查看: 3211|回复: 12
[Allegro16.6以下] 6层-基于 AM335x以太网/IP通信开发平台PCB文件+原理图(AM335X+
BLOG:https://blog.csdn.net/
发表于 2018-11-28 09:15:47 | 显示全部楼层 |阅读模式
特性
    [li]基于 AM335x 处理器的设计通过免去外部 ASIC/FPGA,可节约 30% 的系统 BOM 成本[/li][li]可扩展的 HMI、PLC 和 I/O 解决方案,可以访问其他外设和接口[/li][li]TI 提供的免费板级支持包和工业软件开发套件[/li][li]支持与同一硬件(例如,EtherCAT、PROFIBUS、PROFINET 等)进行其他工业通信[/li][li]生产就绪的开发平台子系统,包括原理图、BOM、用户指南、应用手册、白皮书、软件、演示和更多内容[/li]
基于 AM335x ARM Cortex-A8 处理器的以太网IP 通信开发平台.7z (3.44 MB, 下载次数: 29) 基于 AM335x以太网/IP通信开发平台PCB文件+原理图
6层PCB设计,2508Pins[/hide]
ItemNumberQuantityValueDescriptionPCB FootprintPart Reference
11OSD-9616 -A1
210.01uF SM-7351-CAP-0402C1
310.01uF SM-7351-CAP-0402C2
410.01uF SM-7351-CAP-0402C3
510.1uF SM-7351-CAP-0402C4
610.01uF SM-7351-CAP-0402C5
710.1uF SM-7351-CAP-0402C6
810.1uF SM-7351-CAP-0402C7
910.01uF SM-7351-CAP-0402C8
1010.01uF SM-7351-CAP-0402C9
1110.01uF SM-7351-CAP-0402C10
1210.01uF SM-7351-CAP-0402C11
1310.01uF SM-7351-CAP-0402C12
1410.1uF SM-7351-CAP-0402C13
1510.1uF SM-7351-CAP-0402C14
1610.01uF SM-7351-CAP-0402C15
1710.1uF SM-7351-CAP-0402C16
1810.1uF SM-7351-CAP-0402C17
1910.1uF SM-7351-CAP-0402C18
2010.1uF SM-7351-CAP-0402C19
2110.1uF SM-7351-CAP-0402C20
2210.1uF SM-7351-CAP-0402C21
2310.1uF SM-7351-CAP-0402C22
24110uF SM-7351-CAP-0805C23
2514.7uF sm-7351-cap-0805C24
2610.1uF, 6.3V SMD0201C25
2710.1uF, 6.3V SMD0201C26
28110uF SM-7351-CAP-0805C27
29110uF SM-7351-CAP-0805C28
30110uF SM-7351-CAP-0805C29
3110.1uF, 6.3V SMD0201C30
3210.1uF, 6.3V SMD0201C31
3310.1uF SM-7351-CAP-0402C32
3410.001uF SM-7351-CAP-0402C33
3510.01uF SM-7351-CAP-0402C34
3610.01uF SM-7351-CAP-0402C35
3710.01uF SM-7351-CAP-0402C36
3810.01uF SM-7351-CAP-0402C37
39110uF SM-7351-CAP-0805C38
40110uF SM-7351-CAP-0805C39
41122pFCapacitor 22pF 50V10% 0402SM-7351-CAP-0402C40
4210.1uF SM-7351-CAP-0402C41
43122pFCapacitor 22pF 50V10% 0402SM-7351-CAP-0402C42
4410.01uF SM-7351-CAP-0402C43
4514.7uF SM-7351-CAP-0603C44
4614.7uF SM-7351-CAP-0603C45
4710.01uF SM-7351-CAP-0402C46
48110uF SM-7351-CAP-0805C47
49147uF 7343C48
5012.2uFCapacitor 2.2uFCeramic, 6.3V, X5R, 20%SM-7351-CAP-0402C49
5112.2uFCapacitor 2.2uFCeramic, 6.3V, X5R, 20%SM-7351-CAP-0402C50
5212.2uF, 10V SM-7351-CAP-0402C51
5312.2uF, 10V SM-7351-CAP-0402C52
5412.2uFCapacitor 2.2uFCeramic, 6.3V, X5R, 20%SM-7351-CAP-0402C53
55110uF SM-7351-CAP-0805C54
5610.1uF SM-7351-CAP-0402C55
5710.01uF SM-7351-CAP-0402C56
5814.7uF SM-7351-CAP-0603C57
5914.7uF SM-7351-CAP-0603C58
6014.7uF SM-7351-CAP-0603C59
6112.2uFCapacitor 2.2uF 16V10% 0805SM-7351-CAP-0805C60
62110uF SM-7351-CAP-0805C61
6312.2uF SM-7351-CAP-0805C62
6412.2uF SM-7351-CAP-0805C63
65110uF SM-7351-CAP-0805C64
66110uF SM-7351-CAP-0805C65
6714.7uF SM-7351-CAP-0603C66
68110uF SM-7351-CAP-0805C67
6910.01uF SM-7351-CAP-0402C68
7010.01uF SM-7351-CAP-0402C69
7110.1uF SM-7351-CAP-0402C70
7210.1uF SM-7351-CAP-0402C71
7310.1uF SM-7351-CAP-0402C72
7410.1uF SM-7351-CAP-0402C73
7510.1uF SM-7351-CAP-0402C74
7610.1uF SM-7351-CAP-0402C75
7711uF SM-7351-CAP-0402C76
7810.1uF SM-7351-CAP-0402C77
7910.1uF SM-7351-CAP-0402C78
8010.1uF SM-7351-CAP-0402C79
8110.1uF SM-7351-CAP-0402C80
82110uF SM-7351-CAP-0805C81
8310.1uF SM-7351-CAP-0402C82
8410.1uF SM-7351-CAP-0402C83
85110uF SM-7351-CAP-0805C84
8610.1uF SM-7351-CAP-0402C85
8710.1uF SM-7351-CAP-0402C86
8810.1uF SM-7351-CAP-0402C87
8910.1uF SM-7351-CAP-0402C88
90118pF, 50V SM-7351-CAP-0402C89
91118pF, 50V SM-7351-CAP-0402C90
9210.1uF SM-7351-CAP-0402C91
93110uF SM-7351-CAP-0805C92
9410.1uF SM-7351-CAP-0402C93
95110uF SM-7351-CAP-0805C94
96110uF SM-7351-CAP-0805C95
9710.1uF SM-7351-CAP-0402C96
9812.2uFCapacitor 2.2uF 16V10% 0805SM-7351-CAP-0805C97
9910.01uF SM-7351-CAP-0402C98
100124pF SM-7351-CAP-0402C99
101124pF SM-7351-CAP-0402C100
102110uF SM-7351-CAP-0805C101
103110uF SM-7351-CAP-0805C102
10410.1uF, 6.3V SMD0201C103
105110uF SM-7351-CAP-0805C104
10610.1uF, 6.3V SMD0201C105
10710.01uF SM-7351-CAP-0402C106
108110uF SM-7351-CAP-0805C107
10910.01uF SM-7351-CAP-0402C108
11010.01uF SM-7351-CAP-0402C109
11110.01uF SM-7351-CAP-0402C110
11210.01uF SM-7351-CAP-0402C111
11310.01uF SM-7351-CAP-0402C112
11410.01uF SM-7351-CAP-0402C113
11510.01uF SM-7351-CAP-0402C114
11610.1uF, 6.3V SMD0201C115
11710.01uF SM-7351-CAP-0402C116
11810.1uF, 6.3V SMD0201C117
11910.1uF, 6.3V SMD0201C118
12010.01uF SM-7351-CAP-0402C119
12110.01uF SM-7351-CAP-0402C120
122110uF SM-7351-CAP-0805C121
12310.1uF, 6.3V SMD0201C122
12410.01uF SM-7351-CAP-0402C123
12510.01uF SM-7351-CAP-0402C124
12610.01uF SM-7351-CAP-0402C125
12710.1uF, 6.3V SMD0201C126
12810.1uF, 6.3V SMD0201C127
12910.1uF, 6.3V SMD0201C128
13010.1uF, 6.3V SMD0201C129
13110.01uF SM-7351-CAP-0402C130
13210.01uF SM-7351-CAP-0402C131
13310.01uF SM-7351-CAP-0402C132
13410.1uF, 6.3V SMD0201C133
13510.01uF SM-7351-CAP-0402C134
13610.01uF SM-7351-CAP-0402C135
13710.1uF, 6.3V SMD0201C136
13810.01uF SM-7351-CAP-0402C137
13910.1uF, 6.3V SMD0201C138
14010.01uF SM-7351-CAP-0402C139
14110.1uF, 6.3V SMD0201C140
14210.1uF, 6.3V SMD0201C141
14310.01uF SM-7351-CAP-0402C142
14410.01uF SM-7351-CAP-0402C143
14510.1uF, 6.3V SMD0201C144
1461100pF25V10% SM-7351-CAP-0402C145
14710.1uF, 6.3V SMD0201C146
14810.1uF, 6.3V SMD0201C147
14910.01uF SM-7351-CAP-0402C148
15010.01uF SM-7351-CAP-0402C149
15110.01uF SM-7351-CAP-0402C150
15210.01uF SM-7351-CAP-0402C151
15310.01uF SM-7351-CAP-0402C152
15410.1uF, 6.3V SMD0201C153
155110uF SM-7351-CAP-0805C154
15610.01uF SM-7351-CAP-0402C155
15710.1uF, 6.3V SMD0201C156
15810.01uF SM-7351-CAP-0402C157
15910.1uF, 6.3V SMD0201C158
16010.1uF SM-7351-CAP-0402C159
16110.01uF SM-7351-CAP-0402C160
16210.1uF, 6.3V SMD0201C161
16310.1uF SM-7351-CAP-0402C162
16410.01uF SM-7351-CAP-0402C163
16510.01uF SM-7351-CAP-0402C164
16610.1uF, 6.3V SMD0201C165
16710.01uF SM-7351-CAP-0402C166
16810.1uF SM-7351-CAP-0402C167
16910.1uF, 6.3V SMD0201C168
17010.01uF SM-7351-CAP-0402C169
17110.01uF SM-7351-CAP-0402C170
17210.01uF SM-7351-CAP-0402C171
17310.01uF SM-7351-CAP-0402C172
17410.01uF SM-7351-CAP-0402C173
17510.1uF, 6.3V SMD0201C174
17610.01uF SM-7351-CAP-0402C175
17710.1uF, 6.3V SMD0201C176
17810.01uF SM-7351-CAP-0402C177
179110uF SM-7351-CAP-0805C178
180110uF SM-7351-CAP-0805C179
18110.1uF, 6.3V SMD0201C180
18210.01uF SM-7351-CAP-0402C181
18310.01uF SM-7351-CAP-0402C182
18410.1uF, 6.3V SMD0201C183
1851100pF25V10% SM-7351-CAP-0402C184
18610.1uF SM-7351-CAP-0402C185
18714.7uF SM-7351-CAP-0603C186
18810.01uF SM-7351-CAP-0402C187
18910.1uF SM-7351-CAP-0402C188
190
评分
参与人数 1威望 -5 收起 理由
老吴 -5 重复 http://bbs.ntpcb.com/read.php?tid=119
查看全部评分
BLOG:https://blog.csdn.net/Pieces_thinking
  • 签到天数: 103 天
    7万
    发表于 2018-11-28 09:20:20 | 显示全部楼层
    Re:6层-基于
    学习一下吧
    发表于 2018-11-28 09:29:14 | 显示全部楼层
    发表于 2018-11-28 09:38:49 | 显示全部楼层
    PADS-180606高级班
    终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖金点子奖
    发表于 2018-11-28 09:44:59 | 显示全部楼层
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2018-11-28 09:45:24 | 显示全部楼层
    非常感谢楼主大神的分享
    脸盆
    终身成就奖社区居民
    发表于 2018-11-28 12:33:41 | 显示全部楼层
    mentor  xpedition    球球裙:156782529
    发表于 2018-11-29 10:06:37 | 显示全部楼层
    发表于 2018-12-9 20:12:02 | 显示全部楼层
    3 天前
  • 签到天数: 111 天
    1元学习PADS(3期)
    发表于 2019-2-25 08:57:19 | 显示全部楼层
