Name | PCB Decal | Value | Part Type | ANT2 | ANT2G4_B | N/A | ANT2G4_B | CE1 | CD5.0/2.5 | 47UF/16V | CD5.0/2.5 | CE2 | CD5.0/2.5 | 47UF/16V | CD5.0/2.5 | CE3 | CD5.0/2.5 | 47UF/16V | CD5.0/2.5 | CN3 | CON5/2.0 | 5P 2.0mm | CON5/2.0 | D1 | SOT23 | BAT54S | SOT23 | D10 | SOD323 | 1N5819 | SOD323 | D14 | SOT23 | NC/BAT54C | SOT23 | ED1 | SOT23 | NC/ESDA6V8UL/AZC199-02S | SOT23 | ED2 | SOT23 | NC/ESDA6V8UL/AZC199-02S | SOT23 | ED3 | E0402N | NC | E0402N | ED4 | E0402N | NC/ESD9B5V | E0402N | ED5 | E0402N | NC/ESD9B5V | E0402N | ED6 | E0402N | NC/ESD9B5V | E0402N | ED7 | E0402N | NC/ESD9B5V | E0402N | ED8 | E0402N | NC/ESD9B5V | E0402N | ED9 | E0402N | NC/ESD9B5V | E0402N | ED10 | E0402N | NC/ESD9B5V | E0402N | ED13 | E0402N | NC/ESD9B5V | E0402N | ED14 | E0402N | NC/ESD9B5V | E0402N | ED15 | E0402N | NC/AZ5725-01F/ESD9B5VL | E0402N | ED16 | E0402N | NC/AZ5725-01F/ESD9B5VL | E0402N | ED17 | E0402N | NC/ESD9B5VL | E0402N | ED18 | E0402N | NC/ESD9B5VL | E0402N | ED19 | E0402N | NC/ESD9B5VL | E0402N | ED20 | E0402N | NC/ESD9B5VL | E0402N | ED21 | E0402N | NC/ESD9B5VL | E0402N | F1 | R1206 | 0R | R1206 | FB1 | L0603D | NC/SDCW2012-2-900 | L0603D | FB2 | L0603D | NC/SDCW2012-2-900 | L0603D | FB3 | L0603D | | L0603D | H1 | H3.8MMAA | H3.8MM | H3.8MM | H2 | H3.8MMAA | H3.8MM | H3.8MM | H3 | H3.8MMA | H3.8MM | H3.8MM | H4 | H3.8MMBA | H3.8MM | H3.8MM | IR1 | TO92ECB | VS1838B | TO92ECB | J1 | DC-005AA | DC JACK | DC-005A | J4 | SD_F03AA | TF_SD_SOCKET | SD_F03 | J5 | R0603 | NC | R0603 | J6 | HDMI_AAA | HDMI_A | HDMI_A | J7 | PHONE-4CAAAAAAAA | PHONEJACK | PHONE-4C | J15 | UART-DEBUG | NC/UART-DEBUG | UART-DEBUG | JP4 | RJ45 | RJ45 | RJ45 | L1 | IND-4X4 | 3.3UH/1A | IND_4X4 | L2 | IND-4X4 | 3.3UH/2A | IND_4X4 | L3 | IND-4X4 | 3.3UH/2A | IND_4X4 | L4 | IND-4X4 | 3.3UH/1A | IND_4X4 | L5 | L0603 | 0R/BLM18PG181SN1 | L0603 | L6 | L0603 | BLM18PG181SN1 | L0603 | L7 | L0603 | 1.8UH | L0603 | L8 | L0603 | BLM18PG181SN1 | L0603 | L9 | L0603 | BLM18PG181SN1 | L0603 | L10 | L0603 | BLM18PG181SN1 | L0603 | L11 | L0603 | NC | L0603 | L14 | R0402 | 22NH | R0402 | L15 | L0603 | BLM18PG181SN1 | L0603 | L16 | L0603 | 0R/BLM18PG181SN1 | L0603 | L18 | R0402 | NC | R0402 | L19 | R0402 | NC | R0402 | LED2 | LED2 | LED 3 | LED2 | Q1 | SOT23 | 3904 | SOT23 | Q2 | SOT23 | 3904 | SOT23 | Q5 | SOT23 | NC/WPM2015 | SOT23 | Q6 | SOT23 | NC/WPM2015 | SOT23 | SW1 | SW01 | | SW01 | SW2 | CON-2/2.54MMAAAA | 2P 2.54mm | CON-2/2.54MMA | T19 | T-0.7 | I2S0_LRCK_RX | T-0.7 | T20 | T-0.7B | I2S0_SDI | T-0.7 | U1 | RK2928_BGA313 | RK3028A_BGA | RK2928_BGA313 | U3 | FBGA96 | DDR3_256M_16BIT | FBGA96 | U4 | TSOP1-48 | NAND_FLASH | TSOP1-48 | U5 | SOT25 | WS1015/WS1016/SY8008B | SOT25 | U6 | SOT25 | SY8009A | SOT25 | U7 | SOT25 | PT5108E23E-12 | SOT25 | U8 | SOT25 | SY8009A | SOT25 | U9 | SOT25 | WS1015/WS1016/SY8008B | SOT25 | U10 | GL850G | GL850G/GL852G | GL850G | U11 | SOT23 | ME083A263X | SOT23 | U12 | RK1000QUAD64 | RK1000-S | RK1000QUAD64 | U13 | SOT25 | PT5108E23E-18 | SOT25 | U14 | SOT25 | PT5108E23E-33 | SOT25 | U15 | SOP8 | NJM4580 | SOP8 | U16 | SLP2510P8 | NC/AZ1045-04F/ESDA6V8UD | SLP2510P8 | U17 | SLP2510P8 | NC/AZ1045-04F/ESDA6V8UD | SLP2510P8 | U18 | QFN24-4X4MMAA | RTL8152B | QFN24-4X4MM | U19 | SOIC16 | HR601680 | SOIC16 | U20 | RL-UM12BS | NC/RL-UM12BS-8188EUS | RL-UM12BS | U21 | QFN32-5X5MMA | ESP8089 | QFN32-5X5MM | U22 | SOT25 | SY6280AAC/WS4601 | SOT25 | U23 | SOP14 | NC/MCU | SOP14 | U24 | SOT25 | NC/PT5108E23E-33 | SOT25 | U25 | TSOP1-48 | TSD_FLASH | TSOP1-48 | USB1 | USB-AF90 | USB-AF90 | USB-AF90 | USB2 | USB-AF90 | USB-AF90 | USB-AF90 | Y1 | CRY-D3225 | 24MHZ-20PPM | CRY-D3225 | Y2 | CRY | 12MHZ | CRY | Y4 | CRY-D3225 | 26MHZ-10PPM | CRY-D3225 | Y5 | CRY | 25MHZ | CRY |
