• 接地搭接电缆布局屏蔽!!!
  • 北美液冷生态解码:超微spuermicro,24年营
  • SK海力士全球首发HBM4-16层堆叠、2.0TB/s
  • 2纳米Nanosheet技术及其以后的选择性层减薄
  • 详解UCIe-3D(上):如何通过混合键合技术
[AD格式] 一个开发板底板PCB文件
查看1690 | 回复4 | 2018-2-14 21:59:13 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
CommentPatternQuantityComponents
BAT_SOCK-2032_CR2032HE_2032CR2032HE1BT1
BUZZER_BUZZER_BUZZERBUZZER1BZT1
CAP_0603C_1206C_1000PF/2KV1206C1C139
CM2020SOP38-20-173A1U29
CON4_IDEPWR_0_IDEPWR_IDEPWRIDEPWR1J1
D_DMMELF_DMMELF_1N4148DMMELF2D2, D3
D-ATX-2X10-3.5MS_ATX-POWER20A_HATX-POWER20A1J2
D-BNCX1S_BNC-5_BNCX1SBNC-51J15
D-CE-1000UF20%-16V-20/40_CE10-5CE10-51CT76
D-CON-DC005_POWERJACK_POWERJACKPOWERJACK1JT12
D-CON-USB_SOCKET-AB_USB-H-A_USBUSB-H-A1JT11
D-CRYS-32.768KHZ_XTAL-08_32.768XTAL-081XT1
D-DHD-2X20-2.54MS_IDC40-2_54A_HIDC40-2_54A1JT5
D-INDUC-LH810-10UH_LD8_5-5_LH81LD8_5-51L6
D-PTC-250V-0.12A-RAD0.2_RAD2_JKRAD22PTCT1, PTCT2
D-PTC-30V-4A-RAD0.2_PTC-D_10_5_PTC-D_10_51PTC1
D-RELAY-HLS6-4100-DC5V_HLS6_410HLS6_4100H4JK1, JK2, JK3, JK4
D-SATA-DIP7A_0_SATA7-1_27B_SATASATA7-1_27B10CNT1, CNT2,
D-SCON-10-2.54S_SIP10-2_5A_CON1SIP10-2_5A1JT2
D-SCON-2-2.54S_SIP2-2_5A_CON2SIP2-2_5A3JT1, JT3, JT6
D-SCON-2-7.5S_SIP2-7_5_TERMINALSIP2-7_51JT9
D-SCON-3-2_54S_SIP3-2_5A_CON3_SSIP3-2_5A1JT10
D-SCON-4-2.54S_SIP4-2_5A_CON4SIP4-2_5A1JT7
D-SCON-4-5.08S_IDEPWR_IDEPWRIDEPWR1JT4
D-SCON-45-2_10.0S_BLOCK_3531T_HBLOCK_3531T1J3
D-SCON-45-2_9.0S_BLOCK_3531B_HIBLOCK_3531B1J9
D-SCON-6-1.25S_SIP6-1_27S_SIP6-SIP6-1_27S1CN1
D-TVS-P6KE6V8-DO15_DO-15_P6KE6VDO-152TVST1, TVST2
EC_CE20-10_CE10-5_1000UF/16VCE10-51C29
EC_CE20-10_CE10-5_1000UFCE10-54C5, C6, C11, C65
HDMIHDMI_RX_CON_SMD1J8
HEADER8X2_IDC16-2_54AR_IDC16-3IDC16-3_81AR2J4, J5
HOLE40-8STAR-000_HOLE41-8STAR_HHOLE41-8STAR8H1, H2,
IND_MSS1278_1_LS-SB0560_4UH/20ALS-SB05602L5, L53
JR0325A0_QFN64_4_QFN64-9X9_JMB3QFN64-9X92U1, U2
MARK_MASK1_MARKMASK18FJ1, FJ2,
MOSFET_P_SOT23_SOT23_IRLML6401TSOT231Q10
MOSFET_P_SOT23_SOT23_IRLML6402PSOT231Q12
NB638QFN20-NB6382U45, U46
PULSE H5007_0_H5007_PULSEH5007H50071T1
RJ45A_RJ45A_RJ45RJ45A1J6
S-CRYS-25M-XTAL_49M_XTAL-49M_25XTAL-49M2X1, X2
S-DIODE-1N4148-1206_DMMELF_1N41DMMELF4DT1, DT2, DT3, DT4
SERIALFLASH_25LV512/010_SOP8_0SOP8-6_2-1_272U3, U4
S-GDS-BA301N-4532S_TVS-SMB_SEMITVS-SMB2ZT1, ZT2
S-IC-232-MAX232ACSE_SOP16-6_2-1SOP16-6_2-1_271UT10
S-IC-485-SN65LBC184DR_SOP8-6_2-SOP8-6_2-1_271UT4
S-IC-AP1117-1.8_SOT223_AMC1117-SOT2232UT2, UT5
S-IC-DS1307Z_SOP8-6_2-1_27_DS13SOP8-6_2-1_271UT3
S-IC-L78L05ABUTR-SOT89_SOT-89_LSOT-891UT1
S-IC-LM3526_SOP8-6_2-1_27_MIC20SOP8-6_2-1_271UT9
S-IC-LM358AM-SO8_SOP8-6_2-1_27_SOP8-6_2-1_271UT6
S-IC-MP1482DS-SO8_SON8-6_2-1_27SON8-6_2-1_271U6
S-IC-MP1484EN-SO8_SON8-6_2-1_27SON8-6_2-1_272U7, U10
S-IC-SGM9115_SOP8-6_2-1_27_SG_1SOP8-6_2-1_271UT8
S-IC-SGM9115_SOP8-6_2-1_27_SGM9SOP8-6_2-1_271UT7
S-IC-SRV05-4_SOT23-6_SRV05-4SOT23-61UB1
S-IC-TPS54425_0_S-PVQFN-N14_TPSS-PVQFN-N142U618, U619
S-INDUC-0603L-120R_0603BL_120_10603BL1LB8
S-INDUC-0603L-120R_0603BL_120R@0603BL2LB1, LB3
S-INDUC-0603L-120R_0603L_120R@10603L3L1, L2, L7
S-INDUC-0603L-120R_0603L_120R_10603L1L8
S-INDUC-0805L-600R_0805BL_600R@0805BL6LB2,
S-INDUC-0805L-600R_0805L_600R@10805L2L3, L4
S-INDUC-SCDH127-12X12-10UH_SCDHSCDH127_6X42L9, L11
S-LED-HLRED-0603_0603LED_NC_RED0603LED1LEDT1
S-LED-HLRED-0603_0603LED_RED-060603LED1LED11
S-LED-NLGREEN-0603_0603LED_GREE0603LED10LED1, LED2
S-NPN-MMBT3904-SOT23_SOT23_MM_1SOT235QT2, QT3, QT4, QT5, QT6
S-NPN-MMBT3904-SOT23_SOT23_MMBTSOT2312Q1, Q2, Q3
S-NPN-MMBT3904-SOT23_SOT23_S805SOT231QT1
SRV05-4_SOT23-6_SRV05-4SOT23-62U11, U12
S-S-DIODE-1N5819-1206_1206D_1N51206D17D1, D50
S-TRANS-H1102_STFM16-50-285_H11STFM16-50-2851TT1
USBS_0_USB-H-A_USBS_NCUSB-H-A1J7
重要提示:PCB作品文件展下载说明
暑假期间,免费代管18-28岁小孩,限女性。
sii9000 | 2018-2-14 22:00:13 | 显示全部楼层
MB.7z (2.15 MB, 下载次数: 7)
wcjcn | 2018-2-15 08:18:32 | 显示全部楼层
miaomiao | 2018-2-15 08:58:40 | 显示全部楼层
lcfmax | 2018-2-15 09:00:53 | 显示全部楼层
