[Pads_VX.2x] GM8138 LQFP176+IT6612原厂demo 1V2 PCB DSN
查看3251 | 回复25 | 2020-10-28 16:43:25 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePart TypePCB DecalValue
BAT1MS621FEFL11EMS621FEFL11ENC(MS621FEFL11E)
CE1470UF_25V_20%_LESREC_3P5_8P0470uF
CM31UF_10V_10%_SMD0402_3C04021uF
CM41UF_10V_10%_SMD0402_3C04021uF
CM61UF_10V_10%_SMD0402_2C04021uF
CN1SD_SOCKET_TOP_A_PANASONICSD_STANDARD_ASD_Socket_Top_A_Panasonic
CN2USB_A_RECEPTACLE_SMD_4PCN_USB_AUSB_A_SMD
CON1HDMI_M_0CN_HDMI_19_050_CON/HDMI
CT147UF_6.3V_20%_B_CASECAP_B_352847uF,6.3V
CW160.01UF_50V_20%_SMD0402C04020.01uF
D1RB551V-30_SOD323SOD323RB551V-30
D2RCLAMP0520B_SOT-523RCLAMP0502BNC(RClamp0520B)
FB25FB/0805L0805FB/0805
J11X8P_MALE_DIP_2.0SIP_8P_200NC(1X8P_2.0M)
J21X8P_MALE_DIP_2.0SIP_8P_200NC(1X8P_2.0M)
J3RJ45_0RJ45_PA6TRJ45
J42X22P_FEMALE_DIP_1.27CN22X2_127NC(2X22P_1.27F)
J52X20P_FEMALE_DIP_2.0CN20X2_2002X20P_2.0F
J6RCA_JACK_90D_YELLOW_DIP_2PRCA_JACKRCA_Yellow
J71X2P_MALE_DIP_1.27JP2_125_I1X2P_1.25M
J82X20P_FEMALE_DIP_2.0CN20X2_2002X20P_2.0F
J91X4P_MALE_DIP_2.54SIP_4P1X4P_2.54M
J101X5P_MALE_DIP_2.54SIP_5P1X5P_2.54M
J112X10P_MALE_DIP_1.27CN10X2_1272X10P_1.27M
J121X4P_MALE_DIP_2.54SIP_4P1X4P_2.54M
J13DC_JACKPJ20_3PDC_JACK
J141X2P_MALE_DIP_2.0SIP_2P_2001X2P_2.0M
J152X15P_MALE_2LAYER_DIP_2.0CN15X2_2002X15P_2.0M_2L
J161X2P_FEMALE_DIP_2.0SIP_2P_2001X2P_2.0M
L14.7UH_4.2A_20%_SMD_SB0805L_SB08054.7uH
L22.2UH_1.85A_20%_SMD_SR0302L_SR03022.2uH
L32.2UH_1.85A_20%_SMD_SR0302L_SR03022.2uH
L42.2UH_1.85A_20%_SMD_SR0302L_SR03022.2uH
LED3RED__SMD0603LED0603RED
LED4GREEN__SMD0603LED0603GREEN
MIC1MIC-MICROPHONE0MICMIC-EM5BPS
PB2PUSH_BOTTOM_BLUE_SMD_2PSW_SMD_2PKEY1
RP2033_1/16W_5%_8P4RRP_4NC(33)
RP2222_1/16W_5%_8P4R_0402RP_4_040222
RP2322_1/16W_5%_8P4R_0402RP_4_040222
SW1SWITCH_4_PORT_SMD_8PSW_HDS404SW_SMD
SW2SWITCH_2_PORT_SMD_4PSW_HDS402SW_SMD
SW3SWITCH_4_PORT_SMD_8PSW_HDS404SW_SMD
SW4SW_SPDT3_DIPSW_SPDT3_1SW-SPDT3
SW5SWITCH_4_PORT_SMD_8PSW_HDS404SW_SMD
U1GM8138_EPAD_LQFP176_SKT_7QFP176_040+EPADGM8138_EPAD_LQFP176_SKT
U3K4B2G1646B-HCK0-1600DDR3_FBGA_X16_9X13P3K4B2G1646B-HCK0-1600_2G(128Mx16)
U6W25P80/16SOIC8_208M25P32 SO8
U7SPI_FLASH_SOP16SOP16_300NC(SPI_FLASH,SOP16)
U8K9F1G08U0B(128MBX8)_TSOP48_0TSOP48_12X20NAND FLASH K9F1G08U0B(128Mbx8)
U9G5250C1T1USOT25NC(G5250C1T1U)
U10IP101GRTQFN32_040+EPADIP101GR
U11H1102_1TS8121CTS8121C
U12CAT6612_0QFP80_050IT6612
U13G9131-18T73UFSOT23G9131-18T73Uf
U14AKU2002CMIC_AKU2002CAKU2002C
U15AKU2002CMIC_AKU2002CAKU2002C
U16IR_0ECM_A38_N3IRM3638T,3.3V
U17MP1484_SOP8_0SOP8+EPADMP1482,SOP8
U18G9131-28T73UF_SOT23G9131-28T73Uf
U19G5699_0TDFN12_045_3X3G5699
U20G9131-18T73UFSOT23G9131-18T73Uf
U21G5628ADJT1U_SOT25SOT25G5628
U22DS1307_SOIC8SOIC8_150NC(PT7C4307,SOIC8)
Y112MHZ_OSC_30PPM_SMD5X3_0XTAL_SMD_50X3230MHz
Y2XTAL_25MHZ_0XTAL_127LNC(32.768K)
Y332.768KHZ_CRY_30PPM_SIZE_2X6XTAL_0P7LNC(32.768KHz)
重要提示:PCB作品文件展下载说明
老吴 | 2020-10-28 16:44:59 | 显示全部楼层
PCB 原理图回复可见下载。
游客,如果您要查看本帖隐藏内容请回复
shuszhao | 2020-10-28 17:07:50 | 显示全部楼层
luchonghui74 | 2020-10-28 19:25:03 | 显示全部楼层
cml_l | 2020-10-28 20:33:55 | 显示全部楼层
yangxf0120 | 2020-10-28 21:52:43 | 显示全部楼层
谢谢分享GM8138 LQFP176+IT6612 demo PCB
nj20044 | 2020-10-29 00:05:33 | 显示全部楼层
cityhu | 2020-10-29 00:09:05 | 显示全部楼层
mikewen | 2020-10-29 03:35:52 | 显示全部楼层
kanxue_nmg | 2020-10-29 03:53:00 | 显示全部楼层
