Item |
Qty |
Reference |
Pop option |
Value |
Tol. |
Voltage/Power |
Manufacturer |
Part Number |
Description |
Substitute |
PCB Decal |
1 |
1 |
ANT1 |
NP |
2.45/5.40GHz |
JOHANSON |
2450AD46A5400 |
DUAL BAND CERAMIC CHIP ANTENNA |
JOHANSON-2450AD46A5400 |
2 |
1 |
ANT2 |
NP |
2.45GHz |
JOHANSON |
2450AT43B100 |
2.45 GHz ANTENNA |
JOHANSON-2450AT43B100 |
3 |
2 |
C8 C9 |
0p5F |
10% |
25V COG/NPO |
JOHANSON |
250R05L0R5AV4T |
0201 SIZE SMT CERAMIC CAPACITOR |
250R05L0R5BV4T (20%) 250R05L0R5CV4T (50%) |
0201 |
4 |
2 |
C27 C28 |
NP |
0p5F |
10% |
25V COG/NPO |
JOHANSON |
250R05L0R5AV4T |
0201 |
5 |
1 |
C14 |
NP |
2pF |
±0.1pF |
25V NPO |
JOHANSON |
250R05L2R0BV4T |
0201 |
6 |
2 |
C12 C13 |
NP |
6p8F |
±0.25pF |
25V NPO |
JOHANSON |
250R05L6R8CV4T |
0201 |
7 |
1 |
C25 |
10nF |
10% |
50V X7R |
MURATA |
GRM155R71H103KA88 |
0402 SIZE SMT CERAMIC CAPACITOR |
Any |
0402 |
8 |
12 |
C1 C2 C3 C4 C5 C6 C7 C10 C11 C17 C18 C26 |
100nF |
10% |
16V X7R |
MURATA |
GRM155R71C104KA88 |
Any |
0402 |
9 |
2 |
C19 C20 |
1uF |
10% |
25V X5R |
MURATA |
GRM188R61E105KA12D |
0603 SIZE SMT CERAMIC CAPACITOR |
Any |
0603 |
10 |
2 |
C23 C24 |
4u7F |
10% |
6V3 X5R |
MURATA |
GRM188R60J475KE19D |
Any |
0603 |
11 |
2 |
C21 C22 |
10uF |
20% |
6V3 X5R |
MURATA |
GRM188R60J106ME47D |
Any |
0603 |
12 |
3 |
D1 D2 D3 |
200mA 30V PIV |
MCC |
BAT54 |
SMT SCHOTTKY DIODE |
DIODES INC BAT54-7-F |
SOT23 |
13 |
1 |
FB1 |
200R |
2.5A |
MURATA |
BLM18SG221TN1 |
FERRITE BEAD |
0603 |
14 |
2 |
J1 J4 |
NP |
TE CONNECTIVITY |
3-644456-5 |
5 POSITION SINGLE ROW 0.1" PITCHUNSHROUDED PIN HEADER |
SIP-5P |
15 |
1 |
J2 |
NP |
HIROSE |
U.FL-R-SMT-1 |
MINIATURE COAXIAL RECEPTACLE |
U.FL-R-SMT |
HIROSE-U.FL-R-SMT |
16 |
1 |
J3 |
NP |
TE CONNECTIVITY |
3-644456-3 |
3 POSITION SINGLE ROW 0.1" PITCH PINHEADER |
SIP-3P |
17 |
3 |
J5 J7 J11 |
NP |
TE CONNECTIVITY |
3-644456-5 |
2 POSITION SINGLE ROW 0.1" PITCH PINHEADER |
SIP-2P |
18 |
1 |
J6 |
MAJOR LEAGUE |
SSHQ-105-D-08-GT-LF |
5 POSITION DUAL ROW 0.1" PITCHRECEPTACLE, 9.91mm PIN LENGTH |
REC5X2-REV |
19 |
2 |
J8 J9 |
MAJOR LEAGUE |
SSHQ-123-D-08-GT-LF |
23 POSITION DUAL ROW 0.1" PITCHRECEPTACLE, 9.91mm PIN LENGTH |
REC23X2-REV |
20 |
1 |
J10 |
NP |
SULLINS |
GRPB061VWCN-RC |
6 POSITION 0.05" PITCH RIGHT ANGLEPIN STRIP HEADER |
HEADER6-RA-05 |
21 |
3 |
L6 L7 L9 |
NP |
1n8H |
±0.3nH |
JOHANSON |
L-05B1N8SV6T |
MONOLITHIC 0201 SIZE SMT INDUCTOR |
0201 |
22 |
1 |
L3 |
NP |
2n2H |
0.3nH |
JOHANSON |
L-07C2N2SV6T |
0402 SIZE CHIP INDUCTOR |
0402 |
23 |
1 |
L1 |
NP |
2n7H |
0.3nH |
JOHANSON |
L-07C2N7SV6T |
0402 |
24 |
3 |
L2 L4 L5 |
2n7H |
0.3nH |
300mA |
JOHANSON |
L-07C2N7SV6T |
0402 SIZE CERAMIC CHIP INDUCTOR |
0402 |
25 |
2 |
LED1 LED4 |
RED/GREEN |
2.0V 30mA |
LITEON |
LTST-C155KGJRKT |
DUAL RED/GREEN SMT LED |
LITEON-LTST-C155 |
26 |
1 |
LED2 |
WHITE |
2.93V 5mA |
VISHAY |
VLMW1300-GS08 |
0603 SIZE SMT LED |
0603-LED |
27 |
1 |
LED3 |
BLUE |
3.3V 20mA |
LITEON |
LTST-C170TBKT |
0805 SIZE SMT LED |
0805-LED |
28 |
1 |
M1 |
LSR |
450-0064 |
TIWI BLE MODULE |
TI_WL1271MOD-REVB |
29 |
1 |
PCB1 |
CUSTOM |
750-00430 |
BARE PRINTED CIRCUIT BOARD |
PCBNULL |
30 |
8 |
Q1 Q2 Q3 Q4 Q5 Q6 Q7 Q8 |
8V Vgs |
FAIRCHILD |
FDV301N |
N-CHANNEL DIGITAL DMOSFET |
SOT23 |
31 |
3 |
R1 R4 R5 |
4k75 |
1% |
1/16 W |
KOA |
RK73H1ETTP4751F |
THICK FILM 0402 SMT RESISTOR |
Any |
0402 |
32 |
1 |
R47 |
105k |
1% |
1/16 W |
KOA |
RK73H1ETTP1053F |
Any |
0402 |
33 |
1 |
R48 |
205k |
1% |
1/16 W |
KOA |
RK73H1ETTP2053F |
Any |
0402 |
35 |
4 |
R33 R40 R43 R44 |
100R |
5% |
1/16 W |
KOA |
RK73B1ETTP101J |
Any |
0402 |
34 |
1 |
R50 |
150R |
5% |
1/16 W |
KOA |
RK73B1ETTP151J |
Any |
0402 |
36 |
1 |
R53 |
390R |
5% |
1/16 W |
KOA |
RK73B1ETTP391J |
Any |
0402 |
37 |
2 |
R7 R9 |
NP |
1k0 |
5% |
1/16 W |
KOA |
RK73B1ETTP102J |
Any |
0402 |
38 |
1 |
R52 |
1k0 |
5% |
1/16 W |
KOA |
RK73B1ETTP102J |
Any |
0402 |
39 |
2 |
R2 R3 |
1k5 |
5% |
1/16 W |
KOA |
RK73B1ETTP152J |
Any |
0402 |
40 |
4 |
R6 R29 R34 R41 |
10k |
5% |
1/16 W |
KOA |
RK73B1ETTP103J |
Any |
0402 |
41 |
5 |
R8 R27 R28 R31 R32 |
20k |
5% |
1/16 W |
KOA |
RK73B1ETTP203J |
Any |
0402 |
42 |
3 |
R10 R11 R49 |
51k |
5% |
1/16 W |
KOA |
RK73B1ETTP513J |
Any |
0402 |
43 |
2 |
R38 R39 |
NP |
51k |
5% |
1/16 W |
KOA |
RK73B1ETTP513J |
Any |
0402 |
44 |
1 |
R51 |
100k |
5% |
1/16 W |
KOA |
RK73B1ETTP104J |
Any |
0402 |
45 |
1 |
R46 |
1M0 |
5% |
1/16 W |
KOA |
RK73B1ETTP105J |
Any |
0402 |
46 |
16 |
R12 R13 R14 R15 R16 R17 R18 R19 R20 R21R22 R23 R30 R36 R37 R42 |
0ohm |
1/16 W |
KOA |
RK73Z1ETTP |
Any |
0402 |
47 |
3 |
R24 R25 R26 |
NP |
0ohm |
1/16 W |
KOA |
RK73Z1ETTP |
Any |
0402 |
48 |
2 |
R45 R58 |
NP |
xxx |
KOA |
0402 |
49 |
1 |
S1 |
CTS |
219-2MST |
SMT 2-POS DIP SWITCH |
SMT_DIP_SW_2 |
50 |
1 |
TC1 |
KEYSTONE |
5015 |
MINIATURE SMT TESTPOINT CLIP LOOP |
KEYSTONE-5015 |
51 |
2 |
U1 U5 |
TI |
SN74AVC4T245PW |
4 BIT DUAL SUPPLY BUS TRANSCEIVER |
TSSOP16 |
52 |
1 |
U2 |
ON SEMI |
CAT24C256WI-GT3 |
32KX8 BIT SERIAL EEPROM |
SO8NB |
53 |
1 |
U3 |
TI |
TXS02612RTWR |
SDIO PORT EXPANDER WITH VOLTAGE-LEVELTRANSLATION |
QFN24_4X4-RTW |
54 |
1 |
U6 |
3.0V |
ON SEMI |
NCP303LSN30T1G |
VOLTAGE DETECTOR |
SOT23-5 |
55 |
1 |
U7 |
0.9V |
ON SEMI |
NCP303LSN09T1G |
VOLTAGE DETECTOR |
SOT23-5 |
56 |
1 |
U8 |
1.2-5V 1A |
TI |
TPS72501DCQ |
LOW INPUT VOLTAGE 1A ADJUSTABLE LDOREGULATOR |
SOT223-5 |
57 |
1 |
U9 |
1.8V |
TI |
LP2985-18DBVR |
MICROPOWER, LDO, LOW NOISE REGULATOR |
SOT23-5 |
