TA的每日心情 | 开心 2024-6-20 15:58 |
签到天数: 1 天 [LV.1]初来乍到
长期免费代管18-28岁小
- 8256
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | F3 | CR3216-1206 | CBW321609U102 | CR3216-1206 | F4 | CR3216-1206 | CBW321609U102 | CR3216-1206 | GND | PAD_TEST | TESTPAD | PAD_TEST | HP1 | HP1521 | HFBR1521 | HP1521 | HP2 | HP1521 | HFBR1521 | HP1521 | HP3 | HP1521 | HFBR1521 | HP1521 | HP4 | HP1521 | HFBR1521 | HP1521 | HP5 | HP1521 | HP2521 | HP1521 | HP6 | HP1521 | HP2521 | HP1521 | IA | PAD_TEST | TESTPAD | PAD_TEST | IB | PAD_TEST | TESTPAD | PAD_TEST | IC | PAD_TEST | TESTPAD | PAD_TEST | J1 | SIP2_10 | Jump | SIP2_10 | J2 | SIP2_10 | Jump | SIP2_10 | J3 | SIP2_10 | Jump | SIP2_10 | J4 | SIP2_10 | Jump | SIP2_10 | JP1 | SIP3_10 | Switch | SIP3_10 | JP2 | SIP3_10 | Switch | SIP3_10 | JP3 | SIP3_10 | Switch | SIP3_10 | N1 | SOP14-050-240 | SMT_LM124D | SOP14-050-240 | N2 | SOP14-050-240 | SMT_LM124D | SOP14-050-240 | N3 | SOP14-050-240 | SMT_LM124D | SOP14-050-240 | N4 | SOP14-050-240 | SMT_LM124D | SOP14-050-240 | N5 | SOP14-050-240 | SMT_LM124D | SOP14-050-240 | N6 | SOP14-050-240 | SMT_LM124D | SOP14-050-240 | N7 | SOP14-050-240 | SMT_LM124D | SOP14-050-240 | N8 | SOP14-050-240 | SMT_LM124D | SOP14-050-240 | N9 | SOP8-50-220 | SMT_LM111D | SOP8-50-220 | N11 | SOP8-50-220 | SMT_LM111D | SOP8-50-220 | RL1 | DJ140 | | DJ140 | RL2 | DJ140 | | DJ140 | RL3 | DJ140 | | DJ140 | RL4 | DJ140 | | DJ140 | RL5 | DJ140 | | DJ140 | RL6 | DJ140 | | DJ140 | RL7 | DJ140 | | DJ140 | RL8 | DJ140 | | DJ140 | RP2 | SIP9_8 | 10K | SIP9_8 | RP6 | SIP5_8 | 4.7K | SIP5_8 | RP8 | SIP7_8 | 4.7K | SIP7_8 | RP9 | SIP9_8 | 10K | SIP9_8 | SW1 | SMD_SW | SMT_SW | SMD_SW | SW3 | DIP8 | SW-DIP4 | DIP8 | T1 | PT | PT | PT | T2 | PT | PT | PT | T3 | CT | CT | CT | T4 | CT | CT | CT | T5 | CT | CT | CT | U1 | SOP14-050-240 | SMT_74HC14D_3.3V | SOP14-050-240 | U2 | BATTERY | BATTERY | BATTERY | U3 | SOP44-32-460 | IS61LV25616AL-10TI | SOP44-32-460 | U4 | DIP28 | MAX1480B | DIP28 | U5 | SOP14-050-240 | SMT_74HC14D_3.3V | SOP14-050-240 | U6 | SOP14-050-240 | SMT_74HC14D_3.3V | SOP14-050-240 | U7 | QFP10X10-G44_Y1_95N | AD7865AS-1 | QFP10X10-G44_Y1_95N | U8 | SOP8-50-220 | X5163PI-2.7A | SOP8-50-220 | U9 | SOIC8WA | DS1302SN | SOIC8WA | U10 | 8S1 | AT24C16 | 8S1 | U11 | SOP8-50-220 | TPS76801QD | SOP8-50-220 | U12 | QFP176-050-2626L | TMS320F2812PGFA | QFP176-050-2626L | U13 | SIP-G5_D17 | TPS75733KTTT | SIP-G5_D17 | U14 | DIP18 | 2803R | DIP18 | U15 | SOP48-020-320 | SN74ALVC164245DGGR | SOP48-020-320 | U17 | SOP48-020-320 | SN74ALVC164245DGGR | SOP48-020-320 | U18 | SOP48-020-320 | SN74ALVC164245DGGR | SOP48-020-320 | U19 | QFP144-050-2020L | EPM1270T144 | QFP144-050-2020L | U20 | DIP28 | MAX1480B | DIP28 | U21 | SOP14-050-240 | SMT_74HC14D | SOP14-050-240 | U22 | SOP14-050-240 | SMT_74HC14D | SOP14-050-240 | U32 | LP03NEW | TL431ACLPR | LP03NEW | UM1 | PAD_TEST | TESTPAD | PAD_TEST | US1 | PAD_TEST | TESTPAD | PAD_TEST | UT1 | PAD_TEST | TESTPAD | PAD_TEST | V1 | 318-08 | MMBD4148SE | 318-08 | V15 | 318-08 | MMBD4148SE | 318-08 | V16 | DO-214AB | SMCJ170A | DO-214AB | V17 | DO-214AB | SMCJ170A | DO-214AB | V18 | DO-214AB | SMCJ170A | DO-214AB | V19 | DO-214AB | SMCJ170A | DO-214AB | V20 | DO-214AB | SMCJ170A | DO-214AB | V21 | DO-214AB | SMCJ170A | DO-214AB | V22 | DO-214AB | SMCJ170A | DO-214AB | V23 | DO-214AB | SMCJ170A | DO-214AB | V24 | 318-08 | MMBD4148 | 318-08 | V25 | TO-220 | BU406 | TO-220 | V26 | 318-08 | MMBD4148SE | 318-08 | V27 | ES1D | ES1D | ES1D | V28 | ES1D | ES1D | ES1D | V29 | ES1D | ES1D | ES1D | V30 | ES1D | ES1D | ES1D | V31 | 318-08 | MMBT2222A | 318-08 | V32 | 318-08 | MMBD4148 | 318-08 | V33 | 318-08 | MMBT2222A | 318-08 | V34 | 318-08 | MMBD4148 | 318-08 | V35 | 318-08 | MMBT2222A | 318-08 | V36 | 318-08 | MMBT2222A | 318-08 | V37 | DO-214AB | SMCG5.0A | DO-214AB | V38 | DO-214AB | SMCG5.0A | DO-214AB | V39 | DO-214AB | SMCG5.0A | DO-214AB | V40 | 318-08 | MMBD4148 | 318-08 | V41 | 318-08 | MMBD4148 | 318-08 | V42 | DO-214AC | IN4007 | DO-214AC | V43 | DO-214AC | IN4007 | DO-214AC | V44 | DO-214AC | IN4007 | DO-214AC | V45 | DO-214AC | IN4007 | DO-214AC | V46 | DO-214AC | IN4007 | DO-214AC | V47 | DO-214AC | IN4007 | DO-214AC | V48 | DO-214AC | IN4007 | DO-214AC | V49 | DO-214AC | IN4007 | DO-214AC | V50 | DO-214AC | IN4007 | DO-214AC | V51 | DO-214AC | IN4007 | DO-214AC | V52 | DO-214AC | IN4007 | DO-214AC | V53 | DO-214AC | IN4007 | DO-214AC | V54 | DO-214AC | IN4007 | DO-214AC | V55 | DO-214AC | IN4007 | DO-214AC | V56 | DO-214AC | IN4007 | DO-214AC | V57 | DO-214AC | IN4007 | DO-214AC | V58 | 425 | MMSZ5240B | 425 | V59 | 425 | MMSZ5240B | 425 | V60 | 425 | MMSZ5240B | 425 | V61 | 425 | MMSZ5240B | 425 | V62 | DO-214AC | IN4007 | DO-214AC | V63 | DO-214AC | IN4007 | DO-214AC | V64 | DO-214AC | IN4007 | DO-214AC | V65 | DO-214AC | IN4007 | DO-214AC | V66 | DO-214AC | IN4007 | DO-214AC | V67 | DO-214AC | IN4007 | DO-214AC | V68 | DO-214AC | IN4007 | DO-214AC | V69 | DO-214AC | IN4007 | DO-214AC | V70 | DO-214AC | IN4007 | DO-214AC | V71 | DO-214AC | IN4007 | DO-214AC | V72 | DO-214AC | IN4007 | DO-214AC | V73 | DO-214AC | IN4007 | DO-214AC | V74 | DO-214AC | IN4007 | DO-214AC | V75 | DO-214AC | IN4007 | DO-214AC | V76 | DO-214AC | IN4007 | DO-214AC | V77 | DO-214AC | IN4007 | DO-214AC | V78 | 425 | MMSZ5240B | 425 | V79 | 425 | MMSZ5240B | 425 | V80 | 425 | MMSZ5240B | 425 | V81 | 425 | MMSZ5240B | 425 | V82 | DO-214AC | IN4007 | DO-214AC | V83 | DO-214AC | IN4007 | DO-214AC | V84 | DO-214AC | IN4007 | DO-214AC | V85 | DO-214AC | IN4007 | DO-214AC | V86 | DO-214AC | IN4007 | DO-214AC | V87 | DO-214AC | IN4007 | DO-214AC | V88 | DO-214AC | IN4007 | DO-214AC | V89 | DO-214AC | IN4007 | DO-214AC | VD1 | DIP4 | TLP521 | DIP4 | VD2 | DIP4 | TLP521 | DIP4 | VD3 | DIP4 | TLP521 | DIP4 | VD4 | DIP4 | TLP521 | DIP4 | VD5 | DIP4 | TLP521 | DIP4 | VD6 | DIP4 | TLP521 | DIP4 | VD7 | DIP4 | TLP521 | DIP4 | VD8 | DIP4 | TLP521 | DIP4 | W1 | RP2_1 | 10K | RP2_1 | W2 | RP2_1 | 10K | RP2_1 | W3 | RP2_1 | 10K | RP2_1 | W4 | RP2_1 | 10K | RP2_1 | W5 | RP2_1 | 10K | RP2_1 | W6 | RP2_1 | 10K | RP2_1 | W7 | RP2_1 | 10K | RP2_1 | X1 | MSTB_2_5_12-GF-5_08 | MSTB_2.5/12-GF-5.08 | MSTB_2_5_12-GF-5_08 | X2 | MSTB_2_5_12-GF-5_08 | MSTB_2.5/12-GF-5.08 | MSTB_2_5_12-GF-5_08 | X4 | HEADER_2X7 | CH14 | HEADER_2X7 | X5 | HEADER_2X5 | CH14 | HEADER_2X5 | X7 | HEADER_2X20 | JP2X20 | HEADER_2X20 | X8 | MSTB_2_5_2-5_08 | MSTB_2.5/2--5.08 | MSTB_2_5_2-5_08 | X9 | HEADER_2X10_LCD | JP2X10_LCD | HEADER_2X10_LCD | X10 | MSTB_2_5-6-GF-5_08 | MSTB_2.5/6-GF-5.08 | MSTB_2_5-6-GF-5_08 | X11 | HEADER_2X6 | CH15 | HEADER_2X6 | X12 | MSTB_2_5-4-GF-5_08 | MSTB_2.5/4-GF-5.08 | MSTB_2_5-4-GF-5_08 | X13 | HEADER_2X6 | CH15 | HEADER_2X6 | X14 | MSTB_2_5-4-GF-5_08 | MSTB_2.5/4-GF-5.08 | MSTB_2_5-4-GF-5_08 | X15 | MSTB_2_5-6-GF-5_08 | MSTB_2.5/6-GF-5.08 | MSTB_2_5-6-GF-5_08 | X16 | SIP7_10 | SIP7.10 | SIP7_10 | X17 | MSTB_2_5-4-GF-5_08 | MSTB_2.5/4-GF-5.08 | MSTB_2_5-4-GF-5_08 | Y1 | XTAL | 32.768K | XTAL | Y2 | XTAL | 30M | XTAL | Y3 | ZPB26 | ZPB26 | ZPB26 |
2812.7z
(973 KB, 下载次数: 13)
