[AD格式] 采用 LM53635用于消除高性能 DAQ 系统中的 EMI 影响的多轨电源
查看2021 | 回复2 | 2018-11-28 15:03:45 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
4层1540PIN
游客,如果您要查看本帖隐藏内容请回复
Item #DesignatorQuantityDescriptionPackageReference
1!PCB1Printed CircuitBoard
224Vin,GNDin, TP3, TP8, TP25, TP26, TP27, TP28, TP29, TP30, TP_3P3V, TP_3P8V,TP_5P5V, TP_18P5V, TPAGND1, TPAGND2, TPAGND3, TPAGND4, TPGND1, TPGND2,TPGND3, TPGND4, TPV423TestPoint, Miniature, SMTTestpoint_Keystone_Miniature
3C1, C43, C47,C354, C389, C391, C408, Cin, Cin1, Cin2, Cin3, Cout212CAP, CERM, 10µF, 50 V, +/- 10%, X7R, 12101210
4C31CAP,CERM, 10uF, 10V, +/-10%, X7R, 08050805
5C41CAP, CERM, 1uF,10V, +/-10%, X7R, 06030603
6C51CAP,CERM, 47 µF, 10 V, +/- 10%, X7R, 12101210
7C9, C12, C13,C16, C17, C20, Cout47CAP, CERM, 47µF, 25 V, +/- 20%, X5R, 1206_1901206_190
8C101CAP,CERM, 1000 pF, 100 V, +/- 10%, X7R, AEC-Q200 Grade 1, 06030603
9C11, C42, C45,Cout34CAP, CERM, 1µF, 100 V, +/- 10%, X7S, 08050805
10C14,C182CAP,CERM, 1000 pF, 50 V, +/- 1%, C0G/NP0, 06030603
11C15, C19, C318,C319, C321, C339, C348, C453, CR4799CAP, CERM, 1µF, 25 V, +/- 10%, X7R, 06030603
12C21,C22, C57, C58, C59, C60, C261, C262, C271, C272, C284, C287, C288, C289,C290, C291, C304, C305, C306, C307, C308, C338, C343, C345, C347, CR48126CAP,CERM, 10 µF, 10 V, +/- 10%, X7R, 08050805
13C23, C24, C333CAP, CERM, 10µF, 10 V, +/- 20%, X5R, 06030603
14C251CAP,CERM, 0.47 µF, 25 V, +/- 10%, X7R, 06030603
15C26, C282CAP, CERM, 22µF, 6.3 V, +/- 20%, X5R, 06030603
16C271CAP,CERM, 0.1 µF, 16 V, +/- 10%, X5R, 06030603
17C291CAP, CERM, 4.7µF, 10 V, +/- 20%, X5R, 06030603
18C301CAP,CERM, 0.22 µF, 10 V, +/- 10%, X5R, 06030603
19C311CAP, CERM, 0.22µF, 50 V, +/- 10%, X7R, AEC-Q200 Grade 1, 06030603
20C32,C352CAP,CERM, 0.1 µF, 50 V, +/- 10%, X7R, 06030603
21C341CAP, CERM,0.033 µF, 50 V, +/- 10%, X7R, 06030603
22C371CAP,CERM, 910 pF, 50 V, +/- 5%, C0G/NP0, 06030603
23C381CAP, CERM, 10pF, 50 V, +/- 5%, C0G/NP0, AEC-Q200 Grade 1, 06030603
24C391CAP,CERM, 150 pF, 50 V, +/- 5%, C0G/NP0, 06030603
25C401CAP, CERM,0.022 µF, 50 V, +/- 10%, X7R, 06030603
26C411CAP,CERM, 22 µF, 35 V, +/- 20%, X5R, 08050805
27C461CAP, CERM, 0.01µF, 50 V, +/- 10%, X7R, AEC-Q200 Grade 1, 06030603
28C53,C54, C55, C56, C94, C95, C340, C344, C346, C349, C35011CAP,CERM, 0.1 µF, 16 V, +/- 10%, X7R, 04020402
29C61, C84, C85,C91, C92, C93, C108, C112, C116, C120, C121, C122, C259, C260, C266, C267,C268, C269, C320, C454, C455, C46022CAP, CERM, 0.1µF, 25 V, +/- 5%, X7R, 06030603
30C62,C449, C457, C458, C4595CAP,CERM, 10 µF, 10 V, +/- 10%, X7T, 06030603
31C63, C642CAP, CERM, 0.1µF, 25 V, +/- 10%, X5R, 04020402
32C71,C72, C96, C974CAP,CERM, 100 pF, 100 V, +/- 5%, C0G/NP0, AEC-Q200 Grade 1, 06030603
33C79, C80, C81,C82, C104, C105, C106, C1078CAP, CERM, 0.1µF, 100 V, +/- 10%, X7R, 06030603
34C831CAP,CERM, 68 pF, 100 V, +/- 5%, C0G/NP0, 06030603
35C86, C87, C111,C1144CAP, CERM, 390pF, 100 V, +/- 5%, C0G/NP0, 06030603
36C88,C1192CAP,CERM, 1 µF, 10 V, +/- 10%, X7R, 06030603
37C109, C1152CAP, CERM, 1000pF, 50 V, +/- 5%, C0G/NP0, 06030603
38C110,C1132CAP,CERM, 130 pF, 100 V, +/- 5%, C0G/NP0, 06030603
39C117, C118, C3153CAP, CERM, 1000pF, 100 V, +/- 5%, C0G/NP0, 06030603
40C322,C3232CAP,CERM, 22 µF, 10 V, +/- 20%, X5R, 06030603
41C351, C352, C3533CAP, TA, 4.7µF, 25 V, +/- 10%, 2 ohm, SMD6032-28
42C355,C359, C360, C367, C371, C372, C379, C383, C3849CAP,CERM, 0.1 µF, 100 V, +/- 10%, X7R, 08050805
43C356, C368, C3803CAP, CERM, 4.7µF, 35 V, +/- 10%, X7R, 12061206
44C357,C358, C369, C370, C381, C3826CAP,CERM, 10 µF, 25 V, +/- 10%, X7R, 12061206
45C361, C373, C3853CAP, CERM, 0.47µF, 25 V, +/- 10%, X7R, AEC-Q200 Grade 1, 06030603
46C362,C375, C3883CAP,CERM, 0.1 µF, 50 V, +/- 10%, X6S, 04020402
47C363, C374, C3873CAP, CERM, 100pF, 25 V, +/- 5%, C0G/NP0, 04020402
48C364,C366, C376, C3784CAP,CERM, 22 µF, 16 V, +/- 20%, X7R, AEC-Q200 Grade 1, 12101210
49C4011CAP, CERM, 10µF, 50 V, +/- 10%, X7S, 12101210
50C4021CAP,CERM, 0.1 µF, 50 V, +/- 10%, X5R, 06030603
51C4031CAP, CERM, 4.7µF, 25 V, +/- 10%, X5R, 06030603
52C4041CAP,CERM, 0.47 µF, 50 V, +/- 10%, X5R, 06030603
53C4051CAP, CERM, 1µF, 35 V, +/- 10%, X7R, 06030603
54C4061CAP,CERM, 22 µF, 35 V, +/- 20%, X5R, 12061206
55C4071CAP, CERM,0.022 µF, 25 V, +/- 10%, X7R, 06030603
56C4091CAP,CERM, 100 pF, 50 V, +/- 5%, C0G/NP0, 06030603
57C4521CAP, CERM, 0.22µF, 16 V, +/- 5%, X7R, 08050805
58C4611CAP,CERM, 10 pF, 50 V, +/- 1%, C0G/NP0, 06030603
59Cff1CAP, CERM,0.022 µF, 100 V, +/- 10%, X7R, 06030603
60Cff2,Cff32CAP,CERM, 0.022uF, 50V, +/-10%, X7R, 08050805
61Cout11CAP, CERM, 22µF, 35 V, +/- 20%, JB, 08050805
62Cout51CAP,CERM, 100 µF, 6.3 V, +/- 20%, X6S, 12101210
63Cout61CAP, CERM, 1µF, 25 V, +/- 10%, X7R, 06030603
64Css1CAP,CERM, 4700 pF, 100 V, +/- 10%, X7R, AEC-Q200 Grade 1, 06030603
65Css2, Css32CAP, CERM, 0.01µF, 6.3 V, +/- 10%, X7R, 06030603
66CVCC3V,CVCC5V, CVCC18V3CAP,CERM, 2.2 µF, 6.3 V, +/- 10%, X7R, AEC-Q200 Grade 1, 06030603
67D11Diode,Schottky, 200 V, 4 A, SMCSMC
68D21Diode,Schottky, 100 V, 1 A, PowerDI123PowerDI123
69D14, D18, D21,D224LED, Red, SMDLED_0603
70FDA11LowPower, Precision, 160MHz, Fully Differential Amplifier, RGT0016ARGT0016A
71H1, H2, H3, H44Machine Screw,Round, #4-40 x 1/4, Nylon, Philips panheadScrew
72H5,H6, H7, H84Standoff,Hex, 0.5"L #4-40 NylonStandoff
73H9, H11, H13,H154ROUND STANDOFFM3 STEEL 5MMROUND STANDOFFM3 STEEL 5MM
74J31Header,2.54 mm, 3x1, Gold, THHeader,2.54mm, 3x1, TH
75J4, J72Header(Shrouded),19.7mil, 30x2, Gold, SMTHeader(Shrouded), 19.7mil, 30x2, SMT
76J5,J6, JMTI_-18V, JPRI_-18V, JSI_3.3V, JSI_5V, JSI_18V, JZI_3.3V, JZI_5V,JZI_18V10Header,2.54 mm, 2x1, Gold, THHeader,2.54mm, 2x1, TH
77J81Terminal Block,2x1, Brass, THTerminal Block,2-Leads, Body 10x8.3mm, Pitch 5mm
78J14,J15, J18, J194SMAStraight Jack, Gold, 50 Ohm, THSMAStraight Jack, TH
79J37, J38, J39,JTI_3.3V, JTI_5V, JTI_18V, JTI_-18V7Header, 2mm,3x1, Gold, SMTHeader, 2mm,3x1, SMT
80L11Inductor,Shielded Drum Core, Ferrite, 330 µH, 0.42 A, 1.59 ohm, SMDDR73
81L4, L5, L6, L7,L8, L9, L10, L12, L16, L17, L18, L1912Ferrite Bead,600 ohm @ 100MHz, 2A, 08050805
82L20,L22, L243Inductor,Wirewound, Ferrite, 3.3 µH, 1.21 A, 0.096 ohm, AEC-Q200 Grade 2, SMD3x3mm
83L21, L23, L253Inductor,Shielded Drum Core, Ferrite, 6.8 µH, 1.1 A, 0.142 ohm, SMDInductor,2.8x2.8x2.8mm
84L4011Inductor,Shielded Drum Core, Metal Composite, 68 µH, 0.22 A, 1.15 ohm, SMD3.8x1.65x3.8mm
85OPAN_1, OPAN_2,OPAP_1, OPAP_24Low-Noise,High-Precision, JFET-Input OPERATIONAL AMPLIFIER, D0008AD0008A
86R3,R42RES,0.22 ohm, 1%, 0.1W, 06030603
87R8, R9, R10,R13, R14, R19, R25, R32, R35, R36, R56, R65, R66, R67, R68, R69, R70, R71,R72, R73, R74, R75, R76, R77, R78, R79, R80, R81, R82, R83, R84, R85, R86,R211, R212, R213, R223, R225, R226, R232, R233, R234, R235, R240, R248, R250,R252, R259, R262, R279, R280, R284, R288, R454, RB3, RB5, RB18, RMFBN2,RMFBP259RES, 0, 5%,0.063 W, 04020402
88R211RES,0, 5%, 0.1 W, 06030603
89R221RES, 4.70,0.5%, 0.1 W, 06030603
90R401RES,215 k, 0.1%, 0.1 W, 06030603
91R411RES, 23.2 k,0.1%, 0.1 W, 06030603
92R421RES,1.65 k, 0.1%, 0.1 W, 06030603
93R431RES, 30.9 k,0.1%, 0.1 W, 06030603
94R441RES,2.15 k, 0.1%, 0.1 W, 06030603
95R451RES, 52.3 k,0.1%, 0.1 W, 06030603
96R461RES,910, 5%, 0.1 W, 06030603
97R471RES, 18.0 k,0.1%, 0.1 W, 06030603
98R50,R2162RES,20.0 k, 0.1%, 0.1 W, 06030603
99R64, R872RES, 10.0 k,1%, 0.1 W, 06030603
100R88,R89, R913RES,4.7 k, 5%, 0.063 W, 04020402
101R921RES, 100, 5%,0.063 W, 04020402
102R95,R256, R257, R2784RES,33, 5%, 0.063 W, 04020402
103R97, R98, R107,R108, R110, R214, R485, R4918RES, 1.00 k,0.1%, 0.1 W, 06030603
104R991RES,249, 1%, 0.1 W, 06030603
105R100, R101,R114, R116, RDN2, RDN4, RDP2, RDP48RES, 1.00 k,0.1%, 0.1 W, 06030603
106R103,R104, R115, R1174RES,20.0, 0.1%, 0.1 W, 06030603
107R112, R1132RES, 124, 1%,0.1 W, 06030603
108R215,R4922RES,499, 0.1%, 0.1 W, 06030603
109R217, R218,R246, R2474RES, 49.9 k,0.1%, 0.1 W, 06030603
110R258,R2612RES,10.0 k, 0.1%, 0.1 W, 06030603
111R268, R2692RES, 1.00, 1%,0.1 W, 06030603
112R2901RES,36 k, 5%, 0.063 W, 04020402
113R291, R295, R2983RES, 100 k, 1%,0.063 W, 04020402
114R2941RES,22.6 k, 1%, 0.063 W, 04020402
115R2971RES, 5.62 k,0.1%, 0.063 W, 04020402
116R4011RES,58.3 k, 0.1%, 0.1 W, 06030603
117R4021RES, 1.00 M,1%, 0.1 W, 06030603
118R4041RES,80.6 k, 1%, 0.1 W, 06030603
119R4861RES, 2.49 k,0.1%, 0.1 W, 06030603
120R4881RES,4.99 k, 0.1%, 0.1 W, 06030603
121R4891RES, 4.75, 1%,0.1 W, 06030603
122R4941RES,30.0 k, 0.1%, 0.1 W, 06030603
123RDN1, RDN3,RDP1, RDP34RES, 0, 5%, 0.1W, 06030603
124Renb1RES,20.5 k, 1%, 0.125 W, 08050805
125Renb2, Renb32RES, 3.57 k,0.1%, 0.1 W, 06030603
126Rent1RES,118k ohm, 0.1%, 0.125W, 08050805
127Rent2, Rent32RES, 68.1 k,0.1%, 0.1 W, 06030603
128RES3V,RES5V, RES18V3RES,100 k, 0.1%, 0.1 W, 06030603
129Rfbb1RES, 1.50 k,0.1%, 0.1 W, 06030603
130Rfbb3,Rfbb52RES,1.07 k, 0.1%, 0.125 W, 08050805
131Rfbt1RES, 34.0 k,0.1%, 0.1 W, 06030603
132Rfbt21RES,6.34 k, 0.1%, 0.063 W, 06030603
133Rfbt31RES, 4.02 k,0.1%, 0.1 W, 06030603
134Ron1RES,383 k, 0.1%, 0.1 W, 06030603
135Ron21RES, 113 k,0.1%, 0.1 W, 06030603
136Ron31RES,78.7 k, 0.1%, 0.1 W, 06030603
137RR4131RES, 0.22, 1%,0.1 W, 06030603
138U1,U22HighBandwidth, High Precision, Low Noise and Distortion Amplifier with Ultra-FastTransition time Low Power mode, DBV0006ADBV0006A
139U31High-PrecisionVoltage Reference with Integrated High-Bandwidth Buffer, DGK0008ADGK0008A
140U3P8V,U5P5V, U18P5V3LM53635,RNL0022A (VQFN-HR-22)RNL0022A
141U41Precision, LowNoise, Low Iq Operational Amplifier, 2.2 to 5.5 V, -40 to 125 degC, 5-pinSOT23 (DBV0005A), Green (RoHS & no Sb/Br)DBV0005A
142U512ASIMPLE SWITCHER® Power Module with 42V Maximum Input, 7 pin TO-PMODTZA07A
143U6, U7, U8336-V, 1-A,4.17-μVRMS, RF LDO Voltage Regulator, RGW0020ARGW0020A
144U91SIMPLESWITCHER® 75V, 0.5A Step-Down Switching Regulator, 16-pin TSSOPMTC16
145U101Low NoiseNegative Bias Generator, 8-pin Mini SOIC, Pb-FreeMUA08A
146U111SingleOutput High PSRR LDO, 200 mA, Adjustable -1.18 to -33 V Output, -3 to -36 VInput, with Ultra-Low Noise, 8-pin MSOP (DGN), -55 to 125 degC, Green (RoHS& no Sb/Br)DGN0008D
147U13, U142I2C BUS EEPROM(2-Wire), TSSOP-B8TSSOP-8
148U151Ultra-LowJitter Programmable Oscillator with Internal EEPROM, SIA0008BSIA0008B
149U18, U312LOW-POWERSINGLE POSITIVE-EDGE-TRIGGERED D-TYPE FLIP-FLOP, DCK0005ADCK0005A
150U19,U322SINGLESCHMITT-TRIGGER INVERTER GATE, DBV0005ADBV0005A
151U2211A SIMPLESWITCHER® Power Module with 42V Maximum Input, 7 pin TO-PMODTZA07A
152U2313ASIMPLE SWITCHER® Power Module with 42V Maximum Input Voltage, 7-pin TO-PMOD,Pb-FreeTZA07A
153U331Low Skew,1-to-4 Multiplexed Differential/LVCMOS-to-LVCMOS/TTL Fanout Buffer, PW0016APW0016A
154U4011SIMPLESWITCHER 3.5 V to 60 V 1 A Synchronous Step-Down Voltage Converter, PWP0016G(TSSOP-16)PWP0016G
155U4141Low-Noise, 900kHz, RRIO, Precision Operational Amplifier, Zerø-Drift Series, 2.2 to 5.5 V,-40 to 125 degC, 5-pin SOT23 (DBV0005A), Green (RoHS & no Sb/Br)DBV0005A
156U4151High-Bandwidth,High-Precision, Low THD+N, 16-Bit and 18-Bit Analog-to-Digital Converter(ADC) Drivers, DBV0006ADBV0006A
157U4221Low Noise, VeryLow Drift, Precision Voltage Reference, -40 to 125 degC, 8-pin MSOP (DGK),Green (RoHS & no Sb/Br)DGK0008A
158UADS1,UADS2220-Bit,High-Speed SAR ADCs With Integrated Reference Buffer, Integrated LDO, andmultiSPI Digital Interface, RGE0024H (VQFN-24)RGE0024H
159C89, C90, C316,C3170CAP, CERM, 1000pF, 100 V, +/- 5%, C0G/NP0, 06030603
160C3350CAP,CERM, 0.01 µF, 50 V, +/- 5%, C0G/NP0, AEC-Q200 Grade 1, 06030603
161CMFB0CAP, CERM, 68pF, 100 V, +/- 5%, C0G/NP0, 06030603
162FID1,FID2, FID3, FID4, FID5, FID60Fiducialmark.  There is nothing to buy ormount.Fiducial
163R11, R12, R15,R17, R18, R20, R24, R26, R27, R29, R30, R31, R33, R34, R255, R260, R263,R453, R457, REN0, REN1, RMFBN, RMFBP, RR4570RES, 0, 5%,0.063 W, 04020402
164R900RES,4.7 k, 5%, 0.063 W, 04020402
重要提示:PCB作品文件展下载说明
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
经纬 | 2018-11-29 10:00:40 | 显示全部楼层
匿名 miaomiaoy | 2019-11-14 17:48:52 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
