[Allegro16.6以下] MC9S12XEP100MAL DEMO 板PCB和原理图(MC9S08JM60CGTE+MCZ33903CD5EK)
查看4138 | 回复24 | 2018-1-26 15:26:45 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
D1DIODE_SCHTKY_POWERDI-123_3MMX2MSBR3U30P1QPOWERDI-123_3MMX2MM
D2LED_HSMX-C170_IC_0.8MM_370-300HSMS-C170HSMX-C170
D3DIODE_SCHTKY_POWERDI-123_3MMX2MSBR3U30P1QPOWERDI-123_3MMX2MM
D4ZDIODE_SOD123_IC_1.35MM_480-762MMSZ8V2T1GSOD123
D5DIODE_SCHTKY_POWERDI-123_3MMX2MSBR3U30P1QPOWERDI-123_3MMX2MM
D6LED_LED_0603_IC_0.85MM_370-7654GREENLED_0603
D7LED_LED_0603_IC_0.8MM_370-75080ORANGELED_0603
D9LED_TRI_COLOR_LED6_5X6MM_IC_2.6LED RED/GRN/BLLED6_5X6MM
D10LED_LED_0603_IC_0.8MM_370-76537YEL/GRNLED_0603
D11LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWLED_0603
J1HDR_2X8_M_CON2X8_2P54_TH_IO_8.6CON 2X8CON2X8_2P54_TH
J2CONN_HDR_10X2_CON20_2P54_TH_IO_CON 2X10CON20_2P54_TH
J3HDR_2X8_M_CON2X8_2P54_TH_IO_8.6CON 2X8CON2X8_2P54_TH
J4HDR_2X8_M_CON2X8_2P54_TH_IO_8.6CON 2X8CON2X8_2P54_TH
J5CONN_HDR_10X2_CON20_2P54_TH_IO_CON 2X10CON20_2P54_TH
J6CONN_HDR_10X2_CON20_2P54_TH_IO_CON 2X10CON20_2P54_TH
J7CONN_HDR_3X2_HDR203_IO_8.58MM_2HDR_2X3HDR203
J8CONN_HDR_4X1_CON_HDR_4M_100_TH_HDR 1X4 RACON_HDR_4M_100_TH_RA
J9DC_POWER_JACK_SHD_CON3_PWR_JACKCON PWR 3CON3_PWR_JACK_TH_PJ051A
J10CONN_HDR_3X1_HDR103_A_IO_8.74MMHDR 1X3HDR103_A
J11JUMPER_2_2MM_HDR1X2_5P48X2P69_IHDR1X2HDR1X2_5P48X2P69
J12CONN_HDR_4X1_CON_HDR_4M_100_TH_HDR 1X4 RACON_HDR_4M_100_TH_RA
J13CONN_HDR_3X1_HDR103_A_IO_8.74MMHDR 1X3HDR103_A
J14CONN_HDR_3X2_HDR203_IO_8.58MM_2HDR_2X3HDR203
J15CONN_HDR_2X1_HDR1X2_5P48X2P69_IHDR1X2HDR1X2_5P48X2P69
J16MICRO_USB_CONN_10PIN_CON_MICROAUSB_MICRO_ABCON_MICROAB_10F_25_SM_RA
JP1CONN_HDR_1X1_HDR101_IO_8.59MM_2HDR_1X1HDR101
L2BEAD_IND_1206_DISCRETE_1.3MM_18BLM31AJ601SN1LIND_1206
L3BEAD_IND_0805_DISCRETE_1.05MM_330 OHMIND_0805
L4BEAD_IND_0805_DISCRETE_1.05MM_330 OHMIND_0805
Q1TRAN_PNP_SOT223_SOT223_IC_1.75BCP53SOT223
RST1TEST_POINT_TESTPOINT_135_070MILTESTLOOPTESTPOINT_135_070MIL
SH1RES_SHORT-2_SH0402_DISCRETE_0.10SH0402
SH2RES_SHORT-2_SH0603_DISCRETE_0.10SH0603
SW1EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402WSW4_SPST_4P8X3P6_2P5
SW2EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402WSW4_SPST_4P8X3P6_2P5
SW3EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402WSW4_SPST_4P8X3P6_2P5
SW4EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402WSW4_SPST_4P8X3P6_2P5
U1SPX3819M5_FIX_5P_SOT23_5S_IC_1.SPX3819M5-L-3-3SOT23_5S
U2MCZ33903BD_SOIC_1_SOIC32_0P65_7MCZ33903CD5EKSOIC32_0P65_7P6X11P1_5P2EPAD
U3MC9S12XEP100_1_LQFP112_IC_1.6MMMC9S12XEP100MALLQFP112
U4MC9S08JM60CGT_0_QFN48_0P5_5P25XMC9S08JM60CGTEQFN48_0P5_5P25X5P25_A
U5MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMSO8
U6NC7SV04_UDFN6_1X1P5MM_IC_0.5MM_74LVC1G04GMUDFN6_1X1P5MM
U774LVCH1T45_0_SOT891_6P_0P35_1P074LVCH1T45GFSOT891_6P_0P35_1P05X1P05
U874LVCH1T45_0_SOT891_6P_0P35_1P074LVCH1T45GFSOT891_6P_0P35_1P05X1P05
U9DDTD122LC_SC70_3_IC_1.1MM_480-7DDTC113ZUA-7-FSC70_3
U10RCLAMP0502A_6P_SOT666_IC_0.6MM_RClamp0502A.TCTSOT666
U11DDTA113ZCA_3P_SC70_3_IC_1.1MM_4DDTA113ZUA-7-FSC70_3
U1274LVCH1T45_0_SOT891_6P_0P35_1P074LVCH1T45GFSOT891_6P_0P35_1P05X1P05
U13DDTD122LC_SC70_3_IC_1.1MM_480-7DDTC113ZUA-7-FSC70_3
Y1XTAL_CS10_XTAL2_3P3X2P6_IC_1MM_8MHZXTAL2_3P3X2P6
Y2XTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_4MHzXTL2_ECS_CSM7_SM
重要提示:PCB作品文件展下载说明
老吴 | 2018-1-26 15:38:30 | 显示全部楼层
MC9S12XEP100MAL.7z (1.92 MB, 下载次数: 9)
qrfbntel | 2018-1-26 17:11:21 | 显示全部楼层
worldof422 | 2018-1-26 18:44:50 | 显示全部楼层
yangxf0120 | 2018-1-26 19:54:09 | 显示全部楼层
谢谢分享MC9S12XEP100MAL DEMO 板PCB和原理图
带刀的老鼠 | 2018-1-26 20:29:09 | 显示全部楼层
zhaoxiyao5210 | 2018-1-26 21:25:48 | 显示全部楼层
mini | 2018-1-27 00:19:27 | 显示全部楼层
单枪舞九州 | 2018-1-27 07:42:29 | 显示全部楼层
marktsui | 2018-1-27 08:16:41 | 显示全部楼层
