[PADS9.5以下] 全网首发展讯SC6825A(SP6825A)手机PCB和原理图-SC2712E+AR6302G+BK351
查看3909 | 回复20 | 2017-12-16 22:22:14 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePart TypePCB DecalValue
ANT0400CON-SPRING-PGC-1.5-2.8-3P-3.0PHCON-SPRING-PGC-1.5-2.8-3P-3.0PH
ANT7200CON-SPRING-PGC-1.5-2.8-2P-3.0PHCON-SPRING-PGC-1.5-2.8-2P-3.0PH
D4100DIODE-SCHOTTKY-WSB5503W-2/TRSOD-323
D5100DIODE-LED-LTPL-C064WD-WADIODE-LED-LTPL-C064WD-WA
D6100DIODE-ZENER-PZU5.1BSOD-323
D6300DIODE-LED-WHITE-0603LED-0603
D6301DIODE-LED-WHITE-0603LED-0603
D6302DIODE-LED-WHITE-0603LED-0603
FB3108BEAD-1K-OHM-100MHZ-250MA-0402SL04021000ohm@100MHz
FB4100BEAD-470-OHM-100MHZ-0.5A-0603SL0603-S470ohm@100MHz 500mA
FB4102BEAD-1K-OHM-100MHZ-250MA-0402SL04021000ohm@100MHz
FB4103BEAD-1K-OHM-100MHZ-250MA-0402SL04021000ohm@100MHz(NF)
FD6201NC-FIDUCIALMARKPAD-FID
FD6202NC-FIDUCIALMARKPAD-FID
FD6203NC-FIDUCIALMARKPAD-FID
FD6204NC-FIDUCIALMARKPAD-FID
J0400CON-RF-SWITCH-MM8430-2610RA1CON-RF-SWITCH-MM8430-2610RA1
J3100CON-EAR-KJ367ANS-1BBJ03ACON-EAR-KJ367ANS-1BBJ03A
J4100CON-BTB-F-DF37NC-34DS-0.4VCON-BTB-F-DF37NC-34DS-0.4V
J4101CON-FPC-FH26-51S-0.3SHW(05)-REVCON-FPC-FH26-51S-0.3SHW(05)-REV
J4102CON-FPC-FH34SRJ-6S-0.5SHCON-FPC-FH34SRJ-6S-0.5SH(NF)
J5100CON-BTB-F-BBR43-30KB533_2CON-BTB-F-BBR43-30KB533_2
J5101CON-BTB-F-DF37NC-24DS-0.4VCON-BTB-F-DF37NC-24DS-0.4V
J6100CON-BAT-02-0321138-1CON-BAT-02-0321138-1
J6200CON-USB-MICRO-HY07-AB0700CON-USB-MICRO-HY07-AB0700
J6201CON-BTB-F-BAF04-24156-0502CON-BTB-F-BAF04-24156-0502
J6401SOCKET-SIM-WKSM018-3001SOCKET-SIM-WKSM018-3001
J6500SOCKET-CARD-TFLASH-TFRPN-S1015-TP00SOCKET-CARD-TFLASH-TFRPN-S1015-TP00
L0300IND-POWER-2.2UH-SPH252012H2R2MTIND-POWER-SPH25202.2uH
L0409IND-NF-0402IND-NF-0402NF
L0410IND-CER-5.6NH-0402SL04025.6nH(NF)
L0411IND-CER-5.6NH-0402SL04025.6nH(NF)
L0412IND-NF-0402IND-NF-0402NF
L0413IND-CER-9.1NH-0402SL0402NF
L0414IND-NF-0402IND-NF-0402NF
L0415IND-NF-0402IND-NF-0402NF
L0416IND-NF-0402IND-NF-0402NF
L0423IND-CER-2.4NH-0402SL04022.4nH
L0425IND-CER-5.6NH-0402SL04025.6nH
L4100IND-POWER-10UH-SWPA3012S100MTIND-POWER-SWPA3010uH
L7202IND-NF-0402IND-NF-0402NF
M6600MOTOR-F103030-146MOTOR-F103030-146(NF)
MIC3100AUDIO-MIC-ACMG4013-05S-443-006AUDIO-MIC-ACMG4013-05S-443-006
MLV6501MLV-AVLC5S02050SMLV0402
Q6100FET-P_DIODE-FDFMA2P853MICROFET-2X2(NF)
Q6101FET-N-2SK3019SOT-416
Q6102TRIODE-PNP-PBSS5320XSOT-89
R7220NC-SOLDER-SHORT-0402NC-SOLDER-SHORT-04020
REC3100AUDIO-RECEIVER-SDRP0612KJ02-F1-GAUDIO-RECEIVER-SDRP0612KJ02-F1-G
S6300SWITCH-PUSH-ST-1114RSWITCH-PUSH-ST-1114R
S6301SWITCH-PUSH-ST-1114RSWITCH-PUSH-ST-1114R
S6302SWITCH-PUSH-ST-1114RSWITCH-PUSH-ST-1114R
S6303SWITCH-PUSH-ST-1114RSWITCH-PUSH-ST-1114R
SPK3100AUDIO-SPK-DMSP1420KJ-10-GAUDIO-SPK-DMSP1420KJ-10-G
TP6200NC-TP-JTAG-10PINNC-TP-JTAG-10PIN
TVS6100TVS-ESD5Z3.3T1G-3.3V-105PF-SOD-523SOD-523(NF)
TVS6200TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5G
TVS6201TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5G
TVS6202TVS-ESD5Z7.0T1GSOD-523(NF)
U0200ASIC-SC2712E-217-0.4BGA6.9X8.1-217-0.4-SC2712E
U0400RF-TRANCEIVER-SR1019BGA5X5-65
U0401RF-SAW-SAWEN881MCX0F00RF-SAW-1.80X1.35
U0405RF-SAW-SAWEN1G84CV0F00RF-SAW-SAWEN1G84CV0F00
U0406RF-SAW-SAWFD1G90CA0F00RF-SAW-SAWFD1G90CA0F00(NF)
U0407RF-SW+PA-RF9802RF-SW+PA-RF9802
U0500MEM-NAND+LPDDR2-K5A4G2GQCM-B019BGA11.5X13-162-0.5
U2100ASIC-SC6825A-517-0.4BGA12.1X12.1-517-0.4-SC6825A
U4100EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U4101EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U4102EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U4103EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U4104EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U4105POWER-DC2DC-KTD257EHD-TRSOT23-6
U4106ASIC-SENSOR-TP-FT5306DE4QFN6X6-48
U4107EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U4108EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U4109EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U5100POWER-DC2DC-SGM3140POWER-DC2DC-SGM3140
U5200SENSOR-MOTION-LIS3DHSENSOR-MOTION-LIS3DH
U5202SENSOR-LIGHT+PROX-STK3171-018SENSOR-LIGHT+PROX-STK3171-018
U7100BT+FM-BK3512QBQFNWB4X4-32
U7200CON-RF-SWITCH-MM8430-2610RA1CON-RF-SWITCH-MM8430-2610RA1
U7201POWER-LDO-XC6219B332MRSOT23-53.3V
U7202RF-SWITCH-SKY13317-373LFRF-SWITCH-SKY13317-373LF
U7203RF-SAW-LFB212G45CL1D172RF-SAW-LFB212G45CL1D172
U7204WIFI-AR6302G-BL3BWIFI-AR6302G-BL3B
U7205POWER-LDO-XC6221A182MRSOT23-51.8V(NF)
U7206RF-BALUN-HHM17125D1RF-BALUN-HHM17125D1
U7207RF-BALUN-TBL-1005-245-MA1RF-BALUN-TBL-1005-245-MA1
X0200XTAL-CRYSTAL-32.768K-TFX-02-12.5-J01173XTAL-CRYSTAL-32.768K-TFX-02-12.5-J0117332.768K
X0401XTAL-CRYSTAL-SQ3D02600B2IBACRYSTAL-26M26MHz
X7200XTAL-CRYSTAL-SQ3D02600B2IBACRYSTAL-26M26MHz(NF)
重要提示:PCB作品文件展下载说明
老吴 | 2017-12-16 22:23:16 | 显示全部楼层
资料不是很新,但是太难找了。1RMB 。 有需要的下载。
SC6825V1_PCB&sch.7z (2.74 MB, 下载次数: 13)
xnima_irumei | 2017-12-17 06:42:06 | 显示全部楼层
bingbill21 | 2017-12-17 07:18:13 | 显示全部楼层
longxuekai | 2017-12-17 07:28:52 | 显示全部楼层
单枪舞九州 | 2017-12-17 08:12:16 | 显示全部楼层
wjgmr | 2017-12-17 08:31:12 | 显示全部楼层
SC2712E+AR6302G+BK3512QB+SR1019
sunrain | 2017-12-17 08:49:49 | 显示全部楼层
RMB出售啊,55555555555555
丁响820425 | 2017-12-17 08:56:46 | 显示全部楼层
layout007 | 2017-12-17 09:05:33 | 显示全部楼层
