重要提示:PCB作品文件展下载说明
ITM |
QTY |
REF DESIGNATIORS |
PART |
DESCRIPTION |
MAN |
PART # |
1 |
17 |
C7,C8,C9,C10,C11,C12,C13,C14,C15,C16,C18,C19,C20,C21,C22,C23,C79 |
0.1uF |
Capacitor 0.1uF 16V 10% 0402 X7R |
Kemet |
C0402C104K4RACT |
2 |
5 |
C1,C2,C3,C4,C17, |
10uF,0805 |
CAP CER 10UF 10V Y5V 0805 |
TDK |
C2012Y5V1A106Z |
3 |
2 |
D5,D6 |
598-8170-107F |
LED Green SMD 20mA 2V 0805 |
Dialight |
598-8170-107F |
4 |
4 |
FB1,FB2,FB3,FB8 |
IND,MMZ1608R301A |
FERRITE CHIP 300 OHM 500MA 0603 |
TDK |
MMZ1608R301A |
5 |
1 |
SW1 |
2 POS Dip Switch |
SWITCH TAPE SEAL 2 POS SMD |
CTS |
219-2MST |
6 |
2 |
P1,P2 |
2x23 HEADER FEMALE |
.100 CL Dual Row- Straight Socket Strip-using .025" Sq. Pins |
MLE |
SSHQ-123-D-08-G-LF |
MLE |
SSHQ-123-D-08-F-LF |
7 |
1 |
P3 |
2x5 HEADER FEMALE |
MLE |
SSHQ-105-D-08-G-LF |
2x5 HEADER FEMALE |
MLE |
SSHQ-105-D-08-F-LF |
8 |
1 |
P4 |
CONN_HDMI |
CONN RCPT HDMI TYPE A R/A SMD |
FCI |
10029449-001RLF |
9 |
1 |
Q1 |
DMC56404 |
TRANS NPN/NPN W/RES 50V SMINI6 |
Panasonic |
DMC564040R |
10 |
1 |
RT1 |
PTC_RXEF010 |
POLYSWITCH PTC RESET 0.1A |
Polyswitch |
RXEF010 |
11 |
20 |
R16,R18,R20,R22,R24,R26,R28,R31,R33,R35,R36,R38,R40,R42,R44,R45,R58,R60,R62,R64, |
33,402 |
RES 33.0 OHM 1/16W 1% 0402 SMD |
Yaego |
RC0402FR-0733RL |
12 |
20 |
R37,R39,R41,R43,R52,R54,R59,R63,R65,R66,R69,R70,R74,R75,R76,R77,R78,R79,R80,R81 |
10,402 |
RES 10.0 OHM 1/16W 1% 0402 SMD |
Yaego |
RC0402FR-0710RL |
13 |
4 |
R86,R90,R94,R95,R123 |
10K |
Resistor 10Kohm 1/16W 5% 0402 |
Rohm |
MCR01MZPJ103 |
14 |
1 |
R87 |
510 |
RES 510 OHM 1/16W 1% 0402 SMD |
Yaego |
RC0402FR-07510RL |
15 |
2 |
R88,R92 |
1.1K |
RES 1.10K OHM 1/16W 1% 0402 SMD |
Yageo |
RC0402FR-071K1L |
16 |
5 |
R89,R93,R116,R117,R118 |
4.75K |
RES 4.75K OHM 1/16W 1% 0402 SMD |
Stackpole Electronics |
RMCF0402FT4K75 |
17 |
1 |
R111 |
.1,0805 |
RES .10 OHM 1/8W 5% 0805 |
CTS |
73L3R10J |
18 |
2 |
R119,R120 |
470,5% |
RES 470 OHM 1/10W 5% 0402 SMD |
Panasonic |
ERJ-2GEJ471X |
19 |
2 |
R121,R122 |
100K,1% |
Resistor 100Kohm 1/16W 1% 0402 |
Yageo |
CRCW0402100KJNED |
20 |
2 |
R114,R115 |
5.6K |
RES 5.6K OHM 1/16W 5% 0402 SMD |
Yaego |
RC0402JR-075K6L |
21 |
1 |
U1 |
74AVC32t245 |
IC BUS TRANSCVR 32BIT 96BGA |
TI |
SN74AVC32T245ZKER |
22 |
1 |
U2 |
TFP410 |
IC TRANSMITTER DIGITAL 64-HTQFP |
TI |
TFP410PAP |
23 |
1 |
U3 |
TXS0102DCU |
IC VOLT-LEVEL TRANSLATOR 8-US8 |
TI |
TXS0102DCUR |
24 |
1 |
U8 |
CAT24C256W |
IC EEPROM 256KBIT 400KHZ 8SOIC |
ON |
CAT24C256WI-G |
重要提示:PCB作品文件展下载说明
