• 芯片制造中的阻挡层沉积技术介绍
  • 接地搭接电缆布局屏蔽!!!
  • 北美液冷生态解码:超微spuermicro,24年营
  • SK海力士全球首发HBM4-16层堆叠、2.0TB/s
  • 2纳米Nanosheet技术及其以后的选择性层减薄
[Pads_VX.2x] 视频编码器 Video_Encoder_EI3_Extender_Board(ADV7511KSTZ)(压缩文
查看2211 | 回复8 | 2018-11-25 16:48:39 | 显示全部楼层 |阅读模式
BAD1BADMARKBADMARK
C1402CAP_NON_POLARIZED
C2402CAP_NON_POLARIZED
C3402CAP_NON_POLARIZED
C4402CAP_NON_POLARIZED
C7402CAP_NON_POLARIZED
C8402CAP_NON_POLARIZED
C9402CAP_NON_POLARIZED
C10402CAP_NON_POLARIZED
C11402CAP_NON_POLARIZED
C12402CAP_NON_POLARIZED
C14402CAP_NON_POLARIZED
C15402CAP_NON_POLARIZED
C16402CAP_NON_POLARIZED
C17402CAP_NON_POLARIZED
C18402CAP_NON_POLARIZED
C19402CAP_NON_POLARIZED
C20402CAP_NON_POLARIZED
C21402CAP_NON_POLARIZED
C22805CAP_NON_POLARIZED
C23402CAP_NON_POLARIZED
C26402CAP_NON_POLARIZED
C29402CAP_NON_POLARIZED
C30402CAP_NON_POLARIZED
C31603CAP_NON_POLARIZED
C32402CAP_NON_POLARIZED
C33603CAP_NON_POLARIZED
C34402CAP_NON_POLARIZED
C35402CAP_NON_POLARIZED
C36402CAP_NON_POLARIZED
C37402CAP_NON_POLARIZED
C38805CAP_NON_POLARIZED
C39805CAP_NON_POLARIZED
C40402CAP_NON_POLARIZED
C41402CAP_NON_POLARIZED
C42402CAP_NON_POLARIZED
C43402CAP_NON_POLARIZED
C44402CAP_NON_POLARIZED
C45402CAP_NON_POLARIZED
C46603CAP_NON_POLARIZED
C47603CAP_NON_POLARIZED
C48402CAP_NON_POLARIZED
C49805CAP_NON_POLARIZED
C50402CAP_NON_POLARIZED
C51402CAP_NON_POLARIZED
C52402CAP_NON_POLARIZED
C53402CAP_NON_POLARIZED
C54402CAP_NON_POLARIZED
C55402CAP_NON_POLARIZED
C56402CAP_NON_POLARIZED
C57402CAP_NON_POLARIZED
C58805CAP_NON_POLARIZED
C59402CAP_NON_POLARIZED
C60402CAP_NON_POLARIZED
C61402CAP_NON_POLARIZED
C62402CAP_NON_POLARIZED
C63603CAP_NON_POLARIZED
C64402CAP_NON_POLARIZED
C65402CAP_NON_POLARIZED
C66805CAP_NON_POLARIZED
C67603CAP_NON_POLARIZED
C68805CAP_NON_POLARIZED
C69402CAP_NON_POLARIZED
C70402CAP_NON_POLARIZED
C71402CAP_NON_POLARIZED
C72402CAP_NON_POLARIZED
C73402CAP_NON_POLARIZED
C74402CAP_NON_POLARIZED
C75402CAP_NON_POLARIZED
C76402CAP_NON_POLARIZED
C77402CAP_NON_POLARIZED
C80402CAP_NON_POLARIZED
C81402CAP_NON_POLARIZED
C82402CAP_NON_POLARIZED
C83402CAP_NON_POLARIZED
C84805CAP_NON_POLARIZED
C85805CAP_NON_POLARIZED
C86402CAP_NON_POLARIZED
C87402CAP_NON_POLARIZED
C90402CAP_NON_POLARIZED
C91402CAP_NON_POLARIZED
C92805CAP_NON_POLARIZED
C93402CAP_NON_POLARIZED
C94402CAP_NON_POLARIZED
C95805CAP_NON_POLARIZED
C96402CAP_NON_POLARIZED
D1SOT23DDIO_SCHOTTKY_BAT54S
D2SOT23DDIO_SCHOTTKY_BAT54S
D3SOT23DDIO_SCHOTTKY_BAT54S
D4SOD-123FLDIO_SCHOTTKY
D5SOD-123FLDIO_SCHOTTKY
D6SOD-123FLDIO_SCHOTTKY
D7SOT23DDIO_AD1580
D8DIO_DB3X314DIO_SCHOTTKY
D9DIO_RCLAMP0524DIO_RCLAMP0524
D10DIO_RCLAMP0524DIO_RCLAMP0524
D11DIO_RCLAMP0524DIO_RCLAMP0524
F11206FUS_STANDARD
FER1FIL_NFE61PTFER_EMIFILTER
FER2FIL_NFE61PTFER_EMIFILTER
FER3FIL_NFE61PTFER_EMIFILTER
FER4FIL_NFE61PTFER_EMIFILTER
FER5FIL_NFE61PTFER_EMIFILTER
FER6FIL_NFE61PTFER_EMIFILTER
FER7FIL_NFE61PTFER_EMIFILTER
FER8FIL_NFE61PTFER_EMIFILTER
J1CUI-STACK_RCJ-32265CON_RCA_3
J2CUI-STACK_MD-40SMCON_SVIDEO
J3EDAC_634-015-263-032CON_VGA
J4HIROSE_FX8-120S-SV(21)CON_EI3_1A_DB
J5FCI_10029449-002TLFCON_HDMI
J6CON012CON_RCA
L11008IND_STANDARD
L21008IND_STANDARD
L31008IND_STANDARD
L41008IND_STANDARD
L51008IND_STANDARD
L61008IND_STANDARD
L71008IND_STANDARD
L81008IND_STANDARD
L91008IND_STANDARD
LED1LED001LED_STANDARD
LED2LED001LED_STANDARD
M1MTHOLE1MTHOLE1
M2MTHOLE1MTHOLE1
MF1FIDFID
MF2FIDFID
MF3FIDFID
MF4FIDFID
MF5FIDFID
MF6FIDFID
MF9FIDFID
MF10FIDFID
P1CON027CON_POWER_MINI
R1402RES_STANDARD
R2402RES_STANDARD
R3402RES_STANDARD
R4402RES_STANDARD
R5805RES_STANDARD
R6805RES_STANDARD
R7805RES_STANDARD
R8805RES_STANDARD
R9805RES_STANDARD
R10805RES_STANDARD
R11402RES_STANDARD
R12402RES_STANDARD
R13402RES_STANDARD
R14402RES_STANDARD
R15402RES_STANDARD
R16402RES_STANDARD
R17402RES_STANDARD
R18402RES_STANDARD
R19402RES_STANDARD
R20402RES_STANDARD
R21402RES_STANDARD
R22402RES_STANDARD
R23402RES_STANDARD
R24402RES_STANDARD
R25402RES_STANDARD
R26402RES_STANDARD
R27402RES_STANDARD
R28402RES_STANDARD
R29402RES_STANDARD
R30402RES_STANDARD
R31402RES_STANDARD
R32603RES_STANDARD
R33402RES_STANDARD
R34402RES_STANDARD
R35402RES_STANDARD
R36402RES_STANDARD
R37402RES_STANDARD
R38402RES_STANDARD
R39402RES_STANDARD
R40402RES_STANDARD
R41603RES_STANDARD
R42603RES_STANDARD
R43402RES_STANDARD
R44402RES_STANDARD
R45402RES_STANDARD
R46402RES_STANDARD
R47603RES_STANDARD
R48603RES_STANDARD
R49402RES_STANDARD
R50402RES_STANDARD
R51402RES_STANDARD
R52603RES_STANDARD
R53603RES_STANDARD
R54402RES_STANDARD
R55603RES_VARISTOR
R56402RES_STANDARD
R57402RES_STANDARD
R58402RES_STANDARD
RN1RNET8RNET_8BUSSED
RN2RNET8RNET_8BUSSED
TP1TP_5001_DBLMSC_TEST_POINT_DBL
TP2TP_5001_DBLMSC_TEST_POINT_DBL
TP3TP_5001_DBLMSC_TEST_POINT_DBL
TP4TP_5001_SQMSC_TEST_POINT_SQ
TP5TP_5001_SQMSC_TEST_POINT_SQ
TP6TP_5001_SQMSC_TEST_POINT_SQ
TP7TP_5001_DBLMSC_TEST_POINT_DBL
TP8TP_5001_SQMSC_TEST_POINT_SQ
TP9TP_5001_SQMSC_TEST_POINT_SQ
TP10TP_5001_SQMSC_TEST_POINT_SQ
TP11TP_5001_SQMSC_TEST_POINT_SQ
TP12TP_5001_SQMSC_TEST_POINT_SQ
TP13TP_5001_SQMSC_TEST_POINT_SQ
TP14TP_5001_SQMSC_TEST_POINT_SQ
TP15TP_5001_SQMSC_TEST_POINT_SQ
TP16TP_5001_TRMSC_TEST_POINT_TR
TP17TP_5001_TRMSC_TEST_POINT_TR
TP19TP_5001_TRMSC_TEST_POINT_TR
TP20TP_5001_TRMSC_TEST_POINT_TR
TP21TP_5001_TRMSC_TEST_POINT_TR
TP22TP_5001_TRMSC_TEST_POINT_TR
TP23TP_5001_TRMSC_TEST_POINT_TR
TP24TP_5001_TRMSC_TEST_POINT_TR
TP25TP_5001_SQMSC_TEST_POINT_SQ
U1SOIC16ICS_SN74AVC4T245
U2LQFP64ICS_ADV7341
U3TSSOP56ICS_SN74CB3Q16211
U4SOT23-5ICS_SN74XXX1G04
U5SOT23-5ICS_SN74XXX1G04
U6LFBGA84ICS_SN74AVC24T245
U7TSSOP14ICS_PI3C3125
U8TSSOP14ICS_PI3C3125
U9TSSOP14ICS_PI3C3125
U10TSSOP56ICS_SN74CB3Q16211
U11TSSOP56ICS_SN74CB3Q16211
U12TSSOP56ICS_SN74CB3Q16211
U13TSSOP56ICS_SN74CB3Q16211
U14LQFP100ICS_ADV7511
U15OSC003OSC_SMT_OE_POWER
U16OSC003OSC_SMT_OE_POWER
U17OSC015OSC_SMT_OE_POWER
U18TSSOP24ICS_SN74AVC8T245
U19QFN65P600X600-29NICS_MCP23017
U22SOT23-5ICS_SN74XXX1G125
U23SC70_6ICS_ADA4430
U24SC70_6ICS_ADA4430
U25SC70_6ICS_ADA4430
VR1LFCSP8ICS_ADP1706
VR2LFCSP8ICS_ADP1706
XXXXHIROSE_FX8-120P-SV1(91)_MHCON_EI3_1A_KIT
XXXX1HIROSE_FX8-120P-SV1(91)_MHCON_EI3_1A_KIT
购买主题 本主题需向作者支付 5 枚金币 才能浏览
重要提示:PCB作品文件展下载说明
ky175 | 2018-11-25 21:23:07 | 显示全部楼层
cdl511 | 2018-11-25 21:52:43 | 显示全部楼层
nexuizhua | 2018-11-25 22:02:26 | 显示全部楼层
lijun769954670 | 2018-11-26 08:35:21 | 显示全部楼层
djg | 2018-11-26 08:53:41 | 显示全部楼层
lcfmax | 2018-11-26 08:54:06 | 显示全部楼层
djg | 2018-11-26 08:54:34 | 显示全部楼层
zblin1987 | 2018-11-26 08:56:57 | 显示全部楼层
