重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | ANT10 | ANT_3PIN | ANT-3PIN | ANT_3PIN | ANT11 | ANT_3PIN | ANT-3PIN | ANT_3PIN | D24 | ESD0402 | NC/ESD5451X | ESD0402 | D25 | ESD0402 | NC/ESD9B5VL-2/TR | ESD0402 | D26 | ESD0402 | NC/ESD9B5VL-2/TR | ESD0402 | D27 | ESD0402 | NC/ESD9B5VL-2/TR | ESD0402 | D28 | LED-DIP1 | RED_BLUE_LED | LED-DIP1 | D29 | SOD123 | IN4736(5.6V) | SOD123 | D35 | SOD123 | IN5819SL | SOD123 | D36 | SOD123 | IN5819SL | SOD123 | DC1 | ESD0402 | ESD5451X | ESD0402 | DH2 | ESD0402 | ESD5451X | ESD0402 | DH3 | ESD0402 | ESD5451X | ESD0402 | DH4 | ESD0402 | ESD5451X | ESD0402 | DH5 | ESD0402 | ESD5451X | ESD0402 | DH8 | ESD0402 | ESD5451X | ESD0402 | DK1 | ESD0402 | NC/ESD5451X | ESD0402 | DR5 | R0402A | 240-1% | R0402 | DU3 | ESD0402 | ESD9B5VL-2/TR | ESD0402 | DU4 | ESD0402 | ESD9B5VL-2/TR | ESD0402 | ESD2 | ESD0402 | NC/ESD5451X | ESD0402 | FB9 | L0603 | 0R | L0603 | H1 | VIA-M3 | H1 | VIA-M3 | H2 | VIA-M3 | H1 | VIA-M3 | H5 | VIA-120 | H1 | VIA-120 | H6 | VIA-120 | H1 | VIA-120 | H7 | VIA-78 | H1 | VIA-78 | H8 | VIA-78 | H1 | VIA-78 | J3 | AV3-8.4-5 | AV3-8.4-5 | AV3-8.4-5 | J5 | SIP5-2.54MM | PH-2.54X5 | SIP5-2.54MM | J6 | PH-2.54X5A | PH-2.54X5 | PH-2.54X5A | J10 | RJ-45B | RJ45A | RJ-45B | J12 | DC-JACK | DC-208 | DC-JACK | J21 | CON4_2.54 | PH-4A | CON4_2.54 | J25 | XH-2-2_54 | XH-2-2_54 | XH-2-2_54 | JH1 | HDMI\YKF45-7012-1 | HDMI_19PLUG | HDMI\YKF45-7012-1 | JU2 | USB_AF_3.0_SIDE_M | USB_AF_3.0_SIDE_M | USB_AF_3.0_SIDE_M | K1 | TS-026-3 | TS-026-3 | TS-026-3 | L15 | PL_3X3_0.015 | NC/3.3UH | PL_3X3_0.015 | LP2 | CD35 | 1.5UH_3ADCR_0.1R | CD35 | LP3 | CD35 | 1.5UH_3ADCR_0.1R | CD35 | LP4 | CD35 | 1.5UH_3ADCR_0.1R | CD35 | LP5 | CD35 | 1.5UH_2ADCR_0.1R | CD35 | LP6 | CD35 | 1.5UH_2ADCR_0.1R | CD35 | MASK1 | SMD | SMD | SMD | MASK2 | SMD | SMD | SMD | MASK3 | SMD | SMD | SMD | MASK4 | SMD | SMD | SMD | OR1 | R0402A | 100K | R0402 | OR2 | R0402A | 4.7K1% | R0402 | OU2 | SOT23-5 | LPW5210 | SOT23-5 | P2 | USB-AF-04-004C | USB-AF-04-004C | USB-AF-04-004C | QC1 | SOT-23 | BSN20 | SOT-23 | QH1 | SOT-23 | BSN20 | SOT-23 | QH2 | SOT-23 | BSN20 | SOT-23 | QH3 | SOT-23 | BSN20 | SOT-23 | QL1 | SOT-23 | MMBT3904 | SOT-23 | QL2 | SOT-23 | MMBT3904 | SOT-23 | U1 | H6 | H6-BGA-1219 | H6 | U19 | TSSOP14 | SGM89000 | TSSOP14 | U23 | SMDTR16P | PM44-11BP | SMDTR16P | U24 | IIR | IR_MODULE | IIR | U39 | 8189ETV | 8189ETV | 8189ETV | U50 | SOT23-5 | LP3987H-33B5F | SOT23-5 | UD1 | LPDDR3_FBGA178 | LPDDR3_FBGA178 | LPDDR3_FBGA178 | UH1 | RCLAMP0524P | AZ1345-04F | RCLAMP0524P | UH2 | RCLAMP0524P | AZ1345-04F | RCLAMP0524P | UN1 | EMMCA | EMMC5_0_BGA169 | EMMC | UN2 | TSOP48 | NC/H27UCG8T2BTRBC | TSOP48 | UP2 | QFN56P40B700_700H75 | AXP805 | QFN56P40B700_700H75 | UU2 | RCLAMP0524P | AZ1345-04F | RCLAMP0524P | X1 | XTAL_3225 | 24M_20PF_10PPM | XTAL_3225 | X2 | XTAL_3225 | 24M_20PF_10PPM | XTAL_3225 | X3 | MC-146 | 32K768_20PF | MC-146 | X7 | XTAL_3225 | NC/26MHZ_20PF | XTAL_3225 |
重要提示:PCB作品文件展下载说明
