新手练习的板子,没什么参考价值。有需要封装的下载提取。
MSD3463.7z
(277 KB, 下载次数: 35)
请输入描述
Name | PCB Decal | Value | Part Type | A01 | TUNER_RF_PART | 屏蔽盒子13X9 | TUNER_RF_PART | CA1 | CE6.5MM-2.5MM | P12/470UF/10V | CE6.5MM-2.5MM | CA2 | CE6.5MM-2.5MM | 220UF/16V | CE6.5MM-2.5MM | CA3 | CE6.5MM-2.5MM | 220UF/16V | CE6.5MM-2.5MM | CA4 | CE5MM-2MM | 100UF/16V | CE5MM-2MM | CA5 | CE5MM-2MM | 47UF/16V | CE5MM-2MM | CA6 | CE8MM | 470UF/16V | CE8MM | CA7 | CE5MM-2MM | 100UF/16V | CE5MM-2MM | CN1 | CON04-2.0 | CN4-2.0 | CON04 | CN2 | J-B2.0-14P-L | CON14-2.0MM | J-B2.0-14P-L | CN8 | J-A2.0-15PX2-L | CON40-2X15 | J-A2.0-15PX2-L | CN9 | HK-PHA-2.54-3P-LD | 3P2.5MM | HK-PHA-2.54-3P-LD | CN14 | HK-PHA-2.54-2P-LD | 3P2.5MM | HK-PHA-2.54-2P-LD | CON1 | DC-JACK3P | DC-3IN | DC-JACK3P | CON2 | CN-2.0-6PB | CN6P-2.0R | CN-2.0-6P | CON3 | G_HDMI-1 | HDMI-W | G_HDMI | CON4 | G_AV3_8.4_30 | AV3 | G_AV3-1 | CON5 | CN-2.0-4P | P2/CN4P-2.0R | CN-2.0-4P | CON7 | CN-2.0-4PA | CON4_2.0 | CN-2.0-4P | CON10 | VGAS | VGA-W | VGAS | CON11 | G_EARPHONE5-A | PHONEJACK | G_EARPHONE5-A | CON13 | G_EARPHONE5-A | PHONEJACK | G_EARPHONE5-A | CON14 | HK-USB2.0-001-WD | USB-A | HK-USB2.0-001-WD | CP21 | C0402 | 0.1UF | C0402 | CT0 | C0402 | NC/8.2PF | C0402 | CT1 | C0402 | NC/8.2PF | C0402 | CT25 | C0402 | 470PF | C0402 | CT27 | C0402 | 0.1UF | C0402 | CT29 | C0402 | 0.1UF | C0402 | CT32 | C0402 | 0.1UF | C0402 | CT33 | C0402 | 0.1UF | C0402 | D1 | D4148 | 1N4148 | D4148 | D202 | SOT-23 | BAV99 | SOT-23 | D410 | D0402 | NC | D0402 | D411 | D0402 | NC | D0402 | D601 | D0402 | NC/AZ5123 | D0402 | D602 | D0402 | NC/AZ5123 | D0402 | DT412 | T_SOT-23 | BAV99 | T_SOT-23 | FB201 | L0603 | 150MA/1K | L0603 | FB203 | L0402 | 0R | L0402 | FB204 | L0402 | 0R | L0402 | FB205 | L0402 | 150MA/120R | L0402 | FB206 | L0402 | 0R | L0402 | FB210 | L0402 | 150MA/120R | L0402 | FB211 | L0402 | 150MA/120R | L0402 | H1 | HK-HOLE-3.5 | NC | HK-HOLE-3.5 | H2 | HK-HOLE-3.5 | NC | HK-HOLE-3.5 | H3 | HK-HOLE-3.5 | NC | HK-HOLE-3.5 | H4 | HK-HOLE-3.5 | NC | HK-HOLE-3.5 | H105 | TPAD | NC | TPAD | H106 | TPAD | NC | TPAD | H107 | TPAD | NC | TPAD | L1 | LP5.5MMX2.5MM_2MM1 | 4.7uH | LD05_3 | L104 | LP5.5MMX2.5MM_2MMA_CT | 4.7UH/3A | 5.5X2.5X2MMA | L1017 | R0402 | 220NH | R0402 | L1018 | R0402 | 220NH | R0402 | LT16 | L0402 | 180NH | L0402 | LT18 | L0402 | GZ1005D102CTF | L0402 | LT19 | L0402 | 68NH | L0402 | LT24 | L0402 | GZ1005D102CTF | L0402 | N1 | N_SOT23-6L | mp1471 | N_MP1470 | PD1 | SR562A | RF107 | DIODE | Q1 | SOT-23 | MMBT3904 | SOT-23 | Q2 | SOT-23 | MMBT3904 | SOT-23 | Q3 | SOT-23 | MMBT3904 | SOT-23 | Q4 | SOT-23 | MMBT3906 | SOT-23 | Q101 | SOT-23 | 3904 | SOT-23 | Q304 | T_SOT-23 | MMBT3904 | T_SOT-23 | Q305 | T_SOT-23 | AO3401A | T_SOT-23 | QP3 | SOT-23 | 3904 | SOT-23 | QP4 | SOT23-100 | 3401 | SOT23-100 | U1 | SOT-223 | AS1117L-3.3 | SOT-223 | U2 | TO-252 | 1117-3.3 | TO-252 | U3 | DIP18 | TDA1517P | DIP18 | U9 | IC-128P-LQFP-14X14A | MSD3463GU | IC-128P-LQFP-14X14 | U105 | SOT-23-6 | SY8009B/2A | SOT-23-6 | U106 | SOT-223 | 1117-1.8V | SOT-223 | U204 | SOP8-255-50 | EN25Q32 | SOP8-255-50 | U905 | QFN_24-NEW | R840 | QFN_24-NEW | XT2 | XTAL49S | 16MHZ/16PF | XTAL49S | Y201 | XTAL\HC49\F | 24MHZ | XTAL\HC49\F |
