• 芯片制造中的阻挡层沉积技术介绍
  • 接地搭接电缆布局屏蔽!!!
  • 北美液冷生态解码:超微spuermicro,24年营
  • SK海力士全球首发HBM4-16层堆叠、2.0TB/s
  • 2纳米Nanosheet技术及其以后的选择性层减薄
[Pads_VX.2x] ADZS-BF707 Blackfin低功耗成像平台(BLIP)评估板(压缩文件内包
查看1849 | 回复0 | 2018-11-25 16:38:39 | 显示全部楼层 |阅读模式
PartTypeRefDesPartDecal
CAP_NON_POLARIZEDC10805
CAP_NON_POLARIZEDC20805
CAP_NON_POLARIZEDC30805
CAP_NON_POLARIZEDC40402
CAP_NON_POLARIZEDC50402
CAP_NON_POLARIZEDC60402
CAP_NON_POLARIZEDC70402
CAP_NON_POLARIZEDC80402
CAP_NON_POLARIZEDC90402
CAP_NON_POLARIZEDC100402
CAP_NON_POLARIZEDC110402
CAP_NON_POLARIZEDC120402
CAP_NON_POLARIZEDC130402
CAP_NON_POLARIZEDC140402
CAP_NON_POLARIZEDC150402
CAP_NON_POLARIZEDC160402
CAP_NON_POLARIZEDC170402A
CAP_NON_POLARIZEDC180402
CAP_NON_POLARIZEDC190402
CAP_NON_POLARIZEDC200402
CAP_NON_POLARIZEDC210402A
CAP_NON_POLARIZEDC220402
CAP_NON_POLARIZEDC230402
CAP_NON_POLARIZEDC240402A
CAP_NON_POLARIZEDC250402A
CAP_NON_POLARIZEDC260402A
CAP_NON_POLARIZEDC270402
CAP_NON_POLARIZEDC280402
CAP_NON_POLARIZEDC290402
CAP_NON_POLARIZEDC300402
CAP_NON_POLARIZEDC310402
CAP_NON_POLARIZEDC320402
CAP_NON_POLARIZEDC330402
CAP_NON_POLARIZEDC340402
CAP_NON_POLARIZEDC350402A
CAP_NON_POLARIZEDC360402A
CAP_NON_POLARIZEDC370402A
CAP_NON_POLARIZEDC380402
CAP_NON_POLARIZEDC390402
CAP_NON_POLARIZEDC400402
CAP_NON_POLARIZEDC410402
CAP_NON_POLARIZEDC420402
CAP_NON_POLARIZEDC430402
CAP_NON_POLARIZEDC440402
CAP_NON_POLARIZEDC450402
CAP_NON_POLARIZEDC460402
CAP_NON_POLARIZEDC470402
CAP_NON_POLARIZEDC480402
CAP_NON_POLARIZEDC490402
CAP_NON_POLARIZEDC500402
CAP_NON_POLARIZEDC510402
CAP_NON_POLARIZEDC520402
CAP_NON_POLARIZEDC530402
CAP_NON_POLARIZEDC540402
CAP_NON_POLARIZEDC550402
CAP_NON_POLARIZEDC560402
CAP_NON_POLARIZEDC570402
CAP_NON_POLARIZEDC580402
CAP_NON_POLARIZEDC590402
CAP_NON_POLARIZEDC600402
CAP_NON_POLARIZEDC610805
CAP_NON_POLARIZEDC620402
CAP_NON_POLARIZEDC630402
CAP_NON_POLARIZEDC640402
CAP_NON_POLARIZEDC650402
CAP_NON_POLARIZEDC660402
CAP_NON_POLARIZEDC670402
CAP_NON_POLARIZEDC680402
CAP_NON_POLARIZEDC690603
CAP_NON_POLARIZEDC700603
CAP_NON_POLARIZEDC760603
CAP_NON_POLARIZEDC790603
CAP_NON_POLARIZEDC800805
CAP_NON_POLARIZEDC810402
CAP_NON_POLARIZEDC820402
CAP_NON_POLARIZEDC830603
CAP_NON_POLARIZEDC840402
CAP_NON_POLARIZEDC850402
CAP_NON_POLARIZEDC860402
CAP_NON_POLARIZEDC870402
CAP_NON_POLARIZEDC880402
CAP_NON_POLARIZEDC890402
CAP_NON_POLARIZEDC900805
CAP_NON_POLARIZEDC910402
CAP_NON_POLARIZEDC920402
CAP_NON_POLARIZEDC930402
CAP_NON_POLARIZEDC940402
CAP_NON_POLARIZEDC950402
CAP_NON_POLARIZEDC960402
CAP_NON_POLARIZEDC970402
CAP_NON_POLARIZEDC980402
CAP_NON_POLARIZEDC990402
CAP_NON_POLARIZEDC1000402
CAP_NON_POLARIZEDC1010402
CAP_NON_POLARIZEDC1020402
CAP_NON_POLARIZEDC1030603
CAP_NON_POLARIZEDC1040402
CAP_NON_POLARIZEDC1050603
CAP_NON_POLARIZEDC1060402
CAP_NON_POLARIZEDC1070402
CAP_NON_POLARIZEDC1080402
CAP_NON_POLARIZEDC1090805
CAP_NON_POLARIZEDC1100805
CAP_NON_POLARIZEDC1110402
CAP_NON_POLARIZEDC1120402
CAP_NON_POLARIZEDC1130402
CAP_NON_POLARIZEDC1140402
CAP_NON_POLARIZEDC1150402
CAP_NON_POLARIZEDC1160402
CAP_NON_POLARIZEDC1170805
CAP_NON_POLARIZEDC1180402
CAP_NON_POLARIZEDC1190402
DIO_ESD_3D1SOT23-3
DIO_SCHOTTKYD2SOD-123FL
DIO_ESDA5V3D3SOT95P280-6N
DIO_ESD7004D4DFN50P250X100-10N
DIO_SCHOTTKYD5SOD-123FL
DIO_ESDA5V3D7SOT95P280-6N
DIO_ESD7004D8DFN50P250X100-10N
DIO_SCHOTTKYD9SOD-123FL
FUS_STANDARDF10603
FER_STANDARDFER10603
FER_STANDARDFER20603
FER_STANDARDFER40603
FER_STANDARDFER50603
FER_STANDARDFER60603
CON_4X2_FJ2SAMTEC_SFMC-104-T1-L-D
CON_SD_8BITJ3CON067
IND_XAL40XXL1IND_XAL40XX
IND_STANDARDL20805
IND_STANDARDL30805
IND_COUPLEDL4IND_DLW5BT
LED_STANDARDLED1LED_0603
LED_STANDARDLED3LED_0603
LED_STANDARDLED4LED_0603
CON_CORTEX_DEBUG_HEADER_SMTP3SAMTEC_SHF-105-01-L-D-SM-K
CON_USB_MINI_ABP4HIROSE_ZX62D-AB-5P8
CON_POWER_MINIP5CON045
CON_40X1P6TE_4-1734839-0
CON_USB_MINI_BP8CON069
BSR16Q1SOT95P240-3N
RES_STANDARDR10402
RES_STANDARDR20402
RES_STANDARDR30402
RES_STANDARDR40402
RES_STANDARDR50402
RES_STANDARDR60402
RES_STANDARDR70402
RES_STANDARDR80402
RES_STANDARDR90402
RES_STANDARDR100402
RES_STANDARDR110402
RES_VARISTORR120603
RES_STANDARDR130402
RES_STANDARDR140402
RES_STANDARDR150402
RES_STANDARDR160402
RES_STANDARDR170402
RES_STANDARDR180402
RES_STANDARDR190402
RES_STANDARDR200402
RES_STANDARDR210603
RES_STANDARDR220805
RES_STANDARDR230402
RES_STANDARDR240402
RES_STANDARDR250603
RES_STANDARDR260402
RES_STANDARDR270402
RES_STANDARDR280402
RES_STANDARDR290402
RES_STANDARDR300402
RES_STANDARDR310402
RES_STANDARDR320402
RES_STANDARDR330402
RES_STANDARDR340402
RES_STANDARDR350402
RES_STANDARDR360402
RES_STANDARDR370402
RES_STANDARDR380402
RES_STANDARDR390402
RES_STANDARDR400402
RES_STANDARDR410402
RES_STANDARDR420402
RES_STANDARDR430402
RES_STANDARDR440402
RES_STANDARDR450402
RES_STANDARDR460402
RES_STANDARDR470402
RES_STANDARDR480603
RES_STANDARDR490402
RES_STANDARDR500402
RES_STANDARDR510402
RES_STANDARDR520402
RES_STANDARDR530402
RES_STANDARDR540402
RES_THERMISTORR551206
RES_STANDARDR560402
RES_STANDARDR570402
RES_STANDARDR580402
RES_STANDARDR590603
RES_STANDARDR600402
RES_STANDARDR610402
RES_STANDARDR620402
RES_STANDARDR630402
RES_STANDARDR640402
RES_STANDARDR650402
RES_STANDARDR660402
RES_STANDARDR670402
RES_STANDARDR680402
RES_STANDARDR690402
RES_STANDARDR700402
RES_STANDARDR710402
RES_STANDARDR720603
RES_STANDARDR730402
RES_STANDARDR740402
RES_STANDARDR750402
RES_STANDARDR770402
RES_STANDARDR780402
RES_STANDARDR790402
RES_STANDARDR800402
RES_STANDARDR810402
RES_STANDARDR820402
RES_STANDARDR831206
RES_STANDARDR840402
RES_STANDARDR850402
RES_STANDARDR860402
RES_STANDARDR870402
RES_STANDARDR880402
RES_STANDARDR890402
RES_STANDARDR900402
RES_STANDARDR910402
RES_STANDARDR920402
RES_STANDARDR930402
RES_STANDARDR940402
RES_STANDARDR950402
RES_STANDARDR960402
RES_STANDARDR981206
RES_STANDARDR1010402
RES_STANDARDR1020402
RES_STANDARDR1030402
RES_STANDARDR1040402
RES_STANDARDR1050402
RES_STANDARDR1060402
RES_STANDARDR1070402
RES_STANDARDR1080402
RES_STANDARDR1090402
RES_STANDARDR1100402
RES_STANDARDR1110402
RES_STANDARDR1120402
RES_STANDARDR1130402
RES_STANDARDR1140402
RES_STANDARDR1150402
RES_STANDARDR1170402
RES_STANDARDR1180402
RES_STANDARDR1190402
RES_STANDARDR1200402
RES_STANDARDR1210402
RES_STANDARDR1220402
RES_STANDARDR1240402
RES_STANDARDR1250402
RES_STANDARDR1260402
RES_STANDARDR1270402
RES_STANDARDR1280402
RES_STANDARDR1290402
RES_STANDARDR1300402
RES_STANDARDR1310402
RES_STANDARDR1320402
RES_STANDARDR1330402
RES_STANDARDR1340402
RES_STANDARDR1350402
RES_STANDARDR1360402
RES_STANDARDR1370402
RES_STANDARDR1380402
RES_STANDARDR1400402
RES_STANDARDR1410402
RES_STANDARDR1420402
RES_STANDARDR1430402
RES_STANDARDR1460603
RES_STANDARDR1470402
RES_STANDARDR1480402
RES_STANDARDR1490603
RES_STANDARDR1500402
RES_STANDARDR1511206
RES_STANDARDR1520402
RES_STANDARDR1530402
RES_STANDARDR1540402
RES_STANDARDR1550402
RNET_8ISOLATEDRN2RNS003
RNET_8ISOLATEDRN3RNS003
RNET_8ISOLATEDRN4RNS003
RNET_8ISOLATEDRN5RNS003
RNET_4SERIESRN6RNS005
RNET_4SERIESRN7RNS005
RNET_4SERIESRN8RNS005
RNET_4SERIESRN9RNS005
RNET_4SERIESRN10RNS005
RNET_4SERIESRN11RNS005
RNET_4SERIESRN12RNS005
RNET_4SERIESRN13RNS005
RNET_4SERIESRN14RNS005
RNET_4SERIESRN15RNS005
RNET_8ISOLATEDRN17RNS003
RNET_8ISOLATEDRN18RNS003
SW_MOM_PBSW1SWT024
SW_MOM_PBSW2SWT024
SW_MOM_PBSW3SWT024
SW_MOM_PBSW4SWT024
MSC_TEST_POINTTP1TP
MSC_TEST_POINTTP3TP
MSC_TEST_POINTTP4TP
MSC_TEST_POINTTP5TP
MSC_TEST_POINT_TRTP6TP_5001_TR
MSC_TEST_POINTTP7TP
MSC_TEST_POINTTP9TP
MSC_TEST_POINTTP10TP
ADP2370U1DFN50P300X300-9N
MT46H128M16LFB7U2BGA60C80P9X10_1000X1000
ICS_ADM6315U3SOT143
ICS_OVM7692_RACAU4BGA25C50X54P5X5_282X318
ADP195U5DFN65P200X200-7N
DSP_BF707U7BGA184C80P14X14_1200X1200_SCKT
ICS_M25P80U8SO8W
ICS_ASX340AT_DSU10BGA63C65P8X8_7500X7500_SCKT
ICS_SN74XXX1G08U11SOT23-5
ICS_LTC6993-3U12SOT95P280-6N
ADP2230ACPZ-R7U13DFN50P300X300-11N
SN74LVC2G14U14SOT65P210-6N
ICS_FT232RQU15QFN50P500X500-33NA
ICS_ADP220VR1BGA6C50P2X3_100X150
MSC_COPPERW14A
OSC_CRYSTAL_GNDY1OSC013
OSC_CRYSTAL_GNDY2OSC013
FIDUCIAL-GTZF1FIDUCIAL-GT
FIDUCIAL-GTZF2FIDUCIAL-GT
FIDUCIAL-GTZF3FIDUCIAL-GT
FIDUCIAL-GTZF4FIDUCIAL-GT
FIDUCIAL-GTZF5FIDUCIAL-GT
FIDUCIAL-GTZF6FIDUCIAL-GT
MTHOLE3ZH1MTHOLE3
MTHOLE3ZH2MTHOLE3
MTHOLE3ZH3MTHOLE3
MTHOLE3ZH4MTHOLE3
MTHOLE3ZH5MTHOLE3
MTHOLE3ZH6MTHOLE3
MTHOLE3ZH7MTHOLE3
MTHOLE3ZH8MTHOLE3
购买主题 本主题需向作者支付 5 枚金币 才能浏览
重要提示:PCB作品文件展下载说明
