• 芯片制造中的阻挡层沉积技术介绍
  • 接地搭接电缆布局屏蔽!!!
  • 北美液冷生态解码:超微spuermicro,24年营
  • SK海力士全球首发HBM4-16层堆叠、2.0TB/s
  • 2纳米Nanosheet技术及其以后的选择性层减薄
[Allegro16.6以下] 基于stm32f107+nRF24L01+DP83848的2.4G射频板原理图和PCB
查看17605 | 回复122 | 2018-9-5 16:15:14 | 显示全部楼层 |阅读模式
[/free] 捕获.PNG
Part Reference
Value
PCB Footprint
BT1
LM2576HV
to-263
TM3_1
TM3
TM3
TM3_2
TM3
TM3
C13
1000pF,2KV
STC3216
C26
1000pF,2KV
STC3216
C33
10uF
STC3216
C35
10uF
STC3216
C36
10uF
STC3216
C54
10uF
STC3216
C57
10uF
STC3216
C58
10uF
STC3216
C67
10uF
STC3216
TVS1
SMBJ12CA
SR3218
TVS2
SMBJ12CA
SR3218
TVS3
SMBJ12CA
SR3218
R10
101
SR0402
R11
101
SR0402
R12
101
SR0402
R13
101
SR0402
R14
101
SR0402
R17
101
SR0402
R18
101
SR0402
R19
101
SR0402
R20
101
SR0402
R21
101
SR0402
R4
101
SR0402
R5
101
SR0402
R6
101
SR0402
R7
101
SR0402
R8
101
SR0402
R26
1M
SR0402
R27
1M
SR0402
R28
1M
SR0402
L7
2.7nH
SR0402
L8
2.7nH
SR0402
L9
2.7nH
SR0402
R22
22K
SR0402
R23
22K
SR0402
R9
22K
SR0402
L1
3.9nH
SR0402
L2
3.9nH
SR0402
L3
3.9nH
SR0402
R1
5K
SR0402
R2
5K
SR0402
R3
5K
SR0402
L4
8.2nH
SR0402
L5
8.2nH
SR0402
L6
8.2nH
SR0402
BT2
AMS1117-3.3V
sot223
U1
HMC274
sop16
U2
HMC274
sop16
U3
HMC274
sop16
SMT1
IN5622
smb
F1
FUSE
SF6127
F2
FUSE
SF6127
F3
FUSE
SF6127
F4
FUSE
SF6127
C10
1.0pF
SC0402
C11
1.0pF
SC0402
C12
1.0pF
SC0402
C5
1.5pF
SC0402
C6
1.5pF
SC0402
C8
1.5pF
SC0402
C30
100nF
SC0402
C32
100nF
SC0402
C34
100nF
SC0402
C1
100pF
SC0402
C2
100pF
SC0402
C3
100pF
SC0402
C4
100pF
SC0402
C7
100pF
SC0402
C9
100pF
SC0402
C23
10nF
SC0402
C29
10nF
SC0402
C31
10nF
SC0402
C17
1nF
SC0402
C24
1nF
SC0402
C25
1nF
SC0402
C15
2.2nF
SC0402
C16
2.2nF
SC0402
C18
2.2nF
SC0402
C37
22pF
SC0402
C38
22pF
SC0402
C39
22pF
SC0402
C40
22pF
SC0402
C41
22pF
SC0402
C42
22pF
SC0402
C14
33nF
SC0402
C19
33nF
SC0402
C20
33nF
SC0402
C21
4.7pF
SC0402
C22
4.7pF
SC0402
C27
4.7pF
SC0402
RV1
14K680D
RV_14D
J1
RJ45
rj45_A
R29
res0603
R53
res0603
R54
res0603
R43
1.5K
res0603
R32
10k
res0603
R35
10k
res0603
R39
10K
res0603
R45
10k
res0603
R50
10K
res0603
R34
120R
res0603
R41
1k
res0603
R47
1k
res0603
R57
1K
res0603
R58
1K
res0603
R59
1K
res0603
R48
1M
res0603
R36
2.2K
res0603
R37
2.2K
res0603
R51
2.2K
res0603
R56
2.2K
res0603
R40
330
res0603
R42
330
res0603
R44
330
res0603
R46
330
res0603
R49
330
res0603
R52
330
res0603
R55
330
res0603
R38
4.87K,1%
res0603
R30
49.9
res0603
R31
49.9
res0603
R33
49.9
res0603
R60
49.9
res0603
R24
75
res0603
R25
75
res0603
U4
nRF24L01-U
qfn20p4_4
U5
nRF24L01-U
qfn20p4_4
U6
nRF24L01-U
qfn20p4_4
SMA1
SMA
mysma
SMA2
SMA
mysma
SMA3
SMA
mysma
U7
MAX3485
max3485
U9
DP83848
lqfp48
U8
STM32F107VCT6
lqfp100
LED2
LED
led-2p-1X2
LED3
LED
led-2p-1X2
LED4
LED
led-2p-1X2
LED5
LED
led-2p-1X2
LED1
LED
LD0603
POWER1
POWER_IN JACK
jack-2_5mm_b
L11
100uH
IND-5x5
L10
10uH
ind0603
TEST1
testinterface
HDR254M-1X4
TEST2
testinterface
HDR254M-1X4
CRY4
25MHz
hc49smd
J2
H1102NL
h1102nl
STLINK1
ST-LINK
DIP4
CRY1
16MHz SMD
cry2520a
CRY2
16MHz SMD
cry2520a
CRY3
16MHz SMD
cry2520a
485INTERFACE
CON4
CON4_200
C28
100uF
CAPAE1300X1300
C43
0.1uF
cap0603
C44
0.1uF
cap0603
C46
0.1uF
cap0603
C47
0.1uF
cap0603
C48
0.1uF
cap0603
C49
0.1uF
cap0603
C52
0.1uF
cap0603
C53
0.1uF
cap0603
C55
0.1uF
cap0603
C56
0.1uF
cap0603
C65
0.1uF
cap0603
C68
0.1uF
cap0603
C69
0.1uF
cap0603
C70
0.1uF
cap0603
C59
100nF
cap0603
C60
100nF
cap0603
C61
100nF
cap0603
C62
100nF
cap0603
C63
100nF
cap0603
C64
100nF
cap0603
C50
10pF
cap0603
C66
10pF
cap0603
C51
1000uF
C220UF25V
SW1
2-pin-sw
button-2p
U10
3SPC090F
3SPC090F
tmp.zip (466 KB, 下载次数: 59)
azsxdcf3784 | 2018-9-5 19:15:09 | 显示全部楼层
yangxf0120 | 2018-9-5 19:25:26 | 显示全部楼层
谢谢分享基于stm32f107+nRF24L01+DP83848的2.4G射频板原理图和PCB
zhifang88 | 2018-9-5 21:41:34 | 显示全部楼层
vickey168 | 2018-9-5 22:25:01 | 显示全部楼层
ls1408 | 2018-9-6 08:32:05 | 显示全部楼层
miaomiao | 2018-9-6 09:34:54 | 显示全部楼层
i_333333 | 2018-9-6 09:48:28 | 显示全部楼层
非常感谢楼主大神的分享
带刀的老鼠 | 2018-9-6 12:43:10 | 显示全部楼层
boarmy | 2018-9-6 20:35:26 | 显示全部楼层
