M_8BIT | U6 | SSD2828_QFN68 | QFN_68 | SSD2828QN4 QFN68 | U7 | TD2108 | SOT23-5P | TZ92108W33E | U8 | TD2108 | SOT23-5P | TZ92108W18E | U9 | TD2108 | SOT-23-5 | TZ92108W18E | U10 | MT2492 | SOT23-6 | FR8205 | U11 | TZ3218 | SOT23-6 | FP6381AS5CTR | U13 | TD2108 | SOT-23-5 | TZ92108W28E | U14 | AW1612_0 | QFN48 | AXP202 | U15 | BD9D321EFJ-E2 | | | U16 | TD2108 | SOT-23-5 | TZ92108W12E | U17 | LP3301S | SOT23-6 | MT3540 | U18 | TD2108 | SOT-23-5 | TZ92108W18E | U19 | LM4990_0 | MSOP8 | TZ99563 | U20 | LPW5206H | SOT23-5 | HR1103A | U21 | BD9D321EFJ-E2 | | | U22 | TD2108 | SOT-23-5 | TZ92108W28E | U23 | TD2108 | SOT-23-5 | TZ92108W18E/nc | U25 | TD2108 | SOT23-5P | TZ92108W33E | U26 | TD2108 | SOT-23-5 | TZ92108W18E | U27 | TD2108 | SOT-23-5 | TZ92108W18E/NC | U28 | TD2108 | SOT23-5P | TZ92108W33E | U30 | NT50358A | | | U34 | TT7001(SOT23-6) | SOT23-6 | FP6755S6CTR/SOT23-6 | U35 | TD2108 | SOT-23-5 | TZ92109W33E | U37 | TD2108 | SOT-23-5 | TZ92108W33E | U41 | TD2108 | SOT-23-5 | TZ92108W15E/NC | U43 | AP6493_8 | AP6212 | AP6xxx | U100 | 12_HEADER | IC/LQFP-32/0M8X7MX7M | R7F0C908 | U502 | 169_BALL_EMMC | BGA169/THGBM1GXDXEBAI/TOSHIBA | 169 ball eMMC | UA1 | DS8008_4 | SOT23-5 | TZ92108-18 | UA13 | DS8008_4 | SOT23-5 | TZ92108-1V8 | VBUS | TP | STD_PAD1.0 | DDRVCC | VCC_TP | TP | STD_PAD1.0 | DDRVCC | X301 | CRYSTAL | X32.768-SMT9H032 | XTL721-S999-286 | Y1 | XTAL_4PIN | SMY_4P_79X98_PAD37X39_24H | 12.0MHZ | Y2 | CRYSTAL-4_1 | XTL571200-S366-002 | 24M-30ppm | Y3 | XTAL_4PIN | SMY_4P_79X98_PAD37X39_24H | 12MHZ | Y1001 | XTAL_4PIN | SMY_4P_79X98_PAD37X39_24H | 26MHZ |
重要提示:PCB作品文件展下载说明
