[Allegro16.6以下] MKM34Z256CLL7 PCB文件共享
查看4326 | 回复17 | 2018-4-6 17:54:08 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BT20BATTERY_CR2032_LF_IC_5.4MM_801BATTERYCR2032_LF
D20DIODE_SOD-123_IC_1.35MM_480-760MMSD4148T1GSOD-123
D21DUALDIODE_CC_SOT23_SOT23_A_IC_1BAT54CLT1SOT23_A
D90DIODE_CASE403D_02_IC_2.41MM_480MRA4007T3GCASE403D_02
D91DIODE_CASE403D_02_IC_2.41MM_480MRA4007T3GCASE403D_02
D92DIODE_CASE403D_02_IC_2.41MM_480MRA4007T3GCASE403D_02
D94DIODE_CASE403D_02_IC_2.41MM_480MRA4007T3GCASE403D_02
D95DIODE_DIODE2_2P9X1P9_IC_1.43MM_ES1JLDIODE2_2P9X1P9
D201DUALDIODE_SERIES_SOT23_SOT23_A_BAV99LT1SOT23_A
D211DUALDIODE_SERIES_SOT23_SOT23_A_BAV99LT1SOT23_A
D221DUALDIODE_SERIES_SOT23_SOT23_A_BAV99LT1SOT23_A
D301DIODE_SOD-123_IC_1.35MM_480-760MMSD4148T1GSOD-123
D302DIODE_SOD-123_IC_1.35MM_480-760MMSD4148T1GSOD-123
D303DIODE_SOD-123_IC_1.35MM_480-760MMSD4148T1GSOD-123
D321LED_LED2_100_3_TH_IC_6.1MM_370TSAL4400LED2_100_3_TH
D351LED_LED_2_3P85_IC_5.9MM_370-765WP7104LSRDLED_2_3P85
D352LED_LED_2_3P85_IC_5.9MM_370-765WP7104LSRDLED_2_3P85
DS300LCD_44P_LCD_44P_96P5X37_IC_3MM_LK-LCD-REV2LCD_44P_96P5X37
J1CONN_HDR_5X2_CON_2X5_FTS_SM_IO_HDR 2X5CON_2X5_FTS_SM
J20CONN_HDR_2X1_HDR102_STAG_SM_IO_HDR_1X2HDR102_STAG_SM
J21CONN_HDR_2X1_HDR102_STAG_SM_IO_HDR_1X2HDR102_STAG_SM
J22CONN_HDR_2X1_HDR102_STAG_SM_IO_HDR_1X2HDR102_STAG_SM
J201CONN_HDR_2X1_CON_2X1_5P08_IO_18CON TB 2CON_2X1_5P08
J211CONN_HDR_2X1_CON_2X1_5P08_IO_18CON TB 2CON_2X1_5P08
J221CONN_HDR_2X1_CON_2X1_5P08_IO_18CON TB 2CON_2X1_5P08
J231CONN_HDR_2X1_CON_2X1_5P08_IO_18CON TB 2CON_2X1_5P08
J241CONN_HDR_2X1_CON_2X1_5P08_IO_18CON TB 2CON_2X1_5P08
J251CONN_HDR_2X1_CON_2X1_5P08_IO_18CON TB 2CON_2X1_5P08
J261CONN_HDR_2X1_CON_2X1_5P08_IO_18CON TB 2CON_2X1_5P08
J301CONN_HDR_5X2_HDR205_SM_IO_9.65HDR_2X5HDR205_SM
J302CONN_HDR_2X1_CON_2X1_5P08_IO_18CON TB 2CON_2X1_5P08
J311CONN_HDR_10X2_CON2X10F_SMT_SSW_CON_2X10CON2X10F_SMT_SSW
J312HDR_2X8_M_HDR_2X8_2P54_SM_IO_10CON 2X8HDR_2X8_2P54_SM
J314CONN_HDR_6X2_CON_2X6_SKT_100_SMCON 2X6 SKTCON_2X6_SKT_100_SM
J315CONN_HDR_3X2_HDR203_TSM_SM_IO_1HDR_2X3HDR203_TSM_SM
J316CONN_HDR_2X1_HDR102_STAG_SM_IO_HDR_1X2HDR102_STAG_SM
J317CONN_HDR_2X1_HDR102_STAG_SM_IO_HDR_1X2HDR102_STAG_SM
J318CONN_HDR_2X1_HDR102_STAG_SM_IO_HDR_1X2HDR102_STAG_SM
J361CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2HDR102
J362CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2HDR102
J363HDR_2X8_M_HDR_2X8_2P54_SM_IO_10CON 2X8HDR_2X8_2P54_SM
JP1CONN_HDR_1X1_HDR101_IO_8.59MM_2HDR 1X1HDR101
JP2CONN_HDR_1X1_HDR101_IO_8.59MM_2HDR 1X1HDR101
JP3CONN_HDR_1X1_HDR101_IO_8.59MM_2HDR 1X1HDR101
JP4CONN_HDR_1X1_HDR101_IO_8.59MM_2HDR 1X1HDR101
JP5CONN_HDR_1X1_HDR101_IO_8.59MM_2HDR 1X1HDR101
JP6CONN_HDR_1X1_HDR101_IO_8.59MM_2HDR 1X1HDR101
L20INDUCTOR_IND_2012_DISCRETE_0.851uHIND_2012
L21INDUCTOR_IND_2012_DISCRETE_0.851uHIND_2012
L90IND_IND_LPS6225_DISCRETE_3.5MM1500uHIND_LPS6225
L91INDUCTOR_IND_RFB0807_TH_DISCRET470uHIND_RFB0807_TH
Q321PT12_PHTRANS_2P_PHTRANS_4P19MM_OP506BPHTRANS_4P19MM
RV201VARISTOR_VARISTOR_21P5X5P4MM_DI20S0271VARISTOR_21P5X5P4MM
RV211VARISTOR_VARISTOR_21P5X5P4MM_DI20S0271VARISTOR_21P5X5P4MM
RV221VARISTOR_VARISTOR_21P5X5P4MM_DI20S0271VARISTOR_21P5X5P4MM
SW371SW_PB_ESW_SW4_PB_ESW_SM_P177_ICTL3301AF160QGSW4_PB_ESW_SM_P177
TP262TESTPAD_TESTPOINT_70MIL_IC_0.170 MILTESTPOINT_70MIL
U1PKM34Z256CLL7_LQFP_100P_LQFP100MKM34Z256CLL7LQFP100_0P5_14X14
U20SPX3819M5_5P_SOT23-5_A_IC_1.45SPX3819M5-LSOT23-5_A
U90LNK302DN_8P_SO8_1P27_3P9X4P9_ICLNK306DNSO8_1P27_3P9X4P9
U281LMV321_SOT23_5S_IC_1.22MM_315-7LMV321SOT23_5S
U301SFH6106_4P_SOP4_2P54_6P8X4P8_ICSFH6106-4SOP4_2P54_6P8X4P8
U302SFH6106_4P_SOP4_2P54_6P8X4P8_ICSFH6106-4SOP4_2P54_6P8X4P8
U303SFH6106_4P_SOP4_2P54_6P8X4P8_ICSFH6106-4SOP4_2P54_6P8X4P8
U381MAG3112_DFN_10P_DFN_10_0P4_2X2_MAG3110DFN_10_0P4_2X2_A
U391AT24C64AN_SO8_IC_1.75MM_334-772AT24C32DSO8
Y1XTAL_XTL2_ECS_SM_IC_8.84MM_230-32.768KHzXTL2_ECS_SM
重要提示:PCB作品文件展下载说明
PCB打样,PCB快速加急打样。私信我。
eda_layout | 2018-4-6 17:55:38 | 显示全部楼层
PCB文件共享
MKM34Z256CLL7.7z (1.52 MB, 下载次数: 2)
为明天努力 | 2018-4-6 18:24:00 | 显示全部楼层
喧嚣 | 2018-4-6 18:36:05 | 显示全部楼层
i_333333 | 2018-4-6 18:57:58 | 显示全部楼层
非常感谢楼主大神的分享
cityhu | 2018-4-6 19:09:53 | 显示全部楼层
yangxf0120 | 2018-4-6 19:35:35 | 显示全部楼层
谢谢分享MKM34Z256CLL7 PCB文件
带刀的老鼠 | 2018-4-6 22:47:49 | 显示全部楼层
wangy2000 | 2018-4-7 07:33:24 | 显示全部楼层
谢谢分享,学习学习。
sym21ic | 2018-4-7 08:52:29 | 显示全部楼层
