[Allegro16.6以下] XC7K325T_FBG900+32个Nand FLASH 做的一个存储卡 PCB和原理图
查看10200 | 回复42 | 2018-5-23 15:14:25 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
F1FUSE_L0603MS_X_FUSE_5AX_FUSE_5AL0603MS
FM1PANEL_PAD_PANEL_PAD_X_PANEL_PADX_PANEL_PADPANEL_PAD
FM2PANEL_PAD_PANEL_PAD_X_PANEL_PADX_PANEL_PADPANEL_PAD
FM8OPTICS_120_F_PAD_M120_X_OPTICSX_OPTICSF_PAD_M120
H1MH_HOLES_125_95I6_X_MH1X_MH1HOLES_125_95I6
H2MH_HOLES_125_95I6_X_MH1X_MH1HOLES_125_95I6
J1HEAD6_SIP6_JTAG_X_HEAD6X_HEAD6SIP6_JTAG
J2FINGER_PCI_EX8_FINGER-PCI-EX8_XX_Finger_PCI_EX8FINGER-PCI-EX8
L1INDUCTOR_XAL6000_2.2UH2.2uHXAL6000
L2INDUCTOR_XAL6000_2.2UH2.2uHXAL6000
L3INDUCTOR_IND_SDR73B_0.75UH0.75uHIND_SDR73B
L4INDUCTOR_IND_SDR73B_0.47UH0.47uHIND_SDR73B
L5INDUCTOR_XAL4000_1.0UH1.0uHXAL4000
L6INDUCTOR_XAL4000_1.0UH1.0uHXAL4000
LED1LED_LED0603_DISCRETE_LEDGREENLED GREENLED0603
LED2LED_LED0603_DISCRETE_LEDGREENLED GREENLED0603
LED3LED_LED0603_DISCRETE_LEDORANGELED ORANGELED0603
LED4LED_LED0603_DISCRETE_LEDREDLED REDLED0603
LED5LED_LED0603_DISCRETE_LEDREDLED REDLED0603
M25HOLE_PTH_R197D118_X_STUDX_StudPTH_R197D118
M26HOLE_PTH_R197D118_X_STUDX_StudPTH_R197D118
M27HOLE_PTH_R197D118_X_STUDX_StudPTH_R197D118
M28HOLE_PTH_R197D118_X_STUDX_StudPTH_R197D118
M29HOLE_PTH_R197D118_X_STUDX_StudPTH_R197D118
M30HOLE_PTH_R197D118_X_STUDX_StudPTH_R197D118
NAND1NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND2NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND3NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND4NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND5NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND6NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND7NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND8NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND9NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND10NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND11NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND12NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND13NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND14NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND15NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND16NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND49NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND50NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND51NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND52NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND53NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND54NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND55NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND56NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND57NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND58NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND59NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND60NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND61NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND62NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND63NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
NAND64NAND_ONFI_BGA152_DDR2_NAND_BGA1NAND_ONFI_BGA152NAND_BGA152_14X18MM
Q1MMBT3904LT1G_SOT_23_123_1_MMBT3MMBT3904SOT_23_123_1
Q2MMBT3904LT1G_SOT_23_123_1_MMBT3MMBT3904SOT_23_123_1
Q3MMBT3904LT1G_SOT_23_123_1_MMBT3MMBT3904SOT_23_123_1
Q4MMBT3904LT1G_SOT_23_123_1_MMBT3MMBT3904SOT_23_123_1
U1XC7K325T_FBG900_SOC_IRONWOOD_FFXC7K325T_FBG900SOC_IRONWOOD_FF900
U2TI-TMP102_SOT-563_TMP102TMP102SOT-563
U3TI-TMP102_SOT-563_TMP102TMP102SOT-563
U4TPS54620RGYR_QFN3R5X3R5-14_TPS5TPS54620RGYRQFN3R5X3R5-14
U5TPS54620RGYR_QFN3R5X3R5-14_TPS5TPS54620RGYRQFN3R5X3R5-14
U6TPS54618RTET_QFN16P_3X3_1_7M_TPTPS54618RTETQFN16P_3X3_1_7M
U7TPS54618RTET_QFN16P_3X3_1_7M_TPTPS54618RTETQFN16P_3X3_1_7M
U8TPS62095_QFN16P_3X3_1_7M_TPS620TPS62095QFN16P_3X3_1_7M
U9TPS62095_QFN16P_3X3_1_7M_TPS620TPS62095QFN16P_3X3_1_7M
U10TI-TMP102_SOT-563_TMP102TMP102SOT-563
U11MCP6561T_SOT23_5_MCP6561TMCP6561TSOT23_5
U12SPI_FLASH_16P_SO16_SOT162_1_SPISPI_FLASH_16PSO16_SOT162_1
U29AOZ1361DI_DFN10-EP_065_400X400_AOZ1361DIDFN10-EP_065_400X400
Y1OSCILLATOR_0_OSC4P_7X5_100MHZ100MHzOSC4P_7X5
重要提示:PCB作品文件展下载说明
老吴 | 2018-5-23 15:18:46 | 显示全部楼层
PCB和原理图共享下载。收集于网络,请勿用作商业用途,如有侵权请联系我删除。
XC7K325T.7z (2.61 MB, 下载次数: 120)
zqshbs | 2018-5-23 18:56:11 | 显示全部楼层
地沟油 | 2018-5-23 20:16:30 | 显示全部楼层
南亭好远 | 2018-5-23 20:16:38 | 显示全部楼层
kenxjy | 2018-5-23 21:31:29 | 显示全部楼层
miaomiao | 2018-5-23 21:56:50 | 显示全部楼层
wangy2000 | 2018-5-24 07:24:53 | 显示全部楼层
学习了,收藏,积累。谢谢。
chjchjchj816 | 2018-5-24 08:44:10 | 显示全部楼层
丁响820425 | 2018-5-24 08:49:14 | 显示全部楼层
