REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
BT1 | BATTERY_SN2032-1_CR2032-3V_SKT | CR2032-3V_SKT | SN2032-1 |
CON1 | POWER_JACK_KLDX-0202-A_POWER-JA | POWER-JACK | KLDX-0202-A |
CON2 | SATA_CONNECTOR_SATA7_PIN_CON_67 | 67490-1220 | SATA7_PIN_CON |
CON3 | SATA_CONNECTOR_SATA7_PIN_CON_67 | 67490-1220 | SATA7_PIN_CON |
CON4 | SATA_CONNECTOR_SATA7_PIN_CON_67 | 67490-1220 | SATA7_PIN_CON |
CON5 | SATA_CONNECTOR_SATA7_PIN_CON_67 | 67490-1220 | SATA7_PIN_CON |
CON6 | CON_1X4_2217R-04WH2_1X4CON_RA | 1x4Con_RA | 2217R-04WH2 |
CON7 | CON_1X4_2217R-04WH2_1X4CON_RA | 1x4Con_RA | 2217R-04WH2 |
CON8 | 67910-0002_67910-0002__MM60-EZH | 67910-0002__MM60-EZH039-B5-R850 | 67910-0002__MM60-EZH039-B5-R850 |
CON9 | 67910-0002_67910-0002__MM60-EZH | 67910-0002__MM60-EZH039-B5-R850 | 67910-0002__MM60-EZH039-B5-R850 |
CON10 | USB3_U3F09D-F1N2_U3F09D-F1N2 | U3F09D-F1N2 | U3F09D-F1N2 |
CON11 | 1367073-1_SFP+_U77-A1618-2X0X_1 | 1367073-1__U77-A1618-2001 | 1367073-1__U77-A1618-2001 |
CON12 | PEX4_64PINS_PEX-CONX4_WPES-064A | WPES-064AN41B22UWC | PEX-CONX4 |
CON13 | USBX1_USB_B_SMT_USB-001H-BW-U | USB-001H-BW-U | USB_B_SMT |
CON14 | CON_2X17_SUB20_CON-HEADER-17X2- | CON_2x17_SUB20 | CON-HEADER-17X2-100MIL_B |
CON15 | SDCN24-A0-6012_SDCN24-A0-6012_S | SDCN24-A0-6012 | SDCN24-A0-6012 |
CON16 | USBX1_USB-CU01_USBTYPE-A | USB Type-A | USB-CU01 |
CON17 | CON_2X6_PS3M44-206_PS3M44-206-G | PS3M44-206-GBOPOT-U | PS3M44-206 |
CON18 | BH1S-20G_JTAG_HEADER_20_JTAG20 | JTAG 20Pin | HEADER_20 |
CON19 | SI-51005-F_CON_COMBO1-4S_MAGJAC | SI-51005-F | CON_COMBO1-4S_MAGJACK |
CON20 | SI-51005-F_CON_COMBO1-4S_MAGJAC | SI-51005-F | CON_COMBO1-4S_MAGJACK |
CON21 | 5075BMR-05-SM_17105-4K27-02_171 | 17105-4K27-02 | 17105-4K27-02 |
CON22 | CON_1X2_CI0102P1VK0_1X2CON | 1x2 Con | CI0102P1VK0 |
CON23 | 104118_SD_104118_001_8_104118-0 | 104118-0811 | SD_104118_001_8 |
D1 | NUP2201MR6T1G_TSOP-6_NUP2201MR6 | NUP2201MR6T1G | TSOP-6 |
D2 | BAT54C_SOT23-1A3C-DIOD_BAT54C | BAT54C | SOT23-1A3C-DIOD |
D3 | NUP2201MR6T1G_TSOP-6_NUP2201MR6 | NUP2201MR6T1G | TSOP-6 |
D4 | NUP2201MR6T1G_TSOP-6_NUP2201MR6 | NUP2201MR6T1G | TSOP-6 |
D5 | NUP2201MR6T1G_TSOP-6_NUP2201MR6 | NUP2201MR6T1G | TSOP-6 |
D6 | ESD7104_WSD7104_ESD7104MUTAG | ESD7104MUTAG | WSD7104 |
D7 | BAT750_SOT23-1A3C-DIOD_BAT54 | BAT54 | SOT23-1A3C-DIOD |
FB24 | FERRITE_BEAD_0805_FB_120OHM | FB_120ohm | 805 |
JP1 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP2 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP3 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP4 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP5 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP6 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP7 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP8 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP9 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP10 | HEADER_1X6_PIN6_HEADER_1X6 | Header_1x6 | PIN6 |
JP11 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP12 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP13 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP14 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP15 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP16 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
JP17 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
L1 | INDUCTOR_NC_SMTPI1354-4R2M_4.2U | 4.2uH | SMTPI1354-4R2M |
L2 | INDUCTOR_SNS5040_1.2UH | 1.2uH | SNS5040 |
L3 | INDUCTOR_SNS8040_6.8UH | 6.8uH | SNS8040 |
L4 | INDUCTOR_NC_SMTPI1354-4R2M_4.2U | 4.2uH | SMTPI1354-4R2M |
L5 | INDUCTOR_UNIPAC_FDV0840_6.9UH | 6.9uH | FDV0840 |
L6 | INDUCTOR_SNS5040_1.2UH | 1.2uH | SNS5040 |
L7 | INDUCTOR_SNS5040_1.2UH | 1.2uH | SNS5040 |
L8 | INDUCTOR_UNIPAC_FDV0840_6.9UH | 6.9uH | FDV0840 |
L9 | INDUCTOR_SNS5040_1.2UH | 1.2uH | SNS5040 |
L10 | CHOKE_CMX2_DLP11TB800UL2_DLP11T | DLP11TB800UL2 | DLP11TB800UL2 |
L11 | CHOKE_CMX2_DLP11TB800UL2_DLP11T | DLP11TB800UL2 | DLP11TB800UL2 |
L12 | INDUCTOR_1008_1UH | 1uH | 1008 |
L13 | INDUCTOR_1008_1UH | 1uH | 1008 |
L14 | INDUCTOR_SMTER65-1R0M_1UH | 1uH | SMTER65-1R0M |
LED1 | LED_LED_AC-EL15-21-VGC_SMTRED | SMT RED | LED_AC-EL15-21-VGC |
LED2 | LED_LED_0603_AC_SMTGREEN | SMT Green | LED_0603_AC |
LED3 | LED_LED_0603_AC_SMTGREEN | SMT Green | LED_0603_AC |
LED4 | LED_LED_AC-EL15-21-VGC_SMTRED | SMT RED | LED_AC-EL15-21-VGC |
LED5 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED6 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED7 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED8 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED9 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED10 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
M10 | HOLE_HOLE-5P8X3P2MM_HOLE-5.8X3. | HOLE-5.8x3.2mm | HOLE-5P8X3P2MM |
M11 | HOLE_HOLE-5P8X3P2MM_HOLE-5.8X3. | HOLE-5.8x3.2mm | HOLE-5P8X3P2MM |
M12 | HOLE_HOLE-5P8X3P2MM_HOLE-5.8X3. | HOLE-5.8x3.2mm | HOLE-5P8X3P2MM |
M13 | HOLE_HOLE-5P8X3P2MM_HOLE-5.8X3. | HOLE-5.8x3.2mm | HOLE-5P8X3P2MM |
Q1 | FDS6680A_SOIC8_FDS6680A_NL | FDS6680A_NL | SOIC8 |
Q2 | FDV301N_SOT23-GSD_FDV301N | FDV301N | SOT23-GSD |
Q3 | AON6414AL_DFN_5X6_8L_EPAD_AON64 | AON6414AL | DFN_5X6_8L_EPAD |
Q4 | AON6414AL_DFN_5X6_8L_EPAD_AON64 | AON6414AL | DFN_5X6_8L_EPAD |
Q5 | AON6414AL_DFN_5X6_8L_EPAD_AON64 | AON6414AL | DFN_5X6_8L_EPAD |
Q6 | FDS6680A_SOIC8_FDS6680A_NL | FDS6680A_NL | SOIC8 |
Q7 | FDS6680A_SOIC8_FDS6680A_NL | FDS6680A_NL | SOIC8 |
Q8 | FDV301N_SOT23-GSD_FDV301N | FDV301N | SOT23-GSD |
Q9 | AON6414AL_DFN_5X6_8L_EPAD_AON64 | AON6414AL | DFN_5X6_8L_EPAD |
Q10 | AON6414AL_DFN_5X6_8L_EPAD_AON64 | AON6414AL | DFN_5X6_8L_EPAD |
Q11 | AON6414AL_DFN_5X6_8L_EPAD_AON64 | AON6414AL | DFN_5X6_8L_EPAD |
Q12 | FDS6680A_SOIC8_FDS6680A_NL | FDS6680A_NL | SOIC8 |
Q13 | FDV301N_SOT23-GSD_FDV301N | FDV301N | SOT23-GSD |
Q14 | FDC6325L_SOT23_6P_FDC6330 | FDC6330 | SOT23_6P |
Q15 | FDC6325L_SOT23_6P_FDC6330 | FDC6330 | SOT23_6P |
Q16 | FDC6325L_SOT23_6P_FDC6330 | FDC6330 | SOT23_6P |
Q17 | FDC6325L_SOT23_6P_FDC6330 | FDC6330 | SOT23_6P |
Q18 | BCX51_SOT89-MIR_BCX51-10 | BCX51-10 | SOT89-MIR |
Q19 | FDV301N_SOT23-GSD_FDV301N | FDV301N | SOT23-GSD |
Q20 | FDC6325L_SOT23_6P_FDC6330 | FDC6330 | SOT23_6P |
Q21 | FDV301N_SOT23-GSD_FDV301N | FDV301N | SOT23-GSD |
Q22 | FDC6325L_SOT23_6P_FDC6330 | FDC6330 | SOT23_6P |
SW1 | IT-1102-SMD_IT-1102-SMD_IT-1102 | IT-1102-SMD | IT-1102-SMD |
SW2 | SWPUSHBUTTON_SWITCH-IT-1102V_4 | IT-1102VC | SWITCH-IT-1102V_4PINS |
SW3 | RMR-08_RMR-08-T_RMR-08 | RMR-08 | RMR-08-T |
SW4 | SWPUSHBUTTON_SWITCH-IT-1102V_4 | IT-1102VC | SWITCH-IT-1102V_4PINS |
SW5 | SK12D07VG6D-G_SK12D07VG6D-G_SK1 | SK12D07VG6D-G | SK12D07VG6D-G |
T1 | DLW21HN121SQ2_CHOKE_0805_0805US | 0805USB-421ML | CHOKE_0805 |
T2 | DLW21HN121SQ2_CHOKE_0805_0805US | 0805USB-421ML | CHOKE_0805 |
T3 | DLW21HN121SQ2_CHOKE_0805_0805US | 0805USB-421ML | CHOKE_0805 |
T4 | DLW21HN121SQ2_CHOKE_0805_0805US | 0805USB-421ML | CHOKE_0805 |
U1 | PI2DBS6212ZHE_TQFN28_5P5X5P3_0P | PI2DBS6212ZHE | TQFN28_5P5X5P3_0P5_EP_4P05X2P05 |
U2 | 88PH88101_TSSOP-16_88PH8101-A2- | 88PH8101-A2-UBB1C000 | TSSOP-16 |
U3 | PI2DBS6212ZHE_TQFN28_5P5X5P3_0P | PI2DBS6212ZHE | TQFN28_5P5X5P3_0P5_EP_4P05X2P05 |
U4 | 88PH830_88PH830_88PH845-B1-NFB1 | 88PH845-B1-NFB1C000 | 88PH830 |
U5 | NCP380_TSOP-6A_NCP380HSNAJAAT1G | NCP380HSNAJAAT1G | TSOP-6A |
U6 | 88PH88101_TSSOP-16_88PH8101-A2- | 88PH8101-A2-UBB1C000 | TSSOP-16 |
U7 | 88F6820_BGA372_17X17_0P80_88F68 | 88F6820-Z1-BBRT2C000 | BGA372_17X17_0P80 |
U8 | K4B4G0846B-78PIN_BGA78_10P5X9X | MT41K512M8RH-107:E | BGA78_10P5X9X0P8MM |
U9 | 88PH830_88PH830_88PH845-B1-NFB1 | 88PH845-B1-NFB1C000 | 88PH830 |
U10 | K4B4G0846B-78PIN_BGA78_10P5X9X | MT41K512M8RH-107:E | BGA78_10P5X9X0P8MM |
U11 | PCA9515_TSSOP8-BODY3PITCH0P65_P | PCA9515 | TSSOP8-BODY3PITCH0P65 |
U12 | K4B4G0846B-78PIN_BGA78_10P5X9X | MT41K512M8RH-107:E | BGA78_10P5X9X0P8MM |
U13 | K4B4G0846B-78PIN_BGA78_10P5X9X | MT41K512M8RH-107:E | BGA78_10P5X9X0P8MM |
U14 | PCA9515_TSSOP8-BODY3PITCH0P65_P | PCA9515 | TSSOP8-BODY3PITCH0P65 |
U15 | MAX1510_TDFN10_3X3_0P5_EP_MAX15 | MAX1510ETB+ | TDFN10_3X3_0P5_EP |
U16 | NC7SZ126M5X_SOT23-5_NC7SZ126 | NC7SZ126 | SOT23-5 |
U17 | CAT24WC64_DIP8_CAT24C64LI-G__SK | CAT24C64LI-G__SKT | DIP8 |
U18 | NCP380_TSOP-6A_NCP380HSNAJAAT1G | NCP380HSNAJAAT1G | TSOP-6A |
U19 | 88E1512-AX_QFN56_8X8_0P50_EP_4P | 88E1512-A0-NNP2C000 | QFN56_8X8_0P50_EP_4P57 |
U20 | 88E1512-AX_QFN56_8X8_0P50_EP_4P | 88E1512-A0-NNP2C000 | QFN56_8X8_0P50_EP_4P57 |
U21 | 88PH830_88PH830_88PH845-B1-NFB1 | 88PH845-B1-NFB1C000 | 88PH830 |
U22 | CAT24WC64_DIP8_CAT24C64LI-G__SK | CAT24C64LI-G__SKT | DIP8 |
U23 | NC7SB3257P6X_SC70_NC7SB3257 | NC7SB3257 | SC70 |
U24 | NC7SB3257P6X_SC70_NC7SB3257 | NC7SB3257 | SC70 |
U25 | FT232RQ_QFN32_5X5_0P5_EP_3P20_F | FT232RQ-R | QFN32_5X5_0P5_EP_3P20 |
U26 | IP4365CX11_BGA11_1P6X1P2_0P4_MM | IP4365CX11/P | BGA11_1P6X1P2_0P4_MM |
U27 | AP1117YG_SOT89_AP1117YG-13 | AP1117YG-13 | SOT89 |
U28 | AP1117YG_SOT89_AP1117YG-13 | AP1117YG-13 | SOT89 |
U29 | NC7SZ157_SC70_NC7SZ157 | NC7SZ157 | SC70 |
U30 | PI2DBS6212ZHE_TQFN28_5P5X5P3_0P | PI2DBS6212ZHE | TQFN28_5P5X5P3_0P5_EP_4P05X2P05 |
U31 | AP1117YG_SOT89_AP1117YG-13 | AP1117YG-13 | SOT89 |
U32 | PCA9555PW_TSSOP24_7P9X4P5_0P65M | PCA9555 | TSSOP24_7P9X4P5_0P65MM |
U33 | NC7SB3257P6X_SC70_NC7SB3257 | NC7SB3257 | SC70 |
U34 | NC7SZ08XXX_SC-70-2X2P1MM_NC7SZ0 | NC7SZ08 | SC-70-2X2P1MM |
U35 | NC7SZ08XXX_SC-70-2X2P1MM_NC7SZ0 | NC7SZ08 | SC-70-2X2P1MM |
U36 | NC7SZ157_SC70_NC7SZ157 | NC7SZ157 | SC70 |
U37 | NC7SZ157_SC70_NC7SZ157 | NC7SZ157 | SC70 |
U38 | 88PG877_QFN18-4X3_88PG877-A3-NF | 88PG877-A3-NFB1C000 | QFN18-4X3 |
U39 | NC7SZ157_SC70_NC7SZ157 | NC7SZ157 | SC70 |
U40 | M25P64VMF6P_SOIC16-300MIL_M25P1 | M25P128-VMF6P | SOIC16-300MIL |
U41 | NC7SZ08XXX_SC-70-2X2P1MM_NC7SZ0 | NC7SZ08 | SC-70-2X2P1MM |
U42 | PIC16F1937_QFN44_8X8_0P65MM_EPA | PIC16F1937 | QFN44_8X8_0P65MM_EPAD_6P8 |
U43 | NC7SZ08XXX_SC-70-2X2P1MM_NC7SZ0 | NC7SZ08 | SC-70-2X2P1MM |
U44 | PCA9560PW_TSSOP-20_PCA9560PW | PCA9560PW | TSSOP-20 |
U45 | PCA9555PW_TSSOP24_7P9X4P5_0P65M | PCA9555 | TSSOP24_7P9X4P5_0P65MM |
U46 | NC7SZ08XXX_SC-70-2X2P1MM_NC7SZ0 | NC7SZ08 | SC-70-2X2P1MM |
Y1 | CRYSTAL_CCA_2X6_32.768KHZ | 32.768KHz | CCA_2X6 |
Y2 | CXA-025000_CXA_SMD_3P2X2P5_25MH | 25MHz | CXA_SMD_3P2X2P5 |
Y3 | CXA-025000_CXA_SMD_3P2X2P5_25MH | 25MHz | CXA_SMD_3P2X2P5 |
Y4 | CXA-025000_CXA_SMD_3P2X2P5_25MH | 25MHz | CXA_SMD_3P2X2P5 |
