查看: 8033|回复: 40
[Allegro16.6以下] 飞思卡尔 8层 工业核心板 IMX536D(IMX535D)+MC34708  PCB
    17万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2017-9-19 21:42:55 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    D1LED_LED_0603_IC_0.8MM_370-75077LED_GREENLED_0603
    D2ZDIODE_SOD123_IC_1.35MM_480-768MMSZ5231BT1GSOD123
    D4DIODE_TVS_SOD-923_IC_0.40MM_480ESD9L5.0ST5GSOD-923
    D9LED_LED_0603_IC_0.8MM_370-75077LED_GREENLED_0603
    D10LED_LED_0603_IC_0.8MM_370-75078BLUELED_0603
    D11LED_LED_0603_IC_0.8MM_370-75078BLUELED_0603
    D12LED_LED_0603_IC_0.8MM_370-75078BLUELED_0603
    D13LED_LED_0603_IC_0.8MM_370-75078BLUELED_0603
    D14LED_LED_0603_IC_0.9MM_370-75079REDLED_0603
    D16LED_LED_0603_IC_0.8MM_370-75077LED_GREENLED_0603
    D17SR05_SOT_143_IC_1.22MM_480-7809SR05SOT_143
    D18SR05_SOT_143_IC_1.22MM_480-7809SR05SOT_143
    D19DIODE_SCHTKY_DO_TSLP2_IC_0.4MM_BAS3010SDO_TSLP2
    D21DUALDIODE_CA_SOT23_SOT23_IC_1.1BAT54A-7-FSOT23
    F1FUSE_RST_FUSE_1P6X0P8_IC_0.55MMSF-0603FFUSE_1P6X0P8
    F2FUSE_RESETTABLE_IND_1210_IC_0.41.1AIND_1210
    J1DC POWERJACK_PJ-202B_IO_11MM_2CON_1_PWRPJ-202B
    J2CONN_RJ45_DUAL_USB_22F_HYBRID_CHYBRID DUAL USB +RJ45CON_RJ45_USB_22F_50_TH_RA_C
    J3MICRO_USB_CON5_MICROUSB_SKT_SM_47346-0001CON5_MICROUSB_SKT_SM
    J4CONN_SDCARD_1X12_F_CON_SDCARD_1SD/MMC SKTCON_SDCARD_12F_43_SM_RA
    J5CONN_SDC013_19P_CON19_SDCARD_28CONN CRD 19CON19_SDCARD_28X16_SM
    J6SJ-43515TS_CON5_AUD_JACK_RA_TH_AUD_5CON5_AUD_JACK_RA_TH_SJ-43515TS
    J7SATA_PLUG7_CON7_SATA_TH_17X5MM_CON 7 SATACON7_SATA_TH_17X5MM
    J8CONN_HDSUB15P_F_MTABS_CON_DB_15DB15 SMTCON_DB_15F_29_SM_RA
    J9CON30_CON_DF_30F_1MM_SM_RA_IO_1CON 30CON_DF_30F_1MM_SM_RA
    J13QSH060_CON_120S_QSH_SM_05PITCH_QSH-060-01-L-D-ACON_120S_QSH_SM_05PITCH
    J15TSW-110-05-G-D_HDR210_TST_RA_IOTST-110-05-T-D-RAHDR210_TST_RA
    J16CONN_DB9F_MTGTABS_CON_DB9P_190-DB 9CON_DB9P_190-009-263R001
    J18SJ-43515TS_CON5_AUD_JACK_RA_TH_AUD_5CON5_AUD_JACK_RA_TH_SJ-43515TS
    L1INDUCTOR_VLC5020_DISCRETE_2.0MM3.3UHVLC5020
    L2INDUCTOR_IND_0402_DISCRETE_0.55120OHMIND_0402
    L4INDUCTOR_IND_0402_DISCRETE_0.55120OHMIND_0402
    L5DLW43_CHOKE_0805_DISCRETE_1MM_190OHMCHOKE_0805
    L6DLW43_CHOKE_0805_DISCRETE_1MM_190OHMCHOKE_0805
    L7BEAD_0603_CC_DISCRETE_0.95MM_18120OHM0603_CC
    L8INDUCTOR_IND_0402_DISCRETE_0.55120OHMIND_0402
    L9BEAD_0603_CC_DISCRETE_0.95MM_18120OHM0603_CC
    L10BEAD_IND_0603_DISCRETE_0.95MM_1120OHMIND_0603
    L11INDUCTOR_IND_0402_DISCRETE_0.55120OHMIND_0402
    L12BEAD_IND_0603_DISCRETE_0.95MM_1120OHMIND_0603
    L14INDUCTOR_IND_VLS252010_DISCRETE1UHIND_VLS252010
    L16INDUCTOR_IND_VLS252010_DISCRETE1UHIND_VLS252010
    L17INDUCTOR_IND_VLS252010_DISCRETE1UHIND_VLS252010
    L19BEAD_0603_CC_DISCRETE_0.95MM_18120OHM0603_CC
    L20INDUCTOR_FERRITE_IND_0402_DISCR220OHMIND_0402
    L21INDUCTOR_FERRITE_IND_0402_DISCR220OHMIND_0402
    L22INDUCTOR_FERRITE_IND_0402_DISCR220OHMIND_0402
    L23INDUCTOR_FERRITE_IND_0402_DISCR220OHMIND_0402
    L24INDUCTOR_FERRITE_IND_0402_DISCR220OHMIND_0402
    L25INDUCTOR_FERRITE_IND_0402_DISCR220OHMIND_0402
    L26BEAD_IND_0402_DISCRETE_0.55MM_1600 OHMIND_0402
    L27INDUCTOR_IND_0402_DISCRETE_0.55120OHMIND_0402
    L28INDUCTOR_IND_0402_DISCRETE_0.55120OHMIND_0402
    L29INDUCTOR_IND_1210_DISCRETE_1.7MBRL3225IND_1210
    L30INDUCTOR_VLC5020_DISCRETE_2.0_10.47UHVLC5020
    LED2LED_LED1206_IC_1.2MM_370-76344_GREENLED1206
    Q2TRAN_PMOS_MICROFET_MLP6_2X2MM_SFDMA291PMLP6_2X2MM_SLUG
    Q4PNP_DUAL_SOT363_IC_1.1MM_480-77MBT3906DW1T1SOT363
    Q8PNP_1_SOT-563_IC_0.60MM_480-766NSS12100XV6T1GSOT-563
    Q9MOSFET_2N_CHAN_SC70-6_IC_1.1MM_BSS138DW-7SC70-6
    Q10MOSFET_2N_CHAN_SC70-6_IC_1.1MM_BSS138DW-7SC70-6
    Q11MOSFET_2N_CHAN_SC70-6_IC_1.1MM_BSS138DW-7SC70-6
    Q12MOSFET_2N_CHAN_SC70-6_IC_1.1MM_BSS138DW-7SC70-6
    Q14MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401SOT-23
    Q152N7002_SOT23_IC_1.3MM_480-751592N7002SOT23
    Q16PNP_1_SOT-563_IC_0.60MM_480-766NSS12100XV6T1GSOT-563
    Q17PNP_1_SOT-563_IC_0.60MM_480-766NSS12100XV6T1GSOT-563
    Q18NPN_SOT23_IC_1.12MM_480-75757_MMMBT3904SOT23
    QZ2CRYSTAL_1P8X3P5_IC_0.9MM_230-332.768KHZ1P8X3P5
    SH29RES_SHORT-2_SH0603_DISCRETE_4700SH0603
    SH31RES_SHORT-2_SH0805_DISCRETE_470SOLDER SHORTSH0805
    SH32RES_SHORT-2_SH0603_DISCRETE_4700SH0603
    SH33RES_SHORT-2_SH0805_DISCRETE_470SOLDER SHORTSH0805
    SH35RES_SHORT-2_SH0402_DISCRETE_4700SH0402
    SH36RES_SHORT-2_SH0402_DISCRETE_4700SH0402
    SH37RES_SHORT-2_SH0402_DISCRETE_4700SH0402
    SS5SPACER_SPACER_150T_IC_16.13MM_2.635" LONGSPACER_150T
    SW1SW_DIP-10_DIP10_1P27MM_SM_IC_1.SW_DIP-10/SMDIP10_1P27MM_SM
    SW3SW_SPNO_2P_SW2_SPST_4X3_SM_IC_2TL1015AF160QGSW2_SPST_4X3_SM
    SW4SW_SPNO_2P_SW2_SPST_4X3_SM_IC_2TL1015AF160QGSW2_SPST_4X3_SM
    SW5SW_SPNO_2P_SW2_SPST_4X3_SM_IC_2TL1015AF160QGSW2_SPST_4X3_SM
    SW6SW_SPNO_2P_SW2_SPST_4X3_SM_IC_2TL1015AF160QGSW2_SPST_4X3_SM
    SW7SW_SPNO_2P_SW2_SPST_4X3_SM_IC_2TL1015AF160QGSW2_SPST_4X3_SM
    TP1TEST PAD_C035S_IC_0.1MM_280-75TEST POINTC035S
    TP2TEST PAD_C035S_IC_0.1MM_280-75TEST POINTC035S
    TP3TESTPAD_TESTPOINT_39MIL_IC_0MM1 mmTESTPOINT_39MIL
    TP4TESTPAD_TESTPOINT_39MIL_IC_0MM1 mmTESTPOINT_39MIL
    TP5TESTPAD_TESTPOINT_39MIL_IC_0MM1 mmTESTPOINT_39MIL
    TP6TESTPAD_TESTPOINT_39MIL_IC_0MM1 mmTESTPOINT_39MIL
    TP8TESTPAD_TESTPOINT_39MIL_IC_0MM1 mmTESTPOINT_39MIL
    TP9TESTPAD_TESTPOINT_39MIL_IC_0MM1 mmTESTPOINT_39MIL
    TP10TESTPAD_TESTPOINT_39MIL_IC_0MM1 mmTESTPOINT_39MIL
    TP12TESTPAD_TESTPOINT_39MIL_IC_0MM1 mmTESTPOINT_39MIL
    TP22TESTPAD_TESTPOINT_39MIL_IC_0MM1 mmTESTPOINT_39MIL
    TP63TESTLOOP_TPAD_020_IO_0.1MM_211-TPAD_020TPAD_020
    TP64TESTLOOP_TPAD_020_IO_0.1MM_211-TPAD_020TPAD_020
    U2IMX536D_TEPBGA_529P_A_PBGA529_0PCIMX535DVV1CPBGA529_0P8MM
    U32G_DDR3_SDRAM_128MX16_96P_BGA96MT41J128M16HA-15EBGA96_0P8_9P15X14P15
    U42G_DDR3_SDRAM_128MX16_96P_BGA96MT41J128M16HA-15EBGA96_0P8_9P15X14P15
    U52G_DDR3_SDRAM_128MX16_96P_BGA96MT41J128M16HA-15EBGA96_0P8_9P15X14P15
    U62G_DDR3_SDRAM_128MX16_96P_BGA96MT41J128M16HA-15EBGA96_0P8_9P15X14P15
    U71G125_SC70-5_A_1.1MM_312-30153_NC7SP125P5XSC70-5_A
    U9SGTL5000_QFN32_0.9MM_315-77907_SGTL5000 32QFNQFN32
    U121T45_SOT23-6_IC_1.45MM_312-754774LVC1T45SOT23-6
    U131T45_SOT23-6_IC_1.45MM_312-754774LVC1T45SOT23-6
    U14TXB0102_PSOP8_IC_0.9MM_315-7889TXS0102PSOP8
    U15SRV05-4_SOT23_S6_IC_1.45MM_480-SRV05-4SOT23_S6
    U16SRV05-4_SOT23_S6_IC_1.45MM_480-SRV05-4SOT23_S6
    U17LAN8720A-QFN24_QFN24_4X4MM_SLUGLAN8720AQFN24_4X4MM_SLUG
    U23MMA8450QT_16P_QFN5X3_0P5_3X3_ICMMA8450QTQFN5X3_0P5_3X3
    U24SP3232E_SSOP16_IC_1.99MM_312-77SP3232SSOP16
    U251T45_SOT23-6_IC_1.45MM_312-754774LVC1T45SOT23-6
    U261T45_SOT23-6_IC_1.45MM_312-754774LVC1T45SOT23-6
    U27MC34708_PWRMGT_BGA_206P_BGA206_MC34708BGA206_0P8_13X13
    U28FAN5354_12P_MLP12_0P5_3X3P5_IC_FAN5354MLP12_0P5_3X3P5
    U29NCP1595A_DFN6_6P_DFN6_0P95_3X3MNCP1595AMNR2GDFN6_0P95_3X3MM
    X1OSC4_SM_7X5MM_IC_1.9MM_230-30050MHz7X5MM
    Y1XTAL_13Y_A_XTAL4_SX_3225_IC_0.724MHzXTAL4_SX_3225
    imx536x.7z (2.04 MB, 下载次数: 18)
    重要提示:PCB作品文件展下载说明
    发表于 2017-9-19 21:54:18 | 显示全部楼层
    3 小时前
  • 签到天数: 127 天
    你必须非常努力才能显
    发表于 2017-9-20 07:05:10 | 显示全部楼层
    郁闷
    2024-11-7 10:22
  • 签到天数: 9 天
    发表于 2017-9-20 07:13:57 | 显示全部楼层
    PADS-171101高级班
    终身成就奖社区居民优秀斑竹奖特殊贡献奖
    发表于 2017-9-20 08:06:37 | 显示全部楼层
  • 签到天数: 19 天
    终身成就奖优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2017-9-20 08:06:52 | 显示全部楼层
    社区居民忠实会员终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2017-9-20 08:11:10 | 显示全部楼层
    无聊
    2024-9-15 15:54
    发表于 2017-9-20 08:19:01 | 显示全部楼层
    发表于 2017-9-20 08:25:38 | 显示全部楼层
    1元学习PADS(2期)
    发表于 2017-9-20 08:28:47 | 显示全部楼层
